Hello,
I am using Flash Builder 4 premium, version 4.0.1, build 277662. I have a few different projects loaded at the same time. One of my projects does code complete/outline view/hyperlink navigation fine. With the other projects, it does none of these things, at all. Debugging works fine with the projects and they seem to build fine, I have no errors in the problems window. The project where the code complete/outline view/hyperlink navigation is all working actually is using a swc that is built from the projects in which it is not working... and I have double checked that the swc is being generated every time the project is built. Does anyone have an idea why this might be?
Thanks a lot for any help!!!
Karen
Hi Karen,
Can you please explain how your projects are structured? Any external source-paths, library paths, dependencies between library projects etc..?
If possible can you share your library project where this behavior is consistently seen? You can email me at "rbhat AT adobe.com"
Radhakrishna
