I'm using RoboHelp X5 with Windows XP SP3. I have an index that is correct in RoboHelp but not in the .chm file. In RoboHelp, I have General Ledger as a keyword and several sub-keywords. However, in the .chm file, the sub-keywords show up under General Ledger Journal instead of General Ledger. I've attached screen shots of both at the bottom of this post, and I've pasted the applicable section of the project's .hhk file. (The .hhk file is really long, so I didn't want to insert the whole thing.)
While troubleshooting this issue, my coworker changed the keyword from General Ledger to General edger, and that fixed the problem, but obviously we can't keep it that way.
I tried the following:
When the issue first started, the General Ledger subkeywords appeared under Future Periods instead of General Ledger Journal - I'm not sure what I did to change that, but I think it was when I deleted and then reentered the Future Periods keyword.
Unfortunately, none of these worked.I saw another thread with a similar issue where the solution was to create a second index and copy the keywords to it, but I don't think X5 allows a second index.
Any suggestions will be greatly appreciated.
<li><object type="text/sitemap">
<param name="Name" value="General Ledger Journal">
<param name="Local" value="GLOverviews\GLJournal_Overview.htm">
</object>
<ul>
<param name="Name" value="overview">
</object>
<param name="Name" value="fields">
<param name="Name" value="General Ledger Journal - Fields">
<param name="Local" value="GLFields\GLJournal_Fields.htm">
</object>
</ul>
<param name="Name" value="General Ledger">
</object>
<ul>
<param name="Name" value="account record layout">
<param name="Name" value="Account Segments Record Layout">
<param name="Local" value="GLConcepts\Account_Segments_Record_Layout.htm">
</object>
<param name="Name" value="adding account groups">
<param name="Name" value="Add or Change General Ledger Account Groups">
<param name="Local" value="GLProcedures\Add_a_General_Ledger_Account_Group.htm">
</object>
<param name="Name" value="adding accounts">
<param name="Name" value="Add or Change General Ledger Accounts">
<param name="Local" value="GLProcedures\Add_or_Change_a_General_Ledger_Account.htm">
</object>
<param name="Name" value="daily activities flowchart">
<param name="Name" value="General Ledger Daily Activities Flowchart">
<param name="Local" value="GLFlowcharts\GL_Daily_Activities_Flowchart.htm">
</object>
<param name="Name" value="data, limiting export of">
<param name="Name" value="Limit Export of General Ledger Data by Account Number">
<param name="Local" value="GLProcedures\Limit_Export_of_General_Ledger_Data_by_Account_Number.htm">
</object>
<param name="Name" value="deleting accounts">
<param name="Name" value="Delete General Ledger Accounts">
<param name="Local" value="GLProcedures\Delete_General_Ledger_Accounts.htm">
</object>
<param name="Name" value="exporting information">
<param name="Name" value="Export General Ledger Information">
<param name="Local" value="GLProcedures\Export_General_Ledger_Information.htm">
</object>
<param name="Name" value="features">
<param name="Name" value="General Ledger Overview">
<param name="Local" value="GLConcepts\accounts_receivable_overview.htm">
</object>
<param name="Name" value="flowcharts">
<param name="Name" value="General Ledger Maintenance Flowchart">
<param name="Local" value="GLFlowcharts\General_Ledger_Maintenance_Flowchart.htm">
</object>
<param name="Name" value="history, purging">
<param name="Name" value="Purge General Ledger History">
<param name="Local" value="GLProcedures\Purge_General_Ledger_History.htm">
</object>
<param name="Name" value="import utilities">
<param name="Name" value="General Ledger Import Utilities">
<param name="Local" value="GLConcepts\General_Ledger_Import_Utilities.htm">
</object>
<param name="Name" value="importing information">
<param name="Name" value="Import General Ledger Information">
<param name="Local" value="GLProcedures\Import_General_Ledger_Information.htm">
</object>
<param name="Name" value="integrating with Accounts Payable">
</object>
<param name="Name" value="integrating with Accounts Receivable">
</object>
<param name="Name" value="integrating with Advanced Consolidations">
</object>
<param name="Name" value="integrating with Cash Management">
</object>
<param name="Name" value="integrating with Inventory Management">
</object>
<param name="Name" value="integrating with Multicurrency Management">
</object>
<param name="Name" value="integrating with Purchase Order">
</object>
</object>
<param name="Name" value="multicurrency reports">
<param name="Name" value="Multicurrency Reports for General Ledger">
<param name="Local" value="GLConcepts\Multicurrency_Reports_for_General_Ledger.htm">
</object>
<param name="Name" value="period-end flowchart">
<param name="Name" value="General Ledger Period End Flowchart">
<param name="Local" value="GLFlowcharts\General_Ledger_Period_End_Flowchart.htm">
</object>
<param name="Name" value="Registers">
<param name="Name" value="General Ledger Registers">
<param name="Local" value="GLConcepts\General_Ledger_Registers.htm">
</object>
<param name="Name" value="reprinting transaction registers">
<param name="Name" value="Reprint a General Ledger Transaction Register">
<param name="Local" value="GLProcedures\Reprint_a_General_Ledger_Transaction_Register.htm">
</object>
<param name="Name" value="transactions record layout">
<param name="Name" value="General Ledger Transactions Record Layout">
<param name="Local" value="GLConcepts\GL_Transactions_Record_Layout.htm">
</object>
<param name="Name" value="using reports as auditing tools">
<param name="Name" value="General Ledger Reports as Auditing Tools">
<param name="Local" value="GLConcepts\General_Ledger_Reports_as_Auditing_Tools.htm">
</object>
<param name="Name" value="viewing account information">
<param name="Name" value="View General Ledger Account Information">
<param name="Local" value="GLProcedures\View_General_Ledger_Account_Information.htm">
</object>
</ul>
<param name="Name" value="Future Periods">
<param name="Local" value="GLConcepts\Future_Periods.htm">
</object>
</ul>
</html>
Hmmm, odd.
I'd try associating a topic with the General Ledger keyword. Compile again and see if anything changes.
Cheers... Rick
Hi there
Are you using any Build Tags along with a Build Expression to control the output?
I ask because the screen capture of the CHM seems to intimate that General Ledger is absent from the list. If it was linked to a topic and the topic was removed from the build, it would seem to make sense.
Cheers... Rick
Hi Rick,
Thanks for responding so quickly. That particular keyword, General Ledger, is not linked to a topic.
Ashley
Hmmm, odd.
Cheers... Rick
Thanks Rick! That fixed the problem. Fortunately, we had an overview topic that made sense to associate with that keyword.Hopefully we won't run into it again with a keyword that we don't want to associate with a topic. If we do, I'll be back.
