I have a project developed in RH9, information is organized in TOC books and TOC Pages at different levels, to generate Printed documentation from Single Source Layout, generate me a Visual Basic error "error '5' at runtime has occurred: Invalid procedure call or argument". I'm not using VB, for what I do not know why send this error.
I´m using a trial version of RH9, Windows 7, office 2007, Adobe PDF Creation Add-On 9 and Adobe Reader X Spanish
Someone I can guide to solve the problem?
Although old, this post looks to be relevant. Click here.
First check that your macro has been set to Low in Word. Then try one of the sample projects to see if you get the same error.
Peter,
The macro had been set to Low in Word, and using the sample project "salesbuilder", if I generate a Word file through SSL I don't have problems, but if I generate a PDF file send me the error youn can see below this line...
Saving 'Salesbuilder_Printed_Manual.doc'...
Generating 'Salesbuilder_Printed_Manual.pdf'...
Failed the generate PDF file 'C:\Users\Marielos Velazquez\Documents\My RoboHelp Projects\Adobe RoboHelp 9\Samples\Salesbuilder\SalesbuilderProject\!SSL!\Printed_Documentation\Salesbuilder_Printed_Manual.pdf'...
Failed to save 'Salesbuilder_Printed_Manual.doc'...
Cleaning up temporary files...
Internal error encountered, Failed to generate Printed Documentation.
Is this a cut-and-paste from RoboHelp, or did you type the message by hand? Is there really a space between "tio" and "n" in the path 'C:\Users\Marielos Velazquez\Documents\My RoboHelp Projects\Adobe RoboHelp 9\Samples\Salesbuilder\SalesbuilderProject\!SSL!\Printed_Documentatio n\Salesbuilder_Printed_Manual.pdf'? Does the path exist, or are you expecting RoboHelp to create it?
it was a copy-paste from the "Output View" window, and there is not an space between "tio" and "n" in the path... maybe it was a problem when I made de copy-past and I didn't notice, I'll send the path again:
And the path already exists....
Peter,
about the post you sugested, I check it, and I didn't find usefull, I don't have problems with word, and I checked the directory sugested on it, and it's empty....
I've seen the problem where RoboHelp will create the printed document and then you can create the PDF from Word, but do it direct and things fall apart.
So if you use a sample project you can generate a printed output but not in your own project. In the last page of the wizard, what template are you using?
Using the sample project:
when I generate the printed documentation, there are 2 checkbox in the first page of the wizard where you can select the output format: PDF or WORD or both.
when I select just WORD there are no problems to generate the file.
when I select just PDF there are the problem I mentioned a few coments before.....
I'm using Microsoft Word Template : Style Mapping - Salesbuilder - Help.dot
Using My Project:
I have the VB error.....
TKS
I wanted to know what template you are using in your project where you have the VB error.
Microsoft Word Template: Style Mapping.dot
Odd. Try creating a brand new project with one topic and nothing imported. In the last page of the print wizard, select Style Mapping.
If that generates OK, copy that template to your problem project and see if that then works.
If not, try not using a Word template and selecting a CSS. I know that will not be the appearance you want. We'll deal with that when we have got things working.
