I am using auto-sizing pop-ups on an image mapped topic. When you click the image in the compiled Help, the pop-ups open in the upper left-hand corner of the topic instead of over the image in a place relative to the map as it did when the Help was compiled Help with RH5. Also, the pop-up window size does not appear to be auto-sized...it seems to be using a default size though I have not set one. I did a quick search in this forum and did not find anything on this issue...which of course, doesn't mean it isn't here. Is this a known issue or something I need to fix in the code?
Judy
Oh, and I forgot to mention that I am using v8.0.2.208.
Judy
hi,
there is already a thread related to popup position in RH8 @ http://forums.adobe.com/message/2222675#2222675 if you see the post there is a script posted which fixes this popup issue in CHM output. the script is located @ https://acrobat.com/#d=*jVe*gnSEca1AsdOG9gNoQ
RH9 which is released last month has all the popup issues fixed, you can try downloading the trail version of RoboHelp 9.
thanks
Praful
Great, thanks so much!
