Hello,
I can’t install Flash Builder or Catalyst. They are both part of CS5.
I've had a look at the forum and tried a couple of things
· Run as administrator, re-installed Flash Builder or Catalyst
· restarted computer in a minimised state, done a system scan etc
Both of these methods have not worked for me and I keep getting the same message:
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 6 error(s), 4 warning(s)
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
ERROR: The following payload errors were found during install:
ERROR: - Adobe Flash Builder: Install failed
ERROR: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: - Adobe Flash Catalyst CS5: Install failed
I’m running Windows 7, x64 (home premium) with 8 gig memory and a terabyte hard drive.
I’m new to all of this I must confess so any help or advice would be greatly appreciated.
Cheers J
Looking at the log file that you sent (under separate cover), it looks as if your username contains an ampersand - &.
I believe that's one of the characters that java doesn't handle properly in paths, flagged in the error. Here's one way you can test this theory:
- log in as a different user with an alphanumeric-only user name, preferably one with machine Admin rights
- install FB as that user, and see if that succeeds.
If so, then you can switch back to your preferred user account, and run from the
...Copy link to clipboard
Based on those Custom Action errors in the log, the problem could stem from installing into a path containing one or more unsupported characters.
Are you installing to the default location, or using a custom path?
-Chris
Hi Chris and thank you so much for your response.
I'm just instaling into the defualt location.
- cheers,
Gary.
That same error can sometimes mean there's a character it can't handle in the path to your user home folder.
If you send me the full install log, I can probably spot the cause. More info here on where to find the full log:
http://kb2.adobe.com/cps/844/cpsid_84451.html
-Chris
Hi Chris,
I hopefully I've done this right and found what you need to have a look at.
Apologies if I've got it wrong
[ 6204] Sun Feb 13 12:52:24 2011 INFO
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 3.0.122.0
Win OS version: 6.1.0.0 64 bit Type: 1
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
Create Required Folders
Assuming install mode
::START TIMER:: [Bootstrap]
Perform Bootstrapping ...
:: END TIMER :: [Bootstrap] took 11758 miliseconds (11.758 seconds) DTR = 131.996 KBPS (0.128902 MBPS)
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 1
Media db sync skipped as session is already installed
:: END TIMER :: [Sync Media DB] took 125.649 miliseconds (0.125649 seconds)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: E:\Adobe CS5
Updating media info for: {01367616-4132-4311-911F-49D2EA82F7C2}
Type: 1, Volume Order: 1, Media Name: CS5 Master Coll1
Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyWrapperAll\Install.db
Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
Path: E:\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
Path: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
Path: E:\Adobe CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
Updating media info for: {04D84E18-23ED-46EA-9B41-789433E34D03}
Path: E:\Adobe CS5\payloads\AdobeContribute6-FFPlugin\Install.db
Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
Updating media info for: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5}
Type: 1, Volume Order: 2, Media Name: CS5 Master Coll2
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_US\AdobeInDesign7CommonLang-en_US.msi
Updating media info for: {0B754B55-6F63-461E-BB75-E8C883BDF88F}
Path: E:\Adobe CS5\payloads\AdobePremierePro5AllRetail\AdobePremierePro5AllRetail.msi
Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
Path: E:\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
Updating media info for: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\AdobeEncore5RoyaltyAll.msi
Updating media info for: {0E659C1D-7686-4322-A501-58E3FEB4E743}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10AllRetail\AdobeAfterEffects10AllRetail.msi
Updating media info for: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9}
Path: E:\Adobe CS5\payloads\AdobeKoreanSpeechAnalysisModels2All\AdobeKoreanSpeechAnalysisModels2All.msi
Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
Path: E:\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
Path: E:\Adobe CS5\payloads\AdobeFlash11-en_USLanguagePack\AdobeFlash11-en_USLanguagePack.msi
Updating media info for: {157D044B-C60D-1015-B0DB-A40823CC0F49}
Path: E:\Adobe CS5\payloads\AdobeToolhints-mul\Install.db
Updating media info for: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}
Path: E:\Adobe CS5\payloads\AdobeFireworks11All\AdobeFireworks11All.msi
Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
Path: E:\Adobe CS5\payloads\AdobeFlashBuilder-mul\AdobeFlashBuilder-mul.msi
Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
Path: E:\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
Updating media info for: {1A48007B-34D2-44BD-8708-B570F5339C14}
Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyWrapperAll\Install.db
Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
Updating media info for: {20F72893-AEC7-4954-9EAA-F07FD6184781}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyWrapperAll\Install.db
Updating media info for: {22F41D72-2E97-46AE-B8C4-EF66876C7838}
Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedWrapperAll\AdobePremierePro5ProtectedWrapperAll.msi
Updating media info for: {234A555C-70F5-48FB-A7E2-32410EB5AF64}
Path: E:\Adobe CS5\payloads\AdobeItalianSpeechAnalysisModels2All\AdobeItalianSpeechAnalysisModels2All.msi
Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-en_US\AdobeMobileExtension_Flash11-en_US.msi
Updating media info for: {26B63C3A-0BFF-1033-B389-A7ACEC31657E}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_GB\AdobeInDesign7AppLang-en_GB.msi
Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
Path: E:\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
Path: E:\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
Path: E:\Adobe CS5\payloads\AIR2_Flash11-mul\Install.db
Updating media info for: {33A3F995-8333-4676-8D6F-AB7674BB52EA}
Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All\Install.db
Updating media info for: {34F82E6B-8096-45CA-B604-ACACAC22E553}
Path: E:\Adobe CS5\payloads\AdobePremierePro5en_USLanguagePack\AdobePremierePro5en_USLanguagePack.msi
Updating media info for: {36D02DA9-35F2-4686-A2FE-EF3014D2E226}
Path: E:\Adobe CS5\payloads\AdobeSpanishSpeechAnalysisModels2All\AdobeSpanishSpeechAnalysisModels2All.msi
Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
Path: E:\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
Updating media info for: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70}
Path: E:\Adobe CS5\payloads\AdobeFireworks11en_USLanguagePack\AdobeFireworks11en_USLanguagePack.msi
Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
Path: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
Path: E:\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
Updating media info for: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0}
Path: E:\Adobe CS5\payloads\AdobeBuzzword-mul\Install.db
Updating media info for: {406D22BD-7910-479B-96AA-0DB8A36C694B}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedWrapperAll\Install.db
Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Updating media info for: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA}
Path: E:\Adobe CS5\payloads\AdobeContribute6en_USLanguagePack\AdobeContribute6en_USLanguagePack.msi
Updating media info for: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16}
Path: E:\Adobe CS5\payloads\AdobeGermanSpeechAnalysisModels2All\Install.db
Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
Path: E:\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
Updating media info for: {479C08E9-FACF-4190-A37A-81D65B4C8D4E}
Path: E:\Adobe CS5\payloads\AdobeContribute6-IEPlugin\Install.db
Updating media info for: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedWrapperAll\Install.db
Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
Path: E:\Adobe CS5\payloads\AdobeSING3-mul\Install.db
Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\AdobePhotoshop12-en_US_x64.msi
Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
Path: E:\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
Path: E:\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
Updating media info for: {5658F35F-15B9-1033-8337-97B78F2D0BE0}
Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler64-mul\AdobeInDesign7IconHandler64-mul.msi
Updating media info for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\AdobePremierePro5RoyaltyAll.msi
Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-mul\AdobeMobileExtension_Flash11-mul.msi
Updating media info for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Path: E:\Adobe CS5\payloads\AMEDolby5All_x64\AMEDolby5All_x64.msi
Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
Path: E:\Adobe CS5\payloads\BrowserLabCSLive-mul\Install.db
Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
Path: E:\Adobe CS5\payloads\iPhone_Flash11-mul\iPhone_Flash11-mul.msi
Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
Updating media info for: {64D991B0-4E64-47AC-8A35-291DA2E7D02F}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10SupportAll\Install.db
Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
Path: E:\Adobe CS5\payloads\AdobeStoryExtension-mul\Install.db
Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\AdobePhotoshop12-Core_x64.msi
Updating media info for: {681DE732-3F3A-42F2-91C9-84B1CC9B8535}
Path: E:\Adobe CS5\payloads\AdobeContribute6en_GBLanguagePack\AdobeContribute6en_GBLanguagePack.msi
Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
Path: E:\Adobe CS5\payloads\AMECore5All_x64\Install.db
Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
Path: E:\Adobe CS5\payloads\AMECore5All\Install.db
Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US\AdobePhotoshop12-en_US.msi
Updating media info for: {6ACDB89B-63FB-4C7D-8490-7528E248F25B}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10en_USLanguagePack\AdobeAfterEffects10en_USLanguagePack.msi
Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
Path: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
Updating media info for: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9}
Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyWrapperAll\AdobePremierePro5RoyaltyWrapperAll.msi
Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
Path: E:\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
Path: E:\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
Path: E:\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
Path: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
Path: E:\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
Updating media info for: {771C9F59-3F22-4610-A23E-321A98ECA264}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5en_USLanguagePack\AdobeOnLocation5en_USLanguagePack.msi
Updating media info for: {7745F18B-FD8A-4011-BE16-588900C503D0}
Path: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Updating media info for: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\AdobeOnLocation5RoyaltyAll.msi
Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
Path: E:\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
Path: E:\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
Updating media info for: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D}
Path: E:\Adobe CS5\payloads\AdobeContribute6-OfficePlugin\AdobeContribute6-OfficePlugin.msi
Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core\AdobePhotoshop12-Core.msi
Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Updating media info for: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_US\AdobeInDesign7AppLang-en_US.msi
Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
Path: E:\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
Updating media info for: {805ABF27-1582-1033-B4AC-82A1DE0DD827}
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonBase-mul\Install.db
Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB\AdobePhotoshop12-en_GB.msi
Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
Path: E:\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
Path: E:\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
Updating media info for: {92D4A929-78F1-4EC3-B626-08B3CF5B784F}
Path: E:\Adobe CS5\payloads\AMEPCI5All\AMEPCI5All.msi
Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
Path: E:\Adobe CS5\payloads\AIR2_Flash11-en_US\Install.db
Updating media info for: {966B69F2-0FBD-1033-B01C-D13C02FFF33F}
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_GB\AdobeInDesign7CommonLang-en_GB.msi
Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
Path: E:\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
Path: E:\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
Updating media info for: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15-mul\AdobeIllustrator15-mul.msi
Updating media info for: {A013B68A-B1D9-470F-BB0F-816752F096A3}
Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All_x64\Install.db
Updating media info for: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF}
Path: E:\Adobe CS5\payloads\AdobeInternationalEnglishSpeechAnalysisModels2All\AdobeInternationalEnglishSpeechAnalysisModels2All.msi
Updating media info for: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134}
Path: E:\Adobe CS5\payloads\AdobeEncoreFunctionalContent5All\Install.db
Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\AdobePhotoshop12-en_GB_x64.msi
Updating media info for: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E}
Path: E:\Adobe CS5\payloads\AdobeVideoProfilesAE3-mul\Install.db
Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
Path: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
Updating media info for: {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All\Install.db
Updating media info for: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5All\AdobeOnLocation5All.msi
Updating media info for: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyWrapperAll\Install.db
Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
Path: E:\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
Updating media info for: {B842A584-A0BF-4870-A850-9C0E52FD6A20}
Path: E:\Adobe CS5\payloads\AdobeEncore5en_USLanguagePack\AdobeEncore5en_USLanguagePack.msi
Updating media info for: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\AdobePremierePro5ProtectedAll.msi
Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
Path: E:\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
Updating media info for: {BB024724-14D5-4AB6-B21C-74EDA63A0A39}
Path: E:\Adobe CS5\payloads\HIL_Help_Search\Install.db
Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Path: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
Path: E:\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
Updating media info for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\AdobeAfterEffects10ProtectedAll.msi
Updating media info for: {C79312BD-3E76-4474-A10C-1435D1856A4B}
Path: E:\Adobe CS5\payloads\AdobeDreamweaver11-mul\AdobeDreamweaver11-mul.msi
Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
Updating media info for: {C925A34A-01B9-42C3-BB88-C7A78835F0EC}
Path: E:\Adobe CS5\payloads\ph\ph.msi
Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
Path: E:\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
Updating media info for: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3AllTrial\AdobeSoundbooth3AllTrial.msi
Updating media info for: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F}
Path: E:\Adobe CS5\payloads\AdobeAfterEffectsPresets10All\Install.db
Updating media info for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\AdobeAfterEffects10RoyaltyAll.msi
Updating media info for: {CD693E49-C5EF-4FA6-9037-9B636931C02B}
Path: E:\Adobe CS5\payloads\AdobeAmericanEnglishSpeechAnalysisModels2All\Install.db
Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
Path: E:\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
Path: E:\Adobe CS5\payloads\AdobeFlash11-mul\AdobeFlash11-mul.msi
Updating media info for: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_GBLanguagePack\AdobeIllustrator15en_GBLanguagePack.msi
Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
Path: E:\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
Path: E:\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
Updating media info for: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC}
Path: E:\Adobe CS5\payloads\AMEDolby5All\AMEDolby5All.msi
Updating media info for: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_USLanguagePack\AdobeIllustrator15en_USLanguagePack.msi
Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
Path: E:\Adobe CS5\payloads\aifsdk-win\Install.db
Updating media info for: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1}
Path: E:\Adobe CS5\payloads\AdobeAfterEffectsFunctionalContent10All\Install.db
Updating media info for: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D}
Path: E:\Adobe CS5\payloads\AdobeEncore5AllRetail\AdobeEncore5AllRetail.msi
Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
Updating media info for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\AdobeSoundbooth3ProtectedAll.msi
Updating media info for: {DE60F0DE-469A-42DC-A678-978313210057}
Path: E:\Adobe CS5\payloads\AdobeContribute6-mul\AdobeContribute6-mul.msi
Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
Path: E:\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
Updating media info for: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase2-mul\Install.db
Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
Path: E:\Adobe CS5\payloads\Players_Flash11-mul\Players_Flash11-mul.msi
Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
Path: E:\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
Updating media info for: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04}
Path: E:\Adobe CS5\payloads\AdobeDreamweaver11en_USLanguagePack\AdobeDreamweaver11en_USLanguagePack.msi
Updating media info for: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9}
Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler-mul\Install.db
Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
Path: E:\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
Path: E:\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
Path: E:\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
Updating media info for: {E6F68811-F702-492C-A7DA-D22CA670BC22}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3en_USLanguagePack\AdobeSoundbooth3en_USLanguagePack.msi
Updating media info for: {E7F2C606-8529-4028-B26E-8407DB43DD45}
Path: E:\Adobe CS5\payloads\AdobeFrenchSpeechAnalysisModels2All\Install.db
Updating media info for: {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
Path: E:\Adobe CS5\payloads\AdobeFlashCatalyst-mul\AdobeFlashCatalyst-mul.msi
Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
Path: E:\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
Path: E:\Adobe CS5\payloads\TLF_Flash11-mul\TLF_Flash11-mul.msi
Updating media info for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\AdobeSoundbooth3RoyaltyAll.msi
Updating media info for: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040}
Path: E:\Adobe CS5\payloads\AdobeMotionPicture3-mul\Install.db
Updating media info for: {F46A4C18-2EAD-49F0-A244-994226F93B39}
Path: E:\Adobe CS5\payloads\AdobeJapaneseSpeechAnalysisModels2All\AdobeJapaneseSpeechAnalysisModels2All.msi
Updating media info for: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19}
Path: E:\Adobe CS5\payloads\AdobePremiereProFunctionalContent5All\Install.db
Updating media info for: {F6CCA85F-7527-4AFF-82B6-26532A74A244}
Path: E:\Adobe CS5\payloads\AdobeFireworks11en_GBLanguagePack\AdobeFireworks11en_GBLanguagePack.msi
Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
Path: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
Updating media info for: {F77882B9-A94F-44F4-A739-8370749255B6}
Path: E:\Adobe CS5\payloads\AdobePremierePro5SupportAll\Install.db
Updating media info for: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD}
Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All_x64\Install.db
Updating media info for: {F9766AC1-1461-1033-B862-DF8FE1C033BE}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase-mul\AdobeInDesign7AppBase-mul.msi
Updating media info for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Path: E:\Adobe CS5\payloads\AMEPCI5All_x64\AMEPCI5All_x64.msi
Updating media info for: {FBB02B04-C034-4382-A3F6-57416E2752C4}
Path: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\AdobeMasterCollection5-mul.msi
Updating media info for: {FD5603A3-1375-1033-872D-8F09140FFDB2}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppFSet-Roman\Install.db
-------------------- END - Updating Media Sources - END --------------------
Supported RIBS version range: [0.0.66.0,3.0.122.0]
----------------- CreatePayloadSession: machine is x64 ---------------
[ 6204] Sun Feb 13 12:52:30 2011 INFO
______ Verify Dependency Subscribers ______
Setting property "INSTALLDIR" to: C:\Program Files\Adobe
Setting property "installLanguage" to: en_GB
Attempting to find the selected language in the set of available payload languages
Setting property "installSourcePath" to: E:\Adobe CS5
Overwrite property "userASUPath" to: C:\Users\GARY&S~1\AppData\Local\Adobe\OOBE\PDApp\
Found payload actions:
Deciding what installer mode to use...
BEGIN Setting requested payload actions
Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
Action string for {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is none
Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
Action string for {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is none
Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
Action string for {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is none
Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
Action string for {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is none
Value returned on lookup of payload: {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is: true
Action string for {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is none
Payload {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: true
Action string for {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is none
Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
Action string for {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is none
Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
Action string for {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is none
Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: true
Action string for {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is none
Value returned on lookup of payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is: true
Action string for {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is none
Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
Action string for {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is none
Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: true
Action string for {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is none
Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: true
Action string for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is none
Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: true
Action string for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is none
Value returned on lookup of payload: {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is: true
Action string for {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is none
Payload {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: true
Action string for {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is none
Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
Action string for {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is none
Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: true
Action string for {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is none
Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: true
Action string for {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is none
Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: true
Action string for {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is none
Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: true
Action string for {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is none
Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
Action string for {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is none
Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: true
Action string for {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is none
Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: true
Action string for {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is none
Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: true
Action string for {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is none
Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
Action string for {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is none
Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: true
Action string for {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is none
Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: true
Action string for {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is none
Value returned on lookup of payload: {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is: true
Action string for {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is none
Payload {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: true
Action string for {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is none
Value returned on lookup of payload: {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is: true
Action string for {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is none
Payload {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: true
Action string for {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is none
Value returned on lookup of payload: {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is: true
Action string for {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is none
Payload {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: true
Action string for {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is none
Value returned on lookup of payload: {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is: true
Action string for {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is none
Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: true
Action string for {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is none
Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: true
Action string for {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is none
Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: true
Action string for {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is none
Value returned on lookup of payload: {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is: true
Action string for {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is none
Payload {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: true
Action string for {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is none
Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true
Action string for {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is none
Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
Action string for {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is none
Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: true
Action string for {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is none
Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true
Action string for {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is none
Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
Action string for {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is none
Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: true
Action string for {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is none
Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
Action string for {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is none
Value returned on lookup of payload: {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is: true
Action string for {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is none
Payload {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: true
Action string for {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is none
Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true
Action string for {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is none
Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: true
Action string for {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is none
Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: true
Action string for {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is none
Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: true
Action string for {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is none
Value returned on lookup of payload: {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is: true
Action string for {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is none
Payload {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is: true
Action string for {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is none
Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: true
Action string for {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is none
Value returned on lookup of payload: {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is: true
Action string for {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is none
Payload {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is: true
Action string for {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is none
Value returned on lookup of payload: {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is: true
Action string for {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is none
Payload {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: true
Action string for {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is none
Value returned on lookup of payload: {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is: true
Action string for {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is none
Payload {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: true
Action string for {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is none
Value returned on lookup of payload: {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is: true
Action string for {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is none
Payload {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is: true
Action string for {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is none
Value returned on lookup of payload: {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is: true
Action string for {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is none
Value returned on lookup of payload: {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is: true
Action string for {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is none
Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
Action string for {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is none
Value returned on lookup of payload: {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is: true
Action string for {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is none
Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: true
Action string for {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is none
Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: true
Action string for {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is none
Value returned on lookup of payload: {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is: true
Action string for {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is none
Payload {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: true
Action string for {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is none
Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
Action string for {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is none
Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is: true
Action string for {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is none
Payload {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: true
Action string for {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is none
Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is: true
Action string for {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is none
Payload {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: true
Action string for {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is none
Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true
Action string for {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is none
Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: true
Action string for {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is none
Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: true
Action string for {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is none
Value returned on lookup of payload: {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is: true
Action string for {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is none
Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: true
Action string for {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is none
Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
Action string for {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is none
Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true
Action string for {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is none
Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true
Action string for {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is none
Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: true
Action string for {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is none
Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: true
Action string for {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is none
Value returned on lookup of payload: {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is: true
Action string for {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is none
Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: true
Action string for {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is none
Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: true
Action string for {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is none
Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
Action string for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is donotinstall
Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: true
Action string for {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is none
Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
Action string for {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is none
Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: true
Action string for {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is none
Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: true
Action string for {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is none
Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: true
Action string for {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is none
Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true
Action string for {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is none
Value returned on lookup of payload: {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is: true
Action string for {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is none
Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: true
Action string for {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is none
Value returned on lookup of payload: {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is: true
Action string for {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is none
Payload {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: true
Action string for {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is none
Value returned on lookup of payload: {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is: true
Action string for {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is none
Payload {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: true
Action string for {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is none
Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is: true
Action string for {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is none
Value returned on lookup of payload: {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is: true
Action string for {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is none
Value returned on lookup of payload: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is: true
Action string for {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is none
Value returned on lookup of payload: {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is: true
Action string for {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is none
Payload {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is: true
Action string for {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is none
Value returned on lookup of payload: {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is: true
Action string for {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is none
Payload {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is: true
Action string for {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is none
Value returned on lookup of payload: {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is: true
Action string for {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is none
Payload {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is: true
Action string for {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is none
Value returned on lookup of payload: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is: true
Action string for {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is none
Value returned on lookup of payload: {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is: true
Action string for {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is none
Value returned on lookup of payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is: true
Action string for {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is none
Value returned on lookup of payload: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is: true
Action string for {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is none
Value returned on lookup of payload: {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is: false
Action string for {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is donotinstall
Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is not allowed therefore shall be re-checking later
Value returned on lookup of payload: {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is: false
Action string for {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is donotinstall
Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is not allowed therefore shall be re-checking later
Value returned on lookup of payload: {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is: true
Action string for {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is none
Payload {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is: true
Action string for {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is none
Value returned on lookup of payload: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is: true
Action string for {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is none
Value returned on lookup of payload: {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is: true
Action string for {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is none
Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is: true
Action string for {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is none
Value returned on lookup of payload: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is: true
Action string for {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is none
Value returned on lookup of payload: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is: true
Action string for {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is none
Value returned on lookup of payload: {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is: true
Action string for {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is none
Value returned on lookup of payload: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is: true
Action string for {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is none
Value returned on lookup of payload: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is: true
Action string for {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is none
Value returned on lookup of payload: {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is: true
Action string for {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is none
Value returned on lookup of payload: {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is: true
Action string for {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is none
Value returned on lookup of payload: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is: true
Action string for {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is none
Value returned on lookup of payload: {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is: true
Action string for {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is none
Value returned on lookup of payload: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is: true
Action string for {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is none
Value returned on lookup of payload: {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is: true
Action string for {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is none
Value returned on lookup of payload: {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is: true
Action string for {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is none
Value returned on lookup of payload: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is: true
Action string for {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is none
Value returned on lookup of payload: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is: true
Action string for {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is none
Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: true
Action string for {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is none
Value returned on lookup of payload: {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is: true
Action string for {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is none
Value returned on lookup of payload: {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is: true
Action string for {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is none
Payload {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: true
Action string for {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is none
Value returned on lookup of payload: {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is: true
Action string for {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is none
Payload {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: true
Action string for {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is none
Value returned on lookup of payload: {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is: true
Action string for {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is none
Value returned on lookup of payload: {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is: true
Action string for {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is none
Payload {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is: true
Action string for {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is none
Value returned on lookup of payload: {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is: true
Action string for {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is none
Payload {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is: true
Action string for {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is none
Value returned on lookup of payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is: true
Action string for {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is install
Selection of payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is forbidden by the policy.
Value returned on lookup of payload: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is: true
Action string for {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is install
Selection of payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is: true
Action string for {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is install
Selection of payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is: false
Action string for {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is none
Value returned on lookup of payload: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is: true
Action string for {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is install
Selection of payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is forbidden by the policy.
Value returned on lookup of payload: {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is: false
Action string for {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is none
Value returned on lookup of payload: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is: true
Action string for {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is install
Selection of payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is forbidden by the policy.
Value returned on lookup of payload: {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is: true
Action string for {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is install
Selection of payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is: true
Action string for {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is install
Selection of payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is forbidden by the policy.
Value returned on lookup of payload: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is: true
Action string for {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is install
Selection of payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is: true
Action string for {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is install
Selection of payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is forbidden by the policy.
Value returned on lookup of payload: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is: true
Action string for {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is install
Selection of payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is forbidden by the policy.
Value returned on lookup of payload: {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is: true
Action string for {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is install
Value returned on lookup of payload: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is: true
Action string for {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is none
Value returned on lookup of payload: {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is: true
Action string for {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is none
Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is: true
Action string for {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is none
Payload {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is: true
Action string for {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is none
Value returned on lookup of payload: {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is: true
Action string for {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is none
Payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
Action string for {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is install
Value returned on lookup of payload: {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is: true
Action string for {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is none
Payload {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is: true
Action string for {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is none
Value returned on lookup of payload: {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is: true
Action string for {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is none
Payload {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is: true
Action string for {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is none
Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is: true
Action string for {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is none
Value returned on lookup of payload: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is: false
Action string for {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is none
Payload {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is: true
Action string for {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is none
Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is: false
Action string for {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is install
Value returned on lookup of payload: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is: true
Action string for {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is none
Value returned on lookup of payload: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is: false
Action string for {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is none
Payload {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is: true
Action string for {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is none
Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is: true
Action string for {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is none
Value returned on lookup of payload: {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is: true
Action string for {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is none
Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is: true
Action string for {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is none
Payload {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is: true
Action string for {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is none
Value returned on lookup of payload: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
Action string for {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is none
Payload {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: true
Action string for {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is none
Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is: true
Action string for {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is none
Payload {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: true
Action string for {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is none
Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
Action string for {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is none
Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true
Action string for {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is none
Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is: true
Action string for {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is none
Payload {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: true
Action string for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is none
Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
Action string for {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is none
Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: true
Action string for {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is none
Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is: true
Action string for {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is none
Payload {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is: true
Action string for {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is none
Value returned on lookup of payload: {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is: true
Action string for {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is none
Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is: true
Action string for {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is none
Payload {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is: true
Action string for {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is none
Value returned on lookup of payload: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is: false
Action string for {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is none
Payload {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is: true
Action string for {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is none
Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is: true
Action string for {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is none
Payload {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is: true
Action string for {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is none
Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is: true
Action string for {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is none
Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is: true
Action string for {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is none
Payload {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is: true
Action string for {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is none
Value returned on lookup of payload: {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is: true
Action string for {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is none
Payload {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is: true
Action string for {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is none
Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is: true
Action string for {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is none
Payload {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: true
Action string for {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is none
Value returned on lookup of payload: {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is: true
Action string for {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is none
Payload {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: true
Action string for {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is none
Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: true
Action string for {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is none
Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: true
Action string for {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is none
Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is allowed but the user has marked it for not to install
Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is allowed but the user has marked it for not to install
END Setting requested payload actions
Collected advanced path check information for INSTALLDIR
INSTALLDIR is a well-formed path
INSTALLDIR is not the root path
INSTALLDIR is on a local volume
INSTALLDIR is on a writable volume
INSTALLDIR is not on a case sensitive volume
INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
[ 6204] Sun Feb 13 12:52:44 2011 INFO
::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
In InstallPreSystemCheckProc
Custom action return code: 0
:: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 15.9435 miliseconds (0.0159435 seconds)
::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
:: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 14.9719 miliseconds (0.0149719 seconds)
[ 6204] Sun Feb 13 12:52:45 2011 INFO
::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
Font Installer: Fonts STI Custom Hook 1.6 Release
:: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 21.0319 miliseconds (0.0210319 seconds)
::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
CustomHooksTester -> In InstallPreSystemCheckProc
:: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 14.565 miliseconds (0.014565 seconds)
::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
:: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 21.1709 miliseconds (0.0211709 seconds)
::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
:: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 21.0037 miliseconds (0.0210037 seconds)
::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
:: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 29.4713 miliseconds (0.0294713 seconds)
[ 6204] Sun Feb 13 12:52:46 2011 INFO
::START TIMER:: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}]
:: END TIMER :: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 21.3443 miliseconds (0.0213443 seconds)
::START TIMER:: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}]
:: END TIMER :: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}] took 24.5427 miliseconds (0.0245427 seconds)
::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
:: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 15.8478 miliseconds (0.0158478 seconds)
::START TIMER:: [System check :{DE60F0DE-469A-42DC-A678-978313210057}]
:: END TIMER :: [System check :{DE60F0DE-469A-42DC-A678-978313210057}] took 15.0508 miliseconds (0.0150508 seconds)
::START TIMER:: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
:: END TIMER :: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 24.1043 miliseconds (0.0241043 seconds)
[ 6204] Sun Feb 13 12:52:47 2011 INFO
::START TIMER:: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}]
:: END TIMER :: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}] took 36.7976 miliseconds (0.0367976 seconds)
[ 6204] Sun Feb 13 12:52:47 2011 WARN
Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
[ 6204] Sun Feb 13 12:52:48 2011 INFO
Payloads passed preflight validation.
Call PreSession Custom Hook
Calling the custom action code for pre-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
[ 4776] Sun Feb 13 12:52:48 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
Payload exists on removable media: E:\
[ 4776] Sun Feb 13 12:52:49 2011 INFO
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86\, Result: 0
Configuring MSI ProductCode: {08D2E121-7F6A-43EB-97FD-629B44903403}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb3F22.tmp"
1: 0 2: 1033 3: 1252
[ 4776] Sun Feb 13 12:52:50 2011 INFO
=== Logging started: 13/02/2011 12:52:50 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC90_CRT_x86
Action 12:52:50: INSTALL.
Action start 12:52:50: INSTALL.
Action 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action start 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action ended 12:52:50: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
Action 12:52:50: AppSearch. Searching for installed applications
Action start 12:52:50: AppSearch.
Action ended 12:52:50: AppSearch. Return value 0.
Action 12:52:50: FindRelatedProducts. Searching for related applications
Action start 12:52:50: FindRelatedProducts.
Action ended 12:52:50: FindRelatedProducts. Return value 0.
Action 12:52:50: ValidateProductID.
Action start 12:52:50: ValidateProductID.
Action ended 12:52:50: ValidateProductID. Return value 1.
Action 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action start 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action ended 12:52:50: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
Action 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF.
Action start 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF.
Action ended 12:52:50: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF. Return value 1.
Action 12:52:50: CostInitialize. Computing space requirements
Action start 12:52:50: CostInitialize.
[ 4776] Sun Feb 13 12:52:56 2011 INFO
Action ended 12:52:56: CostInitialize. Return value 1.
Action 12:52:56: FileCost. Computing space requirements
Action start 12:52:56: FileCost.
Action ended 12:52:56: FileCost. Return value 1.
Action 12:52:56: IsolateComponents.
Action start 12:52:56: IsolateComponents.
Action ended 12:52:56: IsolateComponents. Return value 0.
Action 12:52:56: CostFinalize. Computing space requirements
Action start 12:52:56: CostFinalize.
Action ended 12:52:56: CostFinalize. Return value 1.
Action 12:52:56: SetODBCFolders. Initializing ODBC directories
Action start 12:52:56: SetODBCFolders.
Action ended 12:52:56: SetODBCFolders. Return value 0.
Action 12:52:56: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:52:56: MigrateFeatureStates.
Action ended 12:52:56: MigrateFeatureStates. Return value 0.
Action 12:52:56: InstallValidate. Validating install
Action start 12:52:56: InstallValidate.
Action ended 12:52:56: InstallValidate. Return value 1.
Action 12:52:56: RemoveExistingProducts. Removing applications
Action start 12:52:56: RemoveExistingProducts.
Action ended 12:52:56: RemoveExistingProducts. Return value 0.
Action 12:52:56: InstallInitialize.
Action start 12:52:56: InstallInitialize.
Action ended 12:52:56: InstallInitialize. Return value 1.
Action 12:52:56: ProcessComponents. Updating component registration
Action start 12:52:56: ProcessComponents.
Action 12:52:56: GenerateScript. Generating script operations for action:
Action ended 12:52:56: ProcessComponents. Return value 1.
Action 12:52:56: UnpublishComponents. Unpublishing Qualified Components
Action start 12:52:56: UnpublishComponents.
Action ended 12:52:56: UnpublishComponents. Return value 0.
Action 12:52:56: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:52:56: MsiUnpublishAssemblies.
Action ended 12:52:56: MsiUnpublishAssemblies. Return value 1.
Action 12:52:56: UnpublishFeatures. Unpublishing product features
Action start 12:52:56: UnpublishFeatures.
Action ended 12:52:56: UnpublishFeatures. Return value 1.
Action 12:52:56: StopServices. Stopping services
Action start 12:52:56: StopServices.
Action ended 12:52:56: StopServices. Return value 1.
Action 12:52:56: DeleteServices. Deleting services
Action start 12:52:56: DeleteServices.
Action ended 12:52:56: DeleteServices. Return value 1.
