Are you accessing a db or what? One way is setup your
application.cfm and setup the client and session management. Then
once the user logins into the application set the client variables.
Say for instance, I login into the system using JonesB.
Once I am authenticate, you will set the following variables:
<cfset client.username = JonesB>
<cfset client.email = jonesb@ourdomain.org>
With this info, you can have access to the information
throughout the application.
Hope this helps.
Sevor Klu
