1. Re: Mulit-Camera Enable
JSS1138 Feb 4, 2011 11:28 AM (in response to CJGerow)This is correct. There is no way to hear both tracks during an edit.
You can switch tracks 1 and 2 in the original sequence. This way you have sound all the way through. Then after the MC editing is done, nest the original sequence onto track 2, delete the video and move the audio up to 1, overwriting the cuts. This will give you all four audio tracks during playback and export.
2. Re: Mulit-Camera Enable
CJGerow Feb 5, 2011 9:44 AM (in response to JSS1138)Jim,
Thanks for setting me straight here. I really do appreciate your help. Is there a way to take all the 4 tracks and combine them before I start my multi-cam? Then I can make this track 1 and this would fix my problem.
Chris
3. Re: Mulit-Camera Enable
JSS1138 Feb 5, 2011 10:29 AM (in response to CJGerow)You could export out a WAV file, and put that on track 1 of the original sequence. That way all four sources are 'burned' into a single track.
4. Re: Mulit-Camera Enable
CJGerow Feb 6, 2011 6:20 AM (in response to JSS1138)Jim,
Yup - that does it. Many thanks.
I did it a little differently - I built a .ACC file (audio only) and then added it to the nested sequence. Then in the Multi Camera Monitor - I selected audio 2. This did the trick for me and I didn't have to move the audio files (which I couldn't do without unlinking all of them).
Is there any got-cha's here?
Chris
5. Re: Mulit-Camera Enable
JSS1138 Feb 6, 2011 3:14 PM (in response to CJGerow)AAC is highly compressed. Use WAV for better quality.
