Hi everyone,
I finished a project in which my edit and storyboard modes show my program perfectly:
However, when I preview the project (both locally and in the web browser), the background turns yellow:
This was recorded in a virtual machine in Unity mode but when I recorded a locally-installed version of the program, the new project did the same thing. Does anyone know how to fix this? I tried poking around with my default preferences but I wanted to check with the Gurus first. I'm using Captivate 5 with the most recent patch installed and I'm running Windows7 locally and XP in my VM.
Krista
Hi Krista
Does it change anything if you edit the properties of the slide and configure a different Slide Quality?
Cheers... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Good to know! Yes, changing the slide quality to OPTIMIZED caused my FMR backgrounds to turn completely white, but when I changed the settings to "high (24 bit)", everything was as they should be.
Thanks for your help!
Krista
Hi there,
another option might be, that you can set the background color for a flash movie in the html file.
Best
TD
