Web Service with complextype
Jun 26, 2006 Jun 26, 2006
I am trying to access a very simple webservice which uses a "complexType" of invoke argument.
A part of the wsdl looks like this:
<complexType name="PongGateRequest">
<sequence>
<element name="version" nillable="true" type="xsd:positiveInteger"/>
<element maxOccurs="unbounded" minOccurs="0" name="linkcode" type="xsd:string"/>
</sequence>
</complexType>
<element name="pongGate">
<complexType>
<sequence>
<element name="req" nillable="true" type="impl:PongGateRequest"/>
</sequence>
</complexType>
</element>
<complexType name="PongGateResponse">
<sequence>
<element name="date" nillable="true" type="xsd:string"/>
<element name="time" nillable="true" type="xsd:string"/>
</sequence>
</complexType>
After reviewing a number of posts and other sites it would seem that the correct way to access this service is to do the following:
<cfscript>
args = structNew();
args.version = 2;
request.service = createObject("webservice"," http://localhost:8600/ponggate/service?wsdl");
request.response = request.service.PongGateRequest(argumentCollection = args );
</cfscript>
However I receive this error message:
Web service operation "PongGateRequest" with parameters {VERSION={2},} could not be found.
Any help with this problem would be appreciated.
Peter
Advanced techniques
478
Jun 30, 2006 Jun 30, 2006
Does any one have a suggestion on how to go about debugging this inorder to get the correct structure for this web service?
Any suggestions are welcomed.
Peter
Guest
Jul 03, 2006 Jul 03, 2006
You could always consume the web service in dreamweaver to see what you should be passing it.
Thank you for the suggestion. However, this was the first thing I tried:
<cfset eTray = structNew()>
<cfset eTray.version = 2>
<cfinvoke
webservice=" http://localhost:8600/ponggate/service?wsdl"
method="PongGateRequest"
returnvariable="aPongGateResponse">
<cfinvokeargument name="req" value="#eTray#"/>
</cfinvoke>
The result was :
Web service operation "PongGateRequest" with parameters {req={{VERSION={2},}},} could not be found.
I am still working on this problem, so any other assistance would be welcomed.
Peter
Jul 04, 2006 Jul 04, 2006
yes i have the same question . i am trying to access a very simple webservice :googel adwords api : https://adwords.google.com/api/adwords/v4/CampaignService?wsdl .
want to add a new campaign ,code just bellow:
<cfset stcCampaign = StructNew()>
<cfset stcCampaign.Name = "Campaign5" & RandRange(1,100)>
<cfset stcCampaign.DailyBudget = 10000 >
<cfdump var="#stcCampaign#" >
<cfset objCampaign = obInfo.addCampaign(stcCampaign)>
the function addCampaign(stcCampaign) is bellow:
<cffunction name="addCampaign" access="public" >
<cfargument name="strCampaign" type="any" required="yes"> <cfinvoke
webservice="#VARIABLES.ws#" method="addCampaign"
returnvariable="VARIABLES.aReturn">
<cfinvokeargument name="campaign" value="#ARGUMENTS.strCampaign#"/>
</cfinvoke>
</cffunction>
it can add new campaign ,but when i set the campaign status ,
code as bellow:
<cfset stcCampaign.status = "Active" >
it cannot run and show some error:
Web service operation "addCampaign" with parameters
{campaign={{NAME={Campaign591},STATUS={{ACTIVE={Active},}},DAILYBUDGET={100­00},}},}
could not be found.
Can you tell me ?Thank you sincely. i use the v3 wsdl .the document
is here
: http://www.google.com/apis/adwords/developer3/CampaignService.html#ad...
Aug 08, 2006 Aug 08, 2006
HELP! I'm seeing the exact same problem on Google Adwords. I've tried everything and even looked at the following site ( http://hcc.musc.edu/research/shared_resources/xml_complex_types_to_cf_structure_notes.cfm) which has some great info on how to proceed but it still doesn't seem to work. Any assistance in this would be GREATLY appreciated!
Documentation
