14 Replies Latest reply: Mar 17, 2011 12:40 AM by Rasool.Irfan RSS
    how get use strobeMediaPlayBack.swc in flex?
    HWAndrew
      Hi all,
      I am new to flex and flash. Our group has developed a silverlight player with media time text search functionality. And we also want to do the same thing in flash. Hope that you guys can give me a hand. Thank you in advance.
      Basically I want to have such a player that: user can input text and a button to trigger submit (HTTP POST) to server.
      Server then send back some xml data and the player can parse the data and show the time text in a list (like cue point).
      Also clicking the cue point the player will seek to that position.
      I try to modify AS3 code in the StrobeMediaPlayBack and create the controls/widgets & logics inside the player. But as I am new to flash, it's not easy.
      So I am trying to comply the StrobeMediaPlayBack to an .swc file and add control (like Button TextInput)  & logics in mxml.
      I add the .swc file in a new flex project project and write the below code in .mxml file.  It get errors when i debug or run it.
      Is it the correct way to add 'object' in mxml ( i guess is not ;< )? Can anyone help?
      Tank you
      Andrew
      <?xml version="1.0" encoding="utf-8"?>
      <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
                             xmlns:s="library://ns.adobe.com/flex/spark"
                                 xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*"
      <fx:Script>
      <![CDATA[
      </fx:Script>
      <local:MyPlayer width="1028" height="540">
      </local:MyPlayer>
      <s:Button>
      </s:Button>
      <s:TextInput>
      </s:TextInput>
      <fx:Declarations>
      <local:StrobeMediaPlayback id="myPlayer">
      </local:StrobeMediaPlayback>
      </fx:Declarations>
      </s:Application>
        • 1. Re: how get use strobeMediaPlayBack.swc in flex?
          HWAndrew Community Member
          Below is the error information:
          VerifyError: Error #1053: Illegal override of synthesizer in org.osmf.layout.LayoutMetadata.
          at flash.display::MovieClip/nextFrame()
          at mx.managers::SystemManager/deferredNextFrame()[E:\dev\4.x\frameworks\projects\framework\s rc\mx\managers\SystemManager.as:267]
          at mx.managers::SystemManager/preloader_preloaderDocFrameReadyHandler()[E:\dev\4.x\framework s\projects\framework\src\mx\managers\SystemManager.as:2460]
          at flash.events::EventDispatcher/dispatchEventFunction()
          at flash.events::EventDispatcher/dispatchEvent()
          at mx.preloaders::Preloader/timerHandler()[E:\dev\4.x\frameworks\projects\framework\src\mx\p reloaders\Preloader.as:488]
          at flash.utils::Timer/_timerDispatch()
          at flash.utils::Timer/tick()
          • 2. Re: how get use strobeMediaPlayBack.swc in flex?
            Andrian Cucu Adobe Employee
            this thread should help you:
            http://forums.adobe.com/thread/702338
            You can find woking samples there.
            -Andrian
            • 3. Re: how get use strobeMediaPlayBack.swc in flex?
              Hi Andrian,
              Thank you for your reply.
              I follow the example you give in the link, using UIcomponent to hold the StrobeMediaPlayBack.
              But still the VerifyError: Error #1053: Illegal override of synthesizer in org.osmf.layout.LayoutMetadata comes out.
              I search google nad some posts tell that it's due to complying the component with different FLEX SDK.
              http://www.flexer.info/2009/01/14/verifyerror-error-1053-illegal-override-of/
              I download the OSMF.swc form osmf home page, and my flex complier is using the flex sdk 4.1.
              Is it the problem?  or any other issue that cause the error?
              thank you
              Andrew
              • 4. Re: how get use strobeMediaPlayBack.swc in flex?
                Flex 4.0 has bundled an obsolete version of the OSMF, and you need to remove it manually from your project settings.
                Check the release notes here http://opensource.adobe.com/wiki/display/osmf/Downloads (Using OSMF with Flex 4 SDK) if you run into troubles.
                • 5. Re: how get use strobeMediaPlayBack.swc in flex?
                  Hi Andrian,
                  I comply the OSMF.swc form source code and now the player works.
