1. Re: Select object with script after creation
Kasyan Servetsky Jan 27, 2011 12:41 AM (in response to mckayk_777-PN6kWE)You can add a label to your border:
myBorder.label = "border";
Later you can select it like so:
app.select( app.activeDocument.pageItems.item("border") );You can run an AS from JS like this:
app.doScript( new File("/pathToYourScript/cropmarks.applescript"), ScriptLanguage.applescriptLanguage); -
2. Re: Select object with script after creation
Harbs. Jan 27, 2011 1:48 AM (in response to Kasyan Servetsky)Kasyan Servetsky wrote:
app.select( app.activeDocument.pageItems.item("border") );Just be forewarned that this code will not work in CS5 or later...
In CS5 you'd need to loop through all the pageItems until you find the object with your label.
Harbs
3. Re: Select object with script after creation
mckayk_777-PN6kWE Jan 30, 2011 3:12 PM (in response to Kasyan Servetsky)Thanks for trying to help... but I must admit that I know less about programming then politicians know about running a country.
(imagine that failed lawyers change over to politics and they get to run the country could only happen in a demonocracy)
This is the first script: It is called "1 Make Layers Page Border.jsx" it needs to select the border it makes and then call the next script.
I will put that script into another post to save confusion
#target indesign
app.activeDocument.layers.add ({name: 'Guides', layerColor: UIColors.blue});
app.activeDocument.layers.add ({name: 'CropMarksLayer', layerColor: UIColors.green});
app.activeDocument.layers.add ({name: 'ColourBars', layerColor: UIColors.red});
app.activeDocument.layers.item('Layer 1').remove();#targetengine 'pageborder125'
var scriptName = "CropMarksLayer",
scriptVersion = "1.25",
layerName = scriptName;var alignStrings = ['Inside','Outside','Center'],
ptBorder = ptBorder||.1, // default border weight (pts)
pgMode = pgMode||1, // -1=active page | 1=all pages
align = align||0, // default alignment index
jDots = jDots||0, // Japanese dots flag,
jDotsStyleName = false,
solidStyleName = false;
var createBorder = function(/*Layer*/layer)
// this: Page [collective allowed]
var pages = this.getElements(),
alignMode = StrokeAlignment[alignStrings[align].toLowerCase()+'Alignment'],
pg;
var recProps = {
fillColor: 'None',
strokeColor: 'Black',
strokeTint: 100,
strokeWeight: ptBorder,
strokeAlignment: alignMode,
strokeType: (jDots && jDotsStyleName) || solidStyleName,
};while( pg=pages.pop() )
recProps.geometricBounds = pg.bounds;
pg.rectangles.add(layer,undefined,undefined,recProps);
};var pageBorderMain = function()
var doc = app.documents.length&&app.activeDocument;
if( !doc ) throw Error("Please open a document before running " + scriptName + ".");
var vwPrefs = doc.viewPreferences,
strokeUnits = ('strokeMeasurementUnits' in vwPrefs)?
vwPrefs.strokeMeasurementUnits:
MeasurementUnits.points;jDotsStyleName = (function()
try{return doc.strokeStyles.itemByName("$ID/Japanese Dots").name;}
catch(_){}
return false;
})();solidStyleName = (function()
try{return doc.strokeStyles.itemByName("$ID/Solid").name;}
catch(_){}
return false;
})();if( !solidStyleName ) throw Error("Unable to find the 'Solid' stroke style in InDesign!");
var canRemove = (function()
var r = false;
try{r=!!doc.layers.itemByName(layerName).id;}
catch(_){}
return r;
var dlgRet = (function()
var dlgTitle = ' ' + scriptName + ' ' + scriptVersion + " | \u00A9Indiscripts.com",
d = app.dialogs.add({name:dlgTitle, canCancel:true}),
pn = d.dialogColumns.add().borderPanels.add(),
dc = pn.dialogColumns.add(),
dr = dc.dialogRows.add(),
// Weight
sWeight = dr.dialogColumns.add().
