Hi All,
I am using RH8.
I have several text hyperlinks between topics within the same project. They work fine (retaining all formatting) when I use the Hyperlink Option - Display in frame. However if I use Display in auto-sizing pop-up, my number lists are not retained in the pop-window text. Other formatting like heading levels, paragraph text etc appear fine though.
What am I doing wrong here?
Any help would be greatly appreciated.
Sangeeta
Just to confirm here. Are you using RH 8.0.2. If not then please install RoboHelp patches 8.0.1 and 8.0.2 in sequence and then see if the issue occurs.
You may find the version of the product installed through Help->About RoboHelp HTML