Action 12:52:56: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:52:56: UnregisterComPlus.
Action ended 12:52:56: UnregisterComPlus. Return value 0.
Action 12:52:56: SelfUnregModules. Unregistering modules
Action start 12:52:56: SelfUnregModules.
Action ended 12:52:56: SelfUnregModules. Return value 1.
Action 12:52:56: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:52:56: UnregisterTypeLibraries.
Action ended 12:52:56: UnregisterTypeLibraries. Return value 0.
Action 12:52:56: RemoveODBC. Removing ODBC components
Action start 12:52:56: RemoveODBC.
Action ended 12:52:56: RemoveODBC. Return value 1.
Action 12:52:56: UnregisterFonts. Unregistering fonts
Action start 12:52:56: UnregisterFonts.
Action ended 12:52:56: UnregisterFonts. Return value 1.
Action 12:52:56: RemoveRegistryValues. Removing system registry values
Action start 12:52:56: RemoveRegistryValues.
Action ended 12:52:56: RemoveRegistryValues. Return value 1.
Action 12:52:56: UnregisterClassInfo. Unregister class servers
Action start 12:52:56: UnregisterClassInfo.
Action ended 12:52:56: UnregisterClassInfo. Return value 0.
Action 12:52:56: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:52:56: UnregisterExtensionInfo.
Action ended 12:52:56: UnregisterExtensionInfo. Return value 0.
Action 12:52:56: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:52:56: UnregisterProgIdInfo.
Action ended 12:52:56: UnregisterProgIdInfo. Return value 0.
Action 12:52:56: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:52:56: UnregisterMIMEInfo.
Action ended 12:52:56: UnregisterMIMEInfo. Return value 0.
Action 12:52:56: RemoveIniValues. Removing INI file entries
Action start 12:52:56: RemoveIniValues.
Action ended 12:52:56: RemoveIniValues. Return value 1.
Action 12:52:56: RemoveShortcuts. Removing shortcuts
Action start 12:52:56: RemoveShortcuts.
Action ended 12:52:56: RemoveShortcuts. Return value 0.
Action 12:52:56: RemoveEnvironmentStrings. Updating environment strings
Action start 12:52:56: RemoveEnvironmentStrings.
Action ended 12:52:56: RemoveEnvironmentStrings. Return value 1.
Action 12:52:56: RemoveDuplicateFiles. Removing duplicated files
Action start 12:52:56: RemoveDuplicateFiles.
Action ended 12:52:56: RemoveDuplicateFiles. Return value 1.
Action 12:52:56: RemoveFiles. Removing files
Action start 12:52:56: RemoveFiles.
Action ended 12:52:56: RemoveFiles. Return value 0.
Action 12:52:56: RemoveFolders. Removing folders
Action start 12:52:56: RemoveFolders.
Action ended 12:52:56: RemoveFolders. Return value 0.
Action 12:52:56: CreateFolders. Creating folders
Action start 12:52:56: CreateFolders.
Action ended 12:52:56: CreateFolders. Return value 0.
Action 12:52:56: MoveFiles. Moving files
Action start 12:52:56: MoveFiles.
Action ended 12:52:56: MoveFiles. Return value 1.
Action 12:52:56: InstallFiles. Copying new files
Action start 12:52:56: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 12:52:56: InstallFiles. Return value 1.
Action 12:52:56: PatchFiles. Patching files
Action start 12:52:56: PatchFiles.
Action ended 12:52:56: PatchFiles. Return value 0.
Action 12:52:56: DuplicateFiles. Creating duplicate files
Action start 12:52:56: DuplicateFiles.
Action ended 12:52:56: DuplicateFiles. Return value 1.
Action 12:52:56: BindImage. Binding executables
Action start 12:52:56: BindImage.
Action ended 12:52:56: BindImage. Return value 1.
Action 12:52:56: CreateShortcuts. Creating shortcuts
Action start 12:52:56: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 12:52:56: CreateShortcuts. Return value 0.
Action 12:52:56: RegisterClassInfo. Registering class servers
Action start 12:52:56: RegisterClassInfo.
Action ended 12:52:56: RegisterClassInfo. Return value 0.
Action 12:52:56: RegisterExtensionInfo. Registering extension servers
Action start 12:52:56: RegisterExtensionInfo.
Action ended 12:52:56: RegisterExtensionInfo. Return value 0.
Action 12:52:56: RegisterProgIdInfo. Registering program identifiers
Action start 12:52:56: RegisterProgIdInfo.
Action ended 12:52:56: RegisterProgIdInfo. Return value 0.
Action 12:52:56: RegisterMIMEInfo. Registering MIME info
Action start 12:52:56: RegisterMIMEInfo.
Action ended 12:52:56: RegisterMIMEInfo. Return value 0.
Action 12:52:56: WriteRegistryValues. Writing system registry values
Action start 12:52:56: WriteRegistryValues.
Action ended 12:52:56: WriteRegistryValues. Return value 1.
Action 12:52:56: WriteIniValues. Writing INI file values
Action start 12:52:56: WriteIniValues.
Action ended 12:52:56: WriteIniValues. Return value 1.
Action 12:52:56: WriteEnvironmentStrings. Updating environment strings
Action start 12:52:56: WriteEnvironmentStrings.
Action ended 12:52:56: WriteEnvironmentStrings. Return value 1.
Action 12:52:56: RegisterFonts. Registering fonts
Action start 12:52:56: RegisterFonts.
Action ended 12:52:56: RegisterFonts. Return value 1.
Action 12:52:56: InstallODBC. Installing ODBC components
Action start 12:52:56: InstallODBC.
Action ended 12:52:56: InstallODBC. Return value 0.
Action 12:52:56: RegisterTypeLibraries. Registering type libraries
Action start 12:52:56: RegisterTypeLibraries.
Action ended 12:52:56: RegisterTypeLibraries. Return value 0.
Action 12:52:56: SelfRegModules. Registering modules
Action start 12:52:56: SelfRegModules.
Action ended 12:52:56: SelfRegModules. Return value 1.
Action 12:52:56: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:52:56: RegisterComPlus.
Action ended 12:52:56: RegisterComPlus. Return value 0.
Action 12:52:56: InstallServices. Installing new services
Action start 12:52:56: InstallServices.
Action ended 12:52:56: InstallServices. Return value 1.
Action 12:52:56: StartServices. Starting services
Action start 12:52:56: StartServices.
Action ended 12:52:56: StartServices. Return value 1.
Action 12:52:56: RegisterUser. Registering user
Action start 12:52:56: RegisterUser.
Action ended 12:52:56: RegisterUser. Return value 0.
Action 12:52:56: RegisterProduct. Registering product
Action start 12:52:56: RegisterProduct.
Registering product
Action ended 12:52:56: RegisterProduct. Return value 1.
Action 12:52:56: PublishComponents. Publishing qualified components
Action start 12:52:56: PublishComponents.
Action ended 12:52:56: PublishComponents. Return value 0.
Action 12:52:56: MsiPublishAssemblies. Publishing assembly information
Action start 12:52:56: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 12:52:56: MsiPublishAssemblies. Return value 1.
Action 12:52:56: PublishFeatures. Publishing product features
Action start 12:52:56: PublishFeatures.
Feature: Publishing product features
Action ended 12:52:56: PublishFeatures. Return value 1.
Action 12:52:56: PublishProduct. Publishing product information
Action start 12:52:56: PublishProduct.
Action ended 12:52:56: PublishProduct. Return value 1.
Action 12:52:56: InstallFinalize.
Action start 12:52:56: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
40d50.msi
Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_CRT_x86_
Message type: 2, Argument: 0
Action 12:52:56: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354041.rbf
File: C:\Config.Msi\354042.rbf
Message type: 2, Argument: 1
[ 4776] Sun Feb 13 12:52:57 2011 INFO
Action ended 12:52:57: InstallFinalize. Return value 1.
Action ended 12:52:57: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
Property(S): Installed = 2009/07/28 04:12:16
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
Property(S): DATABASE = C:\Windows\Installer\35403b.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 12:52:57
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14381
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_508fc1d4bcbb3eca\
Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_d494ac0e\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_f47d3254f657e518\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f75\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC90_CRT_x86
Property(S): ProductVersion = 1.00.0000
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD0A8FEAC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): REBOOT = ReallySuppress
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): MsiSystemRebootPending = 1
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 5888
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb3F22.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductState = 5
Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
=== Logging stopped: 13/02/2011 12:52:57 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:52:57 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 9017.99 miliseconds (9.01799 seconds) DTR = 5.3227 KBPS (0.00519795 MBPS)
Updating driver data - Action: Add driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 0KB
User specified overrideFile:
Calling the custom action code for post-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
Calling the custom action code for pre-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
[ 2916] Sun Feb 13 12:52:57 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_CRT_x86\, Result: 0
Configuring MSI ProductCode: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb604B.tmp"
[ 2916] Sun Feb 13 12:52:58 2011 INFO
=== Logging started: 13/02/2011 12:52:58 ===
Message type: 1, Argument: Microsoft_VC80_CRT_x86
Action 12:52:58: INSTALL.
Action start 12:52:58: INSTALL.
Action 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action ended 12:52:58: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action ended 12:52:58: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action ended 12:52:58: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action ended 12:52:58: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:52:58: AppSearch. Searching for installed applications
Action start 12:52:58: AppSearch.
Action ended 12:52:58: AppSearch. Return value 0.
Action 12:52:58: FindRelatedProducts. Searching for related applications
Action start 12:52:58: FindRelatedProducts.
Action ended 12:52:58: FindRelatedProducts. Return value 0.
Action 12:52:58: ValidateProductID.
Action start 12:52:58: ValidateProductID.
Action ended 12:52:58: ValidateProductID. Return value 1.
Action 12:52:58: CostInitialize. Computing space requirements
Action start 12:52:58: CostInitialize.
Action ended 12:52:58: CostInitialize. Return value 1.
Action 12:52:58: FileCost. Computing space requirements
Action start 12:52:58: FileCost.
Action ended 12:52:58: FileCost. Return value 1.
Action 12:52:58: IsolateComponents.
Action start 12:52:58: IsolateComponents.
Action ended 12:52:58: IsolateComponents. Return value 0.
Action 12:52:58: CostFinalize. Computing space requirements
Action start 12:52:58: CostFinalize.
Action ended 12:52:58: CostFinalize. Return value 1.
Action 12:52:58: SetODBCFolders. Initializing ODBC directories
Action start 12:52:58: SetODBCFolders.
Action ended 12:52:58: SetODBCFolders. Return value 0.
Action 12:52:58: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:52:58: MigrateFeatureStates.
Action ended 12:52:58: MigrateFeatureStates. Return value 0.
Action 12:52:58: InstallValidate. Validating install
Action start 12:52:58: InstallValidate.
Action ended 12:52:58: InstallValidate. Return value 1.
Action 12:52:58: RemoveExistingProducts. Removing applications
Action start 12:52:58: RemoveExistingProducts.
Action ended 12:52:58: RemoveExistingProducts. Return value 0.
Action 12:52:58: InstallInitialize.
Action start 12:52:58: InstallInitialize.
Action ended 12:52:58: InstallInitialize. Return value 1.
Action 12:52:58: SxsInstallCA.
Action start 12:52:58: SxsInstallCA.
[ 2916] Sun Feb 13 12:52:59 2011 INFO
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 12:52:59: SxsInstallCA. Return value 1.
Action 12:52:59: ProcessComponents. Updating component registration
Action start 12:52:59: ProcessComponents.
Action 12:52:59: GenerateScript. Generating script operations for action:
Action ended 12:52:59: ProcessComponents. Return value 1.
Action 12:52:59: UnpublishComponents. Unpublishing Qualified Components
Action start 12:52:59: UnpublishComponents.
Action ended 12:52:59: UnpublishComponents. Return value 0.
Action 12:52:59: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:52:59: MsiUnpublishAssemblies.
Action ended 12:52:59: MsiUnpublishAssemblies. Return value 1.
Action 12:52:59: UnpublishFeatures. Unpublishing product features
Action start 12:52:59: UnpublishFeatures.
Action ended 12:52:59: UnpublishFeatures. Return value 1.
Action 12:52:59: StopServices. Stopping services
Action start 12:52:59: StopServices.
Action ended 12:52:59: StopServices. Return value 1.
Action 12:52:59: DeleteServices. Deleting services
Action start 12:52:59: DeleteServices.
Action ended 12:52:59: DeleteServices. Return value 1.
Action 12:52:59: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:52:59: UnregisterComPlus.
Action ended 12:52:59: UnregisterComPlus. Return value 0.
Action 12:52:59: SelfUnregModules. Unregistering modules
Action start 12:52:59: SelfUnregModules.
Action ended 12:52:59: SelfUnregModules. Return value 1.
Action 12:52:59: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:52:59: UnregisterTypeLibraries.
Action ended 12:52:59: UnregisterTypeLibraries. Return value 0.
Action 12:52:59: RemoveODBC. Removing ODBC components
Action start 12:52:59: RemoveODBC.
Action ended 12:52:59: RemoveODBC. Return value 1.
Action 12:52:59: UnregisterFonts. Unregistering fonts
Action start 12:52:59: UnregisterFonts.
Action ended 12:52:59: UnregisterFonts. Return value 1.
Action 12:52:59: RemoveRegistryValues. Removing system registry values
Action start 12:52:59: RemoveRegistryValues.
Action ended 12:52:59: RemoveRegistryValues. Return value 1.
Action 12:52:59: UnregisterClassInfo. Unregister class servers
Action start 12:52:59: UnregisterClassInfo.
Action ended 12:52:59: UnregisterClassInfo. Return value 0.
Action 12:52:59: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:52:59: UnregisterExtensionInfo.
Action ended 12:52:59: UnregisterExtensionInfo. Return value 0.
Action 12:52:59: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:52:59: UnregisterProgIdInfo.
Action ended 12:52:59: UnregisterProgIdInfo. Return value 0.
Action 12:52:59: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:52:59: UnregisterMIMEInfo.
Action ended 12:52:59: UnregisterMIMEInfo. Return value 0.
Action 12:52:59: RemoveIniValues. Removing INI file entries
Action start 12:52:59: RemoveIniValues.
Action ended 12:52:59: RemoveIniValues. Return value 1.
Action 12:52:59: RemoveShortcuts. Removing shortcuts
Action start 12:52:59: RemoveShortcuts.
Action ended 12:52:59: RemoveShortcuts. Return value 0.
Action 12:52:59: RemoveEnvironmentStrings. Updating environment strings
Action start 12:52:59: RemoveEnvironmentStrings.
Action ended 12:52:59: RemoveEnvironmentStrings. Return value 1.
Action 12:52:59: RemoveDuplicateFiles. Removing duplicated files
Action start 12:52:59: RemoveDuplicateFiles.
Action ended 12:52:59: RemoveDuplicateFiles. Return value 1.
Action 12:52:59: RemoveFiles. Removing files
Action start 12:52:59: RemoveFiles.
Action ended 12:52:59: RemoveFiles. Return value 0.
Action 12:52:59: RemoveFolders. Removing folders
Action start 12:52:59: RemoveFolders.
Action ended 12:52:59: RemoveFolders. Return value 0.
Action 12:52:59: CreateFolders. Creating folders
Action start 12:52:59: CreateFolders.
Action ended 12:52:59: CreateFolders. Return value 0.
Action 12:52:59: MoveFiles. Moving files
Action start 12:52:59: MoveFiles.
Action ended 12:52:59: MoveFiles. Return value 1.
Action 12:52:59: InstallFiles. Copying new files
Action start 12:52:59: InstallFiles.
[ 2916] Sun Feb 13 12:53:01 2011 INFO
[ 2916] Sun Feb 13 12:53:07 2011 INFO
Action ended 12:53:07: InstallFiles. Return value 1.
Action 12:53:07: PatchFiles. Patching files
Action start 12:53:07: PatchFiles.
Action ended 12:53:07: PatchFiles. Return value 0.
Action 12:53:07: DuplicateFiles. Creating duplicate files
Action start 12:53:07: DuplicateFiles.
Action ended 12:53:07: DuplicateFiles. Return value 1.
Action 12:53:07: BindImage. Binding executables
Action start 12:53:07: BindImage.
Action ended 12:53:07: BindImage. Return value 1.
Action 12:53:07: CreateShortcuts. Creating shortcuts
Action start 12:53:07: CreateShortcuts.
Action ended 12:53:07: CreateShortcuts. Return value 0.
Action 12:53:07: RegisterClassInfo. Registering class servers
Action start 12:53:07: RegisterClassInfo.
Action ended 12:53:07: RegisterClassInfo. Return value 0.
Action 12:53:07: RegisterExtensionInfo. Registering extension servers
Action start 12:53:07: RegisterExtensionInfo.
Action ended 12:53:07: RegisterExtensionInfo. Return value 0.
Action 12:53:07: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:07: RegisterProgIdInfo.
Action ended 12:53:07: RegisterProgIdInfo. Return value 0.
Action 12:53:07: RegisterMIMEInfo. Registering MIME info
Action start 12:53:07: RegisterMIMEInfo.
Action ended 12:53:07: RegisterMIMEInfo. Return value 0.
Action 12:53:07: WriteRegistryValues. Writing system registry values
Action start 12:53:07: WriteRegistryValues.
Action ended 12:53:07: WriteRegistryValues. Return value 1.
Action 12:53:07: WriteIniValues. Writing INI file values
Action start 12:53:07: WriteIniValues.
Action ended 12:53:07: WriteIniValues. Return value 1.
Action 12:53:07: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:07: WriteEnvironmentStrings.
Action ended 12:53:07: WriteEnvironmentStrings. Return value 1.
Action 12:53:07: RegisterFonts. Registering fonts
Action start 12:53:07: RegisterFonts.
Action ended 12:53:07: RegisterFonts. Return value 1.
Action 12:53:07: InstallODBC. Installing ODBC components
Action start 12:53:07: InstallODBC.
Action ended 12:53:07: InstallODBC. Return value 0.
Action 12:53:07: RegisterTypeLibraries. Registering type libraries
Action start 12:53:07: RegisterTypeLibraries.
Action ended 12:53:07: RegisterTypeLibraries. Return value 0.
Action 12:53:07: SelfRegModules. Registering modules
Action start 12:53:07: SelfRegModules.
Action ended 12:53:07: SelfRegModules. Return value 1.
Action 12:53:07: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:07: RegisterComPlus.
Action ended 12:53:07: RegisterComPlus. Return value 0.
Action 12:53:07: InstallServices. Installing new services
Action start 12:53:07: InstallServices.
Action ended 12:53:07: InstallServices. Return value 1.
Action 12:53:07: StartServices. Starting services
Action start 12:53:07: StartServices.
Action ended 12:53:07: StartServices. Return value 1.
Action 12:53:07: RegisterUser. Registering user
Action start 12:53:07: RegisterUser.
Action ended 12:53:07: RegisterUser. Return value 0.
Action 12:53:07: RegisterProduct. Registering product
Action start 12:53:07: RegisterProduct.
Registering product
Action ended 12:53:07: RegisterProduct. Return value 1.
Action 12:53:07: PublishComponents. Publishing qualified components
Action start 12:53:07: PublishComponents.
Action ended 12:53:07: PublishComponents. Return value 0.
Action 12:53:07: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:07: MsiPublishAssemblies.
Action ended 12:53:07: MsiPublishAssemblies. Return value 1.
Action 12:53:07: PublishFeatures. Publishing product features
Action start 12:53:07: PublishFeatures.
Action ended 12:53:07: PublishFeatures. Return value 1.
Action 12:53:07: PublishProduct. Publishing product information
Action start 12:53:07: PublishProduct.
Action ended 12:53:07: PublishProduct. Return value 1.
Action 12:53:07: InstallFinalize.
Action start 12:53:07: InstallFinalize.
Action 12:53:07: ProcessComponents. Updating component registration
Action 12:53:07: RemoveODBC. Removing ODBC components
Action 12:53:07: InstallFiles. Copying new files
40d59.msi
Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Feature: Microsoft_VC80_CRT_x86_
Action 12:53:07: RollbackCleanup. Removing backup files
File: C:\Config.Msi\35404a.rbf
File: C:\Config.Msi\35404b.rbf
Action ended 12:53:07: InstallFinalize. Return value 1.
Action ended 12:53:07: INSTALL. Return value 1.
Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
Property(S): Installed = 2009/11/13 21:21:16
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
Property(S): DATABASE = C:\Windows\Installer\354044.msi
Property(S): Time = 12:53:07
Property(S): VirtualMemory = 14373
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\
Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6\
Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\
Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\
Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\
Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\
Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\
Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\
Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\
Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\
Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\
Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\
Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\
Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\
Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\
Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\
Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_ac9cf5cb\
Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_fc126593\
Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_fc1365cf\
Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_fc146616\
Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_a2f43fdd\
Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_2a9735d7\
Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_2a9735d8\
Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_2a9735d9\
Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_2a993653\
Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_2a9a368f\
Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Property(S): ProductName = Microsoft_VC80_CRT_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): RebootYesNo = No
Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb604B.tmp
Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
=== Logging stopped: 13/02/2011 12:53:07 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:08 2011 INFO
:: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 11039.9 miliseconds (11.0399 seconds) DTR = 115.218 KBPS (0.112518 MBPS)
Calling the custom action code for post-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
Calling the custom action code for pre-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
::START TIMER:: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}]
[ 3300] Sun Feb 13 12:53:08 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_MFCLOC_x86.msi, Result: 0
Payload exists on removable media: E:\
[ 3300] Sun Feb 13 12:53:09 2011 INFO
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\, Result: 0
Configuring MSI ProductCode: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb8BDF.tmp"
1: 0 2: 1033 3: 1252
=== Logging started: 13/02/2011 12:53:09 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC80_MFCLOC_x86
Action 12:53:09: INSTALL.
Action start 12:53:09: INSTALL.
Action 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action start 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action ended 12:53:09: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action start 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action ended 12:53:09: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action start 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action ended 12:53:09: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action start 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action ended 12:53:09: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:09: AppSearch. Searching for installed applications
Action start 12:53:09: AppSearch.
Action ended 12:53:09: AppSearch. Return value 0.
Action 12:53:09: FindRelatedProducts. Searching for related applications
Action start 12:53:09: FindRelatedProducts.
Action ended 12:53:09: FindRelatedProducts. Return value 0.
Action 12:53:09: ValidateProductID.
Action start 12:53:09: ValidateProductID.
Action ended 12:53:09: ValidateProductID. Return value 1.
Action 12:53:09: CostInitialize. Computing space requirements
Action start 12:53:09: CostInitialize.
Action ended 12:53:09: CostInitialize. Return value 1.
Action 12:53:09: FileCost. Computing space requirements
Action start 12:53:09: FileCost.
Action ended 12:53:09: FileCost. Return value 1.
Action 12:53:09: IsolateComponents.
Action start 12:53:09: IsolateComponents.
Action ended 12:53:09: IsolateComponents. Return value 0.
Action 12:53:09: CostFinalize. Computing space requirements
Action start 12:53:09: CostFinalize.
Action ended 12:53:09: CostFinalize. Return value 1.
Action 12:53:09: SetODBCFolders. Initializing ODBC directories
Action start 12:53:09: SetODBCFolders.
Action ended 12:53:09: SetODBCFolders. Return value 0.
Action 12:53:09: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:09: MigrateFeatureStates.
Action ended 12:53:09: MigrateFeatureStates. Return value 0.
Action 12:53:09: InstallValidate. Validating install
Action start 12:53:09: InstallValidate.
Action ended 12:53:09: InstallValidate. Return value 1.
Action 12:53:09: RemoveExistingProducts. Removing applications
Action start 12:53:09: RemoveExistingProducts.
Action ended 12:53:09: RemoveExistingProducts. Return value 0.
Action 12:53:09: InstallInitialize.
Action start 12:53:09: InstallInitialize.
Action ended 12:53:09: InstallInitialize. Return value 1.
Action 12:53:09: SxsInstallCA.
Action start 12:53:09: SxsInstallCA.
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
Action ended 12:53:09: SxsInstallCA. Return value 1.
Action 12:53:09: ProcessComponents. Updating component registration
Action start 12:53:09: ProcessComponents.
Action 12:53:09: GenerateScript. Generating script operations for action:
Action ended 12:53:09: ProcessComponents. Return value 1.
Action 12:53:09: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:09: UnpublishComponents.
Action ended 12:53:09: UnpublishComponents. Return value 0.
Action 12:53:09: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:09: MsiUnpublishAssemblies.
Action ended 12:53:09: MsiUnpublishAssemblies. Return value 1.
Action 12:53:09: UnpublishFeatures. Unpublishing product features
Action start 12:53:09: UnpublishFeatures.
Action ended 12:53:09: UnpublishFeatures. Return value 1.
Action 12:53:09: StopServices. Stopping services
Action start 12:53:09: StopServices.
Action ended 12:53:09: StopServices. Return value 1.
Action 12:53:09: DeleteServices. Deleting services
Action start 12:53:09: DeleteServices.
Action ended 12:53:09: DeleteServices. Return value 1.
Action 12:53:09: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:09: UnregisterComPlus.
Action ended 12:53:09: UnregisterComPlus. Return value 0.
Action 12:53:09: SelfUnregModules. Unregistering modules
Action start 12:53:09: SelfUnregModules.
Action ended 12:53:09: SelfUnregModules. Return value 1.
Action 12:53:09: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:09: UnregisterTypeLibraries.
Action ended 12:53:09: UnregisterTypeLibraries. Return value 0.
Action 12:53:09: RemoveODBC. Removing ODBC components
Action start 12:53:09: RemoveODBC.
Action ended 12:53:09: RemoveODBC. Return value 1.
Action 12:53:09: UnregisterFonts. Unregistering fonts
Action start 12:53:09: UnregisterFonts.
Action ended 12:53:09: UnregisterFonts. Return value 1.
Action 12:53:09: RemoveRegistryValues. Removing system registry values
Action start 12:53:09: RemoveRegistryValues.
Action ended 12:53:09: RemoveRegistryValues. Return value 1.
Action 12:53:09: UnregisterClassInfo. Unregister class servers
Action start 12:53:09: UnregisterClassInfo.
Action ended 12:53:09: UnregisterClassInfo. Return value 0.
Action 12:53:09: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:09: UnregisterExtensionInfo.
Action ended 12:53:09: UnregisterExtensionInfo. Return value 0.
Action 12:53:09: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:09: UnregisterProgIdInfo.
Action ended 12:53:09: UnregisterProgIdInfo. Return value 0.
Action 12:53:09: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:09: UnregisterMIMEInfo.
Action ended 12:53:09: UnregisterMIMEInfo. Return value 0.
Action 12:53:09: RemoveIniValues. Removing INI file entries
Action start 12:53:09: RemoveIniValues.
Action ended 12:53:09: RemoveIniValues. Return value 1.
Action 12:53:09: RemoveShortcuts. Removing shortcuts
Action start 12:53:09: RemoveShortcuts.
Action ended 12:53:09: RemoveShortcuts. Return value 0.
Action 12:53:09: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:09: RemoveEnvironmentStrings.
Action ended 12:53:09: RemoveEnvironmentStrings. Return value 1.
Action 12:53:09: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:09: RemoveDuplicateFiles.
Action ended 12:53:09: RemoveDuplicateFiles. Return value 1.
Action 12:53:09: RemoveFiles. Removing files
Action start 12:53:09: RemoveFiles.
Action ended 12:53:09: RemoveFiles. Return value 0.
Action 12:53:09: RemoveFolders. Removing folders
Action start 12:53:09: RemoveFolders.
Action ended 12:53:09: RemoveFolders. Return value 0.
Action 12:53:09: CreateFolders. Creating folders
Action start 12:53:09: CreateFolders.
Action ended 12:53:09: CreateFolders. Return value 0.
Action 12:53:09: MoveFiles. Moving files
Action start 12:53:09: MoveFiles.
Action ended 12:53:09: MoveFiles. Return value 1.
Action 12:53:09: InstallFiles. Copying new files
Action start 12:53:09: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 12:53:09: InstallFiles. Return value 1.
Action 12:53:09: PatchFiles. Patching files
Action start 12:53:09: PatchFiles.
Action ended 12:53:09: PatchFiles. Return value 0.
Action 12:53:09: DuplicateFiles. Creating duplicate files
Action start 12:53:09: DuplicateFiles.
Action ended 12:53:09: DuplicateFiles. Return value 1.
Action 12:53:09: BindImage. Binding executables
Action start 12:53:09: BindImage.
Action ended 12:53:09: BindImage. Return value 1.
Action 12:53:09: CreateShortcuts. Creating shortcuts
Action start 12:53:09: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 12:53:09: CreateShortcuts. Return value 0.
Action 12:53:09: RegisterClassInfo. Registering class servers
Action start 12:53:09: RegisterClassInfo.
Action ended 12:53:09: RegisterClassInfo. Return value 0.
Action 12:53:09: RegisterExtensionInfo. Registering extension servers
Action start 12:53:09: RegisterExtensionInfo.
Action ended 12:53:09: RegisterExtensionInfo. Return value 0.
Action 12:53:09: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:09: RegisterProgIdInfo.
Action ended 12:53:09: RegisterProgIdInfo. Return value 0.
Action 12:53:09: RegisterMIMEInfo. Registering MIME info
Action start 12:53:09: RegisterMIMEInfo.
Action ended 12:53:09: RegisterMIMEInfo. Return value 0.
Action 12:53:09: WriteRegistryValues. Writing system registry values
Action start 12:53:09: WriteRegistryValues.
Action ended 12:53:09: WriteRegistryValues. Return value 1.
Action 12:53:09: WriteIniValues. Writing INI file values
Action start 12:53:09: WriteIniValues.
Action ended 12:53:09: WriteIniValues. Return value 1.
Action 12:53:09: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:09: WriteEnvironmentStrings.
Action ended 12:53:09: WriteEnvironmentStrings. Return value 1.
Action 12:53:09: RegisterFonts. Registering fonts
Action start 12:53:09: RegisterFonts.
Action ended 12:53:09: RegisterFonts. Return value 1.
Action 12:53:09: InstallODBC. Installing ODBC components
Action start 12:53:09: InstallODBC.
Action ended 12:53:09: InstallODBC. Return value 0.
Action 12:53:09: RegisterTypeLibraries. Registering type libraries
Action start 12:53:09: RegisterTypeLibraries.
Action ended 12:53:09: RegisterTypeLibraries. Return value 0.
Action 12:53:09: SelfRegModules. Registering modules
Action start 12:53:09: SelfRegModules.
Action ended 12:53:09: SelfRegModules. Return value 1.
Action 12:53:09: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:09: RegisterComPlus.
Action ended 12:53:09: RegisterComPlus. Return value 0.
Action 12:53:09: InstallServices. Installing new services
Action start 12:53:09: InstallServices.
Action ended 12:53:09: InstallServices. Return value 1.
Action 12:53:09: StartServices. Starting services
Action start 12:53:09: StartServices.
Action ended 12:53:09: StartServices. Return value 1.
Action 12:53:09: RegisterUser. Registering user
Action start 12:53:09: RegisterUser.
Action ended 12:53:09: RegisterUser. Return value 0.
Action 12:53:09: RegisterProduct. Registering product
Action start 12:53:09: RegisterProduct.
Registering product
Action ended 12:53:09: RegisterProduct. Return value 1.
Action 12:53:09: PublishComponents. Publishing qualified components
Action start 12:53:09: PublishComponents.
Action ended 12:53:09: PublishComponents. Return value 0.
Action 12:53:09: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:09: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 12:53:09: MsiPublishAssemblies. Return value 1.
Action 12:53:09: PublishFeatures. Publishing product features
Action start 12:53:09: PublishFeatures.
Feature: Publishing product features
Action ended 12:53:09: PublishFeatures. Return value 1.
Action 12:53:09: PublishProduct. Publishing product information
Action start 12:53:09: PublishProduct.
Action ended 12:53:09: PublishProduct. Return value 1.
Action 12:53:09: InstallFinalize.
Action start 12:53:09: InstallFinalize.
[ 3300] Sun Feb 13 12:53:10 2011 INFO
Action 12:53:10: CreateShortcuts. Creating shortcuts
Shortcut: ARPPRODUCTICON.exe
Action 12:53:10: RegisterProduct. Registering product
40d62.msi
Action 12:53:10: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32-policy",processorArchitecture="x86"
Action 12:53:10: PublishFeatures. Publishing product features
Feature: Microsoft_VC80_MFCLOC_x
Action 12:53:10: PublishProduct. Publishing product information
Message type: 2, Argument: 0
Action 12:53:10: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354053.rbf
File: C:\Config.Msi\354054.rbf
Message type: 2, Argument: 1
Action ended 12:53:10: InstallFinalize. Return value 1.
