I can´t delete or refresh data service in Data/Services panel.
Help!!
Buenas,
Borré el contenido del fichero fml que está dentro de la carpeta .model de la aplicación y lo reemplace por uno sin configurar un data/service.
<?xml version="1.0" encoding="UTF-8"?>
<model xmlns="http://ns.adobe.com/Fiber/1.0">Copy link to clipboard
Are you having problem deleting the services after manually modifying the .fml file or did you change the .fml file contents to solve the problem?
Are you getting any errors when trying to delete/refresh the services.
Thanks.
Hi Sujit ,
Thank you very very much for you post "Building Flex application for BlazeDS Remoting destinations using Flash Builder 4".
I didn´t have any problem when i changed the .fml, only themes change. I didn´t have any message when i couldn´t delete/refresh de services.
So, you made some changes to your function definitions on the server and the changes are not reflecting on the Data/Services panel when you click on Refresh. Is this what is happening?
Please try and share any of the following details:
1. Server side technology used
2. Flash Builder error log. This can be found here Help -> About Flash Builder -> Installation Details -> View Error Log
3. .fml file, which is in .model folder
PS: Glad you liked my article.
