System: Windows Vista, SP2, 3.4ghz P4, 2.5gb ram
RoboHelp 8.02
Hey, any help for this issue I'm experiencing would be very helpful.
I have a project started from scratch in RH8. On one particular help topic, anytime I try to save a change--no matter what the change--RH8 crashes, with the following error message:
"Adobe RoboHelp 8 has stopped working
A problem caused the program to stop working correctly. Please close the program."
There is a single button, labelled "Close the program."
The program is whited out, like it is typically unresponsive, and you can only click the button. RH8 of course closes and you lose all changes. I am using a master page and a modified default.css. Is there any kind of log that you can look at to see where the program crashes?
Appreciate any thoughts or ideas to fix this.
Rich
Have you tried deleting the CPD file and restarting RoboHelp to see if you can then edit this topic?
If not, don't open it but first run Update DHTML from the tools menu. Then open it and try editing.
If that doesn't work, try copying the content to a text file, deleting the topic and recreating it from the content of the text file.
I'm running RH 8.0.2.208, Webhelp
Win XP Pro 2002, SP3
RH is run locally on my computer, no server. All files are saved to my hard drive.
I, too, have the same problem with saving and crashing, only my issue is specific to one project (and with any topic in that project).
It saves OK when I add a new topic! (just a few words in a file) but when I want to modify a topic already existing in the project, it crashes.
I deleted the cpd file and tried again, nothing works. Interesting though......that when it crashes and closes, I re-open the topic and notice the changes I made were SAVED. So, it seems to be saving, but can't quite recover...
I've tried to modify/save a previous project, no issues.
I've tried to modify/save a sample project, no issues.
The project I'm having difficult with is a brand new project (not related to other projects except in css, skin and some images, but all new content) and is much smaller than the previous project I tested.
It worked fine yesterday when I added one new topic + 3 images. Today, I open RH to begin work again and can't save, but only when I work on an existing topic.
Are there any other things I can test or look for to find a cause and solution?
What's the path to the project? "Best practices" is something short like c:\projects\projectname\
Well, it's C:\level1\level2\project. This is the same path level as other projects, which aren't causing an issue.....
Do you think simply by moving it to C:\level1, that this will solve the problem? Could it be that simple?
I'm still perplexed as to why creating and saving a new topic is successful, but modifying and saving a previously existing project causes it to crash. argh!
*******Adobe RoboHelp 8 has encountered a problem and needs to close. We are sorry for the inconvenience.******************
Additional note:
After I created a new topic and saved it successfully, I closed the project. I reopened the project and modified the newly created topic, and also saved it successfully. When I modify a "previously" existing project (not one which was newly created) and save it, it crashes.
Maybe I should just rebuild the project and import everything?
JGaf -I am also having this problem. My environment is identical to yours, and my project currently exists in C:\Projectname. This is only happening in this particular project, and began this afternoon when I replaced a graphic. The only workaround I have found is to avoid the Save and Save All icons like the plague. My changes always save so far. However, this workaround makes me a little nervous. . .
Any help or ideas from the community would be appreciated.
Hi LeighSteele,
I'm sorry but I still haven't found a solution! I tried to use keyboard shortcuts to save and I still have issues. The only thing that's saviing me is that particulat project is shelved for a little while. Of course, when I tried to demonstrate this issue to the IT guys, it didn't happen. So, I'd say about 3 out of every 4 save crashes for me, when saving modified, existing files. Newly created files saved as expected. I was under a tight deadline, so I closed the project and modified some of my docs in notepad! (the horror! ). I was then able to open the project in RH and generate Webhelp with no issues.
I tested the project on a new laptop (new installation, brand new computer) and I was able to modify and save ONE file successfully. This isn't a guarantee it's not going to happen again, so I'm bracing for the worst!
For me, I don't know what triggered the error, if it was an image, a file, etc. I wish I knew what it was....
Sorry I can't be of more help, but I will post the results of working with the project on a new installation of RH on a new computer.
