1. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
Todd_Kopriva Jan 23, 2011 5:16 PM (in response to tfi productions 44)If you go to the plug-in vendors' sites, they'll usually say what color bit depth the plug-ins use.
Here's a good place to start to find plug-in vendors' sites: "Where to find more plug-ins for After Effects"
2. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 23, 2011 5:36 PM (in response to Todd_Kopriva)hello,
i have seen the list from mylenium
and have been to most of the websites
but acutally, many do not say if they are 32bpc
the stats list that the effects will work in 64bit cs5
i was looking on features pages, support pages, etc.
but not much luck...
i emailed some of the big companies asking specifically
so hopefully i'll hear from them this week...
also is my 'solution' correct:
use only 32bpc effects to take advantage of what 32bpc has to offer...
thanks,
j
(many of the articles about 32bpc i've read were associated with you or linked by you, so again, thanks)
3. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 23, 2011 5:39 PM (in response to tfi productions 44)hello,
surprisingly for a Sunday night
a rep from Revision just sent me:
"They all support 32b float per channel, however so you know within PPRO our effect will only work in 8 bit (same for others) as their implementation to support ae-comptabile plugins is currently broken
Pierre
RE:Vision Effects" -
4. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 23, 2011 5:49 PM (in response to tfi productions 44)hello,
Pierre
RE:Vision Effects"Note: i asked him to clarify the PPRO issue..
j
5. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
Todd_Kopriva Jan 23, 2011 5:49 PM (in response to tfi productions 44)>also is my 'solution' correct:
Mostly, but that's a little oversimplified. See this section for some more information: "Special considerations for working with high dynamic range color"
6. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 23, 2011 6:40 PM (in response to Todd_Kopriva)hello Todd,
just heard back from ReVision's rep:
he states that it's an adobe thing
why the 32bpc ReVision effects only work in 8bit inside PPRO cs5
"yes, adobe's implementation within Premiere (nothing we can do other then wait for them to fix)"
and then re: AE:
"YES in AE, if you set the project to 32b float, our plugins will process 32b float (will not clamp values above 1 and under 0...)"
any info from Adobe's side?
(reading up more on 32bpc and HDR)
thanks,
j
7. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
Todd_Kopriva Jan 23, 2011 6:47 PM (in response to tfi productions 44)> any info from Adobe's side?
What is your question?
8. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 23, 2011 7:05 PM (in response to Todd_Kopriva)hello,
Why don't ReVision effects work in 32bpc inside PPRO
but they do in AE?
Does Adobe plan to get ReVision 32bpc effects working as 32bpc in PPRO?
thanks,
j
9. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
Todd_Kopriva Jan 23, 2011 10:36 PM (in response to tfi productions 44)The After Effects forum isn't the best place for questions about the Premiere Pro SDK and internals of Premiere Pro plug-ins. Here's a link to the Premiere Pro SDK forum:
http://forums.adobe.com/community/premiere/premierepro_current/sdk
If you want to make a feature request for Premiere Pro to have a 32-bpc, high-dynamic-range color pipeline like After Effects, then you can submit a feature request. Be sure to articulate in your feature request why you think an NLE needs a complete 32-bpc, high-dynamic-range color pipeline. Usually, this is only considered important and useful for a compositing and visual effects application, and not as much for an NLE.
10. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
Mylenium Jan 24, 2011 12:32 AM (in response to tfi productions 44)I know, I should add processing bit depth to my site some day. You can however assume that most third-party plug-ins work reliably with 32bpc processing in AE, including all the Trapcode tools, RevisionFX, BorisFX, GenArts, Magic Bullet products. It's really only some oldder ones that never have been updated. If you have questions about specific plug-ins, just ask...
Mylenium
11. Re: What vendors make 32bpc plugins for CS5 AE and PPRO?
tfi productions 44 Jan 24, 2011 10:23 AM (in response to Todd_Kopriva)Todd,
i started a thread in the PPRO SDK forum
asking others for their advice about PPRO being a COMPLETE 32bpc application.
i don't know enough to state either way
thanks again for pointing in the right direction,
j
