36 Replies Latest reply on Oct 11, 2013 8:29 AM by BJSouset
    Multiple Text Boxes on 1 Slide...
    NixTheNext Level 1
      There have been a lot of threads about this, but I've been unable to find an answer to the specific situation a colleague is facing.
      We are simulating a mainframe system where the user enters multiple values, then presses enter.  The client wants the simulation to replicate the system as closely as possible, and therefore we would like the user to Tab between the fields.  After the last field is complete, the user should press Enter to move forward.
      I can't get the text boxes to validate upon exit/lose focus...
      In the screen shot below, the text boxes are highlighted for the sake of this thread.  The yellow boxes have shortcuts of "Tab". The last text box (highlighted in purple)  has a shortcut of "Enter".    My hope was that, if a yellow box was not correct, when the user pressed  tab, they'd receive the failure caption, but this has proved wholly  unreliable.  Sometimes it won't appear at all, sometimes the failure caption for a different yellow-shaded text box appears.
      The text boxes don't seem to validate in any discernable order (not by the order they are in the timeline, not by reverse order in the timeline, not by the order they focus when the user presses tab).  I've tried putting an advanced action on the last text box which should check each text box variable against its correct entry and only move forward if each are correct.  This didn't work at all, it would still allow the user to move forward.  I've tried setting it up so that each text box appears after the pause of the previous text box...  I've tried setting the "on complete -> show -> next text box" (maybe I'm missing some key component of this method, 'cause I couldn't get the target to display on this at all)...
      Thanks in advance- I could use any clues you have!
        • 1. Re: Multiple Text Boxes on 1 Slide...
          Lilybiri MVP & Adobe Community Professional
          Hello,
          I couldn't detect which version of CP you are using. If it is the latest one, version 5, you have to know that you cannot assign the same shortcut key (Tab) to different TEB's. I blogged about it a couple of weeks ago:
          Warning tip
          Lilybiri
          1 person found this helpful
          • 2. Re: Multiple Text Boxes on 1 Slide...
            NixTheNext Level 1
            Thanks for the link (I've subscribed now!)...  We're using CS5.
            How would we get multiple text boxes to validate on this one slide?  It's almost like I want a "validate" action for the "focus lost" section...
            • 3. Re: Multiple Text Boxes on 1 Slide...
              Hello,
              What I have been doing in the past, but then you will be forcing a certain sequence for filling in the TEB's, is making the Submit button for the first TEB transparent without text and putting it over the second TEB-field. In this way, when the user clicks on the second TEB (no TAB in that case) he submits his first entry, will eventually get an 'incorrect' message and it will be validated. Then put the Submit button for the second TEB over the third TEB-field etc.
              But I do not know if this is an acceptable solution for you?
              Lilybiri
              • 4. Re: Multiple Text Boxes on 1 Slide...
                NixTheNext Level 1
                Unfortunately, the customer is adamant that this follow the application as closely as possible- which requires tabbing between fields.
                We're investigating having one TEB per slide, with advance on success...  but that also dictates the TEBs be completed in a particular order, increases the number of slides, and is just darn clunky.
                Is there a way to write an advanced action that would validate each text box, and display feedback for those that are not correct?  Basically,
                if TEB32 not equal to ABC, show Caption1
                if TEB31 not equal to 123, show Caption2
                and so on...  The problem I encountered here is trying to execute multiple custom scripts on a single event...
                • 5. Re: Multiple Text Boxes on 1 Slide...
                  Hello,
                  Checking all the entries in the TEB's with an advanced action is indeed possible, and showing appropriate Text Captions based on that check also. This Advanced action will have to be triggered (attached to) an event. Can you have an extra button on the slide to trigger this action? I'm prepared to help you out with the action if you provide me a detailed description, and allows me to use the explanation in an article or in a blog post. I already published several articles about advanced actions. Some are mentioned in my blog:
                  lilybiri's posterous
                  Lilybiri
                  • 6. Re: Multiple Text Boxes on 1 Slide...
                    NixTheNext Level 1
                    I can write the advanced action which will check 1 TEB.  Ideally, I'd like to have an advanced action which executes multiple custom scripts on one event.  Is that possible, without writing code?