Action ended 12:53:10: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {DBBF67A0-1BA6-4CF4-A1EF-007F1FD45598}
Property(S): SourcedirProduct = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): Installed = 2009/11/13 21:27:58
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\35404d.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 12:53:10
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14364
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WinSxsDirectory.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_03ca5532205cb096\
Property(S): payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\
Property(S): WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c\
Property(S): policydir.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3419f7d3\
Property(S): policydir.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_341af80c\
Property(S): payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_341af80d\
Property(S): policydir.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_341af80e\
Property(S): policydir.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_341af80f\
Property(S): policydir.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_341af810\
Property(S): payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_341af811\
Property(S): policydir.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_341af812\
Property(S): payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_8e4db481\
Property(S): policydir.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_8e4db482\
Property(S): policydir.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_8e4db484\
Property(S): payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_8e4db485\
Property(S): policydir.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_8e56b6bb\
Property(S): policydir.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_8ecec4c7\
Property(S): policydir.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_de44348f\
Property(S): payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_de4534cb\
Property(S): policydir.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_de463512\
Property(S): payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_85260ed9\
Property(S): policydir.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_0cc904d3\
Property(S): payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_0cc904d4\
Property(S): policydir.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_0cc904d5\
Property(S): payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_0ccb054f\
Property(S): policydir.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_0ccc058b\
Property(S): payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c\
Property(S): ALLUSERS = 1
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): WinSxsDirectory.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_4db266e67dd280ef\
Property(S): WinSxsPolicies.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_63bb0537\
Property(S): policydir.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_3c7113f3\
Property(S): policydir.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_63c00674\
Property(S): policydir.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_63bf063a\
Property(S): policydir.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_63c00673\
Property(S): policydir.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_63c00675\
Property(S): policydir.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_63c00676\
Property(S): policydir.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_63c00677\
Property(S): policydir.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_63c00678\
Property(S): policydir.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_63c00679\
Property(S): policydir.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_bdf2c2e8\
Property(S): payload.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_bdf2c2e9\
Property(S): policydir.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_bdf2c2eb\
Property(S): payload.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_bdf2c2ec\
Property(S): policydir.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_bdfbc522\
Property(S): policydir.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_be73d32e\
Property(S): payload.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_0de942f6\
Property(S): payload.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_0dea4332\
Property(S): payload.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_0deb4379\
Property(S): payload.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_b4cb1d40\
Property(S): payload.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_3c6e133a\
Property(S): payload.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_3c6e133b\
Property(S): payload.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_3c6e133c\
Property(S): payload.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_3c7013b6\
Property(S): payload.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_3c7113f2\
Property(S): payload.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_3c7113f3\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC80_MFCLOC_x86
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CE0BC0C8E9CBE7B86EACE7CFDEDC978F99CC678F49ABA0E8CE6BC7C8BEDB9088F9ACF798D9AC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): MsiSystemRebootPending = 1
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 5888
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb8BDF.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {AF8EF662-EF5A-426A-AA7B-B83C3A5FFFBB}
=== Logging stopped: 13/02/2011 12:53:10 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:10 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}] took 2031.14 miliseconds (2.03114 seconds) DTR = 289.492 KBPS (0.282707 MBPS)
User specified overrideFile:
Calling the custom action code for post-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86
Calling the custom action code for pre-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57}
::START TIMER:: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}]
[ 4528] Sun Feb 13 12:53:10 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_MFC_x86.msi, Result: 0
[ 4528] Sun Feb 13 12:53:11 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFC_x86\, Result: 0
Configuring MSI ProductCode: {D1A19B02-817E-4296-A45B-07853FD74D57}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb93CD.tmp"
[ 4528] Sun Feb 13 12:53:12 2011 INFO
=== Logging started: 13/02/2011 12:53:12 ===
Message type: 1, Argument: Microsoft_VC80_MFC_x86
Action 12:53:12: INSTALL.
Action start 12:53:12: INSTALL.
Action 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action start 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action ended 12:53:12: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action start 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action ended 12:53:12: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action start 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action ended 12:53:12: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action start 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action ended 12:53:12: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:12: AppSearch. Searching for installed applications
Action start 12:53:12: AppSearch.
Action ended 12:53:12: AppSearch. Return value 0.
Action 12:53:12: FindRelatedProducts. Searching for related applications
Action start 12:53:12: FindRelatedProducts.
Action ended 12:53:12: FindRelatedProducts. Return value 0.
Action 12:53:12: ValidateProductID.
Action start 12:53:12: ValidateProductID.
Action ended 12:53:12: ValidateProductID. Return value 1.
Action 12:53:12: CostInitialize. Computing space requirements
Action start 12:53:12: CostInitialize.
Action ended 12:53:12: CostInitialize. Return value 1.
Action 12:53:12: FileCost. Computing space requirements
Action start 12:53:12: FileCost.
Action ended 12:53:12: FileCost. Return value 1.
Action 12:53:12: IsolateComponents.
Action start 12:53:12: IsolateComponents.
Action ended 12:53:12: IsolateComponents. Return value 0.
Action 12:53:12: CostFinalize. Computing space requirements
Action start 12:53:12: CostFinalize.
Action ended 12:53:12: CostFinalize. Return value 1.
Action 12:53:12: SetODBCFolders. Initializing ODBC directories
Action start 12:53:12: SetODBCFolders.
Action ended 12:53:12: SetODBCFolders. Return value 0.
Action 12:53:12: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:12: MigrateFeatureStates.
Action ended 12:53:12: MigrateFeatureStates. Return value 0.
Action 12:53:12: InstallValidate. Validating install
Action start 12:53:12: InstallValidate.
Action ended 12:53:12: InstallValidate. Return value 1.
Action 12:53:12: RemoveExistingProducts. Removing applications
Action start 12:53:12: RemoveExistingProducts.
Action ended 12:53:12: RemoveExistingProducts. Return value 0.
Action 12:53:12: InstallInitialize.
Action start 12:53:12: InstallInitialize.
Action ended 12:53:12: InstallInitialize. Return value 1.
Action 12:53:12: SxsInstallCA.
Action start 12:53:12: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: uplevel.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 12:53:12: SxsInstallCA. Return value 1.
Action 12:53:12: ProcessComponents. Updating component registration
Action start 12:53:12: ProcessComponents.
Action 12:53:12: GenerateScript. Generating script operations for action:
Action ended 12:53:12: ProcessComponents. Return value 1.
Action 12:53:12: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:12: UnpublishComponents.
Action ended 12:53:12: UnpublishComponents. Return value 0.
Action 12:53:12: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:12: MsiUnpublishAssemblies.
Action ended 12:53:12: MsiUnpublishAssemblies. Return value 1.
Action 12:53:12: UnpublishFeatures. Unpublishing product features
Action start 12:53:12: UnpublishFeatures.
Action ended 12:53:12: UnpublishFeatures. Return value 1.
Action 12:53:12: StopServices. Stopping services
Action start 12:53:12: StopServices.
Action ended 12:53:12: StopServices. Return value 1.
Action 12:53:12: DeleteServices. Deleting services
Action start 12:53:12: DeleteServices.
Action ended 12:53:12: DeleteServices. Return value 1.
Action 12:53:12: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:12: UnregisterComPlus.
Action ended 12:53:12: UnregisterComPlus. Return value 0.
Action 12:53:12: SelfUnregModules. Unregistering modules
Action start 12:53:12: SelfUnregModules.
Action ended 12:53:12: SelfUnregModules. Return value 1.
Action 12:53:12: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:12: UnregisterTypeLibraries.
Action ended 12:53:12: UnregisterTypeLibraries. Return value 0.
Action 12:53:12: RemoveODBC. Removing ODBC components
Action start 12:53:12: RemoveODBC.
Action ended 12:53:12: RemoveODBC. Return value 1.
Action 12:53:12: UnregisterFonts. Unregistering fonts
Action start 12:53:12: UnregisterFonts.
Action ended 12:53:12: UnregisterFonts. Return value 1.
Action 12:53:12: RemoveRegistryValues. Removing system registry values
Action start 12:53:12: RemoveRegistryValues.
Action ended 12:53:12: RemoveRegistryValues. Return value 1.
Action 12:53:12: UnregisterClassInfo. Unregister class servers
Action start 12:53:12: UnregisterClassInfo.
Action ended 12:53:12: UnregisterClassInfo. Return value 0.
Action 12:53:12: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:12: UnregisterExtensionInfo.
Action ended 12:53:12: UnregisterExtensionInfo. Return value 0.
Action 12:53:12: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:12: UnregisterProgIdInfo.
Action ended 12:53:12: UnregisterProgIdInfo. Return value 0.
Action 12:53:12: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:12: UnregisterMIMEInfo.
Action ended 12:53:12: UnregisterMIMEInfo. Return value 0.
Action 12:53:12: RemoveIniValues. Removing INI file entries
Action start 12:53:12: RemoveIniValues.
Action ended 12:53:12: RemoveIniValues. Return value 1.
Action 12:53:12: RemoveShortcuts. Removing shortcuts
Action start 12:53:12: RemoveShortcuts.
Action ended 12:53:12: RemoveShortcuts. Return value 0.
Action 12:53:12: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:12: RemoveEnvironmentStrings.
Action ended 12:53:12: RemoveEnvironmentStrings. Return value 1.
Action 12:53:12: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:12: RemoveDuplicateFiles.
Action ended 12:53:12: RemoveDuplicateFiles. Return value 1.
Action 12:53:12: RemoveFiles. Removing files
Action start 12:53:12: RemoveFiles.
Action ended 12:53:12: RemoveFiles. Return value 0.
Action 12:53:12: RemoveFolders. Removing folders
Action start 12:53:12: RemoveFolders.
Action ended 12:53:12: RemoveFolders. Return value 0.
Action 12:53:12: CreateFolders. Creating folders
Action start 12:53:12: CreateFolders.
Action ended 12:53:12: CreateFolders. Return value 0.
Action 12:53:12: MoveFiles. Moving files
Action start 12:53:12: MoveFiles.
Action ended 12:53:12: MoveFiles. Return value 1.
Action 12:53:12: InstallFiles. Copying new files
Action start 12:53:12: InstallFiles.
Action ended 12:53:12: InstallFiles. Return value 1.
Action 12:53:12: PatchFiles. Patching files
Action start 12:53:12: PatchFiles.
Action ended 12:53:12: PatchFiles. Return value 0.
Action 12:53:12: DuplicateFiles. Creating duplicate files
Action start 12:53:12: DuplicateFiles.
Action ended 12:53:12: DuplicateFiles. Return value 1.
Action 12:53:12: BindImage. Binding executables
Action start 12:53:12: BindImage.
Action ended 12:53:12: BindImage. Return value 1.
Action 12:53:12: CreateShortcuts. Creating shortcuts
Action start 12:53:12: CreateShortcuts.
Action ended 12:53:12: CreateShortcuts. Return value 0.
Action 12:53:12: RegisterClassInfo. Registering class servers
Action start 12:53:12: RegisterClassInfo.
Action ended 12:53:12: RegisterClassInfo. Return value 0.
Action 12:53:12: RegisterExtensionInfo. Registering extension servers
Action start 12:53:12: RegisterExtensionInfo.
Action ended 12:53:12: RegisterExtensionInfo. Return value 0.
Action 12:53:12: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:12: RegisterProgIdInfo.
Action ended 12:53:12: RegisterProgIdInfo. Return value 0.
Action 12:53:12: RegisterMIMEInfo. Registering MIME info
Action start 12:53:12: RegisterMIMEInfo.
Action ended 12:53:12: RegisterMIMEInfo. Return value 0.
Action 12:53:12: WriteRegistryValues. Writing system registry values
Action start 12:53:12: WriteRegistryValues.
Action ended 12:53:12: WriteRegistryValues. Return value 1.
Action 12:53:12: WriteIniValues. Writing INI file values
Action start 12:53:12: WriteIniValues.
Action ended 12:53:12: WriteIniValues. Return value 1.
Action 12:53:12: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:12: WriteEnvironmentStrings.
Action ended 12:53:12: WriteEnvironmentStrings. Return value 1.
Action 12:53:12: RegisterFonts. Registering fonts
Action start 12:53:12: RegisterFonts.
Action ended 12:53:12: RegisterFonts. Return value 1.
Action 12:53:12: InstallODBC. Installing ODBC components
Action start 12:53:12: InstallODBC.
Action ended 12:53:12: InstallODBC. Return value 0.
Action 12:53:12: RegisterTypeLibraries. Registering type libraries
Action start 12:53:12: RegisterTypeLibraries.
Action ended 12:53:12: RegisterTypeLibraries. Return value 0.
Action 12:53:12: SelfRegModules. Registering modules
Action start 12:53:12: SelfRegModules.
Action ended 12:53:12: SelfRegModules. Return value 1.
Action 12:53:12: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:12: RegisterComPlus.
Action ended 12:53:12: RegisterComPlus. Return value 0.
Action 12:53:12: InstallServices. Installing new services
Action start 12:53:12: InstallServices.
Action ended 12:53:12: InstallServices. Return value 1.
Action 12:53:12: StartServices. Starting services
Action start 12:53:12: StartServices.
Action ended 12:53:12: StartServices. Return value 1.
Action 12:53:12: RegisterUser. Registering user
Action start 12:53:12: RegisterUser.
Action ended 12:53:12: RegisterUser. Return value 0.
Action 12:53:12: RegisterProduct. Registering product
Action start 12:53:12: RegisterProduct.
Registering product
Action ended 12:53:12: RegisterProduct. Return value 1.
Action 12:53:12: PublishComponents. Publishing qualified components
Action start 12:53:12: PublishComponents.
Action ended 12:53:12: PublishComponents. Return value 0.
Action 12:53:12: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:12: MsiPublishAssemblies.
Action ended 12:53:12: MsiPublishAssemblies. Return value 1.
Action 12:53:12: PublishFeatures. Publishing product features
Action start 12:53:12: PublishFeatures.
Action ended 12:53:12: PublishFeatures. Return value 1.
Action 12:53:12: PublishProduct. Publishing product information
Action start 12:53:12: PublishProduct.
Action ended 12:53:12: PublishProduct. Return value 1.
Action 12:53:12: InstallFinalize.
Action start 12:53:12: InstallFinalize.
Message type: 0, Argument: 1033
40d6b.msi
[ 4528] Sun Feb 13 12:53:13 2011 INFO
Action 12:53:13: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32-policy"
Action 12:53:13: PublishFeatures. Publishing product features
Feature: Microsoft_VC80_MFC_x86_
Action 12:53:13: PublishProduct. Publishing product information
Action 12:53:13: RollbackCleanup. Removing backup files
File: C:\Config.Msi\35405c.rbf
File: C:\Config.Msi\35405d.rbf
Action ended 12:53:13: InstallFinalize. Return value 1.
Action ended 12:53:13: INSTALL. Return value 1.
Property(S): SourcedirProduct = {D1A19B02-817E-4296-A45B-07853FD74D57}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
Property(S): UpgradeCode = {BA8F3080-8370-4EB2-8827-F83E97A7A343}
Property(S): Installed = 2009/11/13 21:25:22
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\354056.msi
Property(S): Time = 12:53:13
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
Property(S): WinSxsDirectory.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_cbf21254470d8752\
Property(S): payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\
Property(S): WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
Property(S): policydir.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_decaded5\
Property(S): policydir.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_decbdf0e\
Property(S): payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_decbdf0f\
Property(S): policydir.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_decbdf10\
Property(S): payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_decbdf11\
Property(S): policydir.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_decbdf12\
Property(S): payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_decbdf13\
Property(S): policydir.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_decbdf14\
Property(S): policydir.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_38fe9b83\
Property(S): payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_38fe9b84\
Property(S): policydir.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_38fe9b86\
Property(S): payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_38fe9b87\
Property(S): payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_39079dbd\
Property(S): policydir.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_397fabc9\
Property(S): policydir.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_88f51b91\
Property(S): policydir.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_88f61bcd\
Property(S): policydir.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_88f71c14\
Property(S): policydir.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_2fd6f5db\
Property(S): payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_b779ebd5\
Property(S): payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_b779ebd6\
Property(S): payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_b779ebd7\
Property(S): payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_b77bec51\
Property(S): payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_b77cec8d\
Property(S): payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
Property(S): WinSxsDirectory.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_49ef489714173a89\
Property(S): WinSxsPolicies.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_22ca9ad9\
Property(S): policydir.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_fb80a995\
Property(S): policydir.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_22cf9c16\
Property(S): policydir.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_22ce9bdc\
Property(S): policydir.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_22cf9c15\
Property(S): policydir.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_22cf9c17\
Property(S): policydir.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_22cf9c18\
Property(S): policydir.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_22cf9c19\
Property(S): policydir.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_22cf9c1a\
Property(S): policydir.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_22cf9c1b\
Property(S): policydir.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_7d02588a\
Property(S): payload.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_7d02588b\
Property(S): policydir.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_7d02588d\
Property(S): payload.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_7d02588e\
Property(S): policydir.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_7d0b5ac4\
Property(S): policydir.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_7d8368d0\
Property(S): payload.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ccf8d898\
Property(S): payload.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ccf9d8d4\
Property(S): payload.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ccfad91b\
Property(S): payload.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_73dab2e2\
Property(S): payload.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_fb7da8dc\
Property(S): payload.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_fb7da8dd\
Property(S): payload.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_fb7da8de\
Property(S): payload.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_fb7fa958\
Property(S): payload.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_fb80a994\
Property(S): payload.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_fb80a995\
Property(S): ProductCode = {D1A19B02-817E-4296-A45B-07853FD74D57}
Property(S): ProductName = Microsoft_VC80_MFC_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): RebootYesNo = No
Property(S): DWUSLINK = CE8C979FAE7BF06819ACF728AE3C978F3EBCC78FFEEB4798CE8CE7EF9EDBA75FF9ABA7E8FEAC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb93CD.tmp
Property(S): PackageCode = {032B02B2-4D8D-45FF-BB1E-864B26F4ADDC}
=== Logging stopped: 13/02/2011 12:53:13 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:13 2011 INFO
:: END TIMER :: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}] took 3031.97 miliseconds (3.03197 seconds) DTR = 23.747 KBPS (0.0231904 MBPS)
[ 6204] Sun Feb 13 12:53:14 2011 INFO
Calling the custom action code for post-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86
[ 6204] Sun Feb 13 12:53:14 2011 WARN
Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
Calling the custom action code for pre-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
::START TIMER:: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}]
[ 5528] Sun Feb 13 12:53:14 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86\, Result: 0
Configuring MSI ProductCode: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbA108.tmp"
1: 0 2: 1033 3: 1252
[ 5528] Sun Feb 13 12:53:17 2011 INFO
=== Logging started: 13/02/2011 12:53:17 ===
Message type: 1, Argument: Microsoft_VC90_MFC_x86
Action 12:53:17: INSTALL.
Action start 12:53:17: INSTALL.
Action 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action start 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action ended 12:53:17: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
Action 12:53:17: AppSearch. Searching for installed applications
Action start 12:53:17: AppSearch.
Action ended 12:53:17: AppSearch. Return value 0.
Action 12:53:17: FindRelatedProducts. Searching for related applications
Action start 12:53:17: FindRelatedProducts.
Action ended 12:53:17: FindRelatedProducts. Return value 0.
Action 12:53:17: ValidateProductID.
Action start 12:53:17: ValidateProductID.
Action ended 12:53:17: ValidateProductID. Return value 1.
Action 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action start 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action ended 12:53:17: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
Action 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF.
Action start 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF.
Action ended 12:53:17: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF. Return value 1.
Action 12:53:17: CostInitialize. Computing space requirements
Action start 12:53:17: CostInitialize.
Action ended 12:53:17: CostInitialize. Return value 1.
Action 12:53:17: FileCost. Computing space requirements
Action start 12:53:17: FileCost.
Action ended 12:53:17: FileCost. Return value 1.
Action 12:53:17: IsolateComponents.
Action start 12:53:17: IsolateComponents.
Action ended 12:53:17: IsolateComponents. Return value 0.
Action 12:53:17: CostFinalize. Computing space requirements
Action start 12:53:17: CostFinalize.
Action ended 12:53:17: CostFinalize. Return value 1.
Action 12:53:17: SetODBCFolders. Initializing ODBC directories
Action start 12:53:17: SetODBCFolders.
Action ended 12:53:17: SetODBCFolders. Return value 0.
Action 12:53:17: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:17: MigrateFeatureStates.
Action ended 12:53:17: MigrateFeatureStates. Return value 0.
Action 12:53:17: InstallValidate. Validating install
Action start 12:53:17: InstallValidate.
Action ended 12:53:17: InstallValidate. Return value 1.
Action 12:53:17: RemoveExistingProducts. Removing applications
Action start 12:53:17: RemoveExistingProducts.
Action ended 12:53:17: RemoveExistingProducts. Return value 0.
Action 12:53:17: InstallInitialize.
Action start 12:53:17: InstallInitialize.
Action ended 12:53:17: InstallInitialize. Return value 1.
Action 12:53:17: ProcessComponents. Updating component registration
Action start 12:53:17: ProcessComponents.
Action 12:53:17: GenerateScript. Generating script operations for action:
Action ended 12:53:17: ProcessComponents. Return value 1.
Action 12:53:17: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:17: UnpublishComponents.
Action ended 12:53:17: UnpublishComponents. Return value 0.
Action 12:53:17: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:17: MsiUnpublishAssemblies.
Action ended 12:53:17: MsiUnpublishAssemblies. Return value 1.
Action 12:53:17: UnpublishFeatures. Unpublishing product features
Action start 12:53:17: UnpublishFeatures.
Action ended 12:53:17: UnpublishFeatures. Return value 1.
Action 12:53:17: StopServices. Stopping services
Action start 12:53:17: StopServices.
Action ended 12:53:17: StopServices. Return value 1.
Action 12:53:17: DeleteServices. Deleting services
Action start 12:53:17: DeleteServices.
Action ended 12:53:17: DeleteServices. Return value 1.
Action 12:53:17: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:17: UnregisterComPlus.
Action ended 12:53:17: UnregisterComPlus. Return value 0.
Action 12:53:17: SelfUnregModules. Unregistering modules
Action start 12:53:17: SelfUnregModules.
Action ended 12:53:17: SelfUnregModules. Return value 1.
Action 12:53:17: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:17: UnregisterTypeLibraries.
Action ended 12:53:17: UnregisterTypeLibraries. Return value 0.
Action 12:53:17: RemoveODBC. Removing ODBC components
Action start 12:53:17: RemoveODBC.
Action ended 12:53:17: RemoveODBC. Return value 1.
Action 12:53:17: UnregisterFonts. Unregistering fonts
Action start 12:53:17: UnregisterFonts.
Action ended 12:53:17: UnregisterFonts. Return value 1.
Action 12:53:17: RemoveRegistryValues. Removing system registry values
Action start 12:53:17: RemoveRegistryValues.
Action ended 12:53:17: RemoveRegistryValues. Return value 1.
Action 12:53:17: UnregisterClassInfo. Unregister class servers
Action start 12:53:17: UnregisterClassInfo.
Action ended 12:53:17: UnregisterClassInfo. Return value 0.
Action 12:53:17: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:17: UnregisterExtensionInfo.
Action ended 12:53:17: UnregisterExtensionInfo. Return value 0.
Action 12:53:17: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:17: UnregisterProgIdInfo.
Action ended 12:53:17: UnregisterProgIdInfo. Return value 0.
Action 12:53:17: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:17: UnregisterMIMEInfo.
Action ended 12:53:17: UnregisterMIMEInfo. Return value 0.
Action 12:53:17: RemoveIniValues. Removing INI file entries
Action start 12:53:17: RemoveIniValues.
Action ended 12:53:17: RemoveIniValues. Return value 1.
Action 12:53:17: RemoveShortcuts. Removing shortcuts
Action start 12:53:17: RemoveShortcuts.
Action ended 12:53:17: RemoveShortcuts. Return value 0.
Action 12:53:17: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:17: RemoveEnvironmentStrings.
Action ended 12:53:17: RemoveEnvironmentStrings. Return value 1.
Action 12:53:17: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:17: RemoveDuplicateFiles.
Action ended 12:53:17: RemoveDuplicateFiles. Return value 1.
Action 12:53:17: RemoveFiles. Removing files
Action start 12:53:17: RemoveFiles.
Action ended 12:53:17: RemoveFiles. Return value 0.
Action 12:53:17: RemoveFolders. Removing folders
Action start 12:53:17: RemoveFolders.
Action ended 12:53:17: RemoveFolders. Return value 0.
Action 12:53:17: CreateFolders. Creating folders
Action start 12:53:17: CreateFolders.
Action ended 12:53:17: CreateFolders. Return value 0.
Action 12:53:17: MoveFiles. Moving files
Action start 12:53:17: MoveFiles.
Action ended 12:53:17: MoveFiles. Return value 1.
Action 12:53:17: InstallFiles. Copying new files
Action start 12:53:17: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 12:53:17: InstallFiles. Return value 1.
Action 12:53:17: PatchFiles. Patching files
Action start 12:53:17: PatchFiles.
Action ended 12:53:17: PatchFiles. Return value 0.
Action 12:53:17: DuplicateFiles. Creating duplicate files
Action start 12:53:17: DuplicateFiles.
Action ended 12:53:17: DuplicateFiles. Return value 1.
Action 12:53:17: BindImage. Binding executables
Action start 12:53:17: BindImage.
Action ended 12:53:17: BindImage. Return value 1.
Action 12:53:17: CreateShortcuts. Creating shortcuts
Action start 12:53:17: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 12:53:17: CreateShortcuts. Return value 0.
Action 12:53:17: RegisterClassInfo. Registering class servers
Action start 12:53:17: RegisterClassInfo.
Action ended 12:53:17: RegisterClassInfo. Return value 0.
Action 12:53:17: RegisterExtensionInfo. Registering extension servers
Action start 12:53:17: RegisterExtensionInfo.
Action ended 12:53:17: RegisterExtensionInfo. Return value 0.
Action 12:53:17: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:17: RegisterProgIdInfo.
Action ended 12:53:17: RegisterProgIdInfo. Return value 0.
Action 12:53:17: RegisterMIMEInfo. Registering MIME info
Action start 12:53:17: RegisterMIMEInfo.
Action ended 12:53:17: RegisterMIMEInfo. Return value 0.
Action 12:53:17: WriteRegistryValues. Writing system registry values
Action start 12:53:17: WriteRegistryValues.
Action ended 12:53:17: WriteRegistryValues. Return value 1.
Action 12:53:17: WriteIniValues. Writing INI file values
Action start 12:53:17: WriteIniValues.
Action ended 12:53:17: WriteIniValues. Return value 1.
Action 12:53:17: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:17: WriteEnvironmentStrings.
Action ended 12:53:17: WriteEnvironmentStrings. Return value 1.
Action 12:53:17: RegisterFonts. Registering fonts
Action start 12:53:17: RegisterFonts.
Action ended 12:53:17: RegisterFonts. Return value 1.
Action 12:53:17: InstallODBC. Installing ODBC components
Action start 12:53:17: InstallODBC.
Action ended 12:53:17: InstallODBC. Return value 0.
Action 12:53:17: RegisterTypeLibraries. Registering type libraries
Action start 12:53:17: RegisterTypeLibraries.
Action ended 12:53:17: RegisterTypeLibraries. Return value 0.
Action 12:53:17: SelfRegModules. Registering modules
Action start 12:53:17: SelfRegModules.
Action ended 12:53:17: SelfRegModules. Return value 1.
Action 12:53:17: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:17: RegisterComPlus.
Action ended 12:53:17: RegisterComPlus. Return value 0.
Action 12:53:17: InstallServices. Installing new services
Action start 12:53:17: InstallServices.
Action ended 12:53:17: InstallServices. Return value 1.
Action 12:53:17: StartServices. Starting services
Action start 12:53:17: StartServices.
Action ended 12:53:17: StartServices. Return value 1.
Action 12:53:17: RegisterUser. Registering user
Action start 12:53:17: RegisterUser.
Action ended 12:53:17: RegisterUser. Return value 0.
Action 12:53:17: RegisterProduct. Registering product
Action start 12:53:17: RegisterProduct.
Registering product
Action ended 12:53:17: RegisterProduct. Return value 1.
Action 12:53:17: PublishComponents. Publishing qualified components
Action start 12:53:17: PublishComponents.
Action ended 12:53:17: PublishComponents. Return value 0.
Action 12:53:17: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:17: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 12:53:17: MsiPublishAssemblies. Return value 1.
Action 12:53:17: PublishFeatures. Publishing product features
Action start 12:53:17: PublishFeatures.
Feature: Publishing product features
Action ended 12:53:17: PublishFeatures. Return value 1.
Action 12:53:17: PublishProduct. Publishing product information
Action start 12:53:17: PublishProduct.
Action ended 12:53:17: PublishProduct. Return value 1.
Action 12:53:17: InstallFinalize.
Action start 12:53:17: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
40d74.msi
Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_MFC_x86_
Message type: 2, Argument: 0
Action 12:53:17: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354065.rbf
File: C:\Config.Msi\354066.rbf
Message type: 2, Argument: 1
Action ended 12:53:17: InstallFinalize. Return value 1.
Action ended 12:53:17: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {7534F528-4E84-4BFB-A8F2-BBD75974F28F}
Property(S): SourcedirProduct = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
Property(S): Installed = 2009/07/28 04:13:22
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\35405f.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 12:53:17
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14364
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_4bf45688bf9e2dbf\
Property(S): payload.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_a57b1f13\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ecfe4c8afb2661fb\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_4ee8bb30\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC90_MFC_x86
Property(S): ProductVersion = 1.00.0000
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CEDCD08F9EDBA7DF5EAC87CFDEDB978F8EABA08FCEECA7AFCEFCA0AFF9DBF78FB9ABA7F819AC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): MsiSystemRebootPending = 1
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 5888
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbA108.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductState = 5
Property(S): PackageCode = {FCC5DFDD-8D3B-457A-9232-4D938A966CD6}
=== Logging stopped: 13/02/2011 12:53:17 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:18 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}] took 4027.41 miliseconds (4.02741 seconds)
User specified overrideFile:
Calling the custom action code for post-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86
Calling the custom action code for pre-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
::START TIMER:: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}]
[ 5640] Sun Feb 13 12:53:18 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86\, Result: 0
Configuring MSI ProductCode: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbB0D2.tmp"
=== Logging started: 13/02/2011 12:53:18 ===
Message type: 1, Argument: Microsoft_VC90_ATL_x86
Action 12:53:18: INSTALL.
Action start 12:53:18: INSTALL.
Action 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action start 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action ended 12:53:18: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
Action 12:53:18: AppSearch. Searching for installed applications
Action start 12:53:18: AppSearch.
Action ended 12:53:18: AppSearch. Return value 0.
Action 12:53:18: FindRelatedProducts. Searching for related applications
Action start 12:53:18: FindRelatedProducts.
Action ended 12:53:18: FindRelatedProducts. Return value 0.
Action 12:53:18: ValidateProductID.
Action start 12:53:18: ValidateProductID.
Action ended 12:53:18: ValidateProductID. Return value 1.
Action 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action start 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action ended 12:53:18: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
Action 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC.
Action start 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC.
Action ended 12:53:18: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC. Return value 1.
Action 12:53:18: CostInitialize. Computing space requirements
Action start 12:53:18: CostInitialize.
Action ended 12:53:18: CostInitialize. Return value 1.
Action 12:53:18: FileCost. Computing space requirements
Action start 12:53:18: FileCost.
Action ended 12:53:18: FileCost. Return value 1.
Action 12:53:18: IsolateComponents.
Action start 12:53:18: IsolateComponents.
Action ended 12:53:18: IsolateComponents. Return value 0.
Action 12:53:18: CostFinalize. Computing space requirements
Action start 12:53:18: CostFinalize.
Action ended 12:53:18: CostFinalize. Return value 1.
Action 12:53:18: SetODBCFolders. Initializing ODBC directories
Action start 12:53:18: SetODBCFolders.
Action ended 12:53:18: SetODBCFolders. Return value 0.
Action 12:53:18: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:18: MigrateFeatureStates.
Action ended 12:53:18: MigrateFeatureStates. Return value 0.
Action 12:53:18: InstallValidate. Validating install
Action start 12:53:18: InstallValidate.
Action ended 12:53:18: InstallValidate. Return value 1.
Action 12:53:18: RemoveExistingProducts. Removing applications
Action start 12:53:18: RemoveExistingProducts.
Action ended 12:53:18: RemoveExistingProducts. Return value 0.
Action 12:53:18: InstallInitialize.
Action start 12:53:18: InstallInitialize.
[ 5640] Sun Feb 13 12:53:19 2011 INFO
Action ended 12:53:19: InstallInitialize. Return value 1.
Action 12:53:19: ProcessComponents. Updating component registration
Action start 12:53:19: ProcessComponents.
Action 12:53:19: GenerateScript. Generating script operations for action:
Action ended 12:53:19: ProcessComponents. Return value 1.
Action 12:53:19: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:19: UnpublishComponents.
Action ended 12:53:19: UnpublishComponents. Return value 0.
Action 12:53:19: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:19: MsiUnpublishAssemblies.
Action ended 12:53:19: MsiUnpublishAssemblies. Return value 1.
Action 12:53:19: UnpublishFeatures. Unpublishing product features
Action start 12:53:19: UnpublishFeatures.
Action ended 12:53:19: UnpublishFeatures. Return value 1.
Action 12:53:19: StopServices. Stopping services
Action start 12:53:19: StopServices.
Action ended 12:53:19: StopServices. Return value 1.
Action 12:53:19: DeleteServices. Deleting services
Action start 12:53:19: DeleteServices.
Action ended 12:53:19: DeleteServices. Return value 1.
Action 12:53:19: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:19: UnregisterComPlus.
Action ended 12:53:19: UnregisterComPlus. Return value 0.
Action 12:53:19: SelfUnregModules. Unregistering modules
Action start 12:53:19: SelfUnregModules.
