SOLVED
Production version issue
Avatar
Level 2
The code ran fine under beta3. I've changed the configuration
files to match the new names, loaded in the new libraries and jars
and recompiled. However, when I attempt to call the fill() method
on my dataservice I get this error: (Please notice the reference to
C:\dev\enterprise_beta3\frameworks\mx\data\ConcreteDataService.as.
This path does not exist on my machine and it still refers to
beta3). Does this mean I am still missing a vital change to some
configuration??
ReferenceError: Error #1065: Variable
mx.data:DataConsumer::internalSubscribe is not defined.
at
mx.data::DataConsumer/initConsumer()[C:\dev\enterprise_beta3\frameworks\mx\data\DataConsumer.as:85]
at mx.data::ConcreteDataService/
http://www.adobe.com/2006/flex/mx/internal::reconnect()[C:\dev\enterprise_beta3\frameworks\mx\data\C...
at
mx.data::ConcreteDataService/fill()[C:\dev\enterprise_beta3\frameworks\mx\data\ConcreteDataService.as:595]
at
mx.data::DataService/fill()[C:\dev\enterprise_beta3\frameworks\mx\data\DataService.as:482]
at
components::sales/initApp()[C:\workspace\metalsmith-flex\components\sales.mxml:23]
at
components::sales/___Canvas1_creationComplete()[C:\workspace\metalsmith-flex\components\sales.mxml:3]
at
flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/set
initialized()[C:\dev\GMC\sdk\frameworks\mx\core\UIComponent.as:1161]
at
mx.managers::LayoutManager/mx.managers:LayoutManager::doPhasedInstantiation()[C:\dev\GMC\sdk\frameworks\mx\managers\LayoutManager.as:687]
at Function/
http://adobe.com/AS3/2006/builtin::apply()
at
mx.core::UIComponent/mx.core:UIComponent::callLaterDispatcher2()[C:\dev\GMC\sdk\frameworks\mx\core\UIComponent.as:7789]
at
mx.core::UIComponent/mx.core:UIComponent::callLaterDispatcher()[C:\dev\GMC\sdk\frameworks\mx\core\UIComponent.as:7732]
1 Accepted Solution
Avatar
Correct answer by
Level 2
I bet you didn't create a new project but used the previous
one.
Go to the project properties > Flex Build Path
then pick Library Path
there is an entry for enterprise.swc I guess, you should edit
that entry and point it to the same folder but fds.swc (in case you
deployed this new version of FDS in the same place)
HTH
Avatar
Correct answer by
Level 2
one.
HTH
Avatar
Level 2
Absolutely correct. Thank you very much.
Avatar
Level 2
I had the exact same problem, that's why I knew the problem
and the solution :)
