I will need to do database queries in web service using input string as query parameters.
But I need different queries depends on the input string values:
e.g. input1, input2
if input2 is empty or null, then do query one,
if input 2 has value then do query two.
But I don't know how to evalue a string input is null or empty string or with value.
Can any one help?
Many thanks
Laura
Total Likes
Can you use a DecisionPoint and set up different route conditions for each possible query?
Total Likes
Thank you for the reply.
I made it work by using Set Value then route conditions.
I assign the string length to a process integer. then check if the integer is 0 or not.
But I am not sure what form will submit when user didn't give a value. will firm submit "null" or empty string, Can I define empty string as default value?
on form field?
Thanks again.
Total Likes
It will submit an empty string. There is no concept of null in xml data. Everything is treated as a string.
Jasmin
Total Likes
