In my earlier project I produced several different chm files
which all behaved the same when searching from the Search tab. When
searching for instance 'beam' it also found 'beams' and 'beaming'.
Now I have two new projects - one copied from the old one and
one completely new (with only style sheet imported from old
project). They will only perform a simple search; i.e. 'beam' will
only find 'beam' and 'beams' will only find 'beams'. I've checked
the settings for the window, etc., but found nothing that is
different between the old and the new projects.
I also thought it might be something in RoboHelp settings
that had changed, but when generating new output from the old
project, it still behaves in the desired way.
Any clue?
Sara
