5 Replies Latest reply on Feb 3, 2011 3:01 PM by Pablo Souza
    Where do charts get the datatips from?
    JoGlez Level 1
      Hi all,
           My column chart is generating data tips which i cant seem to access if I were to make a datatip function.. What is the default location for this information? yField isn't working and I can't call the data by item.name... If you would like I can send a screen shot of the charts structure and where the info I want is located... but I just cant seem to drill down to it...
        • 1. Re: Where do charts get the datatips from?
          Pablo Souza Level 3
          I'm not sure If I purely understand your issue. Can you send the screen shot and also your data provider structure ?
          But normally you would be able to have access to the data provider and so custom your data tip from a data tip function.
          Also check this link, you can get helpful information about this:
          Pablo Souza
          • 2. Re: Where do charts get the datatips from?
            JoGlez Level 1
            I initially receive an array which is then parsed (thanks to the help of the Flex community member).  below is the function
            static public function buildSeries(dp:ArrayCollection):void
                         if(ConfigData.Global.PowerDetailArray != null)
                        mx.core.FlexGlobals.topLevelApplication.myChart.series = null;
                        var nameTable:Object = {};
                        var timeTable:Object = {};
                        var nameDataList:Array = [];
                        var timeSeriesList:Array = [];
                        var columnSet:ColumnSet = new ColumnSet();
                        columnSet.type = "clustered";
                        for each(var rawItem:Object in dp)
                            var Name:String = rawItem.Name;
                            var time:String = rawItem.Time.toString();
                            var Value:Number = rawItem.Value;
                            var dataItem:Object;
                            //if we already have an object for this site,
                            //then retrieve. Otherwise create one.
                            if( nameTable.hasOwnProperty(Name) )
                                dataItem = nameTable[Name];
                                dataItem = {Name:Name};
                                nameTable[Name] = dataItem;
                            //now add a value pair for the time and power
                            dataItem[time] = Value;
                            //we need to create a series for every unique time you have
                            if( !timeTable.hasOwnProperty(time) )
                                timeTable[time] = 1;
                                var timeSeries:ColumnSeries = new ColumnSeries();
                                timeSeries.yField = time;
                        //invalidate the chart series to force a redraw
                        var chartSeries:Array = mx.core.FlexGlobals.topLevelApplication.myChart.series;
                        mx.core.FlexGlobals.topLevelApplication.myChart.series =chartSeries;
                        ConfigData.Global.PowerDetailArray = new ArrayCollection(nameDataList);
            I will provide the screenshot in a couple of minutes
            • 3. Re: screen shot
              JoGlez Level 1
              this screent shot shows where the data I want is located inside of the structure
              best if you open on your browser
              • 4. Re: screen shot
                JoGlez Level 1
                bumpity bump bump
                • 5. Re: screen shot
                  Pablo Souza Level 3
                  Have you seen the link I sent you before? You can get access to that any data through the DataTip function:
                  This is the dataprovider:
                  public var expenses:ArrayCollection = new ArrayCollection([
                            {Month:"Jan", Profit:2000, Expenses:1500},
                            {Month:"Feb", Profit:1000, Expenses:200},
                                    {Month:"Mar", Profit:1500, Expenses:500}
                  This is how can you have access to any field from your dataprovider:
                  public function dtFunc(hd:HitData):String
                       return hd.item.Month + ":<b>$" +             hd.item.Profit + "</b>";
                  Let me know if you need further help.
                  Best regards,
                  Pablo Souza
