We are about to deploy Adobe AIR Runtime 2.5 in our organization.
To do this we use the following command line
AdobeAIRInstaller.exe -silent -eulaAccepted
This works great. But I am not sure how to disable the automatic updates.
When reading the Adobe AIR configuration guide, http://help.adobe.com/en_US/air/admin/WS485a42d56cd1964167ea49bd124ef17d52a-7ff5.html it says I should create the registry key HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\AIR\UpdateDisabled and set it to 1.
But when I run the AIR SettingsManager application after I set this registry key it says that automatic updates are enabled.
And if I choose to disable automatic updates from the tool it creates the file %APPDATA%\Adobe\AIR\updateDisabled.
How can I make sure that automatic updates are disabled for all users on all the computers we deploy Adobe AIR Runtime 2.5 to?
Since we are doing an enterprise deployment it is not really an option to ask each and every user to run AIR SettingsManager every time they logon to a new computer
Regards Erik
Hi Erik,
Setting HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\AIR\UpdateDisabled to 1 will disable runtime updates for ALL users. Adding the file %APPDATA%\Adobe\AIR\updateDisabled will disable updates on a PER user basis.
Hope this helps,
Chris
Hi Erik,
Hope this helps,
Chris
Thanks Chris!
Made my day a lot easier
// Erik
