14 Replies Latest reply on May 4, 2012 4:43 PM by CaliPVP
    No templates in titler CS5
    jesskaat Newcomer
      Hi there!
      Took the plunge last week. Still getting everything converted and set up, but so far so good. Except.....I just tried to access the templates for lower thirds and there are none. I've already installed the library content download. I've got my library in Encore.
      Any ideas?
      Jessica
        • 2. Re: No templates in titler CS5
          jesskaat Newcomer
          Thanks for the link.
          Do, you think if I do this install again, they get in there? I've done this install already.
          Jess
          • 3. Re: No templates in titler CS5
            jesskaat Newcomer
            For anyone else who may have had the same problem......
            When the adobe download is complete, an icon installer button and a folder "Adobe CS5" are written to the location specified.
            The folder "Adobe CS5" has a sub folder called" Premiere Pro Family Content Installers"
            Inside this folder are several other sub folders and PDFs:
               Adobe Encore CS5 - contains yet more PDFs
               Adobe Encore CS5 Functional Content - has a setup.exe to install that content
               Adobe OnLocation - more PDFs
            and finally.....
               Adobe Premiere Pro CS5 Functional Content - has the setup.exe to install the content which I was missing.
            If you just click on the icon install button - that gets written on download - ONLY the Encore content is installed. You have to locate the above folders and access the setup.exe manually for PP content in the Adobe Premiere Pro CS5 Functional Content folder.
            Hope this clears things up for someone else.
            Best,
            Jessica
            • 4. Re: No templates in titler CS5
              the_wine_snob Legend
              Jessica,
              Glad that you found the Functional Content. The reason that it is separate is that it does require some HDD real estate, and some users choose to not install it. This does limit things a bit, but one can still "create" much of what is included. However, for that little bit of real estate, I find it very useful to at least have the Templates on the machine, as one can use those as a basis for customization. This is for Titles and then in Encore, for Menus.
              Good luck, and thanks for the details on how to install all of the Functional Content. The exact operation changes a bit, from installation from media vs installation from downloads.
              Hunt
              • 5. Re: No templates in titler CS5
                UlfLaursen Helper
                Hi Jessica
                I had the exact same problem, and soleved it the same way, after advice from the forum too.
                /Ulf
                • 6. Re: No templates in titler CS5
                  CaliPVP Newcomer
                  I have the same problem, but I am running on a Mac Pro.  I don't have an .exe I can run.  Any ideas?
                  • 7. Re: No templates in titler CS5
                    Ann Bens Mythic
                    Have you read post 1?
                    • 8. Re: No templates in titler CS5
                      CaliPVP Newcomer
                      I did... that doesn't help me.  I don't get the following option for some unknown reason.
                      Click View Order History.
                      Look at the row with your order number and click Download.
                      On the download page, look at the row with the description for function content. For example, for CS5, look for “Adobe Premiere Pro CS5: Download contains additional ReadMe files plus content (menus, buttons, and backgrounds) for Adobe Encore CS5.”
                      • 9. Re: No templates in titler CS5
                        CaliPVP Newcomer
                        I guess I am SOL unless I pay more money.    Looks like I'll just have to keep making my own.  Time for me to get over it.
                        Support: Hello. Welcome to Adobe Technical Support.
                        Support: I have received your query. Please allow me a moment to verify your account and to review the details of your request.
                        Support: As I understand that you are facing problem in using the templates on your computer, am I correct?
                        ME: That is correct
                        Support: Thank you for confirming the issue.
                        Support: I will glad to help you with this issue.
                        Support: May I have the serial number of the product, please?
                        ME: XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
                        Support: Thank you for the serial number.
                        Support: Just to confirm, whether you were able to launch the software?
                        ME: the software works, it just doesn't have everything that come with it
                        ME: unless the templates are extra?
                        Support: Alright. Thanks for the information.
                        Support: I am from the Installation and Download Chat Support Team and this issue will be handled by Product Experts.
                        Support: I will provide you the phone number.
                        Support: The telephone number is 800-833-6687 available from Monday to Friday, 5 AM to 7 PM PST.
                        Support: Contact the above phone number and they will help you in this matter.
                        Support: Is there anything else I can help you with?
                        ME: Is this not installation?
                        Support: The extra features issue are handled by our Product Experts.
                        ME: do the templates not come with the installation?
                        Support: Yes. It will  but if you contact them, they will help you in this matter.
                        Support: Do you have any other questions for me today?
                        ME: I'm confused, if this is a installation problem why do I need to call them? Is it because of my support level?
                        Support: We support only the product installation support. Templates installation will be handled by our Product Experts.
                        Support: We are not trained on the Templates Installation.
                        ME: So it's not part of the installation, is this correct?
                        Support: Yes.
                        ME: note unless you can help me with installation of the templates that should have been installed with Premiere?
                        Support: I can understand your Concern, Templates are the extra features of the software and it will be always handled by our Product Experts.
                        Support: If you contact them, they will explain in details and help you out.
                        Support: The number is toll free.
                        Adobe offers paid phone support for a US$39 fee per incident as well as other customized support options.
                        • 10. Re: No templates in titler CS5
                          Ann Bens Mythic
                          You cannot get to your Order History?
                          You do not have a download button for the software?
                          Did you download CS6 from Adobe?
                          • 11. Re: No templates in titler CS5
                            rpestes Newcomer
                            I have the install discs and cant find anything on the content disc except a lot of PDF files. Any help?
                            • 12. Re: No templates in titler CS5
                              Ann Bens Mythic
                              OK, then uninstall everything
                              Run Cleaner Tool and reinstall.
                              Don't forget to deactivate.
                              IIRC the functional content for Encore is shown on the installation disk.
                              • 13. Re: No templates in titler CS5
                                CaliPVP Newcomer
                                I haven't tried re-installing yet.  I've had some many projects, I just couldn't find the time.  It would be nice to have to the templates for my projects so that I don't have to create them.  Not that creating them is hard.
                                • 14. Re: No templates in titler CS5
                                  CaliPVP Newcomer
                                       Yes, I can get to my Order History but I don't have anything listed.
                                       No, I don't have a download button for the software.
                                       No, I didn't download CS5 from Adobe.  I bought the media in the Adobe box.
                                  I remember having to reinstall Encore to get the template for it.  I will have to give that a try on Premiere.
