2 Replies Latest reply on Jan 26, 2011 8:05 AM by The Flex Viking
    Assemble static XFA-Based pdf with NoForms or NoXFA error: PageException: PDFM_S19003
    jpadron_uy Newcomer
      Hello
      I have a PDF which I generated with LC Forms (LC ES 8.2).
      Now I am trying generate new flat PDF on Assembler service using the following DDX:
      <DDX xmlns="http://ns.adobe.com/DDX/1.0/">
      <PDF result="out.pdf">
        <PDF source="cabtf1-forpdfgenerated-STATIC.pdf" />
        <NoXFA/>
      </PDF>
      </DDX>
      I tried also to use <NoForms/> tag instead of <NoXFA>, and in both cases, this particular PDF I gives the following error:
      out.pdfcom.adobe.internal.pdfm.util.PageException: PDFM_S19003: Failed to find a matching SVG named color for "2"
      The full stack trace is:
      com.adobe.internal.ddxm.Executive.execute DDXM_N00000: Started processing result named out.pdf</msg><msg t="1.797" l="SEVERE" n="com.adobe.internal.ddxm.Executive" cpu="0.3125">com.adobe.internal.ddxm.Executive.execute DDXM_S00001: Failed to assemble result named out.pdfcom.adobe.internal.pdfm.util.PageException: PDFM_S19003: Failed to find a matching SVG named color for "2"
      at com.adobe.internal.pdfm.util.PageSet.setDocument(PageSet.java:151)
      at com.adobe.internal.pdfm.assembly.PageAssembler.deletePages(PageAssembler.java:117)
      at com.adobe.internal.pdfm.assembly.DocAssembler.prepareBaseDocForAssembly(DocAssembler.java :339)
      at com.adobe.internal.pdfm.assembly.DocAssembler.assemble(DocAssembler.java:161)
      at com.adobe.internal.ddxm.task.pdf.AssemblePDF.execute(AssemblePDF.java:130)
      at com.adobe.internal.ddxm.blueprint.BluePrint.execute(BluePrint.java:275)
      at com.adobe.internal.ddxm.ddx.Node.execute(Node.java:373)
      at com.adobe.internal.ddxm.Executive.execute(Executive.java:270)
      at com.adobe.internal.ddxm.Executive.execute(Executive.java:221)
      at com.adobe.livecycle.assembler.AssemblerServiceImpl.execute(AssemblerServiceImpl.java:465)
      at com.adobe.livecycle.assembler.AssemblerServiceImpl.invoke(AssemblerServiceImpl.java:408)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)...
      Any ideas? ... Not find the error code PDFM_S19003 how I can solve it?
      Thanks.
