I'm using RH 8.02.208 on Win7/64-bit and MS Word 2007.
In previous versions of RH, the Import Word Document feature allowed you to specify that the imported document should be split into separate topics based upon heading levels in the source document. I no longer see this option in RH8. Is it no longer available, or am I missing something obvious?
Dave
File > Project Settings > Import Tab > Word Conversion Settings.
You need to set Pagination for each style you want RH to create topics from.
That worked....thanks very much!
Dave
