We've had a couple of experiences where we haven't been able to capture remotely if the client is using a Virtual Machine. This is a real problem, since we are often working in an application in pre-release stages, and the client is using a VM to build it.
Has anybody seen any solutions to this?
Are you trying to capture an application that is running on a remote machine (VM)? If yes then can you try capturing the "Screen area" instead.
No, unfortunately, it's not about capturing an application. We always capture the screen area, actually. We can get the screenshots, but not any clickboxes, etc.
Marion Deland
Capensys
Tel: 1-212-369-8131
Cell: 1-917-547-6360
www.capensys.com
Capensys is a supplier of top quality blended learning,
including rapid development of courseware, learning portals,
workshops and context sensitive performance support tools.
Hi Marion,
To get clickboxes etc. both Cp5 and the captured application must be running on the same machine. For application running on a remote machine Cp5 does not get the information about UI elements (buttons, menu's etc. ) from the OS hence it just captures the screenshots.
Regards
Rahul
Actually, we've been able to do it, at least with CP4 - just not when the remote machine is running on a VM. If it was on a regular machine, it captureed click boxes, etc., but just centered them around the mouse click - it didn't identify the buttons, etc.
You may need to rely on manual capture entirely, adding in the clicboxes, buttons, and text boxes as needed.
