I just asked. But I asked something else on there and it didn't get an answer. I think there are more questions than answers there.
Here is the .js code, do you think it could be something in here that I can amend?
(function($) {
$.effects.slide = function(o) {
return this.queue(function() {
// Create element
var el = $(this), props = ['position','top','left'];
// Set options
var mode = $.effects.setMode(el, o.options.mode || 'show'); // Set Mode
var direction = o.options.direction || 'left'; // Default Direction
// Adjust
$.effects.save(el, props); el.show(); // Save & Show
$.effects.createWrapper(el).css({overflow:'hidden'}); // Create Wrapper
var ref = (direction == 'up' || direction == 'down') ? 'top' : 'left';
var motion = (direction == 'up' || direction == 'left') ? 'pos' : 'neg';
var distance = o.options.distance || (ref == 'top' ? el.outerHeight({margin:true}) : el.outerWidth({margin:true}));
if (mode == 'show') el.css(ref, motion == 'pos' ? -distance : distance); // Shift
// Animation
var animation = {};
animation[ref] = (mode == 'show' ? (motion == 'pos' ? '+=' : '-=') : (motion == 'pos' ? '-=' : '+=')) + distance;
// Animate
el.animate(animation, { queue: false, duration: o.duration, easing: o.options.easing, complete: function() {
if(mode == 'hide') el.hide(); // Hide
$.effects.restore(el, props); $.effects.removeWrapper(el); // Restore
if(o.callback) o.callback.apply(this, arguments); // Callback
el.dequeue();
})(jQuery);
Here is another file it links to:
;(function($) {
$.effects = $.effects || {}; //Add the 'effects' scope
$.extend($.effects, {
save: function(el, set) {
for(var i=0;i<set.length;i++) {
if(set[i] !== null) $.data(el[0], "ec.storage."+set[i], el[0].style[set[i]]);
restore: function(el, set) {
if(set[i] !== null) el.css(set[i], $.data(el[0], "ec.storage."+set[i]));
setMode: function(el, mode) {
if (mode == 'toggle') mode = el.is(':hidden') ? 'show' : 'hide'; // Set for toggle
return mode;
getBaseline: function(origin, original) { // Translates a [top,left] array into a baseline value
// this should be a little more flexible in the future to handle a string & hash
var y, x;
switch (origin[0]) {
case 'top': y = 0; break;
case 'middle': y = 0.5; break;
case 'bottom': y = 1; break;
default: y = origin[0] / original.height;
switch (origin[1]) {
case 'left': x = 0; break;
case 'center': x = 0.5; break;
case 'right': x = 1; break;
default: x = origin[1] / original.width;
return {x: x, y: y};
createWrapper: function(el) {
if (el.parent().attr('id') == 'fxWrapper')
return el;
var props = {width: el.outerWidth({margin:true}), height: el.outerHeight({margin:true}), 'float': el.css('float')};
el.wrap('<div id="fxWrapper" style="font-size:100%;background:transparent;border:none;margin:0;padding:0"></div>');
var wrapper = el.parent();
if (el.css('position') == 'static'){
wrapper.css({position: 'relative'});
el.css({position: 'relative'});
} else {
var top = el.css('top'); if(isNaN(parseInt(top))) top = 'auto';
var left = el.css('left'); if(isNaN(parseInt(left))) left = 'auto';
wrapper.css({ position: el.css('position'), top: top, left: left, zIndex: el.css('z-index') }).show();
el.css({position: 'relative', top:0, left:0});
wrapper.css(props);
return wrapper;
removeWrapper: function(el) {
return el.parent().replaceWith(el);
return el;
setTransition: function(el, list, factor, val) {
val = val || {};
$.each(list,function(i, x){
unit = el.cssUnit(x);
if (unit[0] > 0) val[x] = unit[0] * factor + unit[1];
return val;
animateClass: function(value, duration, easing, callback) {
var cb = (typeof easing == "function" ? easing : (callback ? callback : null));
var ea = (typeof easing == "object" ? easing : null);
return this.each(function() {
var offset = {}; var that = $(this); var oldStyleAttr = that.attr("style") || '';
if(typeof oldStyleAttr == 'object') oldStyleAttr = oldStyleAttr["cssText"]; /* Stupidly in IE, style is a object.. */
