1. Re: encore not opening CS4
John T Smith Feb 11, 2011 8:59 AM (in response to lisaellensegal)This MAY help...
Reset Preferences = Press/HOLD Ctrl+Alt+Shift while starting program
2. Re: encore not opening CS4
lisaellensegal Feb 11, 2011 9:56 AM (in response to John T Smith)Thanks John,
Still getting hung up - won't even allow me to close the program. Task manager can't even close it. I have to force a restart.
Any more suggestions? I created a temp user and that did not help.
3. Re: encore not opening CS4
Bill Hunt Feb 11, 2011 10:04 AM (in response to lisaellensegal)I created a temp user and that did not help.
In Windows Explorer, try Rt-clicking on the Encore EXE file, and choose Run As Administrator. Does that get the program open?
Good luck,
Hunt
4. Re: encore not opening CS4
Keith_Clark Feb 11, 2011 10:15 AM (in response to Bill Hunt)the_wine_snob wrote:
Good luck,
Hunt
if that doesnt work, are you opening encore via new project? or opening encore via an already compiled project? i think once when i was opening encore via a project there was a currupt assett or something or other and it locked up and wouldnt open, had to delete the project and start over. have you tried going to start > programs > adobe > encore yet and opening a new project?
5. Re: encore not opening CS4
lisaellensegal Feb 11, 2011 10:40 AM (in response to Keith_Clark)Thanks,
1. I did try right clicking and running as admin - no luck
2. First I tried to open a specific project - no luck
second I tried to just open by clicking on the .exe with no luck
3. I tried to create a new user then launch - no luck
I just copied all to an external hard drive, opened the project on my desktop and burned a disc.
Any suggestions regarding my HP DV7 running windows 7 54 bit? -
6. Still not opening after clean re-installation
lisaellensegal Feb 16, 2011 9:35 AM (in response to lisaellensegal)I uninstalled CS4 entirely. I ran the cleaner tool several times. I reinstalled CS4 Master Collection. I am able to use all of my programs EXCEPT Encore. I have used Encore on this computer for years. What is happening? I have no other Adobe programs running. I am trying to run as administrator. I am not opening an existing project. I am running Windows 7 64 bit. I have installed ALL updates.
Thanks for anyone's help in advance.
Lisa
7. Re: Still not opening after clean re-installation
Jeff Bellune Feb 16, 2011 11:19 AM (in response to lisaellensegal) -
8. Re: Still not opening after clean re-installation
lisaellensegal Feb 16, 2011 12:12 PM (in response to Jeff Bellune)Hi Jeff,
I followed these instructions, rebooted, and am still unable to launch encore. It seems to get hung up on "Intializing Transcoding". I have to force shutdown once I try to launch.
I also tried to launch as administrator with no luck.
H E L P P L E A S E
9. Re: Still not opening after clean re-installation
Jeff Bellune Feb 16, 2011 12:24 PM (in response to lisaellensegal)It seems to get hung up on "Intializing Transcoding". I have to force shutdown once I try to launch.
Those were the same symptoms I had with CS4 on Win7, and the Roxio pxengine fix cleared up the problem.
Try this:
Hold down the Ctrl+Alt+Shift keys while you try to launch En. It won't launch, so after about 15 seconds, let go of the keys. Try and launch En again. The previous attempt should have trashed your preferences, so when you launch it the second time you're launching with a fresh set of all the user stuff.
-Jeff
10. Re: Still not opening after clean re-installation
lisaellensegal Feb 16, 2011 2:03 PM (in response to Jeff Bellune)PThank you Jeff. I tried this twice with no luck. Any more ideas?
I appreciate your help.
Lisa
P.S. the real mystery to me is that I have been using this program for about 2 years with no issues
P.S..For grins I tried a third time - no luck so sad
11. Re: Still not opening after clean re-installation
lisaellensegal Feb 17, 2011 7:45 AM (in response to lisaellensegal)Jeff, is it possible that Adobe Encore thinks that I am running a trial version? I can edit hd video in Premiere which leads me to belive that my install is a full version. Is it possible to manually remove preferences?
Lisa
12. Re: Still not opening after clean re-installation
Giorgio1957 Feb 17, 2011 8:08 AM (in response to lisaellensegal)lisaellensegal wrote:
I can edit hd video in Premiere which leads me to belive that my install is a full version..........
