I am trying to send the content of a form as email, in xml format.
An xml file is generated as it is supposed to, and it contains all the data. My problem ist that all generated xml tags are invalid. After every tag name there is a line feed before the closing ">".
The generated file looks like this:
<tag
><innertag
>content</innertag
></tag
Is this a known issue? What can I do so that those line feeds are not inserted?
I am using Adobe LiveCycle Designer 8.2.1
Thank you!
Total Likes
What are you using to view the XML file? I am wondering if the viewing program is adding those linefeeds. If you open the xml file in IE it should be viewable without that issue (just to see if it is theviewer that is adding those carriage returns).
Paul
Total Likes
When I open the generated xml file with the Internet Explorer, the LF characters are displayed as white spaces. When I open it with NotePad, it is displayed as a small rectangle.
I am using Notepad++ which displays "LF" when I check "Show end of line".
Total Likes
So something is adding those chars .....if you save the xml file right out of Acrobat/Reader see if the Line Feeds are there.
Paul
Total Likes
When I open the pdf file with Adobe Acrobat Pro and then click send per email and save the xml file there are those LF characters inside each start tag and end tag.
When I open the file with Notepad++ and tick "Show all symbols" it is displayed as follows:
I am using a data connection to create the form from a xsd document. Can this be the source of the problem? It is a valid xml file.
Total Likes
But what if you save the data right from th eform (without the email). Under the Forms/Manage Form Data/ Export Form Data menu item. This will start a dialog and allow you to save the file locally. See if that one has the issue.
Paul
Total Likes
It's all the same. It does not make any difference, the LF characters are still there.
Thank you for your quick help!
Message was edited by: white_cabbage
Total Likes
I even tried to change the <xsl:output method="xml" indent="yes"/> what did not make any difference.
Total Likes
Can you send your form to LiveCycle8@gmail.com and I will have a look when I get a chance.
Paul
Total Likes
Thank you. You will receive the form in a minute.
Total Likes
Was this issue ever resolved for you? I am having the same problem and cannot find an answer anywhere...
Total Likes