Action ended 12:53:19: SelfUnregModules. Return value 1.
Action 12:53:19: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:19: UnregisterTypeLibraries.
Action ended 12:53:19: UnregisterTypeLibraries. Return value 0.
Action 12:53:19: RemoveODBC. Removing ODBC components
Action start 12:53:19: RemoveODBC.
Action ended 12:53:19: RemoveODBC. Return value 1.
Action 12:53:19: UnregisterFonts. Unregistering fonts
Action start 12:53:19: UnregisterFonts.
Action ended 12:53:19: UnregisterFonts. Return value 1.
Action 12:53:19: RemoveRegistryValues. Removing system registry values
Action start 12:53:19: RemoveRegistryValues.
Action ended 12:53:19: RemoveRegistryValues. Return value 1.
Action 12:53:19: UnregisterClassInfo. Unregister class servers
Action start 12:53:19: UnregisterClassInfo.
Action ended 12:53:19: UnregisterClassInfo. Return value 0.
Action 12:53:19: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:19: UnregisterExtensionInfo.
Action ended 12:53:19: UnregisterExtensionInfo. Return value 0.
Action 12:53:19: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:19: UnregisterProgIdInfo.
Action ended 12:53:19: UnregisterProgIdInfo. Return value 0.
Action 12:53:19: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:19: UnregisterMIMEInfo.
Action ended 12:53:19: UnregisterMIMEInfo. Return value 0.
Action 12:53:19: RemoveIniValues. Removing INI file entries
Action start 12:53:19: RemoveIniValues.
Action ended 12:53:19: RemoveIniValues. Return value 1.
Action 12:53:19: RemoveShortcuts. Removing shortcuts
Action start 12:53:19: RemoveShortcuts.
Action ended 12:53:19: RemoveShortcuts. Return value 0.
Action 12:53:19: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:19: RemoveEnvironmentStrings.
Action ended 12:53:19: RemoveEnvironmentStrings. Return value 1.
Action 12:53:19: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:19: RemoveDuplicateFiles.
Action ended 12:53:19: RemoveDuplicateFiles. Return value 1.
Action 12:53:19: RemoveFiles. Removing files
Action start 12:53:19: RemoveFiles.
Action ended 12:53:19: RemoveFiles. Return value 0.
Action 12:53:19: RemoveFolders. Removing folders
Action start 12:53:19: RemoveFolders.
Action ended 12:53:19: RemoveFolders. Return value 0.
Action 12:53:19: CreateFolders. Creating folders
Action start 12:53:19: CreateFolders.
Action ended 12:53:19: CreateFolders. Return value 0.
Action 12:53:19: MoveFiles. Moving files
Action start 12:53:19: MoveFiles.
Action ended 12:53:19: MoveFiles. Return value 1.
Action 12:53:19: InstallFiles. Copying new files
Action start 12:53:19: InstallFiles.
Action ended 12:53:19: InstallFiles. Return value 1.
Action 12:53:19: PatchFiles. Patching files
Action start 12:53:19: PatchFiles.
Action ended 12:53:19: PatchFiles. Return value 0.
Action 12:53:19: DuplicateFiles. Creating duplicate files
Action start 12:53:19: DuplicateFiles.
Action ended 12:53:19: DuplicateFiles. Return value 1.
Action 12:53:19: BindImage. Binding executables
Action start 12:53:19: BindImage.
Action ended 12:53:19: BindImage. Return value 1.
Action 12:53:19: CreateShortcuts. Creating shortcuts
Action start 12:53:19: CreateShortcuts.
Action ended 12:53:19: CreateShortcuts. Return value 0.
Action 12:53:19: RegisterClassInfo. Registering class servers
Action start 12:53:19: RegisterClassInfo.
Action ended 12:53:19: RegisterClassInfo. Return value 0.
Action 12:53:19: RegisterExtensionInfo. Registering extension servers
Action start 12:53:19: RegisterExtensionInfo.
Action ended 12:53:19: RegisterExtensionInfo. Return value 0.
Action 12:53:19: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:19: RegisterProgIdInfo.
Action ended 12:53:19: RegisterProgIdInfo. Return value 0.
Action 12:53:19: RegisterMIMEInfo. Registering MIME info
Action start 12:53:19: RegisterMIMEInfo.
Action ended 12:53:19: RegisterMIMEInfo. Return value 0.
Action 12:53:19: WriteRegistryValues. Writing system registry values
Action start 12:53:19: WriteRegistryValues.
Action ended 12:53:19: WriteRegistryValues. Return value 1.
Action 12:53:19: WriteIniValues. Writing INI file values
Action start 12:53:19: WriteIniValues.
Action ended 12:53:19: WriteIniValues. Return value 1.
Action 12:53:19: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:19: WriteEnvironmentStrings.
Action ended 12:53:19: WriteEnvironmentStrings. Return value 1.
Action 12:53:19: RegisterFonts. Registering fonts
Action start 12:53:19: RegisterFonts.
Action ended 12:53:19: RegisterFonts. Return value 1.
Action 12:53:19: InstallODBC. Installing ODBC components
Action start 12:53:19: InstallODBC.
Action ended 12:53:19: InstallODBC. Return value 0.
Action 12:53:19: RegisterTypeLibraries. Registering type libraries
Action start 12:53:19: RegisterTypeLibraries.
Action ended 12:53:19: RegisterTypeLibraries. Return value 0.
Action 12:53:19: SelfRegModules. Registering modules
Action start 12:53:19: SelfRegModules.
Action ended 12:53:19: SelfRegModules. Return value 1.
Action 12:53:19: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:19: RegisterComPlus.
Action ended 12:53:19: RegisterComPlus. Return value 0.
Action 12:53:19: InstallServices. Installing new services
Action start 12:53:19: InstallServices.
Action ended 12:53:19: InstallServices. Return value 1.
Action 12:53:19: StartServices. Starting services
Action start 12:53:19: StartServices.
Action ended 12:53:19: StartServices. Return value 1.
Action 12:53:19: RegisterUser. Registering user
Action start 12:53:19: RegisterUser.
Action ended 12:53:19: RegisterUser. Return value 0.
Action 12:53:19: RegisterProduct. Registering product
Action start 12:53:19: RegisterProduct.
Registering product
Action ended 12:53:19: RegisterProduct. Return value 1.
Action 12:53:19: PublishComponents. Publishing qualified components
Action start 12:53:19: PublishComponents.
Action ended 12:53:19: PublishComponents. Return value 0.
Action 12:53:19: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:19: MsiPublishAssemblies.
Action ended 12:53:19: MsiPublishAssemblies. Return value 1.
Action 12:53:19: PublishFeatures. Publishing product features
Action start 12:53:19: PublishFeatures.
Action ended 12:53:19: PublishFeatures. Return value 1.
Action 12:53:19: PublishProduct. Publishing product information
Action start 12:53:19: PublishProduct.
Action ended 12:53:19: PublishProduct. Return value 1.
Action 12:53:19: InstallFinalize.
Action start 12:53:19: InstallFinalize.
40d7d.msi
Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_ATL_x86_
Action 12:53:19: RollbackCleanup. Removing backup files
File: C:\Config.Msi\35406e.rbf
File: C:\Config.Msi\35406f.rbf
Action ended 12:53:19: InstallFinalize. Return value 1.
Action ended 12:53:19: INSTALL. Return value 1.
Property(S): UpgradeCode = {F31F95D5-E2B6-4984-A9D1-CA5E8CF1BFFE}
Property(S): SourcedirProduct = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
Property(S): Installed = 2009/07/28 04:07:38
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
Property(S): DATABASE = C:\Windows\Installer\354068.msi
Property(S): Time = 12:53:19
Property(S): VirtualMemory = 14362
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_51c97d20bbe8350e\
Property(S): payload.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_35349982\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_f0eecac0f8a1c174\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_9e7eb501\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\
Property(S): ProductCode = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Property(S): ProductName = Microsoft_VC90_ATL_x86
Property(S): DWUSLINK = CEAC70DF2E8BD79FDEACA7FFC98B978FCE1B808FFE0BB73FCE1BE08F4EDCE7AFE9FB809F89AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbB0D2.tmp
Property(S): PackageCode = {BC1C6355-192C-4334-94F9-4A03B0DCB75C}
=== Logging stopped: 13/02/2011 12:53:19 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:20 2011 INFO
:: END TIMER :: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}] took 2028.04 miliseconds (2.02804 seconds)
Calling the custom action code for post-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86
Calling the custom action code for pre-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64}
::START TIMER:: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}]
[ 3656] Sun Feb 13 12:53:20 2011 INFO
Installer Operation: PayloadUninstaller
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6B485102-4593-43F6-BA45-F14D690B0C64}
Effective AdobeCode for: {6B485102-4593-43F6-BA45-F14D690B0C64} is {6B485102-4593-43F6-BA45-F14D690B0C64}
Session includes local copy of payload for repair source
Repair payload source package: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
Extracting assets...
[ 3656] Sun Feb 13 12:53:21 2011 INFO
Extracting assets complete. Number assets: 1
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
[ 3656] Sun Feb 13 12:53:22 2011 INFO
Evaluating condition# 1
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6B485102-4593-43F6-BA45-F14D690B0C64}.db
Physical payload repair result:0
[ 6204] Sun Feb 13 12:53:23 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}] took 3017.88 miliseconds (3.01788 seconds) DTR = 2.65086 KBPS (0.00258873 MBPS)
[ 6204] Sun Feb 13 12:53:24 2011 INFO
Calling the custom action code for post-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5
Calling the custom action code for pre-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
[ 2100] Sun Feb 13 12:53:24 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Effective AdobeCode for: {BD0D6363-E961-410F-8BF4-ECD8795F3923} is {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Repair payload source package: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
[ 2100] Sun Feb 13 12:53:25 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
[ 2100] Sun Feb 13 12:53:34 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
[ 6204] Sun Feb 13 12:53:35 2011 INFO
:: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 11046.7 miliseconds (11.0467 seconds) DTR = 325.888 KBPS (0.31825 MBPS)
Calling the custom action code for post-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
Calling the custom action code for pre-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C}
::START TIMER:: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}]
[ 5460] Sun Feb 13 12:53:35 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6F3A624B-1B72-4081-96E8-23261F389C5C}
[ 5460] Sun Feb 13 12:53:36 2011 INFO
Effective AdobeCode for: {6F3A624B-1B72-4081-96E8-23261F389C5C} is {6F3A624B-1B72-4081-96E8-23261F389C5C}
Repair payload source package: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
[ 5460] Sun Feb 13 12:53:37 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
[ 5460] Sun Feb 13 12:53:38 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
[ 6204] Sun Feb 13 12:53:38 2011 INFO
:: END TIMER :: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}] took 3027.26 miliseconds (3.02726 seconds)
Calling the custom action code for post-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
Calling the custom action code for pre-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
::START TIMER:: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}]
[ 6756] Sun Feb 13 12:53:38 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_ATL_x86.msi, Result: 0
[ 6756] Sun Feb 13 12:53:39 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_ATL_x86\, Result: 0
Configuring MSI ProductCode: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb196.tmp"
=== Logging started: 13/02/2011 12:53:39 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC80_ATL_x86
Action 12:53:39: INSTALL.
Action start 12:53:39: INSTALL.
Action 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action start 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action ended 12:53:39: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action start 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action ended 12:53:39: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action start 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action ended 12:53:39: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action start 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action ended 12:53:39: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
Action 12:53:39: AppSearch. Searching for installed applications
Action start 12:53:39: AppSearch.
Action ended 12:53:39: AppSearch. Return value 0.
Action 12:53:39: FindRelatedProducts. Searching for related applications
Action start 12:53:39: FindRelatedProducts.
Action ended 12:53:39: FindRelatedProducts. Return value 0.
Action 12:53:39: ValidateProductID.
Action start 12:53:39: ValidateProductID.
Action ended 12:53:39: ValidateProductID. Return value 1.
Action 12:53:39: CostInitialize. Computing space requirements
Action start 12:53:39: CostInitialize.
Action ended 12:53:39: CostInitialize. Return value 1.
Action 12:53:39: FileCost. Computing space requirements
Action start 12:53:39: FileCost.
Action ended 12:53:39: FileCost. Return value 1.
Action 12:53:39: IsolateComponents.
Action start 12:53:39: IsolateComponents.
Action ended 12:53:39: IsolateComponents. Return value 0.
Action 12:53:39: CostFinalize. Computing space requirements
Action start 12:53:39: CostFinalize.
Action ended 12:53:39: CostFinalize. Return value 1.
Action 12:53:39: SetODBCFolders. Initializing ODBC directories
Action start 12:53:39: SetODBCFolders.
Action ended 12:53:39: SetODBCFolders. Return value 0.
Action 12:53:39: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:39: MigrateFeatureStates.
Action ended 12:53:39: MigrateFeatureStates. Return value 0.
Action 12:53:39: InstallValidate. Validating install
Action start 12:53:39: InstallValidate.
Action ended 12:53:39: InstallValidate. Return value 1.
Action 12:53:39: RemoveExistingProducts. Removing applications
Action start 12:53:39: RemoveExistingProducts.
Action ended 12:53:39: RemoveExistingProducts. Return value 0.
Action 12:53:39: InstallInitialize.
Action start 12:53:39: InstallInitialize.
Action ended 12:53:39: InstallInitialize. Return value 1.
Action 12:53:39: SxsInstallCA.
Action start 12:53:39: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: uplevel.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 12:53:39: SxsInstallCA. Return value 1.
Action 12:53:39: ProcessComponents. Updating component registration
Action start 12:53:39: ProcessComponents.
Action 12:53:39: GenerateScript. Generating script operations for action:
Action ended 12:53:39: ProcessComponents. Return value 1.
Action 12:53:39: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:39: UnpublishComponents.
Action ended 12:53:39: UnpublishComponents. Return value 0.
Action 12:53:39: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:39: MsiUnpublishAssemblies.
Action ended 12:53:39: MsiUnpublishAssemblies. Return value 1.
Action 12:53:39: UnpublishFeatures. Unpublishing product features
Action start 12:53:39: UnpublishFeatures.
Action ended 12:53:39: UnpublishFeatures. Return value 1.
Action 12:53:39: StopServices. Stopping services
Action start 12:53:39: StopServices.
Action ended 12:53:39: StopServices. Return value 1.
Action 12:53:39: DeleteServices. Deleting services
Action start 12:53:39: DeleteServices.
Action ended 12:53:39: DeleteServices. Return value 1.
Action 12:53:39: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:39: UnregisterComPlus.
Action ended 12:53:39: UnregisterComPlus. Return value 0.
Action 12:53:39: SelfUnregModules. Unregistering modules
Action start 12:53:39: SelfUnregModules.
Action ended 12:53:39: SelfUnregModules. Return value 1.
Action 12:53:39: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:39: UnregisterTypeLibraries.
Action ended 12:53:39: UnregisterTypeLibraries. Return value 0.
Action 12:53:39: RemoveODBC. Removing ODBC components
Action start 12:53:39: RemoveODBC.
Action ended 12:53:39: RemoveODBC. Return value 1.
Action 12:53:39: UnregisterFonts. Unregistering fonts
Action start 12:53:39: UnregisterFonts.
Action ended 12:53:39: UnregisterFonts. Return value 1.
Action 12:53:39: RemoveRegistryValues. Removing system registry values
Action start 12:53:39: RemoveRegistryValues.
Action ended 12:53:39: RemoveRegistryValues. Return value 1.
Action 12:53:39: UnregisterClassInfo. Unregister class servers
Action start 12:53:39: UnregisterClassInfo.
Action ended 12:53:39: UnregisterClassInfo. Return value 0.
Action 12:53:39: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:39: UnregisterExtensionInfo.
Action ended 12:53:39: UnregisterExtensionInfo. Return value 0.
Action 12:53:39: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:39: UnregisterProgIdInfo.
Action ended 12:53:39: UnregisterProgIdInfo. Return value 0.
Action 12:53:39: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:39: UnregisterMIMEInfo.
Action ended 12:53:39: UnregisterMIMEInfo. Return value 0.
Action 12:53:39: RemoveIniValues. Removing INI file entries
Action start 12:53:39: RemoveIniValues.
Action ended 12:53:39: RemoveIniValues. Return value 1.
Action 12:53:39: RemoveShortcuts. Removing shortcuts
Action start 12:53:39: RemoveShortcuts.
Action ended 12:53:39: RemoveShortcuts. Return value 0.
Action 12:53:39: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:39: RemoveEnvironmentStrings.
Action ended 12:53:39: RemoveEnvironmentStrings. Return value 1.
Action 12:53:39: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:39: RemoveDuplicateFiles.
Action ended 12:53:39: RemoveDuplicateFiles. Return value 1.
Action 12:53:39: RemoveFiles. Removing files
Action start 12:53:39: RemoveFiles.
Action ended 12:53:39: RemoveFiles. Return value 0.
Action 12:53:39: RemoveFolders. Removing folders
Action start 12:53:39: RemoveFolders.
Action ended 12:53:39: RemoveFolders. Return value 0.
Action 12:53:39: CreateFolders. Creating folders
Action start 12:53:39: CreateFolders.
Action ended 12:53:39: CreateFolders. Return value 0.
Action 12:53:39: MoveFiles. Moving files
Action start 12:53:39: MoveFiles.
Action ended 12:53:39: MoveFiles. Return value 1.
Action 12:53:39: InstallFiles. Copying new files
Action start 12:53:39: InstallFiles.
[ 6756] Sun Feb 13 12:53:40 2011 INFO
Action ended 12:53:40: InstallFiles. Return value 1.
Action 12:53:40: PatchFiles. Patching files
Action start 12:53:40: PatchFiles.
Action ended 12:53:40: PatchFiles. Return value 0.
Action 12:53:40: DuplicateFiles. Creating duplicate files
Action start 12:53:40: DuplicateFiles.
Action ended 12:53:40: DuplicateFiles. Return value 1.
Action 12:53:40: BindImage. Binding executables
Action start 12:53:40: BindImage.
Action ended 12:53:40: BindImage. Return value 1.
Action 12:53:40: CreateShortcuts. Creating shortcuts
Action start 12:53:40: CreateShortcuts.
Action ended 12:53:40: CreateShortcuts. Return value 0.
Action 12:53:40: RegisterClassInfo. Registering class servers
Action start 12:53:40: RegisterClassInfo.
Action ended 12:53:40: RegisterClassInfo. Return value 0.
Action 12:53:40: RegisterExtensionInfo. Registering extension servers
Action start 12:53:40: RegisterExtensionInfo.
Action ended 12:53:40: RegisterExtensionInfo. Return value 0.
Action 12:53:40: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:40: RegisterProgIdInfo.
Action ended 12:53:40: RegisterProgIdInfo. Return value 0.
Action 12:53:40: RegisterMIMEInfo. Registering MIME info
Action start 12:53:40: RegisterMIMEInfo.
Action ended 12:53:40: RegisterMIMEInfo. Return value 0.
Action 12:53:40: WriteRegistryValues. Writing system registry values
Action start 12:53:40: WriteRegistryValues.
Action ended 12:53:40: WriteRegistryValues. Return value 1.
Action 12:53:40: WriteIniValues. Writing INI file values
Action start 12:53:40: WriteIniValues.
Action ended 12:53:40: WriteIniValues. Return value 1.
Action 12:53:40: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:40: WriteEnvironmentStrings.
Action ended 12:53:40: WriteEnvironmentStrings. Return value 1.
Action 12:53:40: RegisterFonts. Registering fonts
Action start 12:53:40: RegisterFonts.
Action ended 12:53:40: RegisterFonts. Return value 1.
Action 12:53:40: InstallODBC. Installing ODBC components
Action start 12:53:40: InstallODBC.
Action ended 12:53:40: InstallODBC. Return value 0.
Action 12:53:40: RegisterTypeLibraries. Registering type libraries
Action start 12:53:40: RegisterTypeLibraries.
Action ended 12:53:40: RegisterTypeLibraries. Return value 0.
Action 12:53:40: SelfRegModules. Registering modules
Action start 12:53:40: SelfRegModules.
Action ended 12:53:40: SelfRegModules. Return value 1.
Action 12:53:40: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:40: RegisterComPlus.
Action ended 12:53:40: RegisterComPlus. Return value 0.
Action 12:53:40: InstallServices. Installing new services
Action start 12:53:40: InstallServices.
Action ended 12:53:40: InstallServices. Return value 1.
Action 12:53:40: StartServices. Starting services
Action start 12:53:40: StartServices.
Action ended 12:53:40: StartServices. Return value 1.
Action 12:53:40: RegisterUser. Registering user
Action start 12:53:40: RegisterUser.
Action ended 12:53:40: RegisterUser. Return value 0.
Action 12:53:40: RegisterProduct. Registering product
Action start 12:53:40: RegisterProduct.
Registering product
Action ended 12:53:40: RegisterProduct. Return value 1.
Action 12:53:40: PublishComponents. Publishing qualified components
Action start 12:53:40: PublishComponents.
Action ended 12:53:40: PublishComponents. Return value 0.
Action 12:53:40: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:40: MsiPublishAssemblies.
Action ended 12:53:40: MsiPublishAssemblies. Return value 1.
Action 12:53:40: PublishFeatures. Publishing product features
Action start 12:53:40: PublishFeatures.
Action ended 12:53:40: PublishFeatures. Return value 1.
Action 12:53:40: PublishProduct. Publishing product information
Action start 12:53:40: PublishProduct.
Action ended 12:53:40: PublishProduct. Return value 1.
Action 12:53:40: InstallFinalize.
Action start 12:53:40: InstallFinalize.
Action 12:53:40: ProcessComponents. Updating component registration
Action 12:53:40: RemoveODBC. Removing ODBC components
Action 12:53:40: InstallFiles. Copying new files
40d86.msi
[ 6756] Sun Feb 13 12:53:41 2011 INFO
Action 12:53:41: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC80.ATL,type="win32",version="8.0.50727.4053",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.ATL,type="win32-policy",version="8.0.50727.4053",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Action 12:53:41: PublishFeatures. Publishing product features
Feature: Microsoft_VC80_ATL_x86_
Action 12:53:41: PublishProduct. Publishing product information
Action 12:53:41: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354077.rbf
File: C:\Config.Msi\354078.rbf
Action ended 12:53:41: InstallFinalize. Return value 1.
Action ended 12:53:41: INSTALL. Return value 1.
Property(S): SourcedirProduct = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
Property(S): UpgradeCode = {B42842E9-F9F7-4A0F-A616-857958BC88BF}
Property(S): Installed = 2009/11/13 01:34:20
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
Property(S): DATABASE = C:\Windows\Installer\354071.msi
Property(S): Time = 12:53:41
Property(S): VirtualMemory = 14350
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
Property(S): WinSxsDirectory.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d1c738ec43578ea1\
Property(S): payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_6e805841\
Property(S): WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_6e845944\
Property(S): payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_6e85597e\
Property(S): payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_6e85597d\
Property(S): policydir.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): ANSIFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_6e85597f\
Property(S): policydir.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_6e855980\
Property(S): payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_6e855983\
Property(S): payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_6e855981\
Property(S): payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_6e855982\
Property(S): payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_c8b815f2\
Property(S): payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_c8b815f3\
Property(S): policydir.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_c8b815f6\
Property(S): payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_c8b815f5\
Property(S): policydir.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_c8c1182c\
Property(S): payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_18ae9600\
Property(S): payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_c9392638\
Property(S): payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_18b09683\
Property(S): policydir.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_18af963c\
Property(S): payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_47336645\
Property(S): payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_47336644\
Property(S): payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_bf90704a\
Property(S): policydir_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
Property(S): payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_47336646\
Property(S): payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
Property(S): policydir.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_473566c0\
Property(S): payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_473666fc\
Property(S): policydir.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): WinSxsDirectory.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_4ddfc6cd11929a02\
Property(S): WinSxsPolicies.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_b2841548\
Property(S): policydir.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_8b3a2404\
Property(S): policydir.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_b2891685\
Property(S): policydir.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_b288164b\
Property(S): policydir.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_b2891684\
Property(S): policydir.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_b2891686\
Property(S): policydir.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_b2891687\
Property(S): policydir.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_b2891688\
Property(S): policydir.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_b2891689\
Property(S): policydir.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_b289168a\
Property(S): policydir.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_0cbbd2f9\
Property(S): payload.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_0cbbd2fa\
Property(S): policydir.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_0cbbd2fc\
Property(S): payload.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_0cbbd2fd\
Property(S): policydir.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_0cc4d533\
Property(S): policydir.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_0d3ce33f\
Property(S): payload.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_5cb25307\
Property(S): payload.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_5cb35343\
Property(S): payload.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_5cb4538a\
Property(S): payload.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_03942d51\
Property(S): payload.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_8b37234b\
Property(S): payload.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_8b37234c\
Property(S): payload.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_8b37234d\
Property(S): payload.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_8b3923c7\
Property(S): payload.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_8b3a2403\
Property(S): payload.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_8b3a2404\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC80_ATL_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = No
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CE0B90581E3CF05FFEAC57B89EEC978F9EDC508F591B0798CEABF7DFDEAB57D8FE1C47B8D9AC
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): MsiSystemRebootPending = 1
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 5888
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb196.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {3C0DD3C2-B6EC-46C4-8544-00189BC45D86}
=== Logging stopped: 13/02/2011 12:53:41 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:41 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}] took 3023.4 miliseconds (3.0234 seconds) DTR = 23.8142 KBPS (0.0232561 MBPS)
User specified overrideFile:
[ 6204] Sun Feb 13 12:53:42 2011 INFO
Calling the custom action code for post-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86
Calling the custom action code for pre-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C}
::START TIMER:: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}]
[ 3380] Sun Feb 13 12:53:42 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {A8798E04-96FF-4564-9157-0D4C89CB794C}
Effective AdobeCode for: {A8798E04-96FF-4564-9157-0D4C89CB794C} is {A8798E04-96FF-4564-9157-0D4C89CB794C}
Repair payload source package: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
[ 3380] Sun Feb 13 12:53:43 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
Completing installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A8798E04-96FF-4564-9157-0D4C89CB794C}.db
[ 6204] Sun Feb 13 12:53:44 2011 INFO
:: END TIMER :: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}] took 2024.29 miliseconds (2.02429 seconds) DTR = 825.967 KBPS (0.806608 MBPS)
Calling the custom action code for post-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
Calling the custom action code for pre-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
::START TIMER:: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}]
[ 1300] Sun Feb 13 12:53:44 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86_x64.msi, Result: 0
Payload exists on removable media: E:\
[ 1300] Sun Feb 13 12:53:45 2011 INFO
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\, Result: 0
Configuring MSI ProductCode: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb19D8.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 12:53:45 ===
Message type: 1, Argument: Microsoft_VC90_CRT_x86_x64
Action 12:53:45: INSTALL.
Action start 12:53:45: INSTALL.
Action 12:53:45: AppSearch. Searching for installed applications
Action start 12:53:45: AppSearch.
Action ended 12:53:45: AppSearch. Return value 0.
Action 12:53:45: FindRelatedProducts. Searching for related applications
Action start 12:53:45: FindRelatedProducts.
Action ended 12:53:45: FindRelatedProducts. Return value 0.
Action 12:53:45: ValidateProductID.
Action start 12:53:45: ValidateProductID.
Action ended 12:53:45: ValidateProductID. Return value 1.
Action 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action start 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action ended 12:53:45: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812. Return value 1.
Action 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action start 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action ended 12:53:45: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B. Return value 1.
Action 12:53:45: CostInitialize. Computing space requirements
Action start 12:53:45: CostInitialize.
Action ended 12:53:45: CostInitialize. Return value 1.
Action 12:53:45: FileCost. Computing space requirements
Action start 12:53:45: FileCost.
Action ended 12:53:45: FileCost. Return value 1.
Action 12:53:45: IsolateComponents.
Action start 12:53:45: IsolateComponents.
Action ended 12:53:45: IsolateComponents. Return value 0.
Action 12:53:45: CostFinalize. Computing space requirements
Action start 12:53:45: CostFinalize.
Action ended 12:53:45: CostFinalize. Return value 1.
Action 12:53:45: SetODBCFolders. Initializing ODBC directories
Action start 12:53:45: SetODBCFolders.
Action ended 12:53:45: SetODBCFolders. Return value 0.
Action 12:53:45: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:45: MigrateFeatureStates.
Action ended 12:53:45: MigrateFeatureStates. Return value 0.
Action 12:53:45: InstallValidate. Validating install
Action start 12:53:45: InstallValidate.
Action ended 12:53:45: InstallValidate. Return value 1.
Action 12:53:45: RemoveExistingProducts. Removing applications
Action start 12:53:45: RemoveExistingProducts.
Action ended 12:53:45: RemoveExistingProducts. Return value 0.
Action 12:53:45: InstallInitialize.
Action start 12:53:45: InstallInitialize.
[ 1300] Sun Feb 13 12:53:46 2011 INFO
Action ended 12:53:46: InstallInitialize. Return value 1.
Action 12:53:46: ProcessComponents. Updating component registration
Action start 12:53:46: ProcessComponents.
Action 12:53:46: GenerateScript. Generating script operations for action:
Action ended 12:53:46: ProcessComponents. Return value 1.
Action 12:53:46: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:46: UnpublishComponents.
Action ended 12:53:46: UnpublishComponents. Return value 0.
Action 12:53:46: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:46: MsiUnpublishAssemblies.
Action ended 12:53:46: MsiUnpublishAssemblies. Return value 1.
Action 12:53:46: UnpublishFeatures. Unpublishing product features
Action start 12:53:46: UnpublishFeatures.
Action ended 12:53:46: UnpublishFeatures. Return value 1.
Action 12:53:46: StopServices. Stopping services
Action start 12:53:46: StopServices.
Action ended 12:53:46: StopServices. Return value 1.
Action 12:53:46: DeleteServices. Deleting services
Action start 12:53:46: DeleteServices.
Action ended 12:53:46: DeleteServices. Return value 1.
Action 12:53:46: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:46: UnregisterComPlus.
Action ended 12:53:46: UnregisterComPlus. Return value 0.
Action 12:53:46: SelfUnregModules. Unregistering modules
Action start 12:53:46: SelfUnregModules.
Action ended 12:53:46: SelfUnregModules. Return value 1.
Action 12:53:46: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:46: UnregisterTypeLibraries.
Action ended 12:53:46: UnregisterTypeLibraries. Return value 0.
Action 12:53:46: RemoveODBC. Removing ODBC components
Action start 12:53:46: RemoveODBC.
Action ended 12:53:46: RemoveODBC. Return value 1.
Action 12:53:46: UnregisterFonts. Unregistering fonts
Action start 12:53:46: UnregisterFonts.
Action ended 12:53:46: UnregisterFonts. Return value 1.
Action 12:53:46: RemoveRegistryValues. Removing system registry values
Action start 12:53:46: RemoveRegistryValues.
Action ended 12:53:46: RemoveRegistryValues. Return value 1.
Action 12:53:46: UnregisterClassInfo. Unregister class servers
Action start 12:53:46: UnregisterClassInfo.
Action ended 12:53:46: UnregisterClassInfo. Return value 0.
Action 12:53:46: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:46: UnregisterExtensionInfo.
Action ended 12:53:46: UnregisterExtensionInfo. Return value 0.
Action 12:53:46: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:46: UnregisterProgIdInfo.
Action ended 12:53:46: UnregisterProgIdInfo. Return value 0.
Action 12:53:46: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:46: UnregisterMIMEInfo.
Action ended 12:53:46: UnregisterMIMEInfo. Return value 0.
Action 12:53:46: RemoveIniValues. Removing INI file entries
Action start 12:53:46: RemoveIniValues.
Action ended 12:53:46: RemoveIniValues. Return value 1.
Action 12:53:46: RemoveShortcuts. Removing shortcuts
Action start 12:53:46: RemoveShortcuts.
Action ended 12:53:46: RemoveShortcuts. Return value 0.
Action 12:53:46: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:46: RemoveEnvironmentStrings.
Action ended 12:53:46: RemoveEnvironmentStrings. Return value 1.
Action 12:53:46: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:46: RemoveDuplicateFiles.
Action ended 12:53:46: RemoveDuplicateFiles. Return value 1.
Action 12:53:46: RemoveFiles. Removing files
Action start 12:53:46: RemoveFiles.
Action ended 12:53:46: RemoveFiles. Return value 0.
Action 12:53:46: RemoveFolders. Removing folders
Action start 12:53:46: RemoveFolders.
Action ended 12:53:46: RemoveFolders. Return value 0.
Action 12:53:46: CreateFolders. Creating folders
Action start 12:53:46: CreateFolders.
Action ended 12:53:46: CreateFolders. Return value 0.
Action 12:53:46: MoveFiles. Moving files
Action start 12:53:46: MoveFiles.
Action ended 12:53:46: MoveFiles. Return value 1.
Action 12:53:46: InstallFiles. Copying new files
Action start 12:53:46: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 12:53:46: InstallFiles. Return value 1.
Action 12:53:46: PatchFiles. Patching files
Action start 12:53:46: PatchFiles.
Action ended 12:53:46: PatchFiles. Return value 0.
Action 12:53:46: DuplicateFiles. Creating duplicate files
Action start 12:53:46: DuplicateFiles.
Action ended 12:53:46: DuplicateFiles. Return value 1.