                    Is there a reason the event in this case can't be (either) focus lost or the shortcut on the last TEB?  I plan to remove the failure captions on the TEBs, and would just put independent captions (not initially visible).
                    • 7. Re: Multiple Text Boxes on 1 Slide...
                      Hello,
                      I thought you wanted one Advanced action in which you will check the entries in all the TEB's (stored in user variables)? Do you think the 'focus lost' event is a good idea to trigger that since you are not sure that it will happen? And if you use the Submit from the 'last' TEB (that can be doubled as a shortcut), this means that you are imposing the sequence, not, you will have to be sure that this one will be the last TEB to be entered? Or do you want an advanced action that will be triggered by all 'focus lost' events and by all the Submit's?
                      What do you mean exactly by multiple custom scripts? Perhaps my lack of knowledge of English is puzzling me? You can trigger only one advanced action with an event, but this action can have a multitude of condtional actions, an unlimited sequence of standard actions and even combinations of standard and conditional actions (as I have been describing in the articles I did mention). If you are thinking about something else, please try to explain by giving more details.
                      Lilybiri
                      • 8. Re: Multiple Text Boxes on 1 Slide...
                        SFNancy Level 1
                        I am using Captivate 5 and have a similar need. I have three TEBs and a Submit button on one slide. I want to allow the user to enter text into each of the TEBs in any order and then click the Submit button to receive feedback (success or failure). The Submit button should trigger the validation of each TEB and display the feedback all at once. I'm thinking I can do this with Advanced Actions, but I'm not entirely sure how. Each TEB has one correct entry, so validation should be fairly straightforward. I have made sure to have a different shortcut action for each TEB. I'm not sure how to tie validation of TEB1, TEB2, and TEB3 to the click of the Submit button; I'm somewhat of a newbie to the more advanced capabilities of Captivate, but am motivated to learn.
                        Any suggestions or guidance is greatly appreciated.
                        • 9. Re: Multiple Text Boxes on 1 Slide...
                          Hello,
                          Will try to work this out as an example, and publish on my blog. I'l try to summarize your requests, and please let me know if this is OK:
                          • 3 TEB's have to be used by user, but sequence is not imposed
                          • Only one entry is correct, and only one attempt is possible?
                          • You do not want feedback after each entry, but only after all have been done
                          • You want only one Submit button (I cannot delay the validation, but faking should be possible)
                          • You said that you have a different shortcut key for each TEB, which ones? Can user also click in the TEB of choice?
                          An advanced conditional action with multiple decisions will be have to be used. I have been written some articles and blog postings about advanced actions. Maybe they could help you to start? This is the link to my blog post, when appropriate in the postings links to the articles (that are more detailed) are inserted.
                          http://lilybiri.posterous.com/
                          Lilybiri
                          • 10. Re: Multiple Text Boxes on 1 Slide...
                            SFNancy Level 1
                            Hi Lilybiri,
                            Thanks for the reply - I have started reviewing your tutorials and they are very helpful .
                            You are close with the requirements; I've made a few minor adjustments to clarify:
                            • 3 TEB's have to be used by user, but sequence is not imposed (cursor begins in TEB1, but user can click in any of the three TEBs to provide answers)
                            • Only one entry is correct, and only one attempt is possible? (only 1 answer is correct for each TEB, but there can be infinite attempts)
                            • You do not want feedback after each entry, but only after all have been done (yes)
                            • You want only one Submit button (I cannot delay the validation, but faking should be possible) (yes)
                            • You said that you have a different shortcut key for each TEB, which ones? Can user also click in the TEB of choice? (user can click in the TEB of choice or, ideally, use the Tab key to move from field to field)
                            This is a knowledge check slide for elearning. The results are not scored or tracked. There are three questions on 1 slide and one TEB for each question. The user can answer any or all of the questions and then click a Submit button to get feedback (success or failure caption). There is one correct answer for each TEB. So when the user clicks the Submit button, they will see feedback next to each TEB based on what was entered.
                            If you have suggestions or can work up an example, it would be most appreciated. I will continue to work through the tutorials and see if I can get it to work as I really want to understand this and learn how to extend Captivate.
                            Thanks again!
                            • 11. Re: Multiple Text Boxes on 1 Slide...