Sorry but I can not understand if this is a trial version or not. Nothing had to lead to believe: Is or Not?
In second analysis, Jeff wrote about the "famous" Roxio exe that solved many problem with Encore CS4, included the one like your.
Have you tried it (of course installed as admin)?
As third: have you installed your suite with Admin privileges?
This is very important.
Adobe likes its software installed and run as Admin.
Sincerely I hope this will helps.....
Giorgio
13. Re: Still not opening after clean re-installation
lisaellensegal Feb 17, 2011 8:50 AM (in response to Giorgio1957)1. this is a full version
2. I tried Jeff's Roxio fix
3. Can you expand on the "Admin" privledges?
Thanks for your reply
14. Re: Still not opening after clean re-installation
Giorgio1957 Feb 17, 2011 10:20 AM (in response to lisaellensegal)Yes, sure:
Installation:
-search for the setup.exe (disc 1)
-right click, a window will open and you'll click on run as admin
run:
-On the icons of the various applications (Encore for ex.) right click
-select properties
-select Compatibility
-mark "Execute as admin"
-select "Apply"
-select "OK"
That's all
I have the italian version of Win Operating System and Adobe Applications, so translation mistakes may occur.
If this will, please forgive me
Ciao
Giorgio
15. encore now opening in windows 7 64 bit
lisaellensegal Feb 17, 2011 11:01 AM (in response to Giorgio1957)Giorgio,
-select properties
-select "Apply"
-select "OK"
Your instructions above allowed Encore to open as it should.
Ciao,
Lisa
16. Re: encore now opening in windows 7 64 bit
Giorgio1957 Feb 18, 2011 2:41 AM (in response to lisaellensegal)Wow, happy in earing this new.
....and, as Bill Hunt says: "happy authoring!!"
Ciao
Giorgio
17. Re: encore now opening in windows 7 64 bit
Bill Hunt Feb 18, 2011 9:26 AM (in response to Giorgio1957)....and, as Bill Hunt says: "happy authoring!!"
Hunt
18. Re: encore now opening in windows 7 64 bit
bituke Jul 13, 2011 1:40 PM (in response to Bill Hunt)I have similar problem
My encore opens but I can't create or open project
I can't run as administrator because don't have password
Windows was installed without password for administrator
My windows XP, Adobe CS4
19. Re: encore now opening in windows 7 64 bit
Bill Hunt Jul 13, 2011 1:45 PM (in response to bituke)This might be an instance, where you will need to consult your IT department.
Good luck,
Hunt
20. Re: encore now opening in windows 7 64 bit
lisaellensegal Jul 13, 2011 2:04 PM (in response to Bill Hunt)Bill is very knowledegable and has helped me with many issues. I always log in as administrator. The only other time that I had an issue was a conflict with my usb scanner plugged in. As soon as I unplugged it, Encore opened.
Good luck,
Lisa
21. Re: encore now opening in windows 7 64 bit
Bill Hunt Jul 13, 2011 2:22 PM (in response to lisaellensegal)Lisa,
First, thank you for the kind words.
Next, thank you for the info on the USB scanner. I had not read of that. Now, having a blank DVD/BD in a burner has kept Encore from opening, but this is a new one, and something to think of. As a side-note: if my USB Epson printer is on, Windows will not launch. You taught me something new today. I'll file that one away, and know to ask about it in the future, if Encore will not launch for another user.
For the Administrator issue, I have two Administrator Accounts: Administrator and Bill Hunt. I have both, as if something has gone wrong with my account, I can fall back on the other. Nearly all programs are installed on my Administrator Account, so Administrator is pretty clean. Now, both are Administrator, and not Accounts with Administrative Privileges - Full Administrator.
From Bill Hunt, I can Rt-click and Run As Administrator, but since that is my account type, I do not need to do that.
In the OP's case, I think that someone, with Full Administrator Privileges will need to set their account up differently, or provide a password. BTW - both of my Accounts are password protected on XP-Pro SP3.
Hunt
22. Re: encore now opening in windows 7 64 bit
bituke Jul 14, 2011 12:59 AM (in response to Bill Hunt)Bill,
What do you think, if I will try to sign as administrator in Save mode?
