Locked
questionable API behavior SQLErrorEvent.ERROR
Guest
Jan 28, 2011 Jan 28, 2011
I'm getting an error when I SELECT on a value which is not present in the database (expected). But it's not being caught by the errorHandler function.
I would like to note that my selectStmt (function readFromDatabase()) is identical to that on Adobe livedocs, so I feel confident that the code is correct.
Let's say, for simplicity, that my database table has columns authors.lName and authors.fName.
If I enter a letter into my txtIn.text (which is being copied to a string variable which is part of the SELECT statement) and the SELECT function can't find an exact match in the table, I get a TypeError: Error #1009. I understand why. But the SQLErrorEvent.Error is not capturing the event.
Apparently, not finding a value in the table is not a SQLErrorEvent?
What is the value of this: var numResults:int = result.data.length; if there is no data? Null? Tracing for a null value doesn't seem to work.
The errorHandler works fine if the the app fails to make a connection. Just not if it fails to find data.
I can't use code to handle this exception because I can't capture it.
And another question; and this one really gets my goat...
Why are there no tutorials...ANYWHERE...on how to handle errors? Tons of tutorials on how to connect to a db, select statements, entering data, etc, etc, etc. But NOTHING on error handling???
Here's my code:
import flash.data.SQLConnection;
import flash.data.SQLMode;
import flash.data.SQLResult;
import flash.events.SQLEvent;
import flash.filesystem.File;
import fl.data.DataProvider;
import fl.controls.List;
import flash.events.KeyboardEvent;
import flash.events.Event;
import flash.events.MouseEvent;
import flash.net.URLRequest;
import flash.display.Loader;
import flash.display.NativeWindow;
import flash.system.Capabilities;
import flash.text.TextField;
import flash.errors.SQLError;
import flash.events.SQLErrorEvent;
var appWindow:NativeWindow = this.stage.nativeWindow;
appWindow.x = (Capabilities.screenResolutionX - appWindow.width) / 2;
appWindow.y = (Capabilities.screenResolutionY - appWindow.height) / 2;
var conn:SQLConnection = new SQLConnection();
conn.addEventListener(SQLEvent.OPEN, readFromDatabase);
conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
var dbFile:File = File.desktopDirectory.resolvePath("bookLibrary.db");
conn.openAsync(dbFile, SQLMode.UPDATE);
txtIn.addEventListener(Event.CHANGE, changeHandler);
var txtIn:TextField;
txtIn.stage.focus = txtIn;
var txtOut:String = "a";
function readFromDatabase(event:Event):void
var selectStmt:SQLStatement = new SQLStatement();
selectStmt.sqlConnection = conn;
// register listeners for the result and failure (status) events
selectStmt.addEventListener(SQLEvent.RESULT, readResultHandler);
selectStmt.addEventListener(SQLErrorEvent.ERROR, errorHandler);
// define the SQL text;
selectStmt.text = "SELECT * FROM authors WHERE lName LIKE '" + txtOut + "%'";
// execute the statement
selectStmt.execute();
function readResultHandler(event:SQLEvent):void
var result:SQLResult = event.target.getResult();
                              //crashes on var numResults:int = result.data.length since it contains no record.
for (var i:int = 0; i < numResults; i++)
var row:Object = result.data;
var dataOut:String;
dataOut = row.lName + ", " + row.fName;
myList.addItem({label:dataOut});
addChild(myList);
authorName.text = row.lName;
function changeHandler(e:Event):void
if (0 < txtIn.text.length)
myList.removeAll();
txtOut = txtIn.text;
readFromDatabase(e);
else
myList.removeAll();
function errorHandler(event:SQLErrorEvent):void
trace("Error message: ", event.error.message);
trace("Details: ", event.error.details);
Reply
Performance issues
478
Adobe Employee , Jan 31, 2011 Jan 31, 2011
Hi Kristin,
It's normal behavior for a select statement to return 0 rows of data.  This is not a SQL error, which is why there is no SQLError to catch.
If you take a look at the docs for the SQLResult.data property
The last line of the docs states:
If a statement does not return any data this property is null. This is the case if the statement is not a SELECT statement, or if it is a SELECT statement that returns 0 rows.
So, in order to validate if data was returned before trying to access any actual
Adobe Employee ,
Hi Kristin,
So, in order to validate if data was returned before trying to access any actual data, you just need to check if .data is null.
in your code:
You might want to change to be something like:
var numResults:int;
if (result.data != null)
    numResults = result.data.length;
else
    numResults = 0;
Chris
Guest
Feb 01, 2011 Feb 01, 2011
Yes, absolutely. That worked. Thank you very much.
