Hi all,
I am testing an excel file reader, and the spreasheet tag brings the empty rows as well. How would I prevent empty rows?
I have 10 rows in excel once I run the this tag it brings 60 more rows(empty rows), and the rowcound becomes 70..
<cfspreadsheet action="read"
src="#form.UPLOADFILE#"
query="myQuery">
<cfdump var="#myQuery#">
It's impossible to tell, based on what you've given us. I imagine there is SOME data in the rows you are saying are empty, even if it's a space in the 70th row, or some formatting or something. This is more likely than CFSPREADSHEET just magicking them out of thin air.
It might pay to export the XLS as CSV data or HTML or something and have a look at why there are more rows than you think.
Adam
I dumped that spreadsheet var it shows the empty rows as well. Is there a way to eliminate those empty rows in fly while reading it from?
It might not be quite what you want, but you can do a Q of Q to get rid of them after the fact.
If you have control over the contents of the XLS file, then I'd approach the issue from the POV of trying to get the data correct in the first place, rather than importing bung data and then dealing with it there.
But one should still take the belt & braces approach of making sure only the data you want makes its way into your system.
Dan's already given you an answer, but you should be asking yourself the question: if I have a query with rows in it I don't want... how do I get rid of those rows?
Adam
yes i know that i should use Q of Q after reading... but was wondering during reading xls how to remove the empty rows. Apparently, there is no way unless the upgraded cfspreadsheet will have. than you guyz.
