Hi experts,
Finally I can connect burrito to my device BUT I always get black screen and Force to close in all apps (test generated by burrito...). That app works fine on the emulator.
I am runnig cyanogen7 (android 2.3) over htc Legend (I´ve tried with both windows7 and machintosh).
Any help will be thaked !!!
See my logcat (I hope I did right, I am not sure):
Microsoft Windows [Versión 6.1.7600]
Copyright (c) 2009 Microsoft Corporation. Reservados todos los derechos.
C:\Users\tadu>cd C:\Program Files\Android\android-sdk-windows\platform-tools
C:\Program Files\Android\android-sdk-windows\platform-tools>adb logcat -c
C:\Program Files\Android\android-sdk-windows\platform-tools>adb logcat *:w
--------- beginning of /dev/log/main
W/GTalkService( 289): [GTalkConnection.27] doConnect: caught XMPPError connecti
ng to mtalk.google.com:5228.: (502)
W/GTalkService( 289): -- caused by: java.net.SocketTimeoutException: Connecti
on timed out
--------- beginning of /dev/log/system
W/ActivityManager( 148): No content provider found for:
W/NativeHelper( 148): Native ABI mismatch from package file
W/PackageManager( 148): Code path for pkg : air.GeoTest1.debug changing from /d
ata/app/air.GeoTest1.debug-1.apk to /data/app/air.GeoTest1.debug-2.apk
W/PackageManager( 148): Resource path for pkg : air.GeoTest1.debug changing fro
m /data/app/air.GeoTest1.debug-1.apk to /data/app/air.GeoTest1.debug-2.apk
W/ResourceType( 148): Failure getting entry for 0x7f0a0000 (t=9 e=0) in package
0 (error -75)
W/RecognitionManagerService( 148): no available voice recognition services foun
d
W/dalvikvm( 4499): No implementation found for native Lcom/adobe/air/AndroidActi
vityWrapper;.nativeSetVisible (Z)V
W/dalvikvm( 4499): threadid=1: thread exiting with uncaught exception (group=0x4
0018560)
E/AndroidRuntime( 4499): FATAL EXCEPTION: main
E/AndroidRuntime( 4499): java.lang.UnsatisfiedLinkError: nativeSetVisible
E/AndroidRuntime( 4499): at com.adobe.air.AndroidActivityWrapper.nativeSe
tVisible(Native Method)
E/AndroidRuntime( 4499): at com.adobe.air.AndroidActivityWrapper.SetVisib
le(AndroidActivityWrapper.java:651)
E/AndroidRuntime( 4499): at com.adobe.air.AndroidActivityWrapper.onSurfac
eInitialized(AndroidActivityWrapper.java:614)
E/AndroidRuntime( 4499): at com.adobe.air.AIRWindowSurfaceView.surfaceCha
nged(AIRWindowSurfaceView.java:438)
E/AndroidRuntime( 4499): at android.view.SurfaceView.updateWindow(Surface
View.java:549)
E/AndroidRuntime( 4499): at android.view.SurfaceView.dispatchDraw(Surface
View.java:348)
E/AndroidRuntime( 4499): at android.view.View.draw(View.java:6883)
E/AndroidRuntime( 4499): at android.view.SurfaceView.draw(SurfaceView.jav
a:334)
E/AndroidRuntime( 4499): at android.view.ViewGroup.drawChild(ViewGroup.ja
va:1646)
E/AndroidRuntime( 4499): at android.view.ViewGroup.dispatchDraw(ViewGroup
.java:1373)
va:1644)
.java:1373)
E/AndroidRuntime( 4499): at android.widget.FrameLayout.draw(FrameLayout.j
ava:357)
va:1646)
.java:1373)
ava:357)
E/AndroidRuntime( 4499): at com.android.internal.policy.impl.PhoneWindow$
DecorView.draw(PhoneWindow.java:1862)
E/AndroidRuntime( 4499): at android.view.ViewRoot.draw(ViewRoot.java:1522
E/AndroidRuntime( 4499): at android.view.ViewRoot.performTraversals(ViewR
oot.java:1258)
E/AndroidRuntime( 4499): at android.view.ViewRoot.handleMessage(ViewRoot.
java:1859)
E/AndroidRuntime( 4499): at android.os.Handler.dispatchMessage(Handler.ja
va:99)
E/AndroidRuntime( 4499): at android.os.Looper.loop(Looper.java:123)
E/AndroidRuntime( 4499): at android.app.ActivityThread.main(ActivityThrea
d.java:3647)
E/AndroidRuntime( 4499): at java.lang.reflect.Method.invokeNative(Native
Method)
E/AndroidRuntime( 4499): at java.lang.reflect.Method.invoke(Method.java:5
07)
E/AndroidRuntime( 4499): at com.android.internal.os.ZygoteInit$MethodAndA
rgsCaller.run(ZygoteInit.java:839)
E/AndroidRuntime( 4499): at com.android.internal.os.ZygoteInit.main(Zygot
eInit.java:597)
E/AndroidRuntime( 4499): at dalvik.system.NativeStart.main(Native Method)
W/ActivityManager( 148): Force finishing activity air.GeoTest1.debug/.AppEntr
y
E/InputDispatcher( 148): channel '40718818 air.GeoTest1.debug/air.GeoTest1.debu
g.AppEntry (server)' ~ Consumer closed input channel or an error occurred. even
ts=0x8
g.AppEntry (server)' ~ Channel is unrecoverably broken and will be disposed!
on timed out
Looks like the AIR runtime has not been installed correctly.
Does uninstalling AIR and then doing a debug launch from Flash Builder help?
P.S: We haven't tested this on cyanogen7 Android builds at all as they are not officially supported.
Thank's for your answer. I have read about someone successfully using
cyanogen 7, But it is very likely that the problem is in the air
installation. I´ve noticed that my air is 5.82 mb, and I guess it should be
about 12 mb (as i saw in some tutorials). The problem is that I can´t find
air it in the market!!! Is the Burrito which is trying to install It.
I will try to uninstall and reinstall air and some other pieces of sw.
2011/2/1 Anirudh Sasikumar <forums@adobe.com>
help?
