5 Replies Latest reply: Feb 12, 2011 8:10 AM by Another Photographer RSS
    LR and DNG support within LR
    Another Photographer Community Member
      I have looked in various souces (including the LR helpful and dpbestflow.org) but could not find an answer to some fundamenal LR/DNG questions:
      (1) Can LR tell me whether a DNG file has an embedded JPG preview and whether it is medium or full size?
      (2) If a DNG file has an embedded JPG preview, will LR use that instead of generating a preview and placing it in the cache (perhaps this would help performance)?
      (3) I understand that some older DNG files might not have a validation hash.  Can LR tell me whether or not a file has a validation hash, and whether or not there is a problem with the hash?
      (4) Can LR tell me whether a DNG has an embedded RAW file within?
        • 1. Re: LR and DNG support within LR
          Ian Lyons CommunityMVP
          1. Lr has no way of telling whether the DNG has or hasn't got an embedded preview, and therefore has no way of indicating its size.
          2. The embedded preview would be during import and up to the point that Lr renders its own previews. So, Lr will for the most part ignore the embedded preview.
          3. No, Lr has no way of telling you whether the validation hash is present or not.
          4. No, Lr has no specific indicator to tell you whether the raw file is embedded, although should should get a good indication by looking at the file size.
          Edit - above apply to existing DNG files. Using the DNG Import preference in File Handling panel of Preferences you can customise 1, 2 and 4 when creating new DNG files during import
          • 2. Re: LR and DNG support within LR
            Assuming that LR cannot tell you whether a validation hash is present, is there another Adobe product that does tell you?  I tried both Bridge and Adobe DNG Converter, and neither one seemed to provide this information.  Are third party apps the only way to do this, and if so which ones?
            • 3. Re: LR and DNG support within LR
              john beardsworth Community Member
              Further to Ian's answers, apart from #2 I can't think of any other app that can return those properties. They're all kind-of useful / interesting, though perhaps still on the geekish rather than the practical side of metadata handling.
              John
              • 4. Re: LR and DNG support within LR
                Thank you.  My reason for wanting to know whether a validation hash is present is as follows: I plan to start using Vuescan, which can produce DNG files.  I thought this would be a great way to introduce validation in the workflow, but I haven't found out yet whether Vuescan produces a hash or not--I understand that this is not really a requirement of the DNG format, especially since earlier versions did not support it.  Note that I cannot use Adobe DNG Converter to add the hash, because Vuescan has the capability of producing 4-channel scans where the fourth channel is the infrared channel, which is the way I intend to use it.  I tried running one of those 4-channel DNG files through ADC and the fourth channel was stripped out.  (So much for ADC preserving all of the underlying data, btw!)
                • 5. Re: LR and DNG support within LR
                  The practical reason is that I'm using Vuescan, which has the ability to produce DNG files and it would be awesome if those files had a validation hash.  I thought the easiest way to find out was to check the files themselves!
                  Sorry for the double post; the forum is playing tricks on me today.