Action 12:53:46: BindImage. Binding executables
Action start 12:53:46: BindImage.
Action ended 12:53:46: BindImage. Return value 1.
Action 12:53:46: CreateShortcuts. Creating shortcuts
Action start 12:53:46: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 12:53:46: CreateShortcuts. Return value 0.
Action 12:53:46: RegisterClassInfo. Registering class servers
Action start 12:53:46: RegisterClassInfo.
Action ended 12:53:46: RegisterClassInfo. Return value 0.
Action 12:53:46: RegisterExtensionInfo. Registering extension servers
Action start 12:53:46: RegisterExtensionInfo.
Action ended 12:53:46: RegisterExtensionInfo. Return value 0.
Action 12:53:46: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:46: RegisterProgIdInfo.
Action ended 12:53:46: RegisterProgIdInfo. Return value 0.
Action 12:53:46: RegisterMIMEInfo. Registering MIME info
Action start 12:53:46: RegisterMIMEInfo.
Action ended 12:53:46: RegisterMIMEInfo. Return value 0.
Action 12:53:46: WriteRegistryValues. Writing system registry values
Action start 12:53:46: WriteRegistryValues.
Action ended 12:53:46: WriteRegistryValues. Return value 1.
Action 12:53:46: WriteIniValues. Writing INI file values
Action start 12:53:46: WriteIniValues.
Action ended 12:53:46: WriteIniValues. Return value 1.
Action 12:53:46: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:46: WriteEnvironmentStrings.
Action ended 12:53:46: WriteEnvironmentStrings. Return value 1.
Action 12:53:46: RegisterFonts. Registering fonts
Action start 12:53:46: RegisterFonts.
Action ended 12:53:46: RegisterFonts. Return value 1.
Action 12:53:46: InstallODBC. Installing ODBC components
Action start 12:53:46: InstallODBC.
Action ended 12:53:46: InstallODBC. Return value 0.
Action 12:53:46: RegisterTypeLibraries. Registering type libraries
Action start 12:53:46: RegisterTypeLibraries.
Action ended 12:53:46: RegisterTypeLibraries. Return value 0.
Action 12:53:46: SelfRegModules. Registering modules
Action start 12:53:46: SelfRegModules.
Action ended 12:53:46: SelfRegModules. Return value 1.
Action 12:53:46: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:46: RegisterComPlus.
Action ended 12:53:46: RegisterComPlus. Return value 0.
Action 12:53:46: InstallServices. Installing new services
Action start 12:53:46: InstallServices.
Action ended 12:53:46: InstallServices. Return value 1.
Action 12:53:46: StartServices. Starting services
Action start 12:53:46: StartServices.
Action ended 12:53:46: StartServices. Return value 1.
Action 12:53:46: RegisterUser. Registering user
Action start 12:53:46: RegisterUser.
Action ended 12:53:46: RegisterUser. Return value 0.
Action 12:53:46: RegisterProduct. Registering product
Action start 12:53:46: RegisterProduct.
Registering product
Action ended 12:53:46: RegisterProduct. Return value 1.
Action 12:53:46: PublishComponents. Publishing qualified components
Action start 12:53:46: PublishComponents.
Action ended 12:53:46: PublishComponents. Return value 0.
Action 12:53:46: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:46: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 12:53:46: MsiPublishAssemblies. Return value 1.
Action 12:53:46: PublishFeatures. Publishing product features
Action start 12:53:46: PublishFeatures.
Feature: Publishing product features
Action ended 12:53:46: PublishFeatures. Return value 1.
Action 12:53:46: PublishProduct. Publishing product information
Action start 12:53:46: PublishProduct.
Action ended 12:53:46: PublishProduct. Return value 1.
Action 12:53:46: InstallFinalize.
Action start 12:53:46: InstallFinalize.
Message type: 0, Argument: 0
Shortcut: ARPPRODUCTICON.exe
40d8f.msi
Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_CRT_x86_
Message type: 2, Argument: 0
Action 12:53:46: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354080.rbf
File: C:\Config.Msi\354081.rbf
Message type: 2, Argument: 1
Action ended 12:53:46: InstallFinalize. Return value 1.
Action ended 12:53:46: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {54AE2BD2-7685-4215-9490-3BBF14C2BBB4}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
Property(S): SourcedirProduct = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): Installed = 2009/03/11 04:02:22
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\35407a.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
[ 1300] Sun Feb 13 12:53:47 2011 INFO
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 12:53:47
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371c1d4\
Property(S): payload.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_a17e7c1e\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): policydir_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_3da38fdebd0e6822\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3e195\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\
Property(S): ProductCode = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): ProductName = Microsoft_VC90_CRT_x86_x64
Property(S): ProductVersion = 1.00.0000
Property(S): DWUSLINK = CE1C879F4EDBE0A8A9ACB06F8E0B978FAE9CF08F598C9758CE1CB08FFE8CF0C8AE8CF0EF8EAC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): PRODUCTLANGUAGE = 0
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb19D8.tmp
Property(S): PackageCode = {EBEBD87C-43F1-4673-9D38-D8BA645AA1C5}
=== Logging stopped: 13/02/2011 12:53:47 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:47 2011 INFO
:: END TIMER :: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}] took 3014.58 miliseconds (3.01458 seconds)
[ 6204] Sun Feb 13 12:53:48 2011 INFO
Calling the custom action code for post-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64
Calling the custom action code for pre-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593}
::START TIMER:: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}]
[ 6544] Sun Feb 13 12:53:48 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86_x64.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\, Result: 0
Configuring MSI ProductCode: {8557397C-A42D-486F-97B3-A2CBC2372593}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb261A.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 12:53:48 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC90_ATL_x86_x64
Action 12:53:48: INSTALL.
Action start 12:53:48: INSTALL.
Action 12:53:48: AppSearch. Searching for installed applications
Action start 12:53:48: AppSearch.
Action ended 12:53:48: AppSearch. Return value 0.
Action 12:53:48: FindRelatedProducts. Searching for related applications
Action start 12:53:48: FindRelatedProducts.
Action ended 12:53:48: FindRelatedProducts. Return value 0.
Action 12:53:48: ValidateProductID.
Action start 12:53:48: ValidateProductID.
Action ended 12:53:48: ValidateProductID. Return value 1.
Action 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action start 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action ended 12:53:48: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C. Return value 1.
Action 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action start 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action ended 12:53:48: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479. Return value 1.
Action 12:53:48: CostInitialize. Computing space requirements
Action start 12:53:48: CostInitialize.
Action ended 12:53:48: CostInitialize. Return value 1.
Action 12:53:48: FileCost. Computing space requirements
Action start 12:53:48: FileCost.
Action ended 12:53:48: FileCost. Return value 1.
Action 12:53:48: IsolateComponents.
Action start 12:53:48: IsolateComponents.
Action ended 12:53:48: IsolateComponents. Return value 0.
Action 12:53:48: CostFinalize. Computing space requirements
Action start 12:53:48: CostFinalize.
Action ended 12:53:48: CostFinalize. Return value 1.
Action 12:53:48: SetODBCFolders. Initializing ODBC directories
Action start 12:53:48: SetODBCFolders.
Action ended 12:53:48: SetODBCFolders. Return value 0.
Action 12:53:48: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:48: MigrateFeatureStates.
Action ended 12:53:48: MigrateFeatureStates. Return value 0.
Action 12:53:48: InstallValidate. Validating install
Action start 12:53:48: InstallValidate.
Action ended 12:53:48: InstallValidate. Return value 1.
Action 12:53:48: RemoveExistingProducts. Removing applications
Action start 12:53:48: RemoveExistingProducts.
Action ended 12:53:48: RemoveExistingProducts. Return value 0.
Action 12:53:48: InstallInitialize.
Action start 12:53:48: InstallInitialize.
Action ended 12:53:48: InstallInitialize. Return value 1.
Action 12:53:48: ProcessComponents. Updating component registration
Action start 12:53:48: ProcessComponents.
Action 12:53:48: GenerateScript. Generating script operations for action:
Action ended 12:53:48: ProcessComponents. Return value 1.
Action 12:53:48: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:48: UnpublishComponents.
Action ended 12:53:48: UnpublishComponents. Return value 0.
Action 12:53:48: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:48: MsiUnpublishAssemblies.
Action ended 12:53:48: MsiUnpublishAssemblies. Return value 1.
Action 12:53:48: UnpublishFeatures. Unpublishing product features
Action start 12:53:48: UnpublishFeatures.
Action ended 12:53:48: UnpublishFeatures. Return value 1.
Action 12:53:48: StopServices. Stopping services
Action start 12:53:48: StopServices.
Action ended 12:53:48: StopServices. Return value 1.
Action 12:53:48: DeleteServices. Deleting services
Action start 12:53:48: DeleteServices.
Action ended 12:53:48: DeleteServices. Return value 1.
Action 12:53:48: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:48: UnregisterComPlus.
Action ended 12:53:48: UnregisterComPlus. Return value 0.
Action 12:53:48: SelfUnregModules. Unregistering modules
Action start 12:53:48: SelfUnregModules.
Action ended 12:53:48: SelfUnregModules. Return value 1.
Action 12:53:48: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:48: UnregisterTypeLibraries.
Action ended 12:53:48: UnregisterTypeLibraries. Return value 0.
Action 12:53:48: RemoveODBC. Removing ODBC components
Action start 12:53:48: RemoveODBC.
Action ended 12:53:48: RemoveODBC. Return value 1.
Action 12:53:48: UnregisterFonts. Unregistering fonts
Action start 12:53:48: UnregisterFonts.
Action ended 12:53:48: UnregisterFonts. Return value 1.
Action 12:53:48: RemoveRegistryValues. Removing system registry values
Action start 12:53:48: RemoveRegistryValues.
Action ended 12:53:48: RemoveRegistryValues. Return value 1.
Action 12:53:48: UnregisterClassInfo. Unregister class servers
Action start 12:53:48: UnregisterClassInfo.
Action ended 12:53:48: UnregisterClassInfo. Return value 0.
Action 12:53:48: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:48: UnregisterExtensionInfo.
Action ended 12:53:48: UnregisterExtensionInfo. Return value 0.
[ 6544] Sun Feb 13 12:53:49 2011 INFO
Action 12:53:49: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:49: UnregisterProgIdInfo.
Action ended 12:53:49: UnregisterProgIdInfo. Return value 0.
Action 12:53:49: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:49: UnregisterMIMEInfo.
Action ended 12:53:49: UnregisterMIMEInfo. Return value 0.
Action 12:53:49: RemoveIniValues. Removing INI file entries
Action start 12:53:49: RemoveIniValues.
Action ended 12:53:49: RemoveIniValues. Return value 1.
Action 12:53:49: RemoveShortcuts. Removing shortcuts
Action start 12:53:49: RemoveShortcuts.
Action ended 12:53:49: RemoveShortcuts. Return value 0.
Action 12:53:49: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:49: RemoveEnvironmentStrings.
Action ended 12:53:49: RemoveEnvironmentStrings. Return value 1.
Action 12:53:49: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:49: RemoveDuplicateFiles.
Action ended 12:53:49: RemoveDuplicateFiles. Return value 1.
Action 12:53:49: RemoveFiles. Removing files
Action start 12:53:49: RemoveFiles.
Action ended 12:53:49: RemoveFiles. Return value 0.
Action 12:53:49: RemoveFolders. Removing folders
Action start 12:53:49: RemoveFolders.
Action ended 12:53:49: RemoveFolders. Return value 0.
Action 12:53:49: CreateFolders. Creating folders
Action start 12:53:49: CreateFolders.
Action ended 12:53:49: CreateFolders. Return value 0.
Action 12:53:49: MoveFiles. Moving files
Action start 12:53:49: MoveFiles.
Action ended 12:53:49: MoveFiles. Return value 1.
Action 12:53:49: InstallFiles. Copying new files
Action start 12:53:49: InstallFiles.
Action ended 12:53:49: InstallFiles. Return value 1.
Action 12:53:49: PatchFiles. Patching files
Action start 12:53:49: PatchFiles.
Action ended 12:53:49: PatchFiles. Return value 0.
Action 12:53:49: DuplicateFiles. Creating duplicate files
Action start 12:53:49: DuplicateFiles.
Action ended 12:53:49: DuplicateFiles. Return value 1.
Action 12:53:49: BindImage. Binding executables
Action start 12:53:49: BindImage.
Action ended 12:53:49: BindImage. Return value 1.
Action 12:53:49: CreateShortcuts. Creating shortcuts
Action start 12:53:49: CreateShortcuts.
Action ended 12:53:49: CreateShortcuts. Return value 0.
Action 12:53:49: RegisterClassInfo. Registering class servers
Action start 12:53:49: RegisterClassInfo.
Action ended 12:53:49: RegisterClassInfo. Return value 0.
Action 12:53:49: RegisterExtensionInfo. Registering extension servers
Action start 12:53:49: RegisterExtensionInfo.
Action ended 12:53:49: RegisterExtensionInfo. Return value 0.
Action 12:53:49: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:49: RegisterProgIdInfo.
Action ended 12:53:49: RegisterProgIdInfo. Return value 0.
Action 12:53:49: RegisterMIMEInfo. Registering MIME info
Action start 12:53:49: RegisterMIMEInfo.
Action ended 12:53:49: RegisterMIMEInfo. Return value 0.
Action 12:53:49: WriteRegistryValues. Writing system registry values
Action start 12:53:49: WriteRegistryValues.
Action ended 12:53:49: WriteRegistryValues. Return value 1.
Action 12:53:49: WriteIniValues. Writing INI file values
Action start 12:53:49: WriteIniValues.
Action ended 12:53:49: WriteIniValues. Return value 1.
Action 12:53:49: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:49: WriteEnvironmentStrings.
Action ended 12:53:49: WriteEnvironmentStrings. Return value 1.
Action 12:53:49: RegisterFonts. Registering fonts
Action start 12:53:49: RegisterFonts.
Action ended 12:53:49: RegisterFonts. Return value 1.
Action 12:53:49: InstallODBC. Installing ODBC components
Action start 12:53:49: InstallODBC.
Action ended 12:53:49: InstallODBC. Return value 0.
Action 12:53:49: RegisterTypeLibraries. Registering type libraries
Action start 12:53:49: RegisterTypeLibraries.
Action ended 12:53:49: RegisterTypeLibraries. Return value 0.
Action 12:53:49: SelfRegModules. Registering modules
Action start 12:53:49: SelfRegModules.
Action ended 12:53:49: SelfRegModules. Return value 1.
Action 12:53:49: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:49: RegisterComPlus.
Action ended 12:53:49: RegisterComPlus. Return value 0.
Action 12:53:49: InstallServices. Installing new services
Action start 12:53:49: InstallServices.
Action ended 12:53:49: InstallServices. Return value 1.
Action 12:53:49: StartServices. Starting services
Action start 12:53:49: StartServices.
Action ended 12:53:49: StartServices. Return value 1.
Action 12:53:49: RegisterUser. Registering user
Action start 12:53:49: RegisterUser.
Action ended 12:53:49: RegisterUser. Return value 0.
Action 12:53:49: RegisterProduct. Registering product
Action start 12:53:49: RegisterProduct.
Registering product
Action ended 12:53:49: RegisterProduct. Return value 1.
Action 12:53:49: PublishComponents. Publishing qualified components
Action start 12:53:49: PublishComponents.
Action ended 12:53:49: PublishComponents. Return value 0.
Action 12:53:49: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:49: MsiPublishAssemblies.
Action ended 12:53:49: MsiPublishAssemblies. Return value 1.
Action 12:53:49: PublishFeatures. Publishing product features
Action start 12:53:49: PublishFeatures.
Action ended 12:53:49: PublishFeatures. Return value 1.
Action 12:53:49: PublishProduct. Publishing product information
Action start 12:53:49: PublishProduct.
Action ended 12:53:49: PublishProduct. Return value 1.
Action 12:53:49: InstallFinalize.
Action start 12:53:49: InstallFinalize.
Action 12:53:49: ProcessComponents. Updating component registration
Action 12:53:49: RemoveODBC. Removing ODBC components
40d98.msi
Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_ATL_x86_
Action 12:53:49: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354089.rbf
File: C:\Config.Msi\35408a.rbf
Action ended 12:53:49: InstallFinalize. Return value 1.
Action ended 12:53:49: INSTALL. Return value 1.
Property(S): UpgradeCode = {B178CFE7-E127-4205-991D-147FA189D61F}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): SourcedirProduct = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): Installed = 2009/03/11 03:58:08
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\354083.msi
Property(S): Time = 12:53:49
Property(S): VirtualMemory = 14349
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_9aefdaaa829eb818\
Property(S): payload.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_021e6992\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): policydir_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_3a15284abf58447e\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe3d5721\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\
Property(S): ProductCode = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): ProductName = Microsoft_VC90_ATL_x86_x64
Property(S): DWUSLINK = CEFCF71FEE8B30FFC9ACD09FCEDB978F9E9B078F69FC00D8CE9B17F8C9CBF7D899AC806FE9AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb261A.tmp
Property(S): PackageCode = {60C47539-11AA-4C6D-BA88-692C748A2ABC}
=== Logging stopped: 13/02/2011 12:53:49 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:50 2011 INFO
:: END TIMER :: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}] took 2030.72 miliseconds (2.03072 seconds)
Calling the custom action code for post-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64
Calling the custom action code for pre-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
::START TIMER:: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}]
[ 4016] Sun Feb 13 12:53:50 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86_x64.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\, Result: 0
Configuring MSI ProductCode: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb2EC3.tmp"
[ 4016] Sun Feb 13 12:53:51 2011 INFO
1: 0 2: 0 3: 1252
[ 4016] Sun Feb 13 12:53:52 2011 INFO
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 12:53:52 ===
Message type: 1, Argument: Microsoft_VC90_MFC_x86_x64
Action 12:53:52: INSTALL.
Action start 12:53:52: INSTALL.
Action 12:53:52: AppSearch. Searching for installed applications
Action start 12:53:52: AppSearch.
Action ended 12:53:52: AppSearch. Return value 0.
Action 12:53:52: FindRelatedProducts. Searching for related applications
Action start 12:53:52: FindRelatedProducts.
Action ended 12:53:52: FindRelatedProducts. Return value 0.
Action 12:53:52: ValidateProductID.
Action start 12:53:52: ValidateProductID.
Action ended 12:53:52: ValidateProductID. Return value 1.
Action 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action start 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action ended 12:53:52: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436. Return value 1.
Action 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action start 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action ended 12:53:52: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7. Return value 1.
Action 12:53:52: CostInitialize. Computing space requirements
Action start 12:53:52: CostInitialize.
Action ended 12:53:52: CostInitialize. Return value 1.
Action 12:53:52: FileCost. Computing space requirements
Action start 12:53:52: FileCost.
Action ended 12:53:52: FileCost. Return value 1.
Action 12:53:52: IsolateComponents.
Action start 12:53:52: IsolateComponents.
Action ended 12:53:52: IsolateComponents. Return value 0.
Action 12:53:52: CostFinalize. Computing space requirements
Action start 12:53:52: CostFinalize.
Action ended 12:53:52: CostFinalize. Return value 1.
Action 12:53:52: SetODBCFolders. Initializing ODBC directories
Action start 12:53:52: SetODBCFolders.
Action ended 12:53:52: SetODBCFolders. Return value 0.
Action 12:53:52: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:53:52: MigrateFeatureStates.
Action ended 12:53:52: MigrateFeatureStates. Return value 0.
Action 12:53:52: InstallValidate. Validating install
Action start 12:53:52: InstallValidate.
Action ended 12:53:52: InstallValidate. Return value 1.
Action 12:53:52: RemoveExistingProducts. Removing applications
Action start 12:53:52: RemoveExistingProducts.
Action ended 12:53:52: RemoveExistingProducts. Return value 0.
Action 12:53:52: InstallInitialize.
Action start 12:53:52: InstallInitialize.
Action ended 12:53:52: InstallInitialize. Return value 1.
Action 12:53:52: ProcessComponents. Updating component registration
Action start 12:53:52: ProcessComponents.
Action 12:53:52: GenerateScript. Generating script operations for action:
Action ended 12:53:52: ProcessComponents. Return value 1.
Action 12:53:52: UnpublishComponents. Unpublishing Qualified Components
Action start 12:53:52: UnpublishComponents.
Action ended 12:53:52: UnpublishComponents. Return value 0.
Action 12:53:52: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 12:53:52: MsiUnpublishAssemblies.
Action ended 12:53:52: MsiUnpublishAssemblies. Return value 1.
Action 12:53:52: UnpublishFeatures. Unpublishing product features
Action start 12:53:52: UnpublishFeatures.
Action ended 12:53:52: UnpublishFeatures. Return value 1.
Action 12:53:52: StopServices. Stopping services
Action start 12:53:52: StopServices.
Action ended 12:53:52: StopServices. Return value 1.
Action 12:53:52: DeleteServices. Deleting services
Action start 12:53:52: DeleteServices.
Action ended 12:53:52: DeleteServices. Return value 1.
Action 12:53:52: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:53:52: UnregisterComPlus.
Action ended 12:53:52: UnregisterComPlus. Return value 0.
Action 12:53:52: SelfUnregModules. Unregistering modules
Action start 12:53:52: SelfUnregModules.
Action ended 12:53:52: SelfUnregModules. Return value 1.
Action 12:53:52: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:53:52: UnregisterTypeLibraries.
Action ended 12:53:52: UnregisterTypeLibraries. Return value 0.
Action 12:53:52: RemoveODBC. Removing ODBC components
Action start 12:53:52: RemoveODBC.
Action ended 12:53:52: RemoveODBC. Return value 1.
Action 12:53:52: UnregisterFonts. Unregistering fonts
Action start 12:53:52: UnregisterFonts.
Action ended 12:53:52: UnregisterFonts. Return value 1.
Action 12:53:52: RemoveRegistryValues. Removing system registry values
Action start 12:53:52: RemoveRegistryValues.
Action ended 12:53:52: RemoveRegistryValues. Return value 1.
Action 12:53:52: UnregisterClassInfo. Unregister class servers
Action start 12:53:52: UnregisterClassInfo.
Action ended 12:53:52: UnregisterClassInfo. Return value 0.
Action 12:53:52: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:53:52: UnregisterExtensionInfo.
Action ended 12:53:52: UnregisterExtensionInfo. Return value 0.
Action 12:53:52: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:53:52: UnregisterProgIdInfo.
Action ended 12:53:52: UnregisterProgIdInfo. Return value 0.
Action 12:53:52: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:53:52: UnregisterMIMEInfo.
Action ended 12:53:52: UnregisterMIMEInfo. Return value 0.
Action 12:53:52: RemoveIniValues. Removing INI file entries
Action start 12:53:52: RemoveIniValues.
Action ended 12:53:52: RemoveIniValues. Return value 1.
Action 12:53:52: RemoveShortcuts. Removing shortcuts
Action start 12:53:52: RemoveShortcuts.
Action ended 12:53:52: RemoveShortcuts. Return value 0.
Action 12:53:52: RemoveEnvironmentStrings. Updating environment strings
Action start 12:53:52: RemoveEnvironmentStrings.
Action ended 12:53:52: RemoveEnvironmentStrings. Return value 1.
Action 12:53:52: RemoveDuplicateFiles. Removing duplicated files
Action start 12:53:52: RemoveDuplicateFiles.
Action ended 12:53:52: RemoveDuplicateFiles. Return value 1.
Action 12:53:52: RemoveFiles. Removing files
Action start 12:53:52: RemoveFiles.
Action ended 12:53:52: RemoveFiles. Return value 0.
Action 12:53:52: RemoveFolders. Removing folders
Action start 12:53:52: RemoveFolders.
Action ended 12:53:52: RemoveFolders. Return value 0.
Action 12:53:52: CreateFolders. Creating folders
Action start 12:53:52: CreateFolders.
Action ended 12:53:52: CreateFolders. Return value 0.
Action 12:53:52: MoveFiles. Moving files
Action start 12:53:52: MoveFiles.
Action ended 12:53:52: MoveFiles. Return value 1.
Action 12:53:52: InstallFiles. Copying new files
Action start 12:53:52: InstallFiles.
Action ended 12:53:52: InstallFiles. Return value 1.
Action 12:53:52: PatchFiles. Patching files
Action start 12:53:52: PatchFiles.
Action ended 12:53:52: PatchFiles. Return value 0.
Action 12:53:52: DuplicateFiles. Creating duplicate files
Action start 12:53:52: DuplicateFiles.
Action ended 12:53:52: DuplicateFiles. Return value 1.
Action 12:53:52: BindImage. Binding executables
Action start 12:53:52: BindImage.
Action ended 12:53:52: BindImage. Return value 1.
Action 12:53:52: CreateShortcuts. Creating shortcuts
Action start 12:53:52: CreateShortcuts.
Action ended 12:53:52: CreateShortcuts. Return value 0.
Action 12:53:52: RegisterClassInfo. Registering class servers
Action start 12:53:52: RegisterClassInfo.
Action ended 12:53:52: RegisterClassInfo. Return value 0.
Action 12:53:52: RegisterExtensionInfo. Registering extension servers
Action start 12:53:52: RegisterExtensionInfo.
Action ended 12:53:52: RegisterExtensionInfo. Return value 0.
Action 12:53:52: RegisterProgIdInfo. Registering program identifiers
Action start 12:53:52: RegisterProgIdInfo.
Action ended 12:53:52: RegisterProgIdInfo. Return value 0.
Action 12:53:52: RegisterMIMEInfo. Registering MIME info
Action start 12:53:52: RegisterMIMEInfo.
Action ended 12:53:52: RegisterMIMEInfo. Return value 0.
Action 12:53:52: WriteRegistryValues. Writing system registry values
Action start 12:53:52: WriteRegistryValues.
Action ended 12:53:52: WriteRegistryValues. Return value 1.
Action 12:53:52: WriteIniValues. Writing INI file values
Action start 12:53:52: WriteIniValues.
Action ended 12:53:52: WriteIniValues. Return value 1.
Action 12:53:52: WriteEnvironmentStrings. Updating environment strings
Action start 12:53:52: WriteEnvironmentStrings.
Action ended 12:53:52: WriteEnvironmentStrings. Return value 1.
Action 12:53:52: RegisterFonts. Registering fonts
Action start 12:53:52: RegisterFonts.
Action ended 12:53:52: RegisterFonts. Return value 1.
Action 12:53:52: InstallODBC. Installing ODBC components
Action start 12:53:52: InstallODBC.
Action ended 12:53:52: InstallODBC. Return value 0.
Action 12:53:52: RegisterTypeLibraries. Registering type libraries
Action start 12:53:52: RegisterTypeLibraries.
Action ended 12:53:52: RegisterTypeLibraries. Return value 0.
Action 12:53:52: SelfRegModules. Registering modules
Action start 12:53:52: SelfRegModules.
Action ended 12:53:52: SelfRegModules. Return value 1.
Action 12:53:52: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:53:52: RegisterComPlus.
Action ended 12:53:52: RegisterComPlus. Return value 0.
Action 12:53:52: InstallServices. Installing new services
Action start 12:53:52: InstallServices.
Action ended 12:53:52: InstallServices. Return value 1.
Action 12:53:52: StartServices. Starting services
Action start 12:53:52: StartServices.
Action ended 12:53:52: StartServices. Return value 1.
Action 12:53:52: RegisterUser. Registering user
Action start 12:53:52: RegisterUser.
Action ended 12:53:52: RegisterUser. Return value 0.
Action 12:53:52: RegisterProduct. Registering product
Action start 12:53:52: RegisterProduct.
Registering product
Action ended 12:53:52: RegisterProduct. Return value 1.
Action 12:53:52: PublishComponents. Publishing qualified components
Action start 12:53:52: PublishComponents.
Action ended 12:53:52: PublishComponents. Return value 0.
Action 12:53:52: MsiPublishAssemblies. Publishing assembly information
Action start 12:53:52: MsiPublishAssemblies.
Action ended 12:53:52: MsiPublishAssemblies. Return value 1.
Action 12:53:52: PublishFeatures. Publishing product features
Action start 12:53:52: PublishFeatures.
Action ended 12:53:52: PublishFeatures. Return value 1.
Action 12:53:52: PublishProduct. Publishing product information
Action start 12:53:52: PublishProduct.
Action ended 12:53:52: PublishProduct. Return value 1.
Action 12:53:52: InstallFinalize.
Action start 12:53:52: InstallFinalize.
40da1.msi
Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_MFC_x86_
Action 12:53:52: RollbackCleanup. Removing backup files
File: C:\Config.Msi\354092.rbf
File: C:\Config.Msi\354093.rbf
Action ended 12:53:52: InstallFinalize. Return value 1.
Action ended 12:53:52: INSTALL. Return value 1.
Property(S): UpgradeCode = {D27B3F91-AF97-4C28-90D0-9243BD36B1CE}
Property(S): SourcedirProduct = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): Installed = 2009/03/11 04:06:40
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\35408c.msi
Property(S): Time = 12:53:52
Property(S): VirtualMemory = 14347
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\
Property(S): payload.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_7264ef23\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): policydir_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_3624aa14c1dce505\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aea75d50\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\
Property(S): ProductCode = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): ProductName = Microsoft_VC90_MFC_x86_x64
[ 4016] Sun Feb 13 12:53:53 2011 INFO
Property(S): DWUSLINK = CECCB788E98CF7E89EAC97BF99EB978FEE8BF08F69BCD7CFCEBC7798696BC0BF497CA0CFBEAC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb2EC3.tmp
Property(S): PackageCode = {C90E5245-A463-4F12-854D-D812F26436F2}
=== Logging stopped: 13/02/2011 12:53:53 ===
1: 2 2: 0
1: 2 2: 1
[ 6204] Sun Feb 13 12:53:53 2011 INFO
:: END TIMER :: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}] took 3032.1 miliseconds (3.0321 seconds) DTR = 21.1075 KBPS (0.0206128 MBPS)
Calling the custom action code for post-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64
Calling the custom action code for pre-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593}
::START TIMER:: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}]
[ 3104] Sun Feb 13 12:53:53 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
Third party application path:E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
CommandLine: -airAppPath AdobeHelp.air -airRuntime AdobeAIRInstaller.exe -eulaAccepted -programMenu -silent
[ 6204] Sun Feb 13 12:54:00 2011 INFO
:: END TIMER :: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}] took 7029.74 miliseconds (7.02974 seconds) DTR = 0.569011 KBPS (0.000555675 MBPS)
Calling the custom action code for post-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp
[ 6204] Sun Feb 13 12:54:00 2011 WARN
Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
Calling the custom action code for pre-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
::START TIMER:: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}]
[ 2580] Sun Feb 13 12:54:00 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
CommandLine: -silent
[ 6204] Sun Feb 13 12:54:03 2011 INFO
:: END TIMER :: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}] took 3028.74 miliseconds (3.02874 seconds)
Calling the custom action code for post-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR
Calling the custom action code for pre-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
::START TIMER:: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}]
[ 6708] Sun Feb 13 12:54:03 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
CommandLine: -silent -eulaAccepted -programMenu adobe_media_player.air
[ 6204] Sun Feb 13 12:54:08 2011 INFO
:: END TIMER :: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}] took 5038.27 miliseconds (5.03827 seconds)
[ 6204] Sun Feb 13 12:54:09 2011 INFO
Calling the custom action code for post-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player
Calling the custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200}
::START TIMER:: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}]
[ 7028] Sun Feb 13 12:54:09 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Installing payload
Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
[ 7028] Sun Feb 13 12:54:10 2011 INFO
Command line arguments: /UILevel=2 REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
1: 0 2: 1033 3: 1252
=== Logging started: 13/02/2011 12:54:10 ===
Message type: 1, Argument: Adobe Flash Player 10 ActiveX
Action 12:54:10: INSTALL.
Action start 12:54:10: INSTALL.
Action 12:54:10: ISSetAllUsers.
Action start 12:54:10: ISSetAllUsers.
InstallShield 12:54:10: Begin SetAllUsers()
InstallShield 12:54:10: Getting records from Upgrade table
InstallShield 12:54:10: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 10.1.52.14 Language: Attributes: 769
InstallShield 12:54:10: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
InstallShield 12:54:10: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 12:54:10: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
InstallShield 12:54:10: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 12:54:10: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
InstallShield 12:54:10: End SetAllUsers()
Action ended 12:54:10: ISSetAllUsers. Return value 1.
Action 12:54:10: AppSearch. Searching for installed applications
Action start 12:54:10: AppSearch.
Action ended 12:54:10: AppSearch. Return value 0.
Action 12:54:10: LaunchConditions. Evaluating launch conditions
Action start 12:54:10: LaunchConditions.
Action ended 12:54:10: LaunchConditions. Return value 1.
Action 12:54:10: FindRelatedProducts. Searching for related applications
Action start 12:54:10: FindRelatedProducts.
Action ended 12:54:10: FindRelatedProducts. Return value 1.
Action 12:54:10: ValidateProductID.
Action start 12:54:10: ValidateProductID.
Action ended 12:54:10: ValidateProductID. Return value 1.
Action 12:54:10: CostInitialize. Computing space requirements
Action start 12:54:10: CostInitialize.
Action ended 12:54:10: CostInitialize. Return value 1.
Action 12:54:10: FileCost. Computing space requirements
Action start 12:54:10: FileCost.
