Hi All,
I need to remove the Glossary and Index buttons from my webhelp skin. Is this possible?
Hi there
If you edit the SSL properties you have options on the second screen. Just clear the check boxes for what you wish to remove.
Cheers... Rick
Hi Rick,
I don't seem to be able to fine the second page of the SSL properties. I open the SSL panel then I right click on "WebHelp Pro (Primary Layout) but I can't find the screen you included in your reply.
Mike
WebHelp Pro?
Are you also publishing to the RoboHelp Server?
Cheers... Rick
No I'm using one of the built in gallery skins that i modified with some different colors. If I open Project Setup/Skins/In Work. The In Work is the name of the skin I'm using. I've attached a screen shot to show what I'm talking about
We are comparing apples to oranges here. You talked about the skin. I gave you the answer how to remove the button. Then you said that you don't see the options I mentioned because you are using WebHelp Pro.
The thing is, many folks choose WebHelp Pro as the output type because they somehow think it's a step better than WebHelp. They fail to understand that it also requires another software component you purchase from Adobe and install on your web server. That's the RoboHelp Server bit.
If you don't have RoboHelp Server installed, you need to be using WebHelp and not WebHelp Pro. Then you will see the dialog I mentioned.
Cheers... Rick
Hello,
Try this. Click on the Project Set-up tab (Project Manager pod)
Open the Windows folder
Double-click the NewWindow
Uncheck the buttons you do not want to display.
Click OK
I hope this helps.
Thanks for that.
However, if someone mistakenly opts for WebHelp Pro without the RoboHelp Server and publishing the project to it, I'm not sure it will do the job, no?
I don't think the OP ever did come back to say what they were using.
Cheers... Rick