if(value.toggle) { that.hasClass(value.toggle) ? value.remove = value.toggle : value.add = value.toggle; }
//Let's get a style offset
var oldStyle = $.extend({}, (document.defaultView ? document.defaultView.getComputedStyle(this,null) : this.currentStyle));
if(value.add) that.addClass(value.add); if(value.remove) that.removeClass(value.remove);
var newStyle = $.extend({}, (document.defaultView ? document.defaultView.getComputedStyle(this,null) : this.currentStyle));
if(value.add) that.removeClass(value.add); if(value.remove) that.addClass(value.remove);
// The main function to form the object for animation
for(var n in newStyle) {
if( typeof newStyle[n] != "function" && newStyle[n] /* No functions and null properties */
&& n.indexOf("Moz") == -1 && n.indexOf("length") == -1 /* No mozilla spezific render properties. */
&& newStyle[n] != oldStyle[n] /* Only values that have changed are used for the animation */
&& (n.match(/color/i) || (!n.match(/color/i) && !isNaN(parseInt(newStyle[n],10)))) /* Only things that can be parsed to integers or colors */
&& (oldStyle.position != "static" || (oldStyle.position == "static" && !n.match(/left|top|bottom|right/))) /* No need for positions when dealing with static positions */
) offset[n] = newStyle[n];
that.animate(offset, duration, ea, function() { // Animate the newly constructed offset object
// Change style attribute back to original. For stupid IE, we need to clear the damn object.
if(typeof $(this).attr("style") == 'object') { $(this).attr("style")["cssText"] = ""; $(this).attr("style")["cssText"] = oldStyleAttr; } else $(this).attr("style", oldStyleAttr);
if(value.add) $(this).addClass(value.add); if(value.remove) $(this).removeClass(value.remove);
if(cb) cb.apply(this, arguments);
//Extend the methods of jQuery
$.fn.extend({
//Save old methods
_show: $.fn.show,
_hide: $.fn.hide,
__toggle: $.fn.toggle,
_addClass: $.fn.addClass,
_removeClass: $.fn.removeClass,
_toggleClass: $.fn.toggleClass,
// New ec methods
effect: function(fx,o,speed,callback) {
return $.effects[fx] ? $.effects[fx].call(this, {method: fx, options: o || {}, duration: speed, callback: callback }) : null;
show: function() {
if(!arguments[0] || (arguments[0].constructor == Number || /(slow|normal|fast)/.test(arguments[0])))
return this._show.apply(this, arguments);
else {
var o = arguments[1] || {}; o['mode'] = 'show';
return this.effect.apply(this, [arguments[0], o, arguments[2] || o.duration, arguments[3] || o.callback]);
hide: function() {
return this._hide.apply(this, arguments);
else {
var o = arguments[1] || {}; o['mode'] = 'hide';
toggle: function(){
if(!arguments[0] || (arguments[0].constructor == Number || /(slow|normal|fast)/.test(arguments[0])) || (arguments[0].constructor == Function))
return this.__toggle.apply(this, arguments);
else {
var o = arguments[1] || {}; o['mode'] = 'toggle';
addClass: function(classNames,speed,easing,callback) {
return speed ? $.effects.animateClass.apply(this, [{ add: classNames },speed,easing,callback]) : this._addClass(classNames);
removeClass: function(classNames,speed,easing,callback) {
return speed ? $.effects.animateClass.apply(this, [{ remove: classNames },speed,easing,callback]) : this._removeClass(classNames);
toggleClass: function(classNames,speed,easing,callback) {
return speed ? $.effects.animateClass.apply(this, [{ toggle: classNames },speed,easing,callback]) : this._toggleClass(classNames);
morph: function(remove,add,speed,easing,callback) {
return $.effects.animateClass.apply(this, [{ add: add, remove: remove },speed,easing,callback]);
switchClass: function() {
return this.morph.apply(this, arguments);
// helper functions
cssUnit: function(key) {
var style = this.css(key), val = [];
$.each( ['em','px','%','pt'], function(i, unit){
if(style.indexOf(unit) > 0)
val = [parseFloat(style), unit];
return val;
* jQuery Color Animations
* Copyright 2007 John Resig
* Released under the MIT and GPL licenses.