Action ended 12:54:10: FileCost. Return value 1.
Action 12:54:10: IsolateComponents.
Action start 12:54:10: IsolateComponents.
Action ended 12:54:10: IsolateComponents. Return value 0.
Action 12:54:10: CostFinalize. Computing space requirements
Action start 12:54:10: CostFinalize.
Action ended 12:54:10: CostFinalize. Return value 1.
Action 12:54:10: SetARPINSTALLLOCATION.
Action start 12:54:10: SetARPINSTALLLOCATION.
Action ended 12:54:10: SetARPINSTALLLOCATION. Return value 1.
Action 12:54:10: SetODBCFolders. Initializing ODBC directories
Action start 12:54:10: SetODBCFolders.
Action ended 12:54:10: SetODBCFolders. Return value 0.
Action 12:54:10: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:54:10: MigrateFeatureStates.
Action ended 12:54:10: MigrateFeatureStates. Return value 0.
Action 12:54:10: InstallValidate. Validating install
Action start 12:54:10: InstallValidate.
Action ended 12:54:10: InstallValidate. Return value 1.
Action 12:54:10: RemoveExistingProducts. Removing applications
Action start 12:54:10: RemoveExistingProducts.
Action ended 12:54:10: RemoveExistingProducts. Return value 0.
Action 12:54:10: InstallInitialize.
Action start 12:54:10: InstallInitialize.
Action ended 12:54:10: InstallInitialize. Return value 1.
Action 12:54:10: CallExeUninstaller.
Action start 12:54:10: CallExeUninstaller.
Action 12:54:10: GenerateScript. Generating script operations for action:
CallExeUninstaller
Action ended 12:54:10: CallExeUninstaller. Return value 1.
Action 12:54:10: MakePropsAvailable.
Action start 12:54:10: MakePropsAvailable.
Action ended 12:54:10: MakePropsAvailable. Return value 1.
Action 12:54:10: AllocateRegistrySpace. Allocating registry space
Action start 12:54:10: AllocateRegistrySpace.
Action ended 12:54:10: AllocateRegistrySpace. Return value 1.
Action 12:54:10: ProcessComponents. Updating component registration
Action start 12:54:10: ProcessComponents.
Action ended 12:54:10: ProcessComponents. Return value 1.
Action 12:54:10: UnpublishComponents. Unpublishing Qualified Components
Action start 12:54:10: UnpublishComponents.
Action ended 12:54:10: UnpublishComponents. Return value 0.
Action 12:54:10: UnpublishFeatures. Unpublishing product features
Action start 12:54:10: UnpublishFeatures.
Action ended 12:54:10: UnpublishFeatures. Return value 1.
Action 12:54:10: StopServices. Stopping services
Action start 12:54:10: StopServices.
Action ended 12:54:10: StopServices. Return value 1.
Action 12:54:10: DeleteServices. Deleting services
Action start 12:54:10: DeleteServices.
Action ended 12:54:10: DeleteServices. Return value 1.
Action 12:54:10: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:54:10: UnregisterComPlus.
Action ended 12:54:10: UnregisterComPlus. Return value 0.
Action 12:54:10: SelfUnregModules. Unregistering modules
Action start 12:54:10: SelfUnregModules.
Action ended 12:54:10: SelfUnregModules. Return value 1.
Action 12:54:10: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:54:10: UnregisterTypeLibraries.
Action ended 12:54:10: UnregisterTypeLibraries. Return value 0.
Action 12:54:10: RemoveODBC. Removing ODBC components
Action start 12:54:10: RemoveODBC.
Action ended 12:54:10: RemoveODBC. Return value 1.
Action 12:54:10: UnregisterFonts. Unregistering fonts
Action start 12:54:10: UnregisterFonts.
Action ended 12:54:10: UnregisterFonts. Return value 1.
Action 12:54:10: RemoveRegistryValues. Removing system registry values
Action start 12:54:10: RemoveRegistryValues.
Action ended 12:54:10: RemoveRegistryValues. Return value 1.
Action 12:54:10: UnregisterClassInfo. Unregister class servers
Action start 12:54:10: UnregisterClassInfo.
Action ended 12:54:10: UnregisterClassInfo. Return value 0.
Action 12:54:10: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:54:10: UnregisterExtensionInfo.
Action ended 12:54:10: UnregisterExtensionInfo. Return value 0.
Action 12:54:10: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:54:10: UnregisterProgIdInfo.
Action ended 12:54:10: UnregisterProgIdInfo. Return value 0.
Action 12:54:10: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:54:10: UnregisterMIMEInfo.
Action ended 12:54:10: UnregisterMIMEInfo. Return value 0.
Action 12:54:10: RemoveIniValues. Removing INI file entries
Action start 12:54:10: RemoveIniValues.
Action ended 12:54:10: RemoveIniValues. Return value 1.
Action 12:54:10: RemoveShortcuts. Removing shortcuts
Action start 12:54:10: RemoveShortcuts.
Action ended 12:54:10: RemoveShortcuts. Return value 0.
Action 12:54:10: RemoveEnvironmentStrings. Updating environment strings
Action start 12:54:10: RemoveEnvironmentStrings.
Action ended 12:54:10: RemoveEnvironmentStrings. Return value 1.
Action 12:54:10: RemoveDuplicateFiles. Removing duplicated files
Action start 12:54:10: RemoveDuplicateFiles.
Action ended 12:54:10: RemoveDuplicateFiles. Return value 1.
Action 12:54:10: RemoveFolders. Removing folders
Action start 12:54:10: RemoveFolders.
Action ended 12:54:10: RemoveFolders. Return value 1.
Action 12:54:10: CreateFolders. Creating folders
Action start 12:54:10: CreateFolders.
Action ended 12:54:10: CreateFolders. Return value 1.
Action 12:54:10: MoveFiles. Moving files
Action start 12:54:10: MoveFiles.
Action ended 12:54:10: MoveFiles. Return value 1.
Action 12:54:10: InstallFiles. Copying new files
Action start 12:54:10: InstallFiles.
Action ended 12:54:10: InstallFiles. Return value 1.
Action 12:54:10: NewCustomAction1.
Action start 12:54:10: NewCustomAction1.
Error 2753.The File 'InstallAX.exe' is not marked for installation.
Action ended 12:54:10: NewCustomAction1. Return value 3.
[ 7028] Sun Feb 13 12:54:11 2011 INFO
Action ended 12:54:11: INSTALL. Return value 3.
Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(S): ProductCode = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SourcedirProduct = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): REMOVE = ALL
Property(S): MACROMED = C:\Windows\SysWOW64\Macromed\
Property(S): FLASH = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): INSTALLDIR = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\354095.msi
Property(S): Time = 12:54:11
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): ProductName = Adobe Flash Player 10 ActiveX
Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(S): ARPNOMODIFY = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): InstallChoice = AR
Property(S): Manufacturer = Adobe Systems, Inc.
Property(S): MsiLogging = voicewarmupx
Property(S): NewProperty2 = 0
Property(S): NewProperty3 = 0
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductVersion = 10.1.52.14
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(S): RemoveFilesCA = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): ARPINSTALLLOCATION = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): VirtualMemory = 14352
Property(S): USERNAME = Gary & Susan
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 110
Property(S): MsiSystemRebootPending = 1
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 5888
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): REBOOT = ReallySuppress
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): /UILEVEL = 2
Property(S): PackagecodeChanging = 1
Property(S): ProductState = -1
Property(S): PackageCode = {8C02D971-B819-4CCC-940B-1F1E34164635}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI67a2f.LOG
=== Logging stopped: 13/02/2011 12:54:11 ===
1: 2 2: 0
1: 2 2: 1
Installation result: 1603
[ 6204] Sun Feb 13 12:54:11 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}] took 2023.54 miliseconds (2.02354 seconds) DTR = 94.8833 KBPS (0.0926595 MBPS)
User specified overrideFile:
Calling the ROLLBACK custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX
[ 6204] Sun Feb 13 12:54:12 2011 INFO
Calling the custom action code for pre-install for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34}
::START TIMER:: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}]
[ 5524] Sun Feb 13 12:54:12 2011 INFO
Installer Operation: InstallThirdPartyPayloadOperation
Installing third party payload
Installing payload
Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Command line arguments: UILevel=2
[ 5524] Sun Feb 13 12:54:13 2011 INFO
=== Logging started: 13/02/2011 12:54:13 ===
Message type: 1, Argument: Adobe Flash Player 10 Plugin
Action 12:54:13: INSTALL.
Action start 12:54:13: INSTALL.
Action 12:54:13: ISSetAllUsers.
Action start 12:54:13: ISSetAllUsers.
InstallShield 12:54:13: Begin SetAllUsers()
InstallShield 12:54:13: Getting records from Upgrade table
InstallShield 12:54:13: UpgradeCode: {D85A1A59-DC52-4D13-9445-EF3F379D4DB5} MinVersion: 6.0.47.0 MaxVersion: 10.1.52.14 Language: Attributes: 769
InstallShield 12:54:13: No related products for UpgradeCode {D85A1A59-DC52-4D13-9445-EF3F379D4DB5} found
InstallShield 12:54:13: End SetAllUsers()
Action ended 12:54:13: ISSetAllUsers. Return value 1.
Action 12:54:13: AppSearch. Searching for installed applications
Action start 12:54:13: AppSearch.
Action ended 12:54:13: AppSearch. Return value 0.
Action 12:54:13: LaunchConditions. Evaluating launch conditions
Action start 12:54:13: LaunchConditions.
Action ended 12:54:13: LaunchConditions. Return value 1.
Action 12:54:13: FindRelatedProducts. Searching for related applications
Action start 12:54:13: FindRelatedProducts.
Action ended 12:54:13: FindRelatedProducts. Return value 1.
Action 12:54:13: ValidateProductID.
Action start 12:54:13: ValidateProductID.
Action ended 12:54:13: ValidateProductID. Return value 1.
Action 12:54:13: CostInitialize. Computing space requirements
Action start 12:54:13: CostInitialize.
Action ended 12:54:13: CostInitialize. Return value 1.
Action 12:54:13: FileCost. Computing space requirements
Action start 12:54:13: FileCost.
Action ended 12:54:13: FileCost. Return value 1.
Action 12:54:13: IsolateComponents.
Action start 12:54:13: IsolateComponents.
Action ended 12:54:13: IsolateComponents. Return value 0.
Action 12:54:13: CostFinalize. Computing space requirements
Action start 12:54:13: CostFinalize.
Action ended 12:54:13: CostFinalize. Return value 1.
Action 12:54:13: SetARPINSTALLLOCATION.
Action start 12:54:13: SetARPINSTALLLOCATION.
Action ended 12:54:13: SetARPINSTALLLOCATION. Return value 1.
Action 12:54:13: SetODBCFolders. Initializing ODBC directories
Action start 12:54:13: SetODBCFolders.
Action ended 12:54:13: SetODBCFolders. Return value 0.
Action 12:54:13: MigrateFeatureStates. Migrating feature states from related applications
Action start 12:54:13: MigrateFeatureStates.
Action ended 12:54:13: MigrateFeatureStates. Return value 0.
Action 12:54:13: InstallValidate. Validating install
Action start 12:54:13: InstallValidate.
Action ended 12:54:13: InstallValidate. Return value 1.
Action 12:54:13: RemoveExistingProducts. Removing applications
Action start 12:54:13: RemoveExistingProducts.
Action ended 12:54:13: RemoveExistingProducts. Return value 1.
Action 12:54:13: InstallInitialize.
Action start 12:54:13: InstallInitialize.
Action ended 12:54:13: InstallInitialize. Return value 1.
Action 12:54:13: MakePropsAvailable.
Action start 12:54:13: MakePropsAvailable.
Action ended 12:54:13: MakePropsAvailable. Return value 1.
Action 12:54:13: AllocateRegistrySpace. Allocating registry space
Action start 12:54:13: AllocateRegistrySpace.
Action ended 12:54:13: AllocateRegistrySpace. Return value 1.
Action 12:54:13: ProcessComponents. Updating component registration
Action start 12:54:13: ProcessComponents.
Action 12:54:13: GenerateScript. Generating script operations for action:
Action ended 12:54:13: ProcessComponents. Return value 1.
Action 12:54:13: UnpublishComponents. Unpublishing Qualified Components
Action start 12:54:13: UnpublishComponents.
Action ended 12:54:13: UnpublishComponents. Return value 0.
Action 12:54:13: UnpublishFeatures. Unpublishing product features
Action start 12:54:13: UnpublishFeatures.
Action ended 12:54:13: UnpublishFeatures. Return value 1.
Action 12:54:13: StopServices. Stopping services
Action start 12:54:13: StopServices.
Action ended 12:54:13: StopServices. Return value 1.
Action 12:54:13: DeleteServices. Deleting services
Action start 12:54:13: DeleteServices.
Action ended 12:54:13: DeleteServices. Return value 1.
Action 12:54:13: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 12:54:13: UnregisterComPlus.
Action ended 12:54:13: UnregisterComPlus. Return value 0.
Action 12:54:13: SelfUnregModules. Unregistering modules
Action start 12:54:13: SelfUnregModules.
Action ended 12:54:13: SelfUnregModules. Return value 1.
Action 12:54:13: UnregisterTypeLibraries. Unregistering type libraries
Action start 12:54:13: UnregisterTypeLibraries.
Action ended 12:54:13: UnregisterTypeLibraries. Return value 0.
Action 12:54:13: RemoveODBC. Removing ODBC components
Action start 12:54:13: RemoveODBC.
Action ended 12:54:13: RemoveODBC. Return value 1.
Action 12:54:13: UnregisterFonts. Unregistering fonts
Action start 12:54:13: UnregisterFonts.
Action ended 12:54:13: UnregisterFonts. Return value 1.
Action 12:54:13: RemoveRegistryValues. Removing system registry values
Action start 12:54:13: RemoveRegistryValues.
Action ended 12:54:13: RemoveRegistryValues. Return value 1.
Action 12:54:13: UnregisterClassInfo. Unregister class servers
Action start 12:54:13: UnregisterClassInfo.
Action ended 12:54:13: UnregisterClassInfo. Return value 0.
Action 12:54:13: UnregisterExtensionInfo. Unregistering extension servers
Action start 12:54:13: UnregisterExtensionInfo.
Action ended 12:54:13: UnregisterExtensionInfo. Return value 0.
Action 12:54:13: UnregisterProgIdInfo. Unregistering program identifiers
Action start 12:54:13: UnregisterProgIdInfo.
Action ended 12:54:13: UnregisterProgIdInfo. Return value 0.
Action 12:54:13: UnregisterMIMEInfo. Unregistering MIME info
Action start 12:54:13: UnregisterMIMEInfo.
Action ended 12:54:13: UnregisterMIMEInfo. Return value 0.
Action 12:54:13: RemoveIniValues. Removing INI file entries
Action start 12:54:13: RemoveIniValues.
Action ended 12:54:13: RemoveIniValues. Return value 1.
Action 12:54:13: RemoveShortcuts. Removing shortcuts
Action start 12:54:13: RemoveShortcuts.
Action ended 12:54:13: RemoveShortcuts. Return value 0.
Action 12:54:13: RemoveEnvironmentStrings. Updating environment strings
Action start 12:54:13: RemoveEnvironmentStrings.
Action ended 12:54:13: RemoveEnvironmentStrings. Return value 1.
Action 12:54:13: RemoveDuplicateFiles. Removing duplicated files
Action start 12:54:13: RemoveDuplicateFiles.
Action ended 12:54:13: RemoveDuplicateFiles. Return value 1.
Action 12:54:13: RemoveFolders. Removing folders
Action start 12:54:13: RemoveFolders.
Action ended 12:54:13: RemoveFolders. Return value 1.
Action 12:54:13: CreateFolders. Creating folders
Action start 12:54:13: CreateFolders.
Folder: Creating folders
Action ended 12:54:13: CreateFolders. Return value 1.
Action 12:54:13: MoveFiles. Moving files
Action start 12:54:13: MoveFiles.
Action ended 12:54:13: MoveFiles. Return value 1.
Action 12:54:13: InstallFiles. Copying new files
Action start 12:54:13: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 12:54:13: InstallFiles. Return value 1.
Action 12:54:13: NewCustomAction1.
Action start 12:54:13: NewCustomAction1.
Action ended 12:54:13: NewCustomAction1. Return value 1.
Action 12:54:13: PatchFiles. Patching files
Action start 12:54:13: PatchFiles.
Action ended 12:54:13: PatchFiles. Return value 1.
Action 12:54:13: DuplicateFiles. Creating duplicate files
Action start 12:54:13: DuplicateFiles.
Action ended 12:54:13: DuplicateFiles. Return value 1.
Action 12:54:13: BindImage. Binding executables
Action start 12:54:13: BindImage.
Action ended 12:54:13: BindImage. Return value 1.
Action 12:54:13: CreateShortcuts. Creating shortcuts
Action start 12:54:13: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 12:54:13: CreateShortcuts. Return value 0.
Action 12:54:13: RegisterClassInfo. Registering class servers
Action start 12:54:13: RegisterClassInfo.
Action ended 12:54:13: RegisterClassInfo. Return value 0.
Action 12:54:13: RegisterExtensionInfo. Registering extension servers
Action start 12:54:13: RegisterExtensionInfo.
Action ended 12:54:13: RegisterExtensionInfo. Return value 0.
Action 12:54:13: RegisterProgIdInfo. Registering program identifiers
Action start 12:54:13: RegisterProgIdInfo.
Action ended 12:54:13: RegisterProgIdInfo. Return value 0.
Action 12:54:13: RegisterMIMEInfo. Registering MIME info
Action start 12:54:13: RegisterMIMEInfo.
Action ended 12:54:13: RegisterMIMEInfo. Return value 0.
Action 12:54:13: WriteRegistryValues. Writing system registry values
Action start 12:54:13: WriteRegistryValues.
Key: Writing system registry values, Name: , Value:
Action ended 12:54:13: WriteRegistryValues. Return value 1.
Action 12:54:13: WriteIniValues. Writing INI file values
Action start 12:54:13: WriteIniValues.
Action ended 12:54:13: WriteIniValues. Return value 1.
Action 12:54:13: WriteEnvironmentStrings. Updating environment strings
Action start 12:54:13: WriteEnvironmentStrings.
Action ended 12:54:13: WriteEnvironmentStrings. Return value 1.
Action 12:54:13: RegisterFonts. Registering fonts
Action start 12:54:13: RegisterFonts.
Action ended 12:54:13: RegisterFonts. Return value 1.
Action 12:54:13: InstallODBC. Installing ODBC components
Action start 12:54:13: InstallODBC.
Action ended 12:54:13: InstallODBC. Return value 0.
Action 12:54:13: RegisterTypeLibraries. Registering type libraries
Action start 12:54:13: RegisterTypeLibraries.
Action ended 12:54:13: RegisterTypeLibraries. Return value 0.
Action 12:54:13: SelfRegModules. Registering modules
Action start 12:54:13: SelfRegModules.
Action ended 12:54:13: SelfRegModules. Return value 1.
Action 12:54:13: RegisterComPlus. Registering COM+ Applications and Components
Action start 12:54:13: RegisterComPlus.
Action ended 12:54:13: RegisterComPlus. Return value 0.
Action 12:54:13: InstallServices. Installing new services
Action start 12:54:13: InstallServices.
Action ended 12:54:13: InstallServices. Return value 1.
Action 12:54:13: StartServices. Starting services
Action start 12:54:13: StartServices.
Action ended 12:54:13: StartServices. Return value 1.
Action 12:54:13: RegisterUser. Registering user
Action start 12:54:13: RegisterUser.
Registering user
Action ended 12:54:13: RegisterUser. Return value 1.
Action 12:54:13: RegisterProduct. Registering product
Action start 12:54:13: RegisterProduct.
Registering product
Action ended 12:54:13: RegisterProduct. Return value 1.
Action 12:54:13: PublishComponents. Publishing qualified components
Action start 12:54:13: PublishComponents.
Action ended 12:54:13: PublishComponents. Return value 0.
Action 12:54:13: PublishFeatures. Publishing product features
Action start 12:54:13: PublishFeatures.
Feature: Publishing product features
Action ended 12:54:13: PublishFeatures. Return value 1.
Action 12:54:13: PublishProduct. Publishing product information
Action start 12:54:13: PublishProduct.
Action ended 12:54:13: PublishProduct. Return value 1.
Action 12:54:13: InstallFinalize.
Action start 12:54:13: InstallFinalize.
Folder: C:\Windows\SysWOW64\Macromed\Flash\
File: InstallPlugin.exe, Directory: C:\Users\GARY&S~1\AppData\Local\Temp\, Size: 2516992
Shortcut: ARPPRODUCTICON.exe
Key: \Software\Macromedia\FlashPlayer, Name: , Value:
Key: \Software\Macromedia\FlashPlayer, Name: FlashPlayerVersion, Value: 10.1.52.14
{BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Feature: FlashPlayerAXInstaller
Message type: 2, Argument: 0
Action 12:54:13: RollbackCleanup. Removing backup files
Message type: 2, Argument: 1
[ 5524] Sun Feb 13 12:54:14 2011 INFO
Action ended 12:54:14: InstallFinalize. Return value 1.
Action ended 12:54:14: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
Property(S): ProductCode = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): ProductToBeRegistered = 1
Property(S): SourcedirProduct = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): VersionNT = 601
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): CostingComplete = 1
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): USERPROFILE = F:\
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\35409a.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 12:54:14
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ProductName = Adobe Flash Player 10 Plugin
Property(S): ALLUSERS = 1
Property(S): ScreenY = 768
Property(S): SecureCustomProperties = ISACTIONPROP1;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_plugin.exe
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): AdminUser = 1
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): VirtualMemory = 14348
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): System64Folder = C:\Windows\system32\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder = C:\Windows\
Property(S): UILEVEL = 2
Property(S): PackageCode = {BD4109FD-A808-4EAE-B2BE-144DA3F3A299}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI67a30.LOG
=== Logging stopped: 13/02/2011 12:54:14 ===
1: 2 2: 0
1: 2 2: 1
Installation result: 0
Third party payload succeded. Testing return code: 0
[ 6204] Sun Feb 13 12:54:14 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}] took 2017.95 miliseconds (2.01795 seconds) DTR = 3280.56 KBPS (3.20367 MBPS)
Calling the custom action code for post-install for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin
Calling the custom action code for pre-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0}
::START TIMER:: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: productName is Adobe Flash Fonts1
Font Installer: Using [AdobeCommon] path: C:\Program Files (x86)\Common Files\Adobe
Custom action return code: 0
:: END TIMER :: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 29.6055 miliseconds (0.0296055 seconds)
::START TIMER:: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}]
[ 3648] Sun Feb 13 12:54:14 2011 INFO
Installer Operation: PayloadUninstaller
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7745F18B-FD8A-4011-BE16-588900C503D0}
Effective AdobeCode for: {7745F18B-FD8A-4011-BE16-588900C503D0} is {7745F18B-FD8A-4011-BE16-588900C503D0}
Session includes local copy of payload for repair source
Repair payload source package: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Extracting assets...
Extracting assets complete. Number assets: 1
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
[ 3648] Sun Feb 13 12:54:15 2011 INFO
Evaluating condition# 1
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7745F18B-FD8A-4011-BE16-588900C503D0}.db
Physical payload repair result:0
[ 6204] Sun Feb 13 12:54:15 2011 INFO
:: END TIMER :: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 1023.53 miliseconds (1.02353 seconds) DTR = 590.115 KBPS (0.576285 MBPS)
Calling the custom action code for post-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
::START TIMER:: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: Did not find any font files under:C:\Program Files (x86)\Common Files\Adobe\SavedFonts\current
:: END TIMER :: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 2.37978 miliseconds (0.00237978 seconds) DTR = 13446.6 KBPS (13.1315 MBPS)
Disk Swap Needed, Prompting user to swap disk CS5 Master Coll2 E:\
[ 6204] Sun Feb 13 12:54:53 2011 INFO
Starting installation from Disk 2 - CS5 Master Coll2
Calling the custom action code for pre-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
::START TIMER:: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}]
[ 6248] Sun Feb 13 12:54:53 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Effective AdobeCode for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} is {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 6248] Sun Feb 13 12:55:08 2011 INFO
Extracting assets complete. Number assets: 2
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 6248] Sun Feb 13 12:55:15 2011 INFO
Evaluating condition# 2
Condition failed
Condition failed
[ 6248] Sun Feb 13 12:55:23 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}.db
[ 6248] Sun Feb 13 12:55:27 2011 INFO
[ 6204] Sun Feb 13 12:55:28 2011 INFO
:: END TIMER :: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}] took 35063.3 miliseconds (35.0633 seconds) DTR = 6585.12 KBPS (6.43078 MBPS)
Calling the custom action code for post-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
Calling the custom action code for pre-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
::START TIMER:: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}]
[ 5252] Sun Feb 13 12:55:28 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Effective AdobeCode for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} is {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
[ 5252] Sun Feb 13 12:55:29 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
Condition failed
Condition failed
[ 5252] Sun Feb 13 12:55:30 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}.db
[ 6204] Sun Feb 13 12:55:31 2011 INFO
:: END TIMER :: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}] took 3029.25 miliseconds (3.02925 seconds)
Calling the custom action code for post-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691}
::START TIMER:: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}]
[ 4844] Sun Feb 13 12:55:31 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Effective AdobeCode for: {0E3C6C75-872D-4B0D-B0B2-31C717250691} is {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Repair payload source package: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 4844] Sun Feb 13 12:55:32 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 4844] Sun Feb 13 12:55:34 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{0E3C6C75-872D-4B0D-B0B2-31C717250691}.db
[ 6204] Sun Feb 13 12:55:34 2011 INFO
:: END TIMER :: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}] took 3023.11 miliseconds (3.02311 seconds) DTR = 1354.9 KBPS (1.32314 MBPS)
Calling the custom action code for post-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
::START TIMER:: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}]
[ 832] Sun Feb 13 12:55:34 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Effective AdobeCode for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} is {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
[ 832] Sun Feb 13 12:55:35 2011 INFO
Repair payload source package: E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
[ 832] Sun Feb 13 12:55:39 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
[ 832] Sun Feb 13 12:55:40 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5DDABB74-A879-4BE7-A4C6-FD41793942DB}.db
[ 6204] Sun Feb 13 12:55:40 2011 INFO
:: END TIMER :: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}] took 6035.72 miliseconds (6.03572 seconds)
[ 6204] Sun Feb 13 12:55:41 2011 INFO
Calling the custom action code for post-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64
Calling the custom action code for pre-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
::START TIMER:: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}]
[ 4644] Sun Feb 13 12:55:41 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Effective AdobeCode for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} is {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Repair payload source package: E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 4644] Sun Feb 13 12:55:43 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 4644] Sun Feb 13 12:55:46 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}.db
[ 6204] Sun Feb 13 12:55:47 2011 INFO
:: END TIMER :: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}] took 6017.98 miliseconds (6.01798 seconds) DTR = 170.821 KBPS (0.166818 MBPS)
Calling the custom action code for post-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64
Calling the custom action code for pre-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E}
::START TIMER:: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}]
[ 6232] Sun Feb 13 12:55:47 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Effective AdobeCode for: {7816FDDE-40D4-482D-AD7D-97858985DB3E} is {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
[ 6232] Sun Feb 13 12:55:48 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
Completing installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7816FDDE-40D4-482D-AD7D-97858985DB3E}.db
[ 6204] Sun Feb 13 12:55:49 2011 INFO
:: END TIMER :: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}] took 2031.72 miliseconds (2.03172 seconds) DTR = 13.7814 KBPS (0.0134584 MBPS)
Calling the custom action code for post-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
Calling the custom action code for pre-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8}
::START TIMER:: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}]
[ 6572] Sun Feb 13 12:55:49 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Effective AdobeCode for: {B8D286BC-A68D-4E74-9F68-8756A49896D8} is {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Condition failed
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{B8D286BC-A68D-4E74-9F68-8756A49896D8}.db
[ 6204] Sun Feb 13 12:55:50 2011 INFO
:: END TIMER :: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}] took 1018.41 miliseconds (1.01841 seconds)
Calling the custom action code for post-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
Calling the custom action code for pre-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
::START TIMER:: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}]
[ 4476] Sun Feb 13 12:55:50 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Effective AdobeCode for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} is {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
[ 4476] Sun Feb 13 12:55:55 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
Condition failed
Condition failed
[ 4476] Sun Feb 13 12:55:56 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{565DE707-5798-4FC3-8DF6-0F58A348A9B0}.db
[ 6204] Sun Feb 13 12:55:57 2011 INFO
:: END TIMER :: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}] took 7032.99 miliseconds (7.03299 seconds) DTR = 3.41249 KBPS (0.00333251 MBPS)
Calling the custom action code for post-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
::START TIMER:: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}]
[ 3884] Sun Feb 13 12:55:57 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Effective AdobeCode for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} is {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 3884] Sun Feb 13 12:55:58 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 3884] Sun Feb 13 12:56:00 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{DE5DE662-2ECB-4D93-967B-221FBCC8A736}.db
[ 6204] Sun Feb 13 12:56:00 2011 INFO
:: END TIMER :: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}] took 3028.75 miliseconds (3.02875 seconds) DTR = 450.35 KBPS (0.439795 MBPS)
Calling the custom action code for post-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
Calling the custom action code for pre-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
::START TIMER:: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}]
[ 2556] Sun Feb 13 12:56:00 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
[ 2556] Sun Feb 13 12:56:01 2011 INFO
Effective AdobeCode for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} is {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 2556] Sun Feb 13 12:56:02 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 2556] Sun Feb 13 12:56:03 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}.db
[ 2556] Sun Feb 13 12:56:04 2011 INFO
[ 6204] Sun Feb 13 12:56:04 2011 INFO
:: END TIMER :: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}] took 4024.33 miliseconds (4.02433 seconds)
[ 6204] Sun Feb 13 12:56:05 2011 INFO
Calling the custom action code for post-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
Calling the custom action code for pre-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4}
::START TIMER:: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}]
[ 4936] Sun Feb 13 12:56:05 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {FBB02B04-C034-4382-A3F6-57416E2752C4}
Effective AdobeCode for: {FBB02B04-C034-4382-A3F6-57416E2752C4} is {FBB02B04-C034-4382-A3F6-57416E2752C4}
Repair payload source package: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
Condition failed
[ 4936] Sun Feb 13 12:56:06 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{FBB02B04-C034-4382-A3F6-57416E2752C4}.db
[ 6204] Sun Feb 13 12:56:06 2011 INFO
:: END TIMER :: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}] took 1028.25 miliseconds (1.02825 seconds)
Calling the custom action code for post-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection
Calling the custom action code for pre-install for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
::START TIMER:: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
In PrePayloadInstallProc
hook checkDirs passed str:
C:\Program Files (x86)\Adobe
detected bad URL character
CHRC_NULL_POINTER_VALUE
Custom action return code: 1
:: END TIMER :: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 1.15487 miliseconds (0.00115487 seconds)
[ 6204] Sun Feb 13 12:56:06 2011 ERROR
Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
[ 6204] Sun Feb 13 12:56:07 2011 INFO
Calling the custom action code for pre-install for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
::START TIMER:: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
:: END TIMER :: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 1.13178 miliseconds (0.00113178 seconds)
[ 6204] Sun Feb 13 12:56:07 2011 ERROR
Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 21458917KB
[ 6204] Sun Feb 13 12:56:09 2011 INFO
Successfully installed 1 component:
- Adobe Flash Player 10 Plugin
Successfully repaired 31 components:
- Microsoft_VC90_ATL_x86
- Adobe Media Player
- Microsoft_VC90_CRT_x86
- Adobe Encore CS5 Third Party Royalty Content
- Microsoft_VC80_ATL_x86
- Adobe Player for Embedding
- AdobeHelp
- Adobe Premiere Pro CS5 Third Party Royalty Content
- Adobe Media Encoder CS5 Dolby X64
- Microsoft_VC90_MFC_x86
- Adobe Media Encoder CS5 X64
- Suite Shared Configuration CS5
- AdobeTypeSupport CS5
- Adobe Flash Fonts1
- Adobe OnLocation CS5 Royalty Content
- Microsoft_VC90_ATL_x86_x64
- Microsoft_VC90_CRT_x86_x64
- Microsoft_VC80_CRT_x86
- Microsoft_VC90_MFC_x86_x64
- DynamiclinkSupport
- Adobe Premiere Pro CS5 Third Party Content
- AdobeCMaps CS5
- Adobe After Effects CS5 Third Party Content
- Adobe After Effects CS5 Third Party Royalty Content
- Microsoft_VC80_MFC_x86
- Microsoft_VC80_MFCLOC_x86
- Adobe Soundbooth CS5 Codecs
- Adobe Soundbooth CS5 Royalty Codecs
- Adobe AIR
- Adobe Media Encoder CS5 PCI X64
- Creative Suite 5 Master Collection
Total components removed: 0
[ 6204] Sun Feb 13 12:56:09 2011 ERROR
The following payload errors were found during install:
- Adobe Flash Builder: Install failed
- Adobe Flash Player 10 ActiveX: Install failed
- Adobe Flash Catalyst CS5: Install failed
Restarting your computer is recommended:
In order to complete the installation, please restart the computer
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 240207 miliseconds (240.207 seconds) DTR = 1038.12 KBPS (1.01379 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 6 error(s), 4 warning(s)
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
ERROR: The following payload errors were found during install:
ERROR: - Adobe Flash Builder: Install failed
ERROR: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: - Adobe Flash Catalyst CS5: Install failed
Search the same string above to find when the error occured.