                  Thank you so much
                  andrew
                  • 6. Re: how get use strobeMediaPlayBack.swc in flex?
                    Celumbra1 Community Member
                    Hi Adrian,
                    I want to try to integrate Strobe into a Flex app. I read your previous thread, but cannot seem to download the examples. Are they posted somewhere new? Or has the newer version of Strobe changed?
                    Thanks.
                    • 7. Re: how get use strobeMediaPlayBack.swc in flex?
                      Hello,
                      You can download the latest Strobe Media Playback source code and binaries from here: http://sourceforge.net/adobe/smp/home/
                      Let us know if this is what you were looking for.
                      -Andrian
                      • 8. Re: how get use strobeMediaPlayBack.swc in flex?
                        Hi Adrian,
                        I was looking for the sample code for integrating Strobe into Flex 4. You
                        posted links for sample code for integrating it into an Air application, but
                        those links seem to no longer function.
                        Thanks.
                        Robert
                        • 9. Re: how get use strobeMediaPlayBack.swc in flex?
                          Here are the links on that thread that I was trying to find. Thanks
                          http://smpfmp.appspot.com/SMPAir.air
                          Here is the zip with the source code of the project:
                          http://smpfmp.appspot.com/SMPAir.zip
                          Here is the mxml file: http://smpfmp.appspot.com/SMPAir.mxml
                          • 10. Re: how get use strobeMediaPlayBack.swc in flex?
                            Hi Adrian,
                            I've tried to integrate the StrobeMediaPlayback into Flex unsuccessfully following the thread here, but the compiler doesn't like the CONFIG::LOGGING properties. I get an error 1120 Access of undefined property LOGGING.
                            I tried commenting all of them out, but then recieved many new errors for basic properties.
                            I am not sure what I am doing wrong. I am using the StrobeMediaPlayback 1.5.1 (and also 1.5 in other experiments), downloaded from the Strobe downloads page. And I am referencing the src folder in the source path under the Flex Build Path option of the project properties menu. I am also referencing the OSMF.swc 1.5 in the build path. I am using the Flex 4.1 compiler and Flash Player 10.1.0. I set the logging flag on the compiler to false.
                            I am using the following MXML code, which is identical to your previous posts. Am I loading the correct versions?
                            Thanks for your help.
                            Robert
                                           creationComplete            ="init(event)"
                                <fx:Declarations>
                                    <!-- Place non-visual elements (e.g., services, value objects) here -->
                                </fx:Declarations>
                                    <fx:Script>
                                        <![CDATA[
                                            import mx.core.UIComponent;
                                            protected function init(event:Event):void
                                                _stage = systemManager.stage;
                                                _stage.align = StageAlign.TOP_LEFT;
                                                _parameters  =
                                                        src:"http://osmf.org/dev/videos/cathy1_SD.mp4"
                                                        , controlBarMode:"floating"
                                                        , controlBarAutoHide: false
                                                        , autoPlay: true
                                                        , showVideoInfoOverlayOnStartUp: true
                                                //var playerInstance:Object = new playerClass();
                                                var playerInstance:StrobeMediaPlayback = new StrobeMediaPlayback();
                                                playerInstance.initialize(_parameters, _stage, systemManager.loaderInfo, null);
                                                var ui:UIComponent = new UIComponent();
                                                ui.addChild(playerInstance as DisplayObject);
                                                addElement(ui);
                                            // Internals
                                            private function onURLLoaderComplete(event:Event):void
                                                var context:LoaderContext = new LoaderContext(false, ApplicationDomain.currentDomain, null);
                                                if (context.hasOwnProperty(ALLOW_LOAD_BYTES_CODE_EXECUTION)) {
                                                    context[ALLOW_LOAD_BYTES_CODE_EXECUTION] = true;
                                                loader.loadBytes((ByteArray)(urlLoader.data), context);
                                            private function instantiatePlayer(event:Event):void
                                                if    (ApplicationDomain.currentDomain.hasDefinition("StrobeMediaPlayback"))
                                                    var playerClass:Class = getDefinitionByName("StrobeMediaPlayback") as Class;
                                                    playerInstance.initialize(_parameters, _stage);
                                                    addElement(ui);
                                                else
                                                    var errorText:TextField = new TextField();
                                                    errorText.width = _stage.stageWidth;
                                                    errorText.multiline = true;
                                                    errorText.htmlText = '<P ALIGN="CENTER"><FONT FACE="Arial" SIZE="12" COLOR="#FFFFFF" LETTERSPACING="0" KERNING="0">Error loading Flash Media Playback components!</FONT></P>';
                                                    errorText.y = _stage.stageHeight / 2 - errorText.height / 2;
                                                    ui.addChild(errorText);
                                                    addElement(ui);
                                            private var urlLoader:URLLoader;
                                            private var urlRequest:URLRequest;
                                            private var loader:Loader;
                                            private var _stage:Stage;
                                            private var _parameters:Object;
                                            /* static */
                                            private static const ALLOW_LOAD_BYTES_CODE_EXECUTION:String = "allowLoadBytesCodeExecution";
                                    </fx:Script>
                            </s:Application>
                            • 11. Re: how get use strobeMediaPlayBack.swc in flex?
