Dan,
I wanted to try your method, but I got another error (if I
take the content of .AS file and put it inside cfsavecontent).
Below is my code ...
Seems that I cannot place import or createChild inside
CFSaveContent. Any help will be very much appreciated.
Keiko
<cfform format="Flash" skin="haloSilver">
<cfsaveContent variable="onLoad">
import mx.controls.ComboBox;
class GridRenderer extends mx.core.UIComponent {
var combo;
var listOwner : MovieClip;
var getCellIndex : Function;
var getDataLabel : Function;
function createChildren(Void) : Void{
combo = createClassObject( ComboBox, "combo", 1,
{owner:this});
combo.dataProvider = [{data:'SGP',label:'Singapore'},
{data:'JPN',label:'Japan'}, {data:'USA',label:'United States of
America'}, {data:'AUS',label:'Australia'},
{data:'IND',label:'India'}];
combo.addEventListener("change", this);
function getPreferredHeight(Void) : Number{
return combo != undefined ? 25:0;
function setValue(str:String, item:Object){
var val = item.country;
for(var i = 0; i < combo.dataProvider.length; i++){
combo.dataProvider
.data == val ? combo.selectedIndex = i : '';
function change() {
listOwner.editField(getCellIndex().itemIndex,
getDataLabel(), combo.selectedItem.data);
function(){
_level0.myGrid.rowHeight=25;
_level0.myGrid.getColumnAt(2).cellRenderer = GridRenderer;
}.call()
</cfsavecontent>
<!--- grid with 3 columns name, firstName, department
<cfgrid name="myGrid" width="400">
<cfgridColumn name="Name">
<cfgridColumn name="Country">
<cfgridrow data="Name 1, SGP">
<cfgridrow data="Name 2, USA">
</cfgrid>
<cfinput type="submit" name="cmdSubmit" value="Submit to
see the form dump">
<!--- onLoad trigger --->
<cfinput type="text" visible="No" width="0" height="0"
name="trigger2" bind="{1==2?'':#onLoad#}">
</cfform>
