Look in the output file myproject.htm; in other words, the
WebHelp launch file. This is what sets up the WebHelp window, with
references to parameters and scripts in several other output files.
Look for these lines:
var strHTML = "<frameset rows=\"150,*\"
hostof=\"parent:toolbar!startpage:yes\" frameborder=\"0\"
border=\"50\"><frame src=\"whskin_tbars.htm\" id=\"toolbar\"
frameborder=\"0\" border=\"0\" scrolling=\"no\" noresize
marginheight=\"25\" marginwidth=\"0\"
title=\"Toolbar\"></frame> . . . . .
Of course, the numbers in your file will be different.
frameset rows sets the height of the main toolbar. If you are
using the default buttons for Contents, etc., RH will stretch their
rectangular outlines vertically.
border=\"50\" inserts an empty space under the main toolbar,
lowering the left and topic panes.
You probably should modify both border parameters because
they serve different browsers (I think).
marginheight=\"25\" adds a margin above the buttons, the same
color or pattern as the rest of the toolbar background.
I don't know what this will do to your layout with buttons
beneath the text.
Please post back with results.
Harvey
