Show 4 replies
1. Re: Launch Multi-Camera Monitor - Sound goes away
JSS1138 Jan 20, 2011 7:29 PM (in response to CJGerow)(I did a render and replace)
Don't do that till after your done editing the MC sequence. Put the audio you want to hear while cutting in Audio 1 on the sequence with the original clips.
2. Re: Launch Multi-Camera Monitor - Sound goes away
CJGerow Jan 21, 2011 7:08 AM (in response to JSS1138)Jim,
Sorry - I put this out of order. I had to do the Render and Replace - before I synced the clips with PluralEyes. That is what it uses to sync the clips.
Chris
3. Re: Launch Multi-Camera Monitor - Sound goes away
CJGerow Jan 21, 2011 8:22 AM (in response to CJGerow)This morning - I took a new look at theMulit-camera Monitor - and found a new button hiding on the bottom of the screen - I needed to select the audio
This fixes my problem
Sorry for the Alert!
Chris
4. Re: Launch Multi-Camera Monitor - Sound goes away
Bill Hunt Jan 21, 2011 2:51 PM (in response to CJGerow)Chris,
The important thing is that the problem is solved, and you are editing. Thanks for also posting what your particular issue was, as it will help others over time.
Good luck,
Hunt