                              Grauzone
                              Hi Celumbra,
                              check in your Properties under "Actionscript -Compiler"  in "Additional Compiler Arguments" and try to input these line:
                              -define CONFIG::LOGGING true -define CONFIG::FLASH_10_1 true
                              than compile again...hope this helps
                              greetz Grau
                              • 12. Re: how get use strobeMediaPlayBack.swc in flex?
                                Hi Grau,
                                Thank you for your reply. It was very helpful. I was able to load into Flex
                                StrobeMediaPlayback 1.5, not 1.5.1.
                                I have an odd experience, however. When compiling the movie locally, using
                                an f4m file as the source, it selects and plays very well, selecting the
                                highest resolution and largest size. But when I serve the swf from the
                                remote web server, the system selects the lowest resolution, even though I
                                am using the same movies,  same f4m manifest, and same FMS server. If I use
                                the setup.html that comes with SMP, served from the remote server, it
                                selects the highest resolution.
                                This leads me to think that there is some metric, other than bandwidth, that
                                is driving SMP to select the lowest resolution, and that is metric is
                                related to something going on in the Flex app. If this is true, can you
                                point me toward what that metric might be and how I might experiment with
                                it?
                                Thanks again for your assistance.
                                Robert
                                If not try to import a new and use (if u unzipped the File that u have
                                downloaded)  this Directory:
                                \osmf\src\player\StrobeMediaPlayback
                                if Not try to add
                                greetz Grau
                                • 13. Re: how get use strobeMediaPlayBack.swc in flex?
                                  Rasool.Irfan Community Member
                                  I am new to this field.
                                  I downloaded the Strobe Media Playback from osmf.og.
                                  Then i imported the Strobe Media Plaback Source into Flash Builder 4( which is a trial version).
                                  I then Deleted the OSMF.swc from the Flex4.1 of flash builder and then added a new OSMF.swc from the strobe media player source
                                  via Project>Properties>ActionScript Build Path>Add SWC.
                                  My current sdk is Flex 4.1
                                  But after doing all configurations.
                                  I am getting the Error
                                  unknown configuration variable 'swf-version'
                                  Project>Properties>ActionScript Compiler
                                  here my Additional Compiler Arguments are:
                                  "-swf-version=11 -define CONFIG::LOGGING true -define CONFIG::FLASH_10_1 true"
                                  So please let me know how to fix it.
                                  I am beginer and donot know much about it.
                                  I will be waiting eagerly for your reply
                                  Thanks And Regards
                                  • 14. Re: how get use strobeMediaPlayBack.swc in flex?
                                    Gelu Blanariu Adobe Employee
                                    I assume you are using OSMF 1.6 Sprint 2 drop. For now it requires the latest Flex SDK 4.5 for compiling. Please use the instructions that are provided here:  http://blogs.adobe.com/osmf/2011/02/getting-started-with-stage-video-support-in-osmf-and-s trobe-media-playback.html .
                                    Hope this helps,
                                    Gelu
