18 Replies Latest reply on Jun 30, 2011 1:19 AM by DanCondonJones
    generatePDFOutput with a variable form.
    DanCondonJones Level 1
      Hi
      I have a process which uses generatePDFOutput2 to produce a PDF.  This works fine at the moment, but I need to pick the form based on a variable value which is passed in.
      I've tried every combination of including the application name or not, with and wtihtout the version number, using forward slashes or backslashes and including the .xdp extension or not, but nothing seems to work.  The document I can find seems to be pretty vague on what I should put in.
      Can anyone help?
      For reference, the path of my form as viewd in the Applications tree is of the structure: APPNAME/APPNAME/1.0/Subfolder/Formname
      When I use a literal value for the Form in generatePDFOutput2 is: URI = Subfolder/Formname.xdp, Created 6/12/10
      Dan
        • 1. Re: generatePDFOutput with a variable form.
          Jasmin Charbonneau Level 4
          Right-click on the form in the Application view and check the absolute-path.
          You want to set the Form property of the GenerateOuputPDF to /Applications + absolute-path.
          Also make sure your Content Root URI is set to repository://
          Jasmin
          • 2. Re: generatePDFOutput with a variable form.
            Thanks for your reply.
            I've just tried that (Content Root URI was previously blank), but it still doesn't work.
            • 3. Re: generatePDFOutput with a variable form.
              What error you get in the server.log?
              It should tell us what url it's trying to load.
              Jasmin
              • 4. Re: generatePDFOutput with a variable form.
                Here's the log, but the path isn't in there:
                2011-01-13 16:09:39,130 INFO
                [com.adobe.idp.dsc.registry.service.impl.ServiceRegistryImpl]
                ServiceRegistryImpl:stop(BTDEV/Processes/GenerateReport, 1.0)
                2011-01-13 16:09:39,366 INFO
                ServiceRegistryImpl:stop(BTDEV/Processes/GetOS, 1.0)
                2011-01-13 16:09:39,477 INFO
                ServiceRegistryImpl:stop(BTDEV/Processes/EventTriggerReport, 1.0)
                2011-01-13 16:10:11,638 INFO  [PreparedSqlHelper] execute statement:
                CALL rpr_workflow.set_component_started(?)
                2011-01-13 16:10:13,156 ERROR [com.adobe.document.XMLFormService]
                ALC-XTG-012-309: [11558] XMLForm, load : 12309, XFA template Model is empty.
                2011-01-13 16:10:13,162 ERROR
                [com.adobe.formServer.PA.XMLFormAgentWrapper] ALC-OUT-002-017: mid,tid:
                12309,11558.-205674800 sev: f text: XMLForm, load : 12309, XFA template Model is empty.
                2011-01-13 16:10:13,239 ERROR
                [com.adobe.livecycle.formsservice.exception.FormServerException]
                ALC-OUT-002-013: XMLFormFactory, PAexecute failure:
                "(com.adobe.document.xmlform.ReturnStatus@4fc9008e) XMLForm, load :
                12309, XFA template Model is empty."
                2011-01-13 16:10:13,241 ERROR [STDERR]
                com.adobe.printSubmitter.PrintException: ALC-FRM-001-013:
                12309, XFA template Model is empty." in
                com.adobe.livecycle.formsservice.exception.RenderFormException, cause:
                ALC-FRM-001-013: XMLFormFactory, PAexecute failure:
                2011-01-13 16:10:13,242 ERROR [STDERR]     at
                com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java:190)
                com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java:110)
                com.adobe.printSubmitter.util.Splitter.endElementNoBatch(Splitter.java:204)
                com.adobe.printSubmitter.util.Splitter.endElement(Splitter.java:179)
                org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
                org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanEndElement(Unknown
                Source)
                org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(U nknown
                Source)
                org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown
                Source)
                org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
                org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
                org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
                org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
                com.adobe.printSubmitter.PrintServer.execute(PrintServer.java:538)
                com.adobe.printSubmitter.PrintServer.submit(PrintServer.java:232)
                com.adobe.printSubmitter.service.OutputServiceImpl.generateOutputInTxn(OutputServiceImpl.j ava:262)
                2011-01-13 16:10:13,243 ERROR [STDERR]     at
                com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutputInTxn(OutputServiceImp l.java:395)
                com.adobe.printSubmitter.service.OutputServiceImpl.access$100(OutputServiceImpl.java:82)
                com.adobe.printSubmitter.service.OutputServiceImpl$2.doInTransaction(OutputServiceImpl.jav a:346)
                com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew( EjbTransactionBMTAdapterBean.java:218)
                sun.reflect.GeneratedMethodAccessor329.invoke(Unknown Source)
                sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                java.lang.reflect.Method.invoke(Method.java:597)
                org.jboss.invocation.Invocation.performCall(Invocation.java:359)
                org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContai ner.java:237)
                org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionIn terceptor.java:158)
                org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
                org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
                org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:17 3)
                org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
                org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceI nterceptor.java:169)
                org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
                org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
                org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.j ava:138)
                org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
                org.jboss.ejb.Container.invoke(Container.java:960)
                org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
                org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
                $Proxy157.doRequiresNew(Unknown Source)
                com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvid er.java:133)
                com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionTe mplate.java:79)
                com.adobe.printSubmitter.service.OutputServiceImpl.invokeGeneratePDFOutputWithSMT(OutputSe rviceImpl.java:341)
                com.adobe.printSubmitter.service.OutputServiceImpl.generatePDFOutput2(OutputServiceImpl.ja va:322)
                2011-01-13 16:10:13,244 ERROR [STDERR]     at
                sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java :118)
                com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.j ava:140)
                com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorC hainImpl.java:60)
                com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassiv ationInterceptor.java:53)