Exit Code: 6 - Silent workflow completed with errors
END - Installer Session
[ 3432] Sun Feb 13 13:04:32 2011 INFO
Visit http://www.adobe.com/go/loganalyzer/ for more information
START - Installer Session
RIBS version: 3.0.122.0
Win OS version: 6.1.0.0 64 bit Type: 1
::START TIMER:: [Total Timer]
CHECK: Single instance running
CHECK : Credentials
Load Deployment File
Create Required Folders
Assuming install mode
::START TIMER:: [Bootstrap]
Perform Bootstrapping ...
:: END TIMER :: [Bootstrap] took 10220.6 miliseconds (10.2206 seconds) DTR = 149.893 KBPS (0.14638 MBPS)
Looking up install source path
Sync Media DB ...
::START TIMER:: [Sync Media DB]
Pre check media db sync
End of Pre check media db sync. Exit code: 1
Media db sync skipped as session is already installed
:: END TIMER :: [Sync Media DB] took 172.551 miliseconds (0.172551 seconds)
Ready to initialize session to start with ...
::START TIMER:: [CreatePayloadSession]
-------------------- BEGIN - Updating Media Sources - BEGIN --------------------
Updated source path: E:\Adobe CS5
Updating media info for: {01367616-4132-4311-911F-49D2EA82F7C2}
Type: 1, Volume Order: 1, Media Name: CS5 Master Coll1
Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyWrapperAll\Install.db
Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
Path: E:\Adobe CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
Path: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
Path: E:\Adobe CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
Updating media info for: {04D84E18-23ED-46EA-9B41-789433E34D03}
Path: E:\Adobe CS5\payloads\AdobeContribute6-FFPlugin\Install.db
Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll_x64\Install.db
Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
Updating media info for: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Support\Install.db
Updating media info for: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5}
Type: 1, Volume Order: 2, Media Name: CS5 Master Coll2
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_US\AdobeInDesign7CommonLang-en_US.msi
Updating media info for: {0B754B55-6F63-461E-BB75-E8C883BDF88F}
Path: E:\Adobe CS5\payloads\AdobePremierePro5AllRetail\AdobePremierePro5AllRetail.msi
Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
Path: E:\Adobe CS5\payloads\AdobeBridge4-mul\Install.db
Updating media info for: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\AdobeEncore5RoyaltyAll.msi
Updating media info for: {0E659C1D-7686-4322-A501-58E3FEB4E743}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10AllRetail\AdobeAfterEffects10AllRetail.msi
Updating media info for: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9}
Path: E:\Adobe CS5\payloads\AdobeKoreanSpeechAnalysisModels2All\AdobeKoreanSpeechAnalysisModels2All.msi
Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
Updating media info for: {11C0657F-2BD4-4CBC-87F3-9455DC91886E}
Path: E:\Adobe CS5\payloads\AdobeFontsRecommended_x64-mul\Install.db
Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
Path: E:\Adobe CS5\payloads\AdobeFlash11-en_USLanguagePack\AdobeFlash11-en_USLanguagePack.msi
Updating media info for: {157D044B-C60D-1015-B0DB-A40823CC0F49}
Path: E:\Adobe CS5\payloads\AdobeToolhints-mul\Install.db
Updating media info for: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}
Path: E:\Adobe CS5\payloads\AdobeFireworks11All\AdobeFireworks11All.msi
Updating media info for: {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
Path: E:\Adobe CS5\payloads\AdobeFlashBuilder-mul\AdobeFlashBuilder-mul.msi
Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
Path: E:\Adobe CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
Updating media info for: {1A48007B-34D2-44BD-8708-B570F5339C14}
Path: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyWrapperAll\Install.db
Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_US\Install.db
Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
Path: E:\Adobe CS5\payloads\DeviceCentral3LP-en_GB\Install.db
Updating media info for: {1E9FC118-651D-4934-97BE-E53CAE5C7D45}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86_x64\Microsoft_VC80_MFCLOC_x86_x64.msi
Updating media info for: {20F72893-AEC7-4954-9EAA-F07FD6184781}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyWrapperAll\Install.db
Updating media info for: {22F41D72-2E97-46AE-B8C4-EF66876C7838}
Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedWrapperAll\AdobePremierePro5ProtectedWrapperAll.msi
Updating media info for: {234A555C-70F5-48FB-A7E2-32410EB5AF64}
Path: E:\Adobe CS5\payloads\AdobeItalianSpeechAnalysisModels2All\AdobeItalianSpeechAnalysisModels2All.msi
Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-en_US\AdobeMobileExtension_Flash11-en_US.msi
Updating media info for: {26B63C3A-0BFF-1033-B389-A7ACEC31657E}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_GB\AdobeInDesign7AppLang-en_GB.msi
Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
Path: E:\Adobe CS5\payloads\AdobeXMPPanelsAll\Install.db
Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
Path: E:\Adobe CS5\payloads\AdobeAPE3-mul\Install.db
Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
Path: E:\Adobe CS5\payloads\AIR2_Flash11-mul\Install.db
Updating media info for: {33A3F995-8333-4676-8D6F-AB7674BB52EA}
Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All\Install.db
Updating media info for: {34F82E6B-8096-45CA-B604-ACACAC22E553}
Path: E:\Adobe CS5\payloads\AdobePremierePro5en_USLanguagePack\AdobePremierePro5en_USLanguagePack.msi
Updating media info for: {36D02DA9-35F2-4686-A2FE-EF3014D2E226}
Path: E:\Adobe CS5\payloads\AdobeSpanishSpeechAnalysisModels2All\AdobeSpanishSpeechAnalysisModels2All.msi
Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All\Install.db
Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
Path: E:\Adobe CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
Updating media info for: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70}
Path: E:\Adobe CS5\payloads\AdobeFireworks11en_USLanguagePack\AdobeFireworks11en_USLanguagePack.msi
Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
Path: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
Path: E:\Adobe CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
Updating media info for: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0}
Path: E:\Adobe CS5\payloads\AdobeBuzzword-mul\Install.db
Updating media info for: {406D22BD-7910-479B-96AA-0DB8A36C694B}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedWrapperAll\Install.db
Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Updating media info for: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA}
Path: E:\Adobe CS5\payloads\AdobeContribute6en_USLanguagePack\AdobeContribute6en_USLanguagePack.msi
Updating media info for: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16}
Path: E:\Adobe CS5\payloads\AdobeGermanSpeechAnalysisModels2All\Install.db
Updating media info for: {4438C826-1FD0-4D04-A70B-24FE1580AB21}
Path: E:\Adobe CS5\payloads\AdobeMiniBridge1-mul\Install.db
Updating media info for: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86_x64\Microsoft_VC80_CRT_x86_x64.msi
Updating media info for: {479C08E9-FACF-4190-A37A-81D65B4C8D4E}
Path: E:\Adobe CS5\payloads\AdobeContribute6-IEPlugin\Install.db
Updating media info for: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedWrapperAll\Install.db
Updating media info for: {4C08199E-0D93-4227-8325-F024E71CA7A1}
Path: E:\Adobe CS5\payloads\AdobeSING3-mul\Install.db
Updating media info for: {50A16F0B-47DA-4583-B4FE-E026719A2024}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US_x64\AdobePhotoshop12-en_US_x64.msi
Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
Path: E:\Adobe CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
Path: E:\Adobe CS5\payloads\AdobeReviewPanel2-mul\Install.db
Updating media info for: {5658F35F-15B9-1033-8337-97B78F2D0BE0}
Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler64-mul\AdobeInDesign7IconHandler64-mul.msi
Updating media info for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\AdobePremierePro5RoyaltyAll.msi
Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
Path: E:\Adobe CS5\payloads\AdobeMobileExtension_Flash11-mul\AdobeMobileExtension_Flash11-mul.msi
Updating media info for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Path: E:\Adobe CS5\payloads\AMEDolby5All_x64\AMEDolby5All_x64.msi
Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
Path: E:\Adobe CS5\payloads\BrowserLabCSLive-mul\Install.db
Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
Path: E:\Adobe CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
Path: E:\Adobe CS5\payloads\iPhone_Flash11-mul\iPhone_Flash11-mul.msi
Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
Updating media info for: {64D991B0-4E64-47AC-8A35-291DA2E7D02F}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10SupportAll\Install.db
Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
Path: E:\Adobe CS5\payloads\AdobeStoryExtension-mul\Install.db
Updating media info for: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core_x64\AdobePhotoshop12-Core_x64.msi
Updating media info for: {681DE732-3F3A-42F2-91C9-84B1CC9B8535}
Path: E:\Adobe CS5\payloads\AdobeContribute6en_GBLanguagePack\AdobeContribute6en_GBLanguagePack.msi
Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
Path: E:\Adobe CS5\payloads\AMECore5All_x64\Install.db
Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
Path: E:\Adobe CS5\payloads\AMECore5All\Install.db
Updating media info for: {69582206-7E5D-4476-A8F4-ECF90E9C8A69}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_US\AdobePhotoshop12-en_US.msi
Updating media info for: {6ACDB89B-63FB-4C7D-8490-7528E248F25B}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10en_USLanguagePack\AdobeAfterEffects10en_USLanguagePack.msi
Updating media info for: {6B485102-4593-43F6-BA45-F14D690B0C64}
Path: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
Updating media info for: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9}
Path: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyWrapperAll\AdobePremierePro5RoyaltyWrapperAll.msi
Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
Path: E:\Adobe CS5\payloads\AdobeLinguisticsAll\Install.db
Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
Path: E:\Adobe CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
Path: E:\Adobe CS5\payloads\AdobeDeviceCentral3-all\Install.db
Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
Path: E:\Adobe CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
Path: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
Updating media info for: {73A4DC5E-226E-42BA-8ECA-2822592AC044}
Path: E:\Adobe CS5\payloads\AdobeVideoProfilesCS3-mul\Install.db
Updating media info for: {771C9F59-3F22-4610-A23E-321A98ECA264}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5en_USLanguagePack\AdobeOnLocation5en_USLanguagePack.msi
Updating media info for: {7745F18B-FD8A-4011-BE16-588900C503D0}
Path: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Updating media info for: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\AdobeOnLocation5RoyaltyAll.msi
Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
Path: E:\Adobe CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
Path: E:\Adobe CS5\payloads\AdobeAPE3_x64-mul\Install.db
Updating media info for: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D}
Path: E:\Adobe CS5\payloads\AdobeContribute6-OfficePlugin\AdobeContribute6-OfficePlugin.msi
Updating media info for: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-Core\AdobePhotoshop12-Core.msi
Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
Path: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Updating media info for: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppLang-en_US\AdobeInDesign7AppLang-en_US.msi
Updating media info for: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}
Path: E:\Adobe CS5\payloads\AdobeFontsRequired_x64-mul\Install.db
Updating media info for: {805ABF27-1582-1033-B4AC-82A1DE0DD827}
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonBase-mul\Install.db
Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
Updating media info for: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB\AdobePhotoshop12-en_GB.msi
Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
Path: E:\Adobe CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
Updating media info for: {925D058B-564A-443A-B4B2-7E90C6432E55}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86_x64\Microsoft_VC80_ATL_x86_x64.msi
Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
Path: E:\Adobe CS5\payloads\AdobeOutputModuleAll\Install.db
Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
Updating media info for: {92D4A929-78F1-4EC3-B626-08B3CF5B784F}
Path: E:\Adobe CS5\payloads\AMEPCI5All\AMEPCI5All.msi
Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
Path: E:\Adobe CS5\payloads\AIR2_Flash11-en_US\Install.db
Updating media info for: {966B69F2-0FBD-1033-B01C-D13C02FFF33F}
Path: E:\Adobe CS5\payloads\AdobeInDesign7CommonLang-en_GB\AdobeInDesign7CommonLang-en_GB.msi
Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
Path: E:\Adobe CS5\payloads\AdobeCMaps3_x64-mul\Install.db
Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
Path: E:\Adobe CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
Updating media info for: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15-mul\AdobeIllustrator15-mul.msi
Updating media info for: {A013B68A-B1D9-470F-BB0F-816752F096A3}
Path: E:\Adobe CS5\payloads\AMEPCIWrapper5All_x64\Install.db
Updating media info for: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF}
Path: E:\Adobe CS5\payloads\AdobeInternationalEnglishSpeechAnalysisModels2All\AdobeInternationalEnglishSpeechAnalysisModels2All.msi
Updating media info for: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134}
Path: E:\Adobe CS5\payloads\AdobeEncoreFunctionalContent5All\Install.db
Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Path: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
Updating media info for: {A47C8AE9-D51B-4A58-A051-396158FC3012}
Path: E:\Adobe CS5\payloads\AdobePhotoshop12-en_GB_x64\AdobePhotoshop12-en_GB_x64.msi
Updating media info for: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E}
Path: E:\Adobe CS5\payloads\AdobeVideoProfilesAE3-mul\Install.db
Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
Path: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
Updating media info for: {AAE6F374-91CB-45FB-9282-4CFA0DED2088}
Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All\Install.db
Updating media info for: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582}
Path: E:\Adobe CS5\payloads\AdobeOnLocation5All\AdobeOnLocation5All.msi
Updating media info for: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyWrapperAll\Install.db
Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
Path: E:\Adobe CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
Path: E:\Adobe CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
Updating media info for: {B842A584-A0BF-4870-A850-9C0E52FD6A20}
Path: E:\Adobe CS5\payloads\AdobeEncore5en_USLanguagePack\AdobeEncore5en_USLanguagePack.msi
Updating media info for: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Path: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\AdobePremierePro5ProtectedAll.msi
Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
Path: E:\Adobe CS5\payloads\AdobePDFL9.9-mul\Install.db
Updating media info for: {BB024724-14D5-4AB6-B21C-74EDA63A0A39}
Path: E:\Adobe CS5\payloads\HIL_Help_Search\Install.db
Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Path: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
Path: E:\Adobe CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
Updating media info for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\AdobeAfterEffects10ProtectedAll.msi
Updating media info for: {C79312BD-3E76-4474-A10C-1435D1856A4B}
Path: E:\Adobe CS5\payloads\AdobeDreamweaver11-mul\AdobeDreamweaver11-mul.msi
Updating media info for: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86_x64\Microsoft_VC80_MFC_x86_x64.msi
Updating media info for: {C925A34A-01B9-42C3-BB88-C7A78835F0EC}
Path: E:\Adobe CS5\payloads\ph\ph.msi
Updating media info for: {CBDD7465-CE11-4A58-9497-C370B65923F1}
Path: E:\Adobe CS5\payloads\AdobeFontsRequired-mul\Install.db
Updating media info for: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3AllTrial\AdobeSoundbooth3AllTrial.msi
Updating media info for: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F}
Path: E:\Adobe CS5\payloads\AdobeAfterEffectsPresets10All\Install.db
Updating media info for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Path: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\AdobeAfterEffects10RoyaltyAll.msi
Updating media info for: {CD693E49-C5EF-4FA6-9037-9B636931C02B}
Path: E:\Adobe CS5\payloads\AdobeAmericanEnglishSpeechAnalysisModels2All\Install.db
Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
Path: E:\Adobe CS5\payloads\SwitchBoard2.0All\Install.db
Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
Path: E:\Adobe CS5\payloads\AdobeFlash11-mul\AdobeFlash11-mul.msi
Updating media info for: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_GBLanguagePack\AdobeIllustrator15en_GBLanguagePack.msi
Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
Path: E:\Adobe CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
Updating media info for: {D31D91FE-F0E8-4DF1-812C-9400BE92A386}
Path: E:\Adobe CS5\payloads\AdobeColorPhotoshop3-mul\Install.db
Updating media info for: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC}
Path: E:\Adobe CS5\payloads\AMEDolby5All\AMEDolby5All.msi
Updating media info for: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154}
Path: E:\Adobe CS5\payloads\AdobeIllustrator15en_USLanguagePack\AdobeIllustrator15en_USLanguagePack.msi
Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
Path: E:\Adobe CS5\payloads\aifsdk-win\Install.db
Updating media info for: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1}
Path: E:\Adobe CS5\payloads\AdobeAfterEffectsFunctionalContent10All\Install.db
Updating media info for: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D}
Path: E:\Adobe CS5\payloads\AdobeEncore5AllRetail\AdobeEncore5AllRetail.msi
Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Path: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
Updating media info for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\AdobeSoundbooth3ProtectedAll.msi
Updating media info for: {DE60F0DE-469A-42DC-A678-978313210057}
Path: E:\Adobe CS5\payloads\AdobeContribute6-mul\AdobeContribute6-mul.msi
Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
Path: E:\Adobe CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
Updating media info for: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase2-mul\Install.db
Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
Path: E:\Adobe CS5\payloads\Players_Flash11-mul\Players_Flash11-mul.msi
Updating media info for: {E39A5ABD-516B-46F9-A042-694BBA6A4E08}
Path: E:\Adobe CS5\payloads\AdobeFontsRecommended-mul\Install.db
Updating media info for: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04}
Path: E:\Adobe CS5\payloads\AdobeDreamweaver11en_USLanguagePack\AdobeDreamweaver11en_USLanguagePack.msi
Updating media info for: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9}
Path: E:\Adobe CS5\payloads\AdobeInDesign7IconHandler-mul\Install.db
Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
Path: E:\Adobe CS5\payloads\AdobeExtensionManager5.0All\Install.db
Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
Path: E:\Adobe CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
Path: E:\Adobe CS5\payloads\AdobeJRECS5-mul\Install.db
Updating media info for: {E6F68811-F702-492C-A7DA-D22CA670BC22}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3en_USLanguagePack\AdobeSoundbooth3en_USLanguagePack.msi
Updating media info for: {E7F2C606-8529-4028-B26E-8407DB43DD45}
Path: E:\Adobe CS5\payloads\AdobeFrenchSpeechAnalysisModels2All\Install.db
Updating media info for: {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
Path: E:\Adobe CS5\payloads\AdobeFlashCatalyst-mul\AdobeFlashCatalyst-mul.msi
Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
Path: E:\Adobe CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
Path: E:\Adobe CS5\payloads\TLF_Flash11-mul\TLF_Flash11-mul.msi
Updating media info for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Path: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\AdobeSoundbooth3RoyaltyAll.msi
Updating media info for: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040}
Path: E:\Adobe CS5\payloads\AdobeMotionPicture3-mul\Install.db
Updating media info for: {F46A4C18-2EAD-49F0-A244-994226F93B39}
Path: E:\Adobe CS5\payloads\AdobeJapaneseSpeechAnalysisModels2All\AdobeJapaneseSpeechAnalysisModels2All.msi
Updating media info for: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19}
Path: E:\Adobe CS5\payloads\AdobePremiereProFunctionalContent5All\Install.db
Updating media info for: {F6CCA85F-7527-4AFF-82B6-26532A74A244}
Path: E:\Adobe CS5\payloads\AdobeFireworks11en_GBLanguagePack\AdobeFireworks11en_GBLanguagePack.msi
Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
Path: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
Updating media info for: {F77882B9-A94F-44F4-A739-8370749255B6}
Path: E:\Adobe CS5\payloads\AdobePremierePro5SupportAll\Install.db
Updating media info for: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD}
Path: E:\Adobe CS5\payloads\AMEDolbyWrapper5All_x64\Install.db
Updating media info for: {F9766AC1-1461-1033-B862-DF8FE1C033BE}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppBase-mul\AdobeInDesign7AppBase-mul.msi
Updating media info for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Path: E:\Adobe CS5\payloads\AMEPCI5All_x64\AMEPCI5All_x64.msi
Updating media info for: {FBB02B04-C034-4382-A3F6-57416E2752C4}
Path: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\AdobeMasterCollection5-mul.msi
Updating media info for: {FD5603A3-1375-1033-872D-8F09140FFDB2}
Path: E:\Adobe CS5\payloads\AdobeInDesign7AppFSet-Roman\Install.db
-------------------- END - Updating Media Sources - END --------------------
[ 3432] Sun Feb 13 13:04:33 2011 INFO
Supported RIBS version range: [0.0.66.0,3.0.122.0]
----------------- CreatePayloadSession: machine is x64 ---------------
[ 3432] Sun Feb 13 13:04:38 2011 INFO
______ Verify Dependency Subscribers ______
Setting property "INSTALLDIR" to: C:\Program Files\Adobe
Setting property "installLanguage" to: en_GB
Attempting to find the selected language in the set of available payload languages
Setting property "installSourcePath" to: E:\Adobe CS5
Overwrite property "userASUPath" to: C:\Users\GARY&S~1\AppData\Local\Adobe\OOBE\PDApp\
Found payload actions:
Deciding what installer mode to use...
BEGIN Setting requested payload actions
Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: true
Action string for {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is none
Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: true
Action string for {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is none
Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: true
Action string for {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is none
Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: true
Action string for {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is none
Value returned on lookup of payload: {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is: true
Action string for {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is none
Payload {55516693-25E2-4620-BF94-6BA66B00419F} Adobe Player for Embedding_3.1_AdobeAPE3-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: true
Action string for {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is none
Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: true
Action string for {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is none
Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: true
Action string for {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is none
Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: true
Action string for {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is none
Value returned on lookup of payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is: true
Action string for {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is none
Payload {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: true
Action string for {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is none
Value returned on lookup of payload: {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is: true
Action string for {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5 is none
Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: true
Action string for {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is none
Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: true
Action string for {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is none
Value returned on lookup of payload: {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is: true
Action string for {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is none
Payload {FA2A2592-3F40-456D-ACEC-166CB79D4F98} Adobe CSXS Infrastructure CS5_2.0.1_AdobeCSXSInfrastructure2-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: true
Action string for {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is none
Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: true
Action string for {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is none
Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: true
Action string for {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is none
Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: true
Action string for {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is none
Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: true
Action string for {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is none
Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: true
Action string for {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is none
Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: true
Action string for {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is none
Value returned on lookup of payload: {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is: true
Action string for {4569AD91-47F4-4D9E-8FC9-717EC32D7AE1} Microsoft_VC80_CRT_x86_x64 is none
Value returned on lookup of payload: {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is: true
Action string for {1E9FC118-651D-4934-97BE-E53CAE5C7D45} Microsoft_VC80_MFCLOC_x86_x64 is none
Value returned on lookup of payload: {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is: true
Action string for {C8C1BAD5-54E6-4146-AD07-3A8AD36569C3} Microsoft_VC80_MFC_x86_x64 is none
Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: true
Action string for {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is none
Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: true
Action string for {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is none
Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: true
Action string for {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is none
Value returned on lookup of payload: {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is: true
Action string for {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is none
Payload {0061DED1-0204-44C5-B6E0-FAD6AA00E320} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: true
Action string for {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is none
Value returned on lookup of payload: {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is: true
Action string for {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is none
Payload {187A7A38-6DD4-4549-AECD-22BA6BC2F002} Adobe ExtendScript Toolkit CS5_3.5.0_AdobeExtendScriptToolkit3.5.0-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: true
Action string for {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is none
Value returned on lookup of payload: {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is: true
Action string for {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is none
Payload {9AF7B703-B806-4C74-94E5-82963EFC0188} Adobe Extension Manager CS5_5.0.1_AdobeExtensionManager5.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: true
Action string for {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is none
Value returned on lookup of payload: {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is: true
Action string for {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is none
Payload {FD58D99B-9927-4226-8E00-959A4F76BD89} Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: true
Action string for {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is none
Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: true
Action string for {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is none
Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: true
Action string for {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is none
Value returned on lookup of payload: {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is: true
Action string for {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is none
Payload {D8676884-2C59-41BB-B315-486D98A20867} Adobe Media Encoder CS5 X64_5.0.1_AMECore5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: true
Action string for {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is none
Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: true
Action string for {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is none
Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
Action string for {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is none
Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: true
Action string for {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is none
Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: true
Action string for {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is none
Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
Action string for {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is none
Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: true
Action string for {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is none
Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
Action string for {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is none
Value returned on lookup of payload: {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is: true
Action string for {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is none
Payload {F9997A85-B21A-48E4-9C8A-7E1352AB1C62} Adobe Player for Embedding x64_3.1_AdobeAPE3_x64-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: true
Action string for {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is none
Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: true
Action string for {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is none
Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: true
Action string for {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is none
Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: true
Action string for {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is none
Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: true
Action string for {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is none
Value returned on lookup of payload: {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is: true
Action string for {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is none
Payload {5056CCD0-DDD6-47D1-9D46-612FA03FF82E} Adobe Media Encoder CS5 PCI WRAPPER X64_5.0.1_AMEPCIWrapper5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is: true
Action string for {A013B68A-B1D9-470F-BB0F-816752F096A3} Adobe Media Encoder CS5 PCI WRAPPER X64 is none
Value returned on lookup of payload: {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is: true
Action string for {7F9C94CD-0BAC-4F8F-8990-6A5886F4D550} Required Common Fonts Installation x64 is none
Value returned on lookup of payload: {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is: true
Action string for {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is none
Payload {5C6A2D6E-4C4B-40AC-998A-B09B24DB631F} Adobe Media Encoder CS5 Dolby WRAPPER X64_5.0.1_AMEDolbyWrapper5All_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is: true
Action string for {F8F0792D-8A6B-44F6-B2AF-AD1A40DF1BFD} Adobe Media Encoder CS5 Dolby WRAPPER X64 is none
Value returned on lookup of payload: {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is: true
Action string for {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is none
Payload {010B3947-C8F7-4F18-BF03-49A8662CC4A9} Adobe Photoshop CS5 Support_12.0.3_AdobePhotoshop12-Support is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is: true
Action string for {0A6FC585-E761-4776-A4F3-BDA1E4FE1B7A} Adobe Photoshop CS5 Support is none
Value returned on lookup of payload: {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is: true
Action string for {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is none
Payload {A1CABA8D-CF84-402F-8948-D2567915D40C} Pixel Bender Toolkit_2.5_aifsdk-win is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: true
Action string for {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is none
Value returned on lookup of payload: {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is: true
Action string for {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is none
Payload {3FE9B5F2-1ABD-1027-89E7-AA1204825831} Adobe InDesign CS5 Application Base Files2_7.0.3.535_AdobeInDesign7AppBase2-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is: true
Action string for {DEC9BB26-1381-1033-A965-E3BD5F2EF8BC} Adobe InDesign CS5 Application Base Files2 is none
Value returned on lookup of payload: {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is: true
Action string for {FD5603A3-1375-1033-872D-8F09140FFDB2} Adobe InDesign CS5 Application Feature Set Files is none
Value returned on lookup of payload: {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is: true
Action string for {805ABF27-1582-1033-B4AC-82A1DE0DD827} Adobe InDesign CS5 Common Base Files is none
Value returned on lookup of payload: {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is: true
Action string for {925D058B-564A-443A-B4B2-7E90C6432E55} Microsoft_VC80_ATL_x86_x64 is none
Value returned on lookup of payload: {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is: true
Action string for {C925A34A-01B9-42C3-BB88-C7A78835F0EC} ph is none
Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: true
Action string for {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is none
Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: true
Action string for {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is none
Value returned on lookup of payload: {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is: true
Action string for {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is none
Payload {03AA8100-8A65-11DF-9F66-0013724DD917} DeviceCentral_3.0.1_AdobeDeviceCentral3-all is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: true
Action string for {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is none
Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
Action string for {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is none
Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is: true
Action string for {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is none
Payload {AD3268E2-8A6B-11DF-8A38-0024E8692489} DeviceCentral_3.0.1_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: true
Action string for {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is none
Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is: true
Action string for {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is none
Payload {123ABCFA-AE86-4B1C-A4D8-A732BEF9C86B} Adobe Bridge CS5_4.0.4_AdobeBridge4-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: true
Action string for {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is none
Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: true
Action string for {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is none
Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: true
Action string for {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is none
Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: true
Action string for {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is none
Value returned on lookup of payload: {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is: true
Action string for {BB024724-14D5-4AB6-B21C-74EDA63A0A39} HIL Help Search is none
Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: true
Action string for {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is none
Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
Action string for {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is none
Value returned on lookup of payload: {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is: true
Action string for {E39A5ABD-516B-46F9-A042-694BBA6A4E08} Recommended Common Fonts Installation is none
Value returned on lookup of payload: {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is: true
Action string for {CBDD7465-CE11-4A58-9497-C370B65923F1} Required Common Fonts Installation is none
Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: true
Action string for {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is none
Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: true
Action string for {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is none
Value returned on lookup of payload: {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is: true
Action string for {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is none
Payload {32841ECE-EC28-42CD-A4DD-6CE832A7EA8D} Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: true
Action string for {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is none
Value returned on lookup of payload: {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is: true
Action string for {4438C826-1FD0-4D04-A70B-24FE1580AB21} Adobe Mini Bridge CS5 is none
Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
Action string for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is donotinstall
Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: true
Action string for {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is none
Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: true
Action string for {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is none
Value returned on lookup of payload: {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is: true
Action string for {11C0657F-2BD4-4CBC-87F3-9455DC91886E} Recommended Common Fonts Installation x64 is none
Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: true
Action string for {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is none
Value returned on lookup of payload: {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is: true
Action string for {D31D91FE-F0E8-4DF1-812C-9400BE92A386} AdobeColorPhotoshop CS5 is none
Value returned on lookup of payload: {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is: true
Action string for {73A4DC5E-226E-42BA-8ECA-2822592AC044} AdobeColorVideoProfilesCS CS5 is none
Value returned on lookup of payload: {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is: true
Action string for {CD693E49-C5EF-4FA6-9037-9B636931C02B} AmericanEnglishSpeechAnalysisModels is none
Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: true
Action string for {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is none
Value returned on lookup of payload: {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is: true
Action string for {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is none
Payload {88BE801D-C8EC-46A4-92AC-06CE56FE0E0A} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: true
Action string for {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is none
Value returned on lookup of payload: {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is: true
Action string for {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is none
Payload {A69CC698-119E-450F-9AEC-2F377C03B33B} AIR2 For Adobe Flash Pro_2.0.1_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: true
Action string for {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is none
Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is: true
Action string for {CC0EF75D-9336-4E4F-B4A2-99E2E60E161F} Adobe After Effects CS5 Presets is none
Value returned on lookup of payload: {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is: true
Action string for {64D991B0-4E64-47AC-8A35-291DA2E7D02F} Adobe After Effects CS5 Support is none
Value returned on lookup of payload: {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is: true
Action string for {D5E7D8B9-9B8F-4DA0-9B2C-167DC889B0E1} Adobe After Effects CS5 Template Projects & Footage is none
Value returned on lookup of payload: {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is: true
Action string for {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is none
Payload {AAC33035-8CD9-4089-900B-10F4350AE81E} Adobe After Effects CS5 Third Party Content Wrapper_10.0.1_AdobeAfterEffects10ProtectedWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is: true
Action string for {406D22BD-7910-479B-96AA-0DB8A36C694B} Adobe After Effects CS5 Third Party Content Wrapper is none
Value returned on lookup of payload: {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is: true
Action string for {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is none
Payload {A8573435-DB08-4E7E-8E19-D16BD9A04736} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper_10.0.1_AdobeAfterEffects10RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is: true
Action string for {20F72893-AEC7-4954-9EAA-F07FD6184781} Adobe After Effects CS5 Third Party RoyaltyContent Wrapper is none
Value returned on lookup of payload: {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is: true
Action string for {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is none
Payload {DF2B2B91-F938-1051-88C6-AE7C8C5B3B23} Adobe Buzzword CS5_1.0_AdobeBuzzword-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is: true
Action string for {3F6B5CAC-733F-1029-B5BD-C0F5E35809F0} Adobe Buzzword CS5 is none
Value returned on lookup of payload: {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is: true
Action string for {A32910E5-4084-4A0E-9FFF-D2E9C1B1C134} Adobe Encore CS5 Library is none
Value returned on lookup of payload: {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is: true
Action string for {1A48007B-34D2-44BD-8708-B570F5339C14} Adobe Encore CS5 Royalty Codecs Installer Wrapper is none
Value returned on lookup of payload: {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is: true
Action string for {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1 is none
Value returned on lookup of payload: {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is: true
Action string for {E4CB336B-159D-1033-B84D-B9A01A0BE4A9} Adobe InDesign CS5 Icon Handler is none
Value returned on lookup of payload: {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is: false
Action string for {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is donotinstall
Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is not allowed therefore shall be re-checking later
Value returned on lookup of payload: {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is: false
Action string for {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is donotinstall
Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is not allowed therefore shall be re-checking later
Value returned on lookup of payload: {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is: true
Action string for {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is none
Payload {6C6D990F-FC88-4F07-912C-DA37468D9A3C} Adobe OnLocation CS5 Royalty Content Wrapper_5.0.1_AdobeOnLocation5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is: true
Action string for {01367616-4132-4311-911F-49D2EA82F7C2} Adobe OnLocation CS5 Royalty Content Wrapper is none
Value returned on lookup of payload: {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is: true
Action string for {F4EC52C6-1223-4EA9-8C48-F4E6AB2EEC19} Adobe Premiere Pro CS5 Functional Content is none
Value returned on lookup of payload: {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is: true
Action string for {F77882B9-A94F-44F4-A739-8370749255B6} Adobe Premiere Pro CS5 Support is none
Value returned on lookup of payload: {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is: true
Action string for {4C08199E-0D93-4227-8325-F024E71CA7A1} Adobe SING CS5 is none
Value returned on lookup of payload: {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is: true
Action string for {4BE1791F-1D8A-4B8E-B803-D97C5D7CB245} Adobe Soundbooth CS5 Codecs Wrapper is none
Value returned on lookup of payload: {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is: true
Action string for {ADAF6949-4547-4B3D-97C5-6FB4D0C08A1E} Adobe Soundbooth CS5 Royalty Codecs Wrapper is none
Value returned on lookup of payload: {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is: true
Action string for {157D044B-C60D-1015-B0DB-A40823CC0F49} Adobe Toolhints CS5 is none
Value returned on lookup of payload: {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is: true
Action string for {A5A8E72E-1B9D-4F99-ADED-F3595CB3D03E} AdobeColorVideoProfilesAE CS5 is none
Value returned on lookup of payload: {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is: true
Action string for {F3ECF5C7-9A9D-460A-B3D6-C7E4C1DFD040} AdobeMotionPicture CS5 is none
Value returned on lookup of payload: {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is: true
Action string for {04D84E18-23ED-46EA-9B41-789433E34D03} Firefox Plugin CS5 is none
Value returned on lookup of payload: {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is: true
Action string for {E7F2C606-8529-4028-B26E-8407DB43DD45} FrenchSpeechAnalysisModels is none
Value returned on lookup of payload: {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is: true
Action string for {4355EE3F-2FDD-4EF4-83EA-2465FBF95B16} GermanSpeechAnalysisModels is none
Value returned on lookup of payload: {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is: true
Action string for {479C08E9-FACF-4190-A37A-81D65B4C8D4E} IE Plugin CS5 is none
Value returned on lookup of payload: {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is: true
Action string for {A1E0C87F-BFE5-490A-898E-05BD4DD2BADF} InternationalEnglishSpeechAnalysisModels is none
Value returned on lookup of payload: {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is: true
Action string for {234A555C-70F5-48FB-A7E2-32410EB5AF64} ItalianSpeechAnalysisModels is none
Value returned on lookup of payload: {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is: true
Action string for {F46A4C18-2EAD-49F0-A244-994226F93B39} JapaneseSpeechAnalysisModels is none
Value returned on lookup of payload: {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is: true
Action string for {0EDAD58E-71F3-4D0E-9D32-A205533FC0E9} KoreanSpeechAnalysisModels is none
Value returned on lookup of payload: {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is: true
Action string for {7B7DE224-2ACA-41E2-A94D-5A6C6D75106D} Office Plugin CS5 is none
Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: true
Action string for {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is none
Value returned on lookup of payload: {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is: true
Action string for {36D02DA9-35F2-4686-A2FE-EF3014D2E226} SpanishSpeechAnalysisModels is none
Value returned on lookup of payload: {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is: true
Action string for {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is none
Payload {22C1290B-8DC3-4C8B-93E2-4373B9AAB1CC} TLF For Adobe Flash Pro_1.0.1_TLF_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: true
Action string for {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is none
Value returned on lookup of payload: {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is: true
Action string for {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is none
Payload {62466A6D-1130-4D66-9D65-ED3E1A988E12} iPhone Publishing_1.0.1_iPhone_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: true
Action string for {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is none
Value returned on lookup of payload: {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is: true
Action string for {5658F35F-15B9-1033-8337-97B78F2D0BE0} Adobe InDesign CS5 Icon Handler x64 is none
Value returned on lookup of payload: {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is: true
Action string for {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is none
Payload {AAA45CA1-CEF2-45A9-9162-6774CFFF8260} Adobe Premiere Pro CS5 Third Party Content Wrapper_5.0.3_AdobePremierePro5ProtectedWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is: true
Action string for {22F41D72-2E97-46AE-B8C4-EF66876C7838} Adobe Premiere Pro CS5 Third Party Content Wrapper is none
Value returned on lookup of payload: {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is: true
Action string for {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is none
Payload {CB8BB160-EC13-4D89-8990-F15F01E74961} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper_5.0.3_AdobePremierePro5RoyaltyWrapperAll is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is: true
Action string for {6BA6F6D7-1D30-482A-B9B8-20E79D6DB4F9} Adobe Premiere Pro CS5 Third Party Royalty Content Wrapper is none
Value returned on lookup of payload: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is: true
Action string for {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is install
Selection of payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content is forbidden by the policy.
