I'm using Flash Builder 4.0.1 and following this tutorial.
I got to the point of adding the service - i entered the rds password, hit next and got the following error:
The CFC file is invalid. Possible causes can be found by accessing: http://localhost:8500//CFIDE/componentutils/cfcexplorer.cfc?method=getCFCMetaData&name=EmployeeServi...">http://localhost:8500//CFIDE/componentutils/cfcexplorer.cfc?method=getCFCMetaData&name=EmployeeServi...
When I browse to that URL I get the following:
The value returned from the getCFCMetaData function is not of type struct.
If the component name is specified as a return type, it is possible that either a definition file for the component cannot be found or is not accessible.
Resources:
* Check the ColdFusion documentation to verify that you are using the correct syntax.
* Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.6; en-US; rv:1.9.2.13) Gecko/20101203 Firefox/3.6.13
Remote Address 0:0:0:0:0:0:0:1%0
Referrer http://localhost:8500//CFIDE/componentutils/cfcexplorer.cfc?method=getCFCMetaData&name=EmployeeServi...
Date/Time 05-Jan-11 08:59 PM
Stack Trace
coldfusion.runtime.UDFMethod$InvalidReturnTypeException: The value returned from the getCFCMetaData function is not of type struct.
at coldfusion.runtime.UDFMethod$ReturnTypeFilter.invoke(UDFMethod.java:429)
at coldfusion.runtime.UDFMethod$ArgumentCollectionFilter.invoke(UDFMethod.java:368)
at coldfusion.filter.FunctionAccessFilter.invoke(FunctionAccessFilter.java:55)
at coldfusion.runtime.UDFMethod.runFilterChain(UDFMethod.java:321)
at coldfusion.runtime.UDFMethod.invoke(UDFMethod.java:517)
at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:496)
at coldfusion.runtime.TemplateProxy.invoke(TemplateProxy.java:355)
at coldfusion.filter.ComponentFilter.invoke(ComponentFilter.java:187)
at coldfusion.filter.ApplicationFilter.invoke(ApplicationFilter.java:381)
at coldfusion.filter.RequestMonitorFilter.invoke(RequestMonitorFilter.java:48)
at coldfusion.filter.BrowserDebugFilter.invoke(BrowserDebugFilter.java:79)
at coldfusion.filter.MonitoringFilter.invoke(MonitoringFilter.java:40)
at coldfusion.filter.PathFilter.invoke(PathFilter.java:94)
at coldfusion.filter.LicenseFilter.invoke(LicenseFilter.java:27)
at coldfusion.filter.ExceptionFilter.invoke(ExceptionFilter.java:70)
at coldfusion.filter.ClientScopePersistenceFilter.invoke(ClientScopePersistenceFilter.java:28)
at coldfusion.filter.BrowserFilter.invoke(BrowserFilter.java:38)
at coldfusion.filter.NoCacheFilter.invoke(NoCacheFilter.java:46)
at coldfusion.filter.GlobalsFilter.invoke(GlobalsFilter.java:38)
at coldfusion.filter.DatasourceFilter.invoke(DatasourceFilter.java:22)
at coldfusion.xml.rpc.CFCServlet.invoke(CFCServlet.java:138)
at coldfusion.xml.rpc.CFCServlet.doPost(CFCServlet.java:289)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:760)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at coldfusion.bootstrap.BootstrapServlet.service(BootstrapServlet.java:89)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:86)
at coldfusion.monitor.event.MonitoringServletFilter.doFilter(MonitoringServletFilter.java:42)
at coldfusion.bootstrap.BootstrapFilter.doFilter(BootstrapFilter.java:46)
at jrun.servlet.FilterChain.doFilter(FilterChain.java:94)
at jrun.servlet.FilterChain.service(FilterChain.java:101)
at jrun.servlet.ServletInvoker.invoke(ServletInvoker.java:106)
at jrun.servlet.JRunInvokerChain.invokeNext(JRunInvokerChain.java:42)
at jrun.servlet.JRunRequestDispatcher.invoke(JRunRequestDispatcher.java:286)
at jrun.servlet.ServletEngineService.dispatch(ServletEngineService.java:543)
at jrun.servlet.http.WebService.invokeRunnable(WebService.java:172)
at jrunx.scheduler.ThreadPool$DownstreamMetrics.invokeRunnable(ThreadPool.java:320)
at jrunx.scheduler.ThreadPool$ThreadThrottle.invokeRunnable(ThreadPool.java:428)
at jrunx.scheduler.ThreadPool$UpstreamMetrics.invokeRunnable(ThreadPool.java:266)
at jrunx.scheduler.WorkerThread.run(WorkerThread.java:66)
Can you let us know which is the documentation you are following?
Also, would it be possible to share your EmployeeService.cfc?
Balaji
Here's the component code that is failing...returntype is 'struct'...does not look like it is returning a struct below (in bold)...please advise, thx!:
<cffunction name="getCFCMetaData" returnType="struct" output="no" access="remote"
hint="Returns MCDL document representing the specified component.">
<cfargument name="name" type="string" required="no" />
<cfargument name="path" type="string" required="no" />
<cftry>
<cfscript>
if ( IsDefined('arguments.path') and arguments.path neq '' )
// we are trimming the extension if provided with path. because of
// 76373. We want to use GetComponentMetadata method as it gives advantage
// over GetMetadata, in terms of not initializing the object to get metadata.
// but Flex builder request come to call this method directly which have .cfc appended in the path.
var trimmedPath = HTMLEditFormat(arguments.path);
var indexOfCFC = FindNoCase("cfc.",reverse(trimmedPath)); // "cfc." = reverse(".cfc")
if (indexOfCFC eq 1) // trimmedPath ends with .cfc
trimmedPath = Left(trimmedPath, len(trimmedPath) - 4); // Remove .cfc
return getComponentMetaData(trimmedPath);
else if( isDefined('arguments.name') )
//This name should be a fully qualified name.
return getComponentMetaData(HTMLEditFormat(name));
</cfscript>
<cfcatch type="coldfusion.runtime.CfJspPage$NoSuchTemplateException">
<cfoutput><h4>Component not found</h4>
The component definition file for component '#HTMLEditFormat(name)#' cannot be found on this server.</cfoutput>
</cfcatch>
</cftry>
</cffunction>
Looked at the documentation for 'getComponentMetaData' function, and it does return a structure, so not sure what could be wrong ??
Any help would be appreciated!
Thx! GK