                              Hello,
                              Finally found time to work this out. I could create a slide with 3 TEB's, that can only have one correct entry each. The slide has one Submit button, user can fill in the TEB's in whatever sequence he wants to do it. He can click on the Submit button after 1, 2 or 3 entries and will see which entries were correct/incorrect. For that purpose I used symbols but it is perfectly possible to replace the symbols by Text Captions. He can then continue to fill in and whenever he clicks on the Submit button everything is checked again. Only when the three entries are correct a second button Continue appears and can be used.
                              I added one feature: when an entry in a TEB is correct, this TEB is disabled to avoid that the user clicks again in it.
                              Could you work it out? I'll try to publish a blog post this weekend to explain the workflow.
                              Lilybiri
                              • 12. Re: Multiple Text Boxes on 1 Slide...
                                SFNancy Level 1
                                Hello Lilybiri!
                                Thank you for your guidance and suggestions.I have not yet worked this out, but I think I am close to a solution.
                                However, I am not a coder and have no formal experience with coding, so I am struggling with the logic part of my advanced actions. I'm sure I am overlooking something very obvious!
                                I can see that there is a great deal of potential with Advanced Actions  in Captivate and I am inspired to learn more. I am still working my way  through your tutorials and other resources I have discovered.
                                Here's what I have so far...I have the slide with three TEBs - each can have only one entry each and there is only one correct answer for each. The TEBs can be filled in in any order or left blank. The slide has one Submit button that, when clicked, evaluates the entry in the TEBs and marks them accordingly with either a Success image or a Failure image. Each TEB has a Success and Failure image associated with it and their visibility is turned off. I have used an advanced action that is tied to the Submit button that checks the entry in TEB1 and shows the Success image if it is correct; else the Failure image is displayed. This works great for TEB1, but I haven't yet worked out how to include TEB2 and TEB3. I have added a second slide following this to display the correct answers and this works correctly as well.
                                The part I'm still trying to work out is how to add multiple if then else statements to the advanced actions I have associated with the Submit button (so basically, on click of the button, check the value entered in TEB1, TEB2, and TEB3 and then display the appropriate Success or Failure image for each). I think this is where perhaps my logic is incorrect. Maybe doing this as three if then else statements combined in some way is the wrong approach.
                                SFNancy
                                • 13. Re: Multiple Text Boxes on 1 Slide...
                                  Hello,
                                  In my example, no shortcuts to move between TEB, only clicking possible (you cannot use twice the shortcut TAB in one slide).
                                  Here are 2 out of 4 decisions for the conditional action to be triggered by the Submit button, with screenshots (will publish more details in my blog). The first three decisions (TEB1, TEB2, TEB3) are similar. The last (Counter) has to be the last, checks if the Continue button can appear.
                                  Lilybiri
                                  • 14. Re: Multiple Text Boxes on 1 Slide...
                                    Mr_TD Level 2
                                    Hi Mrs Zev,
                                    please ignore my post.
                                    Lilybiri has a very good solution to your problem with his advanced action.
                                    My idea cannot compete with Lilybiri's enhanced solution.
                                    As I tend to do things with widgets, I am not into Captivate as much as Lilybiri.
                                    Original Post
                                    Hi Mrs Zev,
                                    I am not sure if your question has been answered completely.
                                    In what you described it would be possible to have 5 slides each with only one active TEB with the TAB shortkey.
                                    The other fake TEBs could be Text fields with variables.
                                    Working without Transistions could do the trick.
                                    Best
                                    TD
                                    Message was edited by: Mr_TD
                                    • 15. Re: Multiple Text Boxes on 1 Slide...
                                      NixTheNext Level 1
                                      I just wanted to reply to everyone- there is SO much good stuff here, I'm behind! Production priorities have taken me away from this topic, but I wanted y'all to know that I'm not 'abandoning' the question. As soon as I can find time to read the conversation thoroughly, I'll let you know where I'm at!
                                      -Thanks again
                                      • 16. Re: Multiple Text Boxes on 1 Slide...
                                        SFNancy Level 1
                                        Hi all,
                                        These images are so helpful - thank you! I am looking forward to Lilybiri's blog post. In the meantime, these examples are helping to trigger my thinking about this and I am going to try to work the rest of this out with the examples as a guide. The thread has been great, causing me to stretch my thinking and to think creatively how best to accomplish what I want with Captivate.