// We override the animation for all of these color styles
jQuery.each(['backgroundColor', 'borderBottomColor', 'borderLeftColor', 'borderRightColor', 'borderTopColor', 'color', 'outlineColor'], function(i,attr){
jQuery.fx.step[attr] = function(fx){
if ( fx.state == 0 ) {
fx.start = getColor( fx.elem, attr );
fx.end = getRGB( fx.end );
fx.elem.style[attr] = "rgb(" + [
Math.max(Math.min( parseInt((fx.pos * (fx.end[0] - fx.start[0])) + fx.start[0]), 255), 0),
Math.max(Math.min( parseInt((fx.pos * (fx.end[1] - fx.start[1])) + fx.start[1]), 255), 0),
Math.max(Math.min( parseInt((fx.pos * (fx.end[2] - fx.start[2])) + fx.start[2]), 255), 0)
].join(",") + ")";
// Color Conversion functions from highlightFade
// By Blair Mitchelmore
// http://jquery.offput.ca/highlightFade/
// Parse strings looking for color tuples [255,255,255]
function getRGB(color) {
var result;
// Check if we're already dealing with an array of colors
if ( color && color.constructor == Array && color.length == 3 )
return color;
// Look for rgb(num,num,num)
if (result = /rgb\(\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*,\s*([0-9]{1,3})\s*\)/.exec(color))
return [parseInt(result[1]), parseInt(result[2]), parseInt(result[3])];
// Look for rgb(num%,num%,num%)
if (result = /rgb\(\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*,\s*([0-9]+(?:\.[0-9]+)?)\%\s*\)/.exec(color))
return [parseFloat(result[1])*2.55, parseFloat(result[2])*2.55, parseFloat(result[3])*2.55];
// Look for #a0b1c2
if (result = /#([a-fA-F0-9]{2})([a-fA-F0-9]{2})([a-fA-F0-9]{2})/.exec(color))
return [parseInt(result[1],16), parseInt(result[2],16), parseInt(result[3],16)];
// Look for #fff
if (result = /#([a-fA-F0-9])([a-fA-F0-9])([a-fA-F0-9])/.exec(color))
return [parseInt(result[1]+result[1],16), parseInt(result[2]+result[2],16), parseInt(result[3]+result[3],16)];
// Look for rgba(0, 0, 0, 0) == transparent in Safari 3
if (result = /rgba\(0, 0, 0, 0\)/.exec(color))
return colors['transparent']
// Otherwise, we're most likely dealing with a named color
return colors[jQuery.trim(color).toLowerCase()];
function getColor(elem, attr) {
var color;
do {
color = jQuery.curCSS(elem, attr);
// Keep going until we find an element that has color, or we hit the body
if ( color != '' && color != 'transparent' || jQuery.nodeName(elem, "body") )
break;
attr = "backgroundColor";
} while ( elem = elem.parentNode );
return getRGB(color);
// Some named colors to work with
// From Interface by Stefan Petre
// http://interface.eyecon.ro/
var colors = {
aqua:[0,255,255],
azure:[240,255,255],
beige:[245,245,220],
black:[0,0,0],
blue:[0,0,255],
brown:[165,42,42],
cyan:[0,255,255],
darkblue:[0,0,139],
darkcyan:[0,139,139],
darkgrey:[169,169,169],
darkgreen:[0,100,0],
darkkhaki:[189,183,107],
darkmagenta:[139,0,139],
darkolivegreen:[85,107,47],