                com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transac tionInterceptor.java:74)
                com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTrans actionBMTAdapterBean.java:197)
                sun.reflect.GeneratedMethodAccessor326.invoke(Unknown Source)
                2011-01-13 16:10:13,245 ERROR [STDERR]     at $Proxy157.doBMT(Unknown
                Source)
                com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvid er.java:95)
                com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInte rceptor.java:72)
                com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrat egyInterceptor.java:55)
                com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercept or.java:37)
                com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterce ptor.java:188)
                com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
                com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
                com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
                com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageR eceiver.java:93)
                com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:225 )
                com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatc her.java:66)
                com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
                com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
                com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker.j ava:347)
                com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
                2011-01-13 16:10:13,246 ERROR [STDERR]     at
                com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTra nsactionCMTAdapterBean.java:357)
                com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew( EjbTransactionCMTAdapterBean.java:299)
                sun.reflect.GeneratedMethodAccessor230.invoke(Unknown Source)
                org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
                org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
                $Proxy156.doRequiresNew(Unknown Source)
                com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvid er.java:143)
                2011-01-13 16:10:13,247 ERROR [STDERR]     at
                com.adobe.idp.jobmanager.execution.workadapter.AbstractExecutableJob.invokeRequest(Abstrac tExecutableJob.java:127)
                com.adobe.idp.jobmanager.execution.workadapter.PersistentExecutableJob.execute(PersistentE xecutableJob.java:60)
                com.adobe.idp.dsc.workmanager.adapter.UnManagedAsynchronousWorkAdapter.run(UnManagedAsynch ronousWorkAdapter.java:39)
                org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java:204)
                org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrapper.java:275)
                EDU.oswego.cs.dl.util.concurrent.PooledExecutor$Worker.run(PooledExecutor.java:743)
                java.lang.Thread.run(Thread.java:619)
                2011-01-13 16:10:13,247 ERROR [STDERR] Caused by:
                com.adobe.livecycle.formsservice.exception.RenderFormException:
                com.adobe.formServer.FormServer.renderForm(FormServer.java:234)
                com.adobe.formServer.FormServer.renderForm(FormServer.java:282)
                com.adobe.formServer.docservice.FormsDocService.renderForm(FormsDocService.java:556)
                com.adobe.printSubmitter.util.FormSubmitter.submit(FormSubmitter.java:169)
                2011-01-13 16:10:13,247 ERROR [STDERR]     ... 142 more
                2011-01-13 16:10:13,248 ERROR [STDERR] Caused by:
                com.adobe.livecycle.formsservice.exception.FormServerException:
                2011-01-13 16:10:13,248 ERROR [STDERR]     at
                com.adobe.formServer.PA.XMLFormAgentWrapper.doPAExecute(XMLFormAgentWrapper.java:362)
                com.adobe.formServer.PA.XMLFormAgentWrapper.execute(XMLFormAgentWrapper.java:203)
                com.adobe.formServer.Controller.doXFARender(Controller.java:738)
                com.adobe.formServer.Controller.doRender(Controller.java:566)
                com.adobe.formServer.Controller.render(Controller.java:139)
                com.adobe.formServer.FormServer.renderForm(FormServer.java:215)
                2011-01-13 16:10:13,248 ERROR [STDERR]     ... 145 more
                2011-01-13 16:10:13,252 ERROR [com.adobe.workflow.AWS] An exception was thrown with name com.adobe.livecycle.output.exception.OutputException
                message:com.adobe.printSubmitter.PrintException: ALC-FRM-001-013:
                com.adobe.livecycle.formsservice.exception.FormServerException while invoking service OutputService and operation generatePDFOutput2 and no fault routes were found to be configured.
                2011-01-13 16:10:13,264 INFO  [PreparedSqlHelper] execute statement:
                CALL rpr_workflow.set_component_errored(?,?)
                • 5. Re: generatePDFOutput with a variable form.
                  What are you setting your path to?
                  What are you setting you Content Root URI to?
                  Jasmin
                  • 6. Re: generatePDFOutput with a variable form.
                    I have the path set to: "/Applications/BTDEV/1.0/Reports/KnowYourNeighbour.xdp" (where BTDEV is the application name and Reports is the subfolder that holds the form).
                    Conent Root URI is now "repository://" as you stated.
                    • 7. Re: generatePDFOutput with a variable form.
                      Let's just to do another test.
                      Go to the following url: http://localhost:8080/repository. This give you access to the repository from a web browser.
                      Browse to your file to make sure it's store in the path you think it's stored in.
                      Let me know.
                      Jasmin
                      • 8. Re: generatePDFOutput with a variable form.
                        I've navigated my way to http://exbtuat2lc1:8080/repository/Applications/BTDEV/1.0/Reports (exbtuat2lc1 is the name of the server) and KnowYourNeighbour.xdp is there.
                        • 9. Re: generatePDFOutput with a variable form.
                          Can you post a screen shot of how you set the form url for the generatePDFOutput?
                          Jasmin
                          • 10. Re: generatePDFOutput with a variable form.
                            This is just a temporary method until I get it properly working, but I st the value of a variable called templatePath and then use that variable in the generatePDFOutput process.
                            I know it is setting the variable's value correctly as I output it as part of the error message
                            • 11. Re: generatePDFOutput with a variable form.
                              OK. I think I've figured it out.
                              Just remove /Applications from your path. For some reason it doesn't seem to need it. So you would end up with /BTDEV/<rest of path> for you path.
                              Jasmin
                              • 12. Re: generatePDFOutput with a variable form.
                                Unfortunately that's still not working.
                                Here's the new log file if that helps:
                                2011-01-17 04:00:00,050 INFO
                                [com.adobe.idp.um.sc