staticTexts.add({
staticLabel: "Weight:",
minWidth: 80,
meWeight = dr.dialogColumns.add().
measurementEditboxes.add({
editValue: ptBorder,
editUnits: strokeUnits,
minimumValue: .1,
maximumValue: 5,
smallNudge: .25,
largeNudge: .1,
// Alignment
sAlign = (dr=dc.dialogRows.add()).dialogColumns.add().
staticTexts.add({
staticLabel: "Alignment:",
minWidth: 80,
ddAlign = dr.dialogColumns.add().
dropdowns.add({
stringList: alignStrings,
selectedIndex: align,
// All Pages flag
cbAllPages = (dc=pn.dialogColumns.add()).dialogRows.add().dialogColumns.add().
checkboxControls.add({
staticLabel: "All Pages",
checkedState: pgMode==1,
// Dots flag
cbDots = jDotsStyleName?
staticLabel: "Dotted Stroke",
checkedState: !!jDots,
{checkedState:false},
// Remove
cbRemove = canRemove?
staticLabel: "Remove the border",
checkedState: false,
{checkedState:false};
var ret = d.show()&&{
ptBorder: meWeight.editValue,
align: ddAlign.selectedIndex,
pgMode: (cbAllPages.checkedState)?1:-1,
jDots: !!cbDots.checkedState,
removeBorder: cbRemove.checkedState,
d.destroy();
return ret;
if( !dlgRet ) return false;
ptBorder = dlgRet.ptBorder;
pgMode = dlgRet.pgMode;
align = dlgRet.align;
jDots = dlgRet.jDots;
// [fix100914]
var activeLayer = (function()
var al = doc.activeLayer;
return ( al.name == layerName )?
(doc.layers.length==1&&doc.layers.add()):
al.getElements()[0];
// [/fix100914]
var removeBorder = dlgRet.removeBorder;
var borderLayer = (function()
var layers = doc.layers;
try{layers.itemByName(layerName).remove();}catch(_){};
return ( removeBorder ) ? null :
layers.add({name: layerName, printable: true}).
move(LocationOptions.atBeginning); // [fix100916]
if( removeBorder ) return;
// [fix100914]
var ro = vwPrefs.rulerOrigin;
vwPrefs.rulerOrigin = RulerOrigin.spreadOrigin;
// [/fix100914]// Main process
createBorder.call(
(pgMode==1)?doc.pages.everyItem():app.activeWindow.activePage,
borderLayer
borderLayer.locked = false;// [fix100914]
if( activeLayer ) doc.activeLayer = activeLayer;
vwPrefs.rulerOrigin = ro;
// [/fix100914]
};app.scriptPreferences.enableRedraw = false;
try {pageBorderMain();}catch(_){alert(_);}
app.scriptPreferences.enableRedraw = true;
app.activeDocument.layers.add ({name: 'Artwork', layerColor: UIColors.lightBlue}); -
4. Re: Select object with script after creation
mckayk_777-PN6kWE Jan 30, 2011 3:15 PM (in response to mckayk_777-PN6kWE)This script is called: "2 AddGuides.applescript"
Then at the end of this script it needs to call one more script called "3 CropMarks.applescript"
These actions I do for every new job that comes into work which can be many times a day.
--AddGuides.applescript
--An InDesign CS4 AppleScript
--Adds guides around the selected object(s).