darkorange:[255,140,0],
darkorchid:[153,50,204],
darkred:[139,0,0],
darksalmon:[233,150,122],
darkviolet:[148,0,211],
fuchsia:[255,0,255],
gold:[255,215,0],
green:[0,128,0],
indigo:[75,0,130],
khaki:[240,230,140],
lightblue:[173,216,230],
lightcyan:[224,255,255],
lightgreen:[144,238,144],
lightgrey:[211,211,211],
lightpink:[255,182,193],
lightyellow:[255,255,224],
lime:[0,255,0],
magenta:[255,0,255],
maroon:[128,0,0],
navy:[0,0,128],
olive:[128,128,0],
orange:[255,165,0],
pink:[255,192,203],
purple:[128,0,128],
violet:[128,0,128],
red:[255,0,0],
silver:[192,192,192],
white:[255,255,255],
yellow:[255,255,0],
transparent: [255,255,255]
* jQuery Easing v1.3 - http://gsgd.co.uk/sandbox/jquery/easing/
* Uses the built in easing capabilities added In jQuery 1.1
* to offer multiple easing options
* TERMS OF USE - jQuery Easing
* Open source under the BSD License.
* Copyright © 2008 George McGinley Smith
* All rights reserved.
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list of
* conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this list
* of conditions and the following disclaimer in the documentation and/or other materials
* provided with the distribution.
* Neither the name of the author nor the names of contributors may be used to endorse
* or promote products derived from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY
* EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
* MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
* EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
* GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
* OF THE POSSIBILITY OF SUCH DAMAGE.
// t: current time, b: begInnIng value, c: change In value, d: duration
jQuery.easing['jswing'] = jQuery.easing['swing'];
jQuery.extend( jQuery.easing,
def: 'easeOutQuad',
swing: function (x, t, b, c, d) {
//alert(jQuery.easing.default);
return jQuery.easing[jQuery.easing.def](x, t, b, c, d);
easeInQuad: function (x, t, b, c, d) {
return c*(t/=d)*t + b;
easeOutQuad: function (x, t, b, c, d) {
return -c *(t/=d)*(t-2) + b;
easeInOutQuad: function (x, t, b, c, d) {
if ((t/=d/2) < 1) return c/2*t*t + b;
return -c/2 * ((--t)*(t-2) - 1) + b;
easeInCubic: function (x, t, b, c, d) {
return c*(t/=d)*t*t + b;
easeOutCubic: function (x, t, b, c, d) {
return c*((t=t/d-1)*t*t + 1) + b;
easeInOutCubic: function (x, t, b, c, d) {
if ((t/=d/2) < 1) return c/2*t*t*t + b;
return c/2*((t-=2)*t*t + 2) + b;
easeInQuart: function (x, t, b, c, d) {
return c*(t/=d)*t*t*t + b;
easeOutQuart: function (x, t, b, c, d) {
return -c * ((t=t/d-1)*t*t*t - 1) + b;
easeInOutQuart: function (x, t, b, c, d) {
if ((t/=d/2) < 1) return c/2*t*t*t*t + b;
return -c/2 * ((t-=2)*t*t*t - 2) + b;
easeInQuint: function (x, t, b, c, d) {
return c*(t/=d)*t*t*t*t + b;
easeOutQuint: function (x, t, b, c, d) {
