I just discovered that holding CTRL and clicking a function to open the declaration fails with a warning that the source could not be found. This happens only when the file is outside the project I am working on.
If I try again, it fails again.
I try again, and it works.
From now on it works every time, until IDE is restarted.
Known bug?
This issue looks like https://bugs.adobe.com/jira/browse/FB-29798 . Was your library project not loaded when you faced this issue? Open any file in library project and then try to 'Open declaration' from referencing project.
-radhakrishna
Hmm.. I just closed FB, started up again, and when I now ctrl-click a library class it says "Loading project", and then opens the file without any problems..
I'll keep an eye out on this one and get back to you with hopefully more useful steps how to reproduce..
Cheers
Hi, This issue looks like https://bugs.adobe.com/jira/browse/FB-29798 . Was your library project not loaded when you faced this issue? Was the file containing definition present in external source folder? Open any file in library project and then try to 'Open declaration' from referencing project. -radhakrishna
