2 Replies Latest reply: Jan 30, 2011 1:14 PM by P Spier RSS
    Soft-Proofing with .icc color profiles
    Canned Pug Community Member
      Hello!
      I'm currently working on a book in InDesign. I've calibrated my monitor with X-rite, and have installed an .icc profile from my outside printer (Blurb Books). Of course when I use it to soft-proof, I see a change on my monitor, so if I dion't like what I see (how it will print), I would have to go back to my working space and make changes, etc and keep rechecking. This seems so weird to me yet nowhere in all the forums and internet have I run across an answer to my question:
      Why not just work entirely in this .icc profile so one doesn't have to go back and forth? You'd see immediately what you're going to get, even though it may not look as pretty on the monitor set in another color space?
      It seems so obvious to me that I know I must be missing something here (as I usually do the obvious), as no-one has addressed it that I can find, anywhere, even Blurb support. They don't even understand what I'm asking!
      thanks!
        • 1. Re: Soft-Proofing with .icc color profiles
          P Spier CommunityMVP
          In fact, that is one perfectly valid method of working, and I would not have a problem at all using that profile as the working space in ID (I have a number of printer supplied profiles that I rotate, depending onthe destination of the job).  But there's a downside to working on images in a device-specific output space. It limits your ability to use the same image in multiple output scenarios, and many (most) output profiles have a smaller gamut (sometimes significantly smaller) than a device-independent RGB space like Adobe RGB, so you lose some colors. That's going to happen no matter what when you convert for output, but if you do your editing and save in the output space, those losses are permanent, even if you later want to ooutput on a different device with larger gamut capability. Profile-to-profile conversion never adds new colors.
          • 2. Re: Soft-Proofing with .icc color profiles
            I never thought of that..a very important consideration.
            Thx.
