I am using RH7
I have generated a Merged Webhelp project with the following structure:
Master
- ChildOne
- ChildTwo
- ChildThree
- etc
The Master project only has one boilerplate topic which has no links.
The Child projects have inter-related links.
I use a custom skin, and custom templates.
My generation settings are:
Output: to folder on my desktop
Mark of web is on
w3c compliance is on
Toolbar: no Index
Show navigation is on
enable hightlight is on
search input field is on
Synchronise TOC is automatic.
When I generate the output - all cross-project links are dead, but links within a child project are ok, By Dead I mean that they don't do anything - no errors, etc. I have also cleared the browser cache, and tested in both IE and Firefox. The cross-project links are reporting as broken in Xenu, but testing the links in RH they are fine.
I generate the Master project first, and then each child project.
The same structure/ skin/ templates/ settings are used in other projects which work fine.
Any ideas??
So you recreated folders with new names and imported topics. Any of those topics that have cross project links are thus looking for folders that no longer exist. It looks like you either have to rename the folders or fix the links.
This should also have screwed topics in the same project but in different folders, unless the target folder didn't get renamed.
After making a backup, you could use a multi file find and replace tool such as FAR to find all instances of say nfpAppendices and replace wit
...Copy link to clipboard
Are you generating the child projects into the correct place?
If you look at the location where you generate the parent, look in mergedProjects and see if the child project content is there.
Post one of the cross project links here.
Are you running the Xenu check on the output? If you are, then something has happened to those links.
As you have got this running with other projects, it has to be something simple that is not right.
Hi Peter
Thanks for quick reply...
Check - All output is in correct folder
Check - Running Xenu against the output.
I have opened two instances of RH and compared the generation settings etc against the working project. no differences...
This link is from the "creditors" child project and links to a topic in the "appendices" project. I have copied it out of the output topic and pasted it here:
"Please refer to the General Reports topic "
Here is the source for the page where the link is located... the link is on line 87<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<!-- saved from url=(0014)about:internet -->
<html>
<head>
<meta http-equiv="content-style-type" content="text/css">
<meta http-equiv="content-type" content="text/html; charset=utf-8">
<meta name="generator" content="Adobe RoboHelp - www.adobe.com">
<title>Creditor Reports</title>
<link rel="stylesheet" href="../AccessBlue_ns.css" type="text/css">
<script type="text/javascript" language="JavaScript">
if (navigator.appName !="Netscape")
{ document.write("<link rel='stylesheet' href='../AccessBlue.css'>");}
</script>
function reDo() {
if (innerWidth != origWidth || innerHeight != origHeight)
location.reload();
if ((parseInt(navigator.appVersion) == 4) && (navigator.appName == "Netscape")) {
origWidth = innerWidth;
origHeight = innerHeight;
onresize = reDo;
onerror = null;
</script>
<style type="text/css">
div.WebHelpPopupMenu { position:absolute; left:0px; top:0px; z-index:4; visibility:hidden; }
</style>
<script type="text/javascript" language="javascript1.2" src="../whmsg.js">
</script>
<script type="text/javascript" language="javascript" src="../whver.js">
</script>
<script type="text/javascript" language="javascript1.2" src="../whproxy.js">
</script>
<script type="text/javascript" language="javascript1.2" src="../whutils.js">
</script>
<script type="text/javascript" language="javascript1.2" src="../whlang.js">
</script>
<script type="text/javascript" language="javascript1.2" src="../whtopic.js">
</script>
</head>
<body>
<script type="text/javascript" language="javascript1.2">
if (window.gbWhTopic)
if (window.addTocInfo)
addTocInfo("Creditors tab\nReport & Analyse group\nReports");
addButton("show",BTN_TEXT,"Show","","","","",0,0,"","","");
if (window.writeBtnStyle)
writeBtnStyle();
if (window.writeIntopicBar)
writeIntopicBar(1);
if(1)
if (window.setRelStartPage)
setRelStartPage("../dx_creditors.htm");
autoSync(1);
sendSyncInfo();
sendAveInfoOut();
else
if (window.gbIE4)
document.location.reload();
</script>
<h1>Creditor Reports</h1>
<p>Please refer to the <a href="../../nfpAppendices/reports/genreports.htm">General Reports</a> topic</p>
highlightSearch();
writeIntopicBar(0);
if(0)
</script>
</body>
</html>
The link is prima facie OK but I stick by if Xenu says the link is broken, then there is something wrong with it. Have you tried with more than one browser?
check - both IE8.0 and Firefox3.6
I just don't know where to begin ... the links are ok within the Source environment, which leads me to think that there is something going wrong with the output generation...
How big is the whole lot zipped up?
just under 8Meg
I've just had a thought. Perhaps a dangerous thing...
I have had my PC rebuilt over Christmas, and had a 2nd disk drive installed.
All of the RoboHelp projects have been moved to the new disk. I have had to manually create the folder structure, and then had SourceSafe get the latest version of each project into the newly created folders. The crux of this is that my folders are now named correctly, whereas the RH xpj still have the original names. for example nfp_appendices.xpj is in the folder nfpAppendices.
Looking at the output, in mergedProjects the folder is referred to as nfp_appendices, but the hyperlink is looking for ../../mergedProjects/nfpAppendices/reports/genreports.htm
could this be the problem? if so, how do i fix it?
After making a backup, you could use a multi file find and replace tool such as FAR to find all instances of say nfpAppendices and replace with nfp_Appendices but you have to be careful. I would review each change rather than hitting the Replace All option.
Have a great weekend.
Good Weekend? I will now!
Thank you very much!
Your assist is, as always, hugely appreciated.
Ron