--For more on InDesign/InCopy scripting, go to
--http://www.adobe.com/products/indesign/scripting/index.html
--or visit the InDesign Scripting forum at http://www.adobeforums.com
tell application "Adobe InDesign CS4"
--Set the user interaction level to allow InDesign to display dialog boxes and alerts.
set user interaction level of script preferences to interact with all
set myObjectTypeList to {rectangle, oval, polygon, graphic line, text frame}
if (count documents) is not equal to 0 then
set mySelection to selection
if (count mySelection) is not equal to 0 then
set myClass to class of item 1 of mySelection
if myClass is in myObjectTypeList then
my myDisplayDialog()
else
display dialog "Please select a rectangle, oval, polygon, graphic line, or text frame, and try again."
end if
else
display dialog "No objects are selected. Please select an object and try again."
end if
else
display dialog "No documents are open. Please open a document, select an object, and try again."
end if
end tell
--handler for displaying the AddGuides dialog box
on myDisplayDialog()
set myDialog to make dialog with properties {name:"AddGuides"}
tell myDialog
tell (make dialog column)
tell (make border panel)
make static text with properties {static label:"Add Guides At:"}
end tell
set myTopCheckbox to make checkbox control with properties {static label:"Top", checked state:true}
set myLeftCheckbox to make checkbox control with properties {static label:"Left", checked state:true}
set myBottomCheckbox to make checkbox control with properties {static label:"Bottom", checked state:true}
set myRightCheckbox to make checkbox control with properties {static label:"Right", checked state:true}
set myXCenterCheckbox to make checkbox control with properties {static label:"Horizontal Center"}
set myYCenterCheckbox to make checkbox control with properties {static label:"Vertical Center"}
set myXPointCheckbox to make checkbox control with properties {static label:"Path Point Horizontal Anchor"}
set myYPointCheckbox to make checkbox control with properties {static label:"Path Point Horizontal Anchor"}
end tell
end tell
make static text with properties {static label:"Add Guides Around:"}
end tell
set myRangeButtons to make radiobutton group
tell myRangeButtons
make radiobutton control with properties {static label:"Each Object"}
make radiobutton control with properties {static label:"Entire Selection", checked state:true}
end tell
end tell
end tell
make static text with properties {static label:"Guides Based On:"}
end tell
set myBasedOnButtons to make radiobutton group
tell myBasedOnButtons
make radiobutton control with properties {static label:"Geometric Bounds", checked state:true}
make radiobutton control with properties {static label:"Visible Bounds"}
end tell
end tell
end tell
end tell
end tell
set myResult to show myDialog
if myResult is true then
--Get the control settings from the dialog box.
set myTopAlign to checked state of myTopCheckbox
set myLeftAlign to checked state of myLeftCheckbox
set myBottomAlign to checked state of myBottomCheckbox
set myRightAlign to checked state of myRightCheckbox
set myXCenterAlign to checked state of myXCenterCheckbox
set myYCenterAlign to checked state of myYCenterCheckbox
set myXPoint to checked state of myXPointCheckbox
set myYPoint to checked state of myYPointCheckbox
set myRange to selected button of myRangeButtons
set myBasedOn to selected button of myBasedOnButtons
destroy myDialog
if (myTopAlign or myLeftAlign or myBottomAlign or myRightAlign or myXCenterAlign or myYCenterAlign or myXPoint or myYPoint) then
my myAddGuides(myTopAlign, myLeftAlign, myBottomAlign, myRightAlign, myXCenterAlign, myYCenterAlign, myRange, myBasedOn, myXPoint, myYPoint)
else
display dialog "No guides were selected."
end if
else
destroy myDialog
end if
end tell
end myDisplayDialog
on myAddGuides(myTopAlign, myLeftAlign, myBottomAlign, myRightAlign, myXCenterAlign, myYCenterAlign, myRange, myBasedOn, myXPoint, myYPoint)
set myDocument to active document
set myGuidesLayerName to "Guides"
try
--Get the layer on which to place the guides.
set myLayer to layer myGuidesLayerName of myDocument
on error
--Create the layer if it didn't already exist.
tell myDocument
set myLayer to make layer with properties {name:myGuidesLayerName}
end tell
end try
--Save the current ruler origin setting.