                                        One thought that came to mind and you may be addressing this in your blog post, Lilybiri, but if not, maybe someone else has a suggestion - in the Correct Entries popup window for each TEB, if I have a correct entry set and I want that to be the only answer a user can enter in that particular TEB to be marked correct, is there a way to assign a variable to it (or reference it in some other way) rather than having to type that same correct entry in as a literal in the Advanced Actions window?
                                        In my screenshot below, you can see what I have typed in the Correct Entries window. In the bottom part of the screenshot, you can then see what I typed into my If statement as a literal in the Advanced Actions window. I'm not sure if this is the right approach to this.
                                        I'm sure I'm missing something obvious.
                                        SFNancy
                                        • 17. Re: Multiple Text Boxes on 1 Slide...
                                          You can assign the correct entry to a user variable, and then change the script accordingly. But I do wonder if this will be a timesaver? It would be if it was possible to put the variable directly in the HUD for the correct entries (the small dialog box that you show in your first screenshot) but that is not the case. That would make the whole thing much more flexible: you define the user variable and assign the correct entry to it, use this variable in the Correct entries HUD for the TEB and in the advanced actions. If the correct entry is different, you would only have to change the content of the user variable. I'm now thinking 'aloud', hope you do not mind. And I will file a feature request to ask for the ability to insert a user variable in the Correct Entries HUD.
                                          In the present situation, I would only store the correct entry in a user variable (labeled here v_TB1Correct) if I needed it several times in the script, but that is not the case, it is only used once. Just tried it out, and those were the steps needed to be able to change the script statement to:
                                          IF varTEB1 is equal to v_TB1Correct
                                          Steps:
                                          • create user variable v_TB1Correct (Project, Variables) without adding the value
                                          • create TEB1 and add correct entry to TEB1 in HUD, copy it to the clipboard
                                          • open Variables dialog box and paste this as value for v_TB1Correct
                                          Alternative workflow:
                                          • create user variable v_TB1Correct  and define the value
                                          • copy the value to the clipboard
                                          • create the TEB and paste the value as correct entry
                                          Advantage: you only have to type the correct entry once, no possible issues with typos, agreed. But it is cumbersome.
                                          Thanks for asking this, I will certainly add it to the blog post as an idea.
                                          Lilybiri
                                          • 18. Re: Multiple Text Boxes on 1 Slide...
                                            Hello,
                                            Finally I decided to write an article, will point to it in a blog post, but it was too technical to have everything in the blog.
                                            Here is the link to the article, blog post will be published tomorrow:
                                            Multiple Text Boxes - one Submit
                                            Lilybiri
                                            • 19. Re: Multiple Text Boxes on 1 Slide...
                                              SFNancy Level 1
                                              Thank you SO much, Lilybiri! This "conversation" has been helpful and I appreciate your guidance and expertise. When I initially set out to create my quiz slide, I didn't think this would be so extensive; you have helped me think differently about the challenge and approaches to solving it.
                                              The article is excellent and I hope that others benefit from all of this.
                                              Thank you again!
                                              SFNancy
                                              • 20. Re: Multiple Text Boxes on 1 Slide...
                                                Thanks for your kind words! It is a win-win situation because your questions made me search for the proper solution and I have introduced a feature request to be able to insert variables in the correct entries HUD for TEB.
                                                Could find time to publish some explanation on the blog too, here is the link:
                                                One Submit button for Multiple Text Entry Boxes
                                                Lilybiri
                                                • 21. Re: Multiple Text Boxes on 1 Slide...
                                                  SFNancy Level 1
                                                  Lilybiri
                                                  Thanks, Lilybiri. That sounds like a valuable feature; I banged my head against the desk for quite some time trying to figure out the best way to reference the correct entries HUD . In the meantime, you have inspired me to learn more about ways to take advantage of Advanced Actions, variables, and the power of Captivate. This has been an enjoyable learning experience for me and I hope that the OP can benefit from all of this as well.
                                                  SFNancy
                                                  • 22. Re: Multiple Text Boxes on 1 Slide...
                                                    brightonjon Level 2
                                                    Ooh, I'm liking that!