return c*((t=t/d-1)*t*t*t*t + 1) + b;
easeInOutQuint: function (x, t, b, c, d) {
if ((t/=d/2) < 1) return c/2*t*t*t*t*t + b;
return c/2*((t-=2)*t*t*t*t + 2) + b;
easeInSine: function (x, t, b, c, d) {
return -c * Math.cos(t/d * (Math.PI/2)) + c + b;
easeOutSine: function (x, t, b, c, d) {
return c * Math.sin(t/d * (Math.PI/2)) + b;
easeInOutSine: function (x, t, b, c, d) {
return -c/2 * (Math.cos(Math.PI*t/d) - 1) + b;
easeInExpo: function (x, t, b, c, d) {
return (t==0) ? b : c * Math.pow(2, 10 * (t/d - 1)) + b;
easeOutExpo: function (x, t, b, c, d) {
return (t==d) ? b+c : c * (-Math.pow(2, -10 * t/d) + 1) + b;
easeInOutExpo: function (x, t, b, c, d) {
if (t==0) return b;
if (t==d) return b+c;
if ((t/=d/2) < 1) return c/2 * Math.pow(2, 10 * (t - 1)) + b;
return c/2 * (-Math.pow(2, -10 * --t) + 2) + b;
easeInCirc: function (x, t, b, c, d) {
return -c * (Math.sqrt(1 - (t/=d)*t) - 1) + b;
easeOutCirc: function (x, t, b, c, d) {
return c * Math.sqrt(1 - (t=t/d-1)*t) + b;
easeInOutCirc: function (x, t, b, c, d) {
if ((t/=d/2) < 1) return -c/2 * (Math.sqrt(1 - t*t) - 1) + b;
return c/2 * (Math.sqrt(1 - (t-=2)*t) + 1) + b;
easeInElastic: function (x, t, b, c, d) {
var s=1.70158;var p=0;var a=c;
if (t==0) return b; if ((t/=d)==1) return b+c; if (!p) p=d*.3;
if (a < Math.abs(c)) { a=c; var s=p/4; }
else var s = p/(2*Math.PI) * Math.asin (c/a);
return -(a*Math.pow(2,10*(t-=1)) * Math.sin( (t*d-s)*(2*Math.PI)/p )) + b;
easeOutElastic: function (x, t, b, c, d) {
return a*Math.pow(2,-10*t) * Math.sin( (t*d-s)*(2*Math.PI)/p ) + c + b;
easeInOutElastic: function (x, t, b, c, d) {
if (t==0) return b; if ((t/=d/2)==2) return b+c; if (!p) p=d*(.3*1.5);
if (t < 1) return -.5*(a*Math.pow(2,10*(t-=1)) * Math.sin( (t*d-s)*(2*Math.PI)/p )) + b;
return a*Math.pow(2,-10*(t-=1)) * Math.sin( (t*d-s)*(2*Math.PI)/p )*.5 + c + b;
easeInBack: function (x, t, b, c, d, s) {
if (s == undefined) s = 1.70158;
return c*(t/=d)*t*((s+1)*t - s) + b;
easeOutBack: function (x, t, b, c, d, s) {
return c*((t=t/d-1)*t*((s+1)*t + s) + 1) + b;
easeInOutBack: function (x, t, b, c, d, s) {
if ((t/=d/2) < 1) return c/2*(t*t*(((s*=(1.525))+1)*t - s)) + b;
return c/2*((t-=2)*t*(((s*=(1.525))+1)*t + s) + 2) + b;
easeInBounce: function (x, t, b, c, d) {
return c - jQuery.easing.easeOutBounce (x, d-t, 0, c, d) + b;
easeOutBounce: function (x, t, b, c, d) {
if ((t/=d) < (1/2.75)) {
return c*(7.5625*t*t) + b;
} else if (t < (2/2.75)) {
return c*(7.5625*(t-=(1.5/2.75))*t + .75) + b;
} else if (t < (2.5/2.75)) {
return c*(7.5625*(t-=(2.25/2.75))*t + .9375) + b;
} else {
return c*(7.5625*(t-=(2.625/2.75))*t + .984375) + b;
easeInOutBounce: function (x, t, b, c, d) {
if (t < d/2) return jQuery.easing.easeInBounce (x, t*2, 0, c, d) * .5 + b;
return jQuery.easing.easeOutBounce (x, t*2-d, 0, c, d) * .5 + c*.5 + b;