Please keep us posted if you find a suitable solution!
Weirdly enough, when I logged into the project today, I could click Save and Save All and had no issues. Crazy! I will keep you posted if I have the issue again and/or if I figure out the cause or solution.
Good luck with your new installation & project!!
I have a purse-sized desk calendar in which I note what I work on each day, what I need to do the next day, etc. I make tick marks in it each time RoboHelp crashes. Yesterday, there were 7 crashes. Today just the one so far. The CPD workaround that Peter G mentions sometimes works, but not always. It seems as though RoboHelp gets confused if I make too many changes before I click save. I had one project a few weeks ago that I had to rebuild from scratch because it just became unusable. "Scratch" meaning I started a new project, then imported everything, including creating the TOC by "importing" the old one. It took the better part of the day, but it no longer crashes. This project is, I think, just too darn big. (One "parent" and 10 "children" and numerous subfolders.) I am thinking of experimenting with changing the virtual memory size. I recall Authorware and Doc2Help were sensitive to RAM size (one needed it to be bigger, the other needed it be smaller; neither worked well with "system managed" size.)
OH, and I'm on RH 8.02, Windows 7, 64-bit, Intel dual core E7200, 2.53 GHz, 4Gb RAM (in case the Adobe developers are paying attention).
Where is the project, local drive or network?
Is this with specific projects or any of them?
Do you get the same problem if you try with the sample projects?
Thanks for listening,
Karla
Were you all patched up when you upgraded the projects from prior versions? There was a big bug early on that messed up old projects.
Adding more RAM is always a good idea - especially if you're running a 64 bit processor. I'd first try running RH8 in XP mode as an admin and see how it behaves.
Adobe never stated that RoboHelp 8 was supported on Windows 7 64 bit. What was stated was that they believed it should work but that it was not supported. A very different thing.
The number of topics is large. Typically I limit projects to 4/5000 and use merged help.
It sounds like deleting the CPD works unless you then go on and make lots of unsaved changes. So if you save more regularly and delete the CPD regularly, do you still have problems?
You can set RoboHelp 8 to automatically create a new CPD each time it opens. Note it is not a project specific setting.
From your website: http://www.grainge.org/pages/authoring/rh8/using_rh8.htm
No | Date | Credit | Item |
26 | 28 Dec 2010 | Duncan Baxter | RoboHelp 8 crashes on Windows 7. RoboHelp 8 is supported on Windows 7, both 32 bit and 64 bit. Most people are running it without problem and I have it installed on three 32 bit machines. The forums have a number of threads started by those who have had problems but I think Duncan's solution looks more definitive than some others. To quote Duncan, "I now have RoboHelp 8 working perfectly well in Windows 7. The issue was resolved by disabling all non-Microsoft Services in the 'Services' tab of the System Configuration. Follow this link if you want to see the full thread. |
Thank you for pointing that out. It was my understanding at the time but subsquently I was advised that it was supported on 32 bit and should run OK on 64 bit, albeit not supported. I will correct that post.
With the volume of material on my site, it is difficult to ensure it is always correct.
I *think* I *might* have figured out why my projects kept crashing. I have several "child" projects in a "parent" folder. They each worked fine until I moved them out of the parent folder. Then when I opened them, they would crash when I clicked save (yes, even if I deleted the CPD file). Then I created a new project and imported everything into the new project. Now it works fine. So I *think* the problem is that the child projects were each created in RH v6 or 7, and I'm now using 8. So creating a new project created them in the new version. BUT you have to be a bit methodical when you import the files. For example, if you have sub folders, create all of those first before you begin importing. Here is my method that seems to be working:
My problem *may* have been because RoboHelp is installed on a 64-bit computer--which is not officially supported. But if RH is crashing for you, then you might want to save some time and frustration by rebuilding the project from scratch. (You might lose half a day of work instead of 2 or 3 days! )
--Karla--
Are you all patched up in RH8? Running in XP mode or in the Win7 virtual machine? Have you thought about adding more RAM?