set myOldRulerOrigin to ruler origin of view preferences of myDocument
--Set the ruler origin to spread origin. If we don't do this,
--guides will be positioned incorrectly when the selection
--contains objects on multiple pages.
set ruler origin of view preferences of myDocument to spread origin
--Get a reference to the current spread.
set mySpread to active spread of active window
--If myRange is 0, draw crop marks around each item in the selection;
--if it's 1, draw crop marks around the bounding box of the selection.
if myRange is 0 then
repeat with myCounter from 1 to (count mySelection)
set myPageItem to item myCounter of mySelection
if myXPoint is true or myYPoint is true then
my myDrawGuidesAtPoints(myPageItem, myXPoint, myYPoint, myLayer, mySpread)
end if
--Get the bounds of the item (using geometric bounds if myBasedOn is 0, or visible bounds if it's 1)
if myBasedOn = 0 then
set myBounds to geometric bounds of myPageItem
else
set myBounds to visible bounds of myPageItem
end if
set myY1 to (item 1 of myBounds)
set myX1 to (item 2 of myBounds)
set myY2 to (item 3 of myBounds)
set myX2 to (item 4 of myBounds)
--Calculate the horizontal center and vertical center of the object.
set myXCenter to myX1 + ((myX2 - myX1) / 2)
set myYCenter to myY1 + ((myY2 - myY1) / 2)
--Draw guides at the specified locations.
if myTopAlign is true then
my myDrawGuide(myY1, horizontal, myLayer, mySpread)
end if
if myLeftAlign is true then
my myDrawGuide(myX1, vertical, myLayer, mySpread)
end if
if myBottomAlign is true then
my myDrawGuide(myY2, horizontal, myLayer, mySpread)
end if
if myRightAlign is true then
my myDrawGuide(myX2, vertical, myLayer, mySpread)
end if
if myXCenterAlign is true then
my myDrawGuide(myXCenter, vertical, myLayer, mySpread)
end if
if myYCenterAlign is true then
my myDrawGuide(myYCenter, horizontal, myLayer, mySpread)
end if
end repeat
else
else
end if
--The following routine calculates the bounds of the entire selection by comparing
--the bounds of individual objects.
if myCounter = 1 then
else
if item 1 of myBounds < myY1 then
end if
if item 2 of myBounds < myX1 then
end if
if item 3 of myBounds > myY2 then
end if
if item 4 of myBounds > myX2 then
end if
end if
end repeat
--Calculate the horizontal center and vertical center of the objects.
end if
end if
end if
end if
end if
end if
end if
--Restore the ruler origin.
set ruler origin of view preferences of myDocument to myOldRulerOrigin
end tell
end myAddGuides
on myDrawGuidesAtPoints(myPageItem, myXPoint, myYPoint, myLayer, mySpread)
repeat with myPathCounter from 1 to (count paths of myPageItem)
repeat with myPointCounter from 1 to (count path points of path myPathCounter of myPageItem)
set myAnchor to anchor of path point myPointCounter of path myPathCounter of myPageItem
if myXPoint is true then
my myDrawGuide(item 1 of myAnchor, vertical, myLayer, mySpread)
end if
if myYPoint is true then
my myDrawGuide(item 2 of myAnchor, horizontal, myLayer, mySpread)
end if
end repeat
end repeat
end tell
end myDrawGuidesAtPoints
on myDrawGuide(myLocation, myGuideOrientation, myLayer, mySpread)
tell mySpread
set myGuide to make guide with properties {orientation:myGuideOrientation, location:myLocation, item layer:myLayer}
end tell
end tell
end myDrawGuide -
5. Re: Select object with script after creation
mckayk_777-PN6kWE Jan 30, 2011 3:18 PM (in response to mckayk_777-PN6kWE)Hope this is not all to confusing, Thank you in advance for help in this matter.
Basically what I am trying to do is to be able to run one script that will call two other scripts to create all the layers I will use in each job add guides and crop marks.
