My groups uses both Frame 7.2 and Frame 9 and we would like to include the Table Continuation variable to our table title paragraph tag definition so that we don't have to manually add the variable. Is this possible now? If so, how?
Sherri McCue
Synopsys, Inc.
Hi Sherri,
I guess it is possible. I am attaching a screen shot you can follow that.
this is for Framemaker 9 and I am not sure about framemaker 7.2
I hope this helps you.,
Thanks & Regards
Priyank
Sherri,
Unfortunately, you can't add a variable as building block in a paragraph tag definition (the Numbering tab woud be the only place where you could do this).
If you use FM's keybopard shortcuts, then hitting "ctrl+0 T <enter>" right after the text entry of the table title should get you the Table Continuation variable (watch the status bar to confirm) inserted quite quickly and efficiently.
Arnis,
Thanks for confirming. My group also would like to have this happen.
Do you have any idea how Adobe makes the variable show up only on the continued captions?
Kev
