Can someone explain why after downloading the latest stable Hero SDK (build 19786), which only has fp10.2 support in the framwork/libs/player directory, would the 'Use minimum version required by the Flex SDK' build property still tell Flash Builder to build for fp10.1?
In my flex-config.xml file from this new SDK, I see the target-player attribute is set to 10.2. Is there a bug in burrito that would fail for that value to be used?
No. That should work. Builder also reads the minimum value from flex-config.xml.
Just to check - you added this as a new SDK in Preferences -> Flash Builder -> Installed Flex SDKs and either made that the default SDK or changed the project to use the new SDK, right?
