The quickest solution is to rename the existing publish
folder and then publish again so that a new folder with the
original name gets created.
This happens occasionally and it will likely be because a
file or folder has become Read Only. Don't bother trying to track
it though, it's not worth the hassle.
Assuming that has worked, you can delete the original folder.
