1. Re: Premiere Elements 8 can't open any project
Bill Hunt Jan 7, 2011 5:03 PM (in response to bruce.romney)Bruce,
Welcome to the forum.
Where is the PREL (Project file) located on your system?
Good luck,
Hunt
2. Re: Premiere Elements 8 can't open any project
bruce.romney Jan 7, 2011 7:10 PM (in response to Bill Hunt)The .prel file is located in a subfolder of the "My Videos" folder.
- Bruce
3. Re: Premiere Elements 8 can't open any project
bruce.romney Jan 7, 2011 7:13 PM (in response to bruce.romney)OK, I tried rebooting and now Premiere is working again. Go figure. Thanks anyway for the help, Bill!
-Bruce
4. Re: Premiere Elements 8 can't open any project
Bill Hunt Jan 7, 2011 8:16 PM (in response to bruce.romney)Bruce,
Sometimes, I think that computers just need to rest, or something like that. Maybe they need for the phase of the Moon to change?
The important part is that you can now Open your Projects, and that is what is important. We may never know the "why."
Good luck,
Hunt
PS - too bad that you cannot give yourself the points, as you deserve them, just for reporting your success!
5. Re: Premiere Elements 8 can't open any project
Ole Pa Jan 8, 2011 2:47 AM (in response to bruce.romney)Hey Bruce -- I'm having the same problem, also on Windows 7. This same problem happened to me 6 months ago. I reported it to the online Adobe support, but got no help. Eventually I worked around it on my own. Now the problem is back and I can not open any project, even after rebooting. The behavour that I see is that I can open a new or old project, but the Premier window shows-up as having zero size. The bug has something to do with the Premier program thinking that the window size should be zero. The program shows-up in the active task list, and the Alt-Tab key shows Premier window has only a window title bar (where as other active programs show-up as a thumbnail image of their window contents), and the system taskbar also shows the Premier program as active but only as a window title bar (see attached image below)
When I reported to the online Adobe support forum that I had worked around the problem, the answer was something like the answer you got. Adobe does not seem to be interested in understanding and fixing the problem, they are just relieved when customers can figure-out work-around on their own. This really bites me where it hurts. I'm burning non-productive hours because of their bugs, and they don't care enough about the bugs to get engineering to fix them. It's things like this that make me look for another software vendor.
6. Re: Premiere Elements 8 can't open any project
bruce.romney Jan 8, 2011 5:39 AM (in response to Ole Pa)Ole,
Yes, I share your frustration with Adobe. My copy of Adobe Premiere Elements is only six months old, and yet Adobe was no help at all, except to refer me to this forum. I duly registered my product, and tried calling their tech support line. The person at the other end of the line (who I think was in India or Pakistan, judging by the accent and bad connection) took down all my information then told me he couldn't help me unless I paid $29. This policy will definitely make me wary of paying for Adobe products in the future.
I happen to develop software for a living, and when someone tells me about a bug, I take it as my professional responsibility to hunt it down and fix it. To do otherwise would reflect badly on me both professionally and personally. But Adobe? Not so much.
- Bruce
7. Re: Premiere Elements 8 can't open any project
Ole Pa Jan 8, 2011 8:14 AM (in response to bruce.romney)Hi Bruce -- Hello kindred soul. I've been programming for 42 years
now, and it always confounds me when these software companies put more
emphasis on features and advertising than on creating a quality
product that we can use. If other appliances worked as poorly as
software, the attorney general would be involved! I do understand
that bugs are unavoidable, but ignoring then is inexcusable.
Thanks for you note. I've found another work-around, so I'm back to
being productive.
Thanks, Jim
On Sat, Jan 8, 2011 at 8:40 AM, bruce.romney@verizon.net
8. Re: Premiere Elements 8 can't open any project
omorv Jan 15, 2011 2:39 PM (in response to bruce.romney)Hello,
I have the exact same problem as you with PE8 and Win7 (x64), and a reboot also helped me. But the problem came back the next time I tried to open PE. Have you expreienced the same? It cant be that we have to reboot every time we want to use PE?
Best regards
Øystein Morvik
Norway
9. Re: Premiere Elements 8 can't open any project
bruce.romney Jan 15, 2011 4:39 PM (in response to omorv)I don't use Premiere Elements very often, so I can't say it happens every time. But yes, I have had this problem before.
If it's any help, I've noticed that when PE starts up correctly, there's a PE window filling the entire screen, behind the initial dialog window. When it starts incorrectly, there's only the dialog window. So noticing that might save you some time.
- Bruce
10. Re: Premiere Elements 8 can't open any project
Ole Pa Jan 15, 2011 5:39 PM (in response to omorv)Hello Øystein Morvik,
I've run into this problem a couple times, and I've managed to get around it. I now believe the problem is due to the Premiere's design of starting with its window maximized, and then automatically resizing the window to what it thinks is the size that I want after it loads the project. When the bug is active, the size seems to be zero, or minimized, or off the screen, or who knows what. Just not anything that I can see. The Windwos task list shows that the program is running, and the little thumbnail that Windows 7 shows of running programs on the taskbar makes be think the window has been resized so that it is zero pixels wide and zero pixels high.
I've included links to the two discussions that I started on this bug. There may be something in those threads that could help you get around this:
http://forums.adobe.com/thread/775008
http://forums.adobe.com/thread/704857
Hope this does not cost you hours of unproductive time
-- Old Pa