                                                    I may have to shamelessly steal that technique for one of my own projects
                                                    Nice work Lieve
                                                    • 23. Re: Multiple Text Boxes on 1 Slide...
                                                      So I should have put a copyright on it?
                                                      You're welcome of course, let me know if you are having issues or seeing something that is not well explained!
                                                      Lilybiri
                                                      • 24. Re: Multiple Text Boxes on 1 Slide...
                                                        monicatl Level 1
                                                        Lilybiri,
                                                        Thanks for such an excellent workflow!  I am doing exactly this in my project & you have saved me a bunch of time...
                                                        I do have a few questions...
                                                        Why do the TEBs need to be configured to Validate User Input?  Their input is being validated through the Advanced Action script, so it seems to me that this option could be disabled for the TEB objects.  Is this still being used in some way?  Is it necessary?
                                                        Also, if I remove the shortcut for my TEB - it forces a submit button to appear.  I can't remove the submit button w/o having a shortcut action.  Currently, I have the default shortcuts defined (Enter) for all my TEBs even though I know only one TEB will actually allow the shortcut.   What does the shortcut do, exactly?
                                                        thanks again for all the help!
                                                        Monica
                                                        • 25. Re: Multiple Text Boxes on 1 Slide...
                                                          BJSouset
                                                          Hi Lilybiri,
                                                          I have been trying to implement the script but somehow I have gone wrong along the lines. Everytime I test the slide it keeps coming up with the ticks regardless whether I put the right information in.
                                                          I don't know what I am doing wrong
                                                          Would it be helpful if I attached the project?
                                                          Thank you,
                                                          Sal
                                                          • 26. Re: Multiple Text Boxes on 1 Slide...
                                                            It is not possible to attach a file. And since a while I have decided not to spend hours to debug files for users anymore for free. If you want to post screenshots of the advanced action, maybe I can detect some bugs?
                                                            And this is an old thread, are you using the same version as the original user?
                                                            • 27. Re: Multiple Text Boxes on 1 Slide...
                                                              BJSouset Level 1
                                                              I am using Captivate 6 I’ll send you some screen shoots of the Advanced action and hopefully it will be something I haven’t done.
                                                              Thanks for your help.
                                                              (Pointless links removed)
                                                              I have applied this to the rest.
                                                              Salwa Saad-Abdulla
                                                              Browne Jacobson LLP
                                                              • 28. Re: Multiple Text Boxes on 1 Slide...
        To insert a screenshot you'll have to use the Browser version of the forums, there is a little still camera icon that will allow to insert images. I can't see what you attached.
        • 30. Re: Multiple Text Boxes on 1 Slide...
        Do you apply the correct On Enter action as well? And did you put the correct values in the v_TEBxCorrect  variables?
        Lilybiri
        • 31. Re: Multiple Text Boxes on 1 Slide...
        BJSouset Level 1
        I have applied the On Enter Action for the main slide as Enterslide and for each TEB I have applied the Checksubmit. The ‘On Focus Lost’ is set on No action for each TEB is that correct?
        Yes I have inserted the correct value for each v_TEBCorrect variables
        Salwa Saad-Abdulla
        Browne Jacobson LLP
        • 32. Re: Multiple Text Boxes on 1 Slide...
        In that case I'm at a loss why it doesn't work, it did for me. There must be a bug somewhere. You know that variables are case sensitive?
        • 33. Re: Multiple Text Boxes on 1 Slide...
        BJSouset Level 1
        Yes I am aware. I remember you saying something about short keys can’t be the same do you think might be causing the problem?
        Salwa Saad-Abdulla
        Browne Jacobson LLP
        • 34. Re: Multiple Text Boxes on 1 Slide...
        Using same shortcut key for different interactive objects on one slide can cause issues, do you have those?
        • 35. Re: Multiple Text Boxes on 1 Slide...
        BJSouset Level 1
        I personally haven’t assigned any but every time I insert a TEB the short key has continue next to it.
        Salwa Saad-Abdulla
        Browne Jacobson LLP
        • 36. Re: Multiple Text Boxes on 1 Slide...
        BJSouset Level 1
        I finally figured it out I hadn’t attached the variable v_TEB1 to each text box.
        Thank you for your help you have been a great support.
        Salwa Saad-Abdulla
        Browne Jacobson LLP
