1. Re: How to get a non adjusted RAW image into PSE
MTSTUNER Feb 10, 2011 2:55 PM (in response to emoglotz)The default settings or from the flyout menu where it says
Camera Raw Defaults is the closest to a non adjusted raw file
that camera raw provides. The default settings can be changed,
so you might want to click in the flyout menu and choose Reset Camera Raw Defaults.
Other viewers such as the camera makers software, might show the file different
because it can read camera settings that camera raw doesn't read and some
viewers aren't really color managed.
Really the idea of adobe camera raw is to make the raw file look like
you want it through using different adjustments in camera raw.
MTSTUNER
2. Re: How to get a non adjusted RAW image into PSE
dj_paige Feb 10, 2011 5:04 PM (in response to emoglotz)When I open a RAW file in ACR, the image is slightly different from the RAW (.nef) image as seen in other image viewers. I believe the difference may be due to the default settings in ACR. What settings correspond to no adjustments at all?
There is no way to match the appearance of other RAW viewers, nor is there any such thing as viewing a non-adjusted RAW photo. Every RAW viewer applies its own defaults.
3. Re: How to get a non adjusted RAW image into PSE
emoglotz Feb 10, 2011 5:37 PM (in response to MTSTUNER)I reset the Camera Raw Defaults as you suggested and got close to what I wanted. I guess the rest must be the difference in viewers as you mentioned.
SMK
