I imported a .fxp in to Flash Builder (FB). It asked me weher to put the new project so i made a new folder.
I added the code for frameRate ="1" to override the FC 24 fps default.
I saved it and exported it ot a new .fxp file
the new .swf that runs at the speed i wanted is located in a folder called *\bin-debug.
The exported .fxp wont open in FC anymore FC says since it has been modified it wont open.
my question:
how do i get the project to look like it came out of FC? the new project folder has so many sub folders and files.
i tried renaming the folders but the project wont run then, i als owant ot be able to use AIR to package it like i do from FC.
any suggestions?
FC 1.0 will not open projects that are modified outside FC 1.0. Try with FC 1.5 preview release http://labs.adobe.com/technologies/flashcatalyst_panini/
When you import the fxp from FC in FB, you can convert the project to AIR by choosing the Add/Change project type context menu option available on right clicking the project.
-Sunil
Thanks i will try the FC 1.5.
When i convert to AIR in FB can i then make an executable product?
That worked in FB to convert to AIR then publish as an executable. Thanks Sunil
Is there any way to call on an external file in Flash Catalyst the same way Adobe Captivate
does?
I would like to have someone be able to click on a button and it open a Word Document, PDF or full size image etc.