Value returned on lookup of payload: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is: true
Action string for {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is install
Selection of payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is: true
Action string for {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is install
Selection of payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is: false
Action string for {D3598CAC-AEB3-4234-A1E0-16F47D5F38CC} Adobe Media Encoder CS5 Dolby is none
Value returned on lookup of payload: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is: true
Action string for {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is install
Selection of payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64 is forbidden by the policy.
Value returned on lookup of payload: {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is: false
Action string for {92D4A929-78F1-4EC3-B626-08B3CF5B784F} Adobe Media Encoder CS5 PCI is none
Value returned on lookup of payload: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is: true
Action string for {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is install
Selection of payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64 is forbidden by the policy.
Value returned on lookup of payload: {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is: true
Action string for {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is install
Selection of payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is: true
Action string for {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is install
Selection of payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content is forbidden by the policy.
Value returned on lookup of payload: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is: true
Action string for {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is install
Selection of payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content is forbidden by the policy.
Value returned on lookup of payload: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is: true
Action string for {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is install
Selection of payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs is forbidden by the policy.
Value returned on lookup of payload: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is: true
Action string for {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is install
Selection of payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs is forbidden by the policy.
Value returned on lookup of payload: {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is: true
Action string for {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection is install
Value returned on lookup of payload: {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is: true
Action string for {CBE4F6C3-788E-4CAC-BA25-26FE39A3BC8C} Adobe Soundbooth is none
Value returned on lookup of payload: {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is: true
Action string for {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is none
Payload {E6F68811-F702-492C-A7DA-D22CA670BC22} Adobe Soundbooth_AdobeSoundbooth3en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is: true
Action string for {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is none
Payload {64C19EC0-24A3-4F6F-A0AD-C701C8C48700} Adobe OnLocation CS5_5.0.1_AdobeOnLocation5All is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is: true
Action string for {ABDC1F61-2C50-4BB1-ACDA-66D412D72582} Adobe OnLocation CS5 is none
Value returned on lookup of payload: {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is: true
Action string for {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is none
Payload {771C9F59-3F22-4610-A23E-321A98ECA264} Adobe OnLocation CS5_AdobeOnLocation5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is: false
Action string for {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is install
Value returned on lookup of payload: {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is: true
Action string for {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is none
Payload {4FC4B869-AD0D-4A56-B626-2926EB2C48D0} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is: true
Action string for {C79312BD-3E76-4474-A10C-1435D1856A4B} Adobe Dreamweaver CS5 is none
Value returned on lookup of payload: {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is: true
Action string for {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is none
Payload {F19DAA62-588A-46D3-A092-C808F565D633} Adobe Dreamweaver CS5_11.0.3_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is: true
Action string for {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is none
Payload {E3E040E8-4CCD-4C71-8BAF-80BB2AD5DA04} Adobe Dreamweaver CS5_AdobeDreamweaver11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is: true
Action string for {DE60F0DE-469A-42DC-A678-978313210057} Adobe Contribute CS5 is none
Value returned on lookup of payload: {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is: false
Action string for {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is none
Payload {414BDCF9-DE14-4083-BE96-2F4193CE8BBA} Adobe Contribute CS5_AdobeContribute6en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is: true
Action string for {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is none
Payload {681DE732-3F3A-42F2-91C9-84B1CC9B8535} Adobe Contribute CS5_AdobeContribute6en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is: false
Action string for {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 is install
Value returned on lookup of payload: {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is: true
Action string for {164965E8-4BB0-4EEB-AFBA-75785A2A2A7F} Adobe Fireworks CS5 is none
Value returned on lookup of payload: {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is: false
Action string for {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is none
Payload {3A8C7CB3-2A2E-4EB9-99C9-DF08C324BA70} Adobe Fireworks CS5_AdobeFireworks11en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is: true
Action string for {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is none
Payload {F6CCA85F-7527-4AFF-82B6-26532A74A244} Adobe Fireworks CS5_AdobeFireworks11en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is: true
Action string for {D8465547-5D5B-4856-A93A-8AC0A05C5D4D} Adobe Encore CS5 is none
Value returned on lookup of payload: {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is: true
Action string for {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is none
Payload {B842A584-A0BF-4870-A850-9C0E52FD6A20} Adobe Encore CS5_AdobeEncore5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is: true
Action string for {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is none
Payload {EA4B7009-6FAC-41b1-BBB6-E76680C924DC} Adobe Illustrator CS5_15.0.2_AdobeIllustrator15-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is: true
Action string for {9B97EC91-B3FD-4BFF-88FC-5345A26AC2E7} Adobe Illustrator CS5 is none
Value returned on lookup of payload: {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is: false
Action string for {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is none
Payload {D3A8C87E-ED6A-41DB-8B21-C29EDA65B154} Adobe Illustrator CS5_AdobeIllustrator15en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is: true
Action string for {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is none
Payload {D0DAEA50-AD52-4BF9-AD5F-3E09564A8692} Adobe Illustrator CS5_AdobeIllustrator15en_GBLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is: true
Action string for {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is none
Payload {5733850A-FF54-431F-A935-71A96AE80F95} Adobe Photoshop CS5 Core_12.0.3_AdobePhotoshop12-Core is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is: true
Action string for {7DFEBBA4-81E1-425B-BBAA-06E9E5BBD97E} Adobe Photoshop CS5 Core is none
Value returned on lookup of payload: {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is: false
Action string for {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is none
Payload {69582206-7E5D-4476-A8F4-ECF90E9C8A69} Adobe Photoshop CS5 English Language Pack_AdobePhotoshop12-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is: true
Action string for {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is none
Payload {87AFDFF2-D852-4B1F-ABFB-0EAFA5A39B7B} Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is: true
Action string for {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is none
Payload {FA5686B7-A305-4A41-93CD-48BAC929C313} Adobe Photoshop CS5 Core_x64_12.0.3_AdobePhotoshop12-Core_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is: true
Action string for {667C8B6C-3EAF-4646-A8EC-D85CCC4D3D84} Adobe Photoshop CS5 Core_x64 is none
Value returned on lookup of payload: {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is: false
Action string for {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is none
Payload {50A16F0B-47DA-4583-B4FE-E026719A2024} Adobe Photoshop CS5 English Language Pack_x64_AdobePhotoshop12-en_US_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is: true
Action string for {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is none
Payload {A47C8AE9-D51B-4A58-A051-396158FC3012} Adobe Photoshop CS5 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64 is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is: true
Action string for {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is none
Payload {D20D27DB-B598-4142-8B7E-BE1342BA77C9} Adobe After Effects CS5_10.0.1_AdobeAfterEffects10AllRetail is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is: true
Action string for {0E659C1D-7686-4322-A501-58E3FEB4E743} Adobe After Effects CS5 is none
Value returned on lookup of payload: {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is: true
Action string for {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is none
Payload {6ACDB89B-63FB-4C7D-8490-7528E248F25B} Adobe After Effects CS5_AdobeAfterEffects10en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is: true
Action string for {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is none
Payload {7E0C3ACA-19FA-1027-8580-84E7230B548F} Adobe InDesign CS5 Application Base Files_7.0.3.535_AdobeInDesign7AppBase-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is: true
Action string for {F9766AC1-1461-1033-B862-DF8FE1C033BE} Adobe InDesign CS5 Application Base Files is none
Value returned on lookup of payload: {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is: false
Action string for {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is none
Payload {7EB208EE-0C2B-1033-A6DC-E1BD0289A1F4} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is: true
Action string for {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is none
Payload {966B69F2-0FBD-1033-B01C-D13C02FFF33F} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is: true
Action string for {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is none
Payload {05BAD153-18C5-1027-8235-EC70CC150594} Adobe InDesign CS5 Application Language Files_7.0.3.535_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is: true
Action string for {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is none
Payload {26B63C3A-0BFF-1033-B389-A7ACEC31657E} Adobe InDesign CS5 Application Language Files_AdobeInDesign7AppLang-en_GB is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is: true
Action string for {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is none
Payload {0A9AAB1E-0FEA-1033-851A-888C0B8E78B5} Adobe InDesign CS5 Common Language Files_AdobeInDesign7CommonLang-en_US is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is: true
Action string for {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is none
Payload {FDE4CB87-FDB7-40CE-A6D9-189E09FCABE8} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5AllRetail is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is: true
Action string for {0B754B55-6F63-461E-BB75-E8C883BDF88F} Adobe Premiere Pro CS5 is none
Value returned on lookup of payload: {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is: true
Action string for {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is none
Payload {B61DD7DA-4942-40A2-AF16-14957DFFEF09} Adobe Premiere Pro CS5_5.0.3_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is: true
Action string for {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is none
Payload {34F82E6B-8096-45CA-B604-ACACAC22E553} Adobe Premiere Pro CS5_AdobePremierePro5en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is: true
Action string for {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is none
Payload {70CAC073-3CDD-498C-80F7-79B76A61D7E6} Adobe Flash CS5_11.0.2_AdobeFlash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: true
Action string for {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is none
Value returned on lookup of payload: {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is: true
Action string for {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is none
Payload {F637969B-336C-4533-9D4D-D0163A39C42F} Adobe Flash CS5_11.0.2_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: true
Action string for {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is none
Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: true
Action string for {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is none
Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: true
Action string for {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is none
Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
Selection of payload {AAE6F374-91CB-45FB-9282-4CFA0DED2088} Adobe Media Encoder CS5 Dolby WRAPPER is allowed but the user has marked it for not to install
Selection of payload {33A3F995-8333-4676-8D6F-AB7674BB52EA} Adobe Media Encoder CS5 PCI WRAPPER is allowed but the user has marked it for not to install
END Setting requested payload actions
Collected advanced path check information for INSTALLDIR
INSTALLDIR is a well-formed path
INSTALLDIR is not the root path
INSTALLDIR is on a local volume
INSTALLDIR is on a writable volume
INSTALLDIR is not on a case sensitive volume
INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
[ 3432] Sun Feb 13 13:04:41 2011 INFO
::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
In InstallPreSystemCheckProc
Custom action return code: 0
:: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 14.8424 miliseconds (0.0148424 seconds)
::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
:: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 18.3078 miliseconds (0.0183078 seconds)
::START TIMER:: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}]
Font Installer: Fonts STI Custom Hook 1.6 Release
:: END TIMER :: [System check :{7F9C94CD-0BAC-4F8F-8990-6A5886F4D550}] took 21.4545 miliseconds (0.0214545 seconds)
[ 3432] Sun Feb 13 13:04:42 2011 INFO
::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
CustomHooksTester -> In InstallPreSystemCheckProc
:: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 14.6595 miliseconds (0.0146595 seconds)
::START TIMER:: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}]
:: END TIMER :: [System check :{E39A5ABD-516B-46F9-A042-694BBA6A4E08}] took 21.1902 miliseconds (0.0211902 seconds)
::START TIMER:: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}]
:: END TIMER :: [System check :{CBDD7465-CE11-4A58-9497-C370B65923F1}] took 43.5172 miliseconds (0.0435172 seconds)
::START TIMER:: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}]
:: END TIMER :: [System check :{11C0657F-2BD4-4CBC-87F3-9455DC91886E}] took 21.5817 miliseconds (0.0215817 seconds)
::START TIMER:: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}]
:: END TIMER :: [System check :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 21.2257 miliseconds (0.0212257 seconds)
[ 3432] Sun Feb 13 13:04:43 2011 INFO
::START TIMER:: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}]
:: END TIMER :: [System check :{04D84E18-23ED-46EA-9B41-789433E34D03}] took 17.4473 miliseconds (0.0174473 seconds)
::START TIMER:: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
:: END TIMER :: [System check :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 15.8019 miliseconds (0.0158019 seconds)
::START TIMER:: [System check :{DE60F0DE-469A-42DC-A678-978313210057}]
:: END TIMER :: [System check :{DE60F0DE-469A-42DC-A678-978313210057}] took 15.0342 miliseconds (0.0150342 seconds)
::START TIMER:: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
:: END TIMER :: [System check :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 15.517 miliseconds (0.015517 seconds)
::START TIMER:: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}]
:: END TIMER :: [System check :{164965E8-4BB0-4EEB-AFBA-75785A2A2A7F}] took 30.7866 miliseconds (0.0307866 seconds)
[ 3432] Sun Feb 13 13:04:43 2011 WARN
Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
[ 3432] Sun Feb 13 13:04:44 2011 WARN
Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
[ 3432] Sun Feb 13 13:04:44 2011 INFO
Payloads passed preflight validation.
Call PreSession Custom Hook
Calling the custom action code for pre-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403}
::START TIMER:: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}]
[ 3068] Sun Feb 13 13:04:44 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
[ 3068] Sun Feb 13 13:04:46 2011 INFO
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86\, Result: 0
Configuring MSI ProductCode: {08D2E121-7F6A-43EB-97FD-629B44903403}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbB06A.tmp"
1: 0 2: 1033 3: 1252
[ 3068] Sun Feb 13 13:04:47 2011 INFO
=== Logging started: 13/02/2011 13:04:47 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC90_CRT_x86
Action 13:04:47: INSTALL.
Action start 13:04:47: INSTALL.
Action 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action start 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action ended 13:04:47: SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
Action 13:04:47: AppSearch. Searching for installed applications
Action start 13:04:47: AppSearch.
Action ended 13:04:47: AppSearch. Return value 0.
Action 13:04:47: FindRelatedProducts. Searching for related applications
Action start 13:04:47: FindRelatedProducts.
Action ended 13:04:47: FindRelatedProducts. Return value 0.
Action 13:04:47: ValidateProductID.
Action start 13:04:47: ValidateProductID.
Action ended 13:04:47: ValidateProductID. Return value 1.
Action 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action start 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7.
Action ended 13:04:47: WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7. Return value 1.
Action 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF.
Action start 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF.
Action ended 13:04:47: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF. Return value 1.
Action 13:04:47: CostInitialize. Computing space requirements
Action start 13:04:47: CostInitialize.
Action ended 13:04:47: CostInitialize. Return value 1.
Action 13:04:47: FileCost. Computing space requirements
Action start 13:04:47: FileCost.
Action ended 13:04:47: FileCost. Return value 1.
Action 13:04:47: IsolateComponents.
Action start 13:04:47: IsolateComponents.
Action ended 13:04:47: IsolateComponents. Return value 0.
Action 13:04:47: CostFinalize. Computing space requirements
Action start 13:04:47: CostFinalize.
Action ended 13:04:47: CostFinalize. Return value 1.
Action 13:04:47: SetODBCFolders. Initializing ODBC directories
Action start 13:04:47: SetODBCFolders.
Action ended 13:04:47: SetODBCFolders. Return value 0.
Action 13:04:47: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:04:47: MigrateFeatureStates.
Action ended 13:04:47: MigrateFeatureStates. Return value 0.
Action 13:04:47: InstallValidate. Validating install
Action start 13:04:47: InstallValidate.
Action ended 13:04:47: InstallValidate. Return value 1.
Action 13:04:47: RemoveExistingProducts. Removing applications
Action start 13:04:47: RemoveExistingProducts.
Action ended 13:04:47: RemoveExistingProducts. Return value 0.
Action 13:04:47: InstallInitialize.
Action start 13:04:47: InstallInitialize.
[ 3068] Sun Feb 13 13:04:48 2011 INFO
Action ended 13:04:48: InstallInitialize. Return value 1.
Action 13:04:48: ProcessComponents. Updating component registration
Action start 13:04:48: ProcessComponents.
Action 13:04:48: GenerateScript. Generating script operations for action:
Action ended 13:04:48: ProcessComponents. Return value 1.
Action 13:04:48: UnpublishComponents. Unpublishing Qualified Components
Action start 13:04:48: UnpublishComponents.
Action ended 13:04:48: UnpublishComponents. Return value 0.
Action 13:04:48: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:04:48: MsiUnpublishAssemblies.
Action ended 13:04:48: MsiUnpublishAssemblies. Return value 1.
Action 13:04:48: UnpublishFeatures. Unpublishing product features
Action start 13:04:48: UnpublishFeatures.
Action ended 13:04:48: UnpublishFeatures. Return value 1.
Action 13:04:48: StopServices. Stopping services
Action start 13:04:48: StopServices.
Action ended 13:04:48: StopServices. Return value 1.
Action 13:04:48: DeleteServices. Deleting services
Action start 13:04:48: DeleteServices.
Action ended 13:04:48: DeleteServices. Return value 1.
Action 13:04:48: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:04:48: UnregisterComPlus.
Action ended 13:04:48: UnregisterComPlus. Return value 0.
Action 13:04:48: SelfUnregModules. Unregistering modules
Action start 13:04:48: SelfUnregModules.
Action ended 13:04:48: SelfUnregModules. Return value 1.
Action 13:04:48: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:04:48: UnregisterTypeLibraries.
Action ended 13:04:48: UnregisterTypeLibraries. Return value 0.
Action 13:04:48: RemoveODBC. Removing ODBC components
Action start 13:04:48: RemoveODBC.
Action ended 13:04:48: RemoveODBC. Return value 1.
Action 13:04:48: UnregisterFonts. Unregistering fonts
Action start 13:04:48: UnregisterFonts.
Action ended 13:04:48: UnregisterFonts. Return value 1.
Action 13:04:48: RemoveRegistryValues. Removing system registry values
Action start 13:04:48: RemoveRegistryValues.
Action ended 13:04:48: RemoveRegistryValues. Return value 1.
Action 13:04:48: UnregisterClassInfo. Unregister class servers
Action start 13:04:48: UnregisterClassInfo.
Action ended 13:04:48: UnregisterClassInfo. Return value 0.
Action 13:04:48: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:04:48: UnregisterExtensionInfo.
Action ended 13:04:48: UnregisterExtensionInfo. Return value 0.
Action 13:04:48: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:04:48: UnregisterProgIdInfo.
Action ended 13:04:48: UnregisterProgIdInfo. Return value 0.
Action 13:04:48: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:04:48: UnregisterMIMEInfo.
Action ended 13:04:48: UnregisterMIMEInfo. Return value 0.
Action 13:04:48: RemoveIniValues. Removing INI file entries
Action start 13:04:48: RemoveIniValues.
Action ended 13:04:48: RemoveIniValues. Return value 1.
Action 13:04:48: RemoveShortcuts. Removing shortcuts
Action start 13:04:48: RemoveShortcuts.
Action ended 13:04:48: RemoveShortcuts. Return value 0.
Action 13:04:48: RemoveEnvironmentStrings. Updating environment strings
Action start 13:04:48: RemoveEnvironmentStrings.
Action ended 13:04:48: RemoveEnvironmentStrings. Return value 1.
Action 13:04:48: RemoveDuplicateFiles. Removing duplicated files
Action start 13:04:48: RemoveDuplicateFiles.
Action ended 13:04:48: RemoveDuplicateFiles. Return value 1.
Action 13:04:48: RemoveFiles. Removing files
Action start 13:04:48: RemoveFiles.
Action ended 13:04:48: RemoveFiles. Return value 0.
Action 13:04:48: RemoveFolders. Removing folders
Action start 13:04:48: RemoveFolders.
Action ended 13:04:48: RemoveFolders. Return value 0.
Action 13:04:48: CreateFolders. Creating folders
Action start 13:04:48: CreateFolders.
Action ended 13:04:48: CreateFolders. Return value 0.
Action 13:04:48: MoveFiles. Moving files
Action start 13:04:48: MoveFiles.
Action ended 13:04:48: MoveFiles. Return value 1.
Action 13:04:48: InstallFiles. Copying new files
Action start 13:04:48: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 13:04:48: InstallFiles. Return value 1.
Action 13:04:48: PatchFiles. Patching files
Action start 13:04:48: PatchFiles.
Action ended 13:04:48: PatchFiles. Return value 0.
Action 13:04:48: DuplicateFiles. Creating duplicate files
Action start 13:04:48: DuplicateFiles.
Action ended 13:04:48: DuplicateFiles. Return value 1.
Action 13:04:48: BindImage. Binding executables
Action start 13:04:48: BindImage.
Action ended 13:04:48: BindImage. Return value 1.
Action 13:04:48: CreateShortcuts. Creating shortcuts
Action start 13:04:48: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 13:04:48: CreateShortcuts. Return value 0.
Action 13:04:48: RegisterClassInfo. Registering class servers
Action start 13:04:48: RegisterClassInfo.
Action ended 13:04:48: RegisterClassInfo. Return value 0.
Action 13:04:48: RegisterExtensionInfo. Registering extension servers
Action start 13:04:48: RegisterExtensionInfo.
Action ended 13:04:48: RegisterExtensionInfo. Return value 0.
Action 13:04:48: RegisterProgIdInfo. Registering program identifiers
Action start 13:04:48: RegisterProgIdInfo.
Action ended 13:04:48: RegisterProgIdInfo. Return value 0.
Action 13:04:48: RegisterMIMEInfo. Registering MIME info
Action start 13:04:48: RegisterMIMEInfo.
Action ended 13:04:48: RegisterMIMEInfo. Return value 0.
Action 13:04:48: WriteRegistryValues. Writing system registry values
Action start 13:04:48: WriteRegistryValues.
Action ended 13:04:48: WriteRegistryValues. Return value 1.
Action 13:04:48: WriteIniValues. Writing INI file values
Action start 13:04:48: WriteIniValues.
Action ended 13:04:48: WriteIniValues. Return value 1.
Action 13:04:48: WriteEnvironmentStrings. Updating environment strings
Action start 13:04:48: WriteEnvironmentStrings.
Action ended 13:04:48: WriteEnvironmentStrings. Return value 1.
Action 13:04:48: RegisterFonts. Registering fonts
Action start 13:04:48: RegisterFonts.
Action ended 13:04:48: RegisterFonts. Return value 1.
Action 13:04:48: InstallODBC. Installing ODBC components
Action start 13:04:48: InstallODBC.
Action ended 13:04:48: InstallODBC. Return value 0.
Action 13:04:48: RegisterTypeLibraries. Registering type libraries
Action start 13:04:48: RegisterTypeLibraries.
Action ended 13:04:48: RegisterTypeLibraries. Return value 0.
Action 13:04:48: SelfRegModules. Registering modules
Action start 13:04:48: SelfRegModules.
Action ended 13:04:48: SelfRegModules. Return value 1.
Action 13:04:48: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:04:48: RegisterComPlus.
Action ended 13:04:48: RegisterComPlus. Return value 0.
Action 13:04:48: InstallServices. Installing new services
Action start 13:04:48: InstallServices.
Action ended 13:04:48: InstallServices. Return value 1.
Action 13:04:48: StartServices. Starting services
Action start 13:04:48: StartServices.
Action ended 13:04:48: StartServices. Return value 1.
Action 13:04:48: RegisterUser. Registering user
Action start 13:04:48: RegisterUser.
Action ended 13:04:48: RegisterUser. Return value 0.
Action 13:04:48: RegisterProduct. Registering product
Action start 13:04:48: RegisterProduct.
Registering product
Action ended 13:04:48: RegisterProduct. Return value 1.
Action 13:04:48: PublishComponents. Publishing qualified components
Action start 13:04:48: PublishComponents.
Action ended 13:04:48: PublishComponents. Return value 0.
Action 13:04:48: MsiPublishAssemblies. Publishing assembly information
Action start 13:04:48: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 13:04:48: MsiPublishAssemblies. Return value 1.
Action 13:04:48: PublishFeatures. Publishing product features
Action start 13:04:48: PublishFeatures.
Feature: Publishing product features
Action ended 13:04:48: PublishFeatures. Return value 1.
Action 13:04:48: PublishProduct. Publishing product information
Action start 13:04:48: PublishProduct.
Action ended 13:04:48: PublishProduct. Return value 1.
Action 13:04:48: InstallFinalize.
Action start 13:04:48: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
354043.msi
Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_CRT_x86_
Message type: 2, Argument: 0
Action 13:04:48: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b14a.rbf
File: C:\Config.Msi\3b14b.rbf
Message type: 2, Argument: 1
Action ended 13:04:48: InstallFinalize. Return value 1.
Action ended 13:04:48: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {0FD62DF3-05EA-44F2-9C45-98FA04CF85DE}
Property(S): SourcedirProduct = {08D2E121-7F6A-43EB-97FD-629B44903403}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
Property(S): Installed = 2009/07/28 04:12:16
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b144.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 13:04:48
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14324
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_508fc1d4bcbb3eca\
Property(S): payload.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_d494ac0e\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_CRT_x86.QFE.D39C9D4D_4A70_32B9_BDB6_3C16D4C5E6B7 = C:\Windows\winsxs\x86_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_1742743b\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4137_none_f47d3254f657e518\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_b7353f75\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_CRT_x86.QFE.58AAC0FC_F91D_35A6_89C5_7544A81A5FCF = C:\Windows\
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {08D2E121-7F6A-43EB-97FD-629B44903403}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC90_CRT_x86
Property(S): ProductVersion = 1.00.0000
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CEBCC75FFEEBF7C8BEACA0F8D9CB978FB9FB078FDE8CE0E8CE2BC08F9EAB5058BEDCD0A8FEAC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): REBOOT = ReallySuppress
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 4116
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbB06A.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductState = 5
Property(S): PackageCode = {5DB7D0CC-71CB-4DD2-993F-C9E909FA78F0}
=== Logging stopped: 13/02/2011 13:04:48 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:04:48 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{08D2E121-7F6A-43EB-97FD-629B44903403}] took 4021.83 miliseconds (4.02183 seconds) DTR = 190.958 KBPS (0.186482 MBPS)
Updating driver data - Action: Add driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 0KB
User specified overrideFile:
Calling the custom action code for post-repair for payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86
Calling the custom action code for pre-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
[ 3800] Sun Feb 13 13:04:48 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_CRT_x86.msi, Result: 0
[ 3800] Sun Feb 13 13:04:49 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_CRT_x86\, Result: 0
Configuring MSI ProductCode: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbBAA9.tmp"
[ 3800] Sun Feb 13 13:04:50 2011 INFO
=== Logging started: 13/02/2011 13:04:50 ===
Message type: 1, Argument: Microsoft_VC80_CRT_x86
Action 13:04:50: INSTALL.
Action start 13:04:50: INSTALL.
Action 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action ended 13:04:50: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action start 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
Action ended 13:04:50: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action ended 13:04:50: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action start 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
Action ended 13:04:50: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:04:50: AppSearch. Searching for installed applications
Action start 13:04:50: AppSearch.
Action ended 13:04:50: AppSearch. Return value 0.
Action 13:04:50: FindRelatedProducts. Searching for related applications
Action start 13:04:50: FindRelatedProducts.
Action ended 13:04:50: FindRelatedProducts. Return value 0.
Action 13:04:50: ValidateProductID.
Action start 13:04:50: ValidateProductID.
Action ended 13:04:50: ValidateProductID. Return value 1.
Action 13:04:50: CostInitialize. Computing space requirements
Action start 13:04:50: CostInitialize.
Action ended 13:04:50: CostInitialize. Return value 1.
Action 13:04:50: FileCost. Computing space requirements
Action start 13:04:50: FileCost.
Action ended 13:04:50: FileCost. Return value 1.
Action 13:04:50: IsolateComponents.
Action start 13:04:50: IsolateComponents.
Action ended 13:04:50: IsolateComponents. Return value 0.
Action 13:04:50: CostFinalize. Computing space requirements
Action start 13:04:50: CostFinalize.
Action ended 13:04:50: CostFinalize. Return value 1.
Action 13:04:50: SetODBCFolders. Initializing ODBC directories
Action start 13:04:50: SetODBCFolders.
Action ended 13:04:50: SetODBCFolders. Return value 0.
Action 13:04:50: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:04:50: MigrateFeatureStates.
Action ended 13:04:50: MigrateFeatureStates. Return value 0.
Action 13:04:50: InstallValidate. Validating install
Action start 13:04:50: InstallValidate.
Action ended 13:04:50: InstallValidate. Return value 1.
Action 13:04:50: RemoveExistingProducts. Removing applications
Action start 13:04:50: RemoveExistingProducts.
Action ended 13:04:50: RemoveExistingProducts. Return value 0.
Action 13:04:50: InstallInitialize.
Action start 13:04:50: InstallInitialize.
Action ended 13:04:50: InstallInitialize. Return value 1.
Action 13:04:50: SxsInstallCA.
Action start 13:04:50: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 13:04:50: SxsInstallCA. Return value 1.
Action 13:04:50: ProcessComponents. Updating component registration
Action start 13:04:50: ProcessComponents.
Action 13:04:50: GenerateScript. Generating script operations for action:
Action ended 13:04:50: ProcessComponents. Return value 1.
Action 13:04:50: UnpublishComponents. Unpublishing Qualified Components
Action start 13:04:50: UnpublishComponents.
Action ended 13:04:50: UnpublishComponents. Return value 0.
Action 13:04:50: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:04:50: MsiUnpublishAssemblies.
Action ended 13:04:50: MsiUnpublishAssemblies. Return value 1.
Action 13:04:50: UnpublishFeatures. Unpublishing product features
Action start 13:04:50: UnpublishFeatures.
Action ended 13:04:50: UnpublishFeatures. Return value 1.
Action 13:04:50: StopServices. Stopping services
Action start 13:04:50: StopServices.
Action ended 13:04:50: StopServices. Return value 1.
Action 13:04:50: DeleteServices. Deleting services
Action start 13:04:50: DeleteServices.
Action ended 13:04:50: DeleteServices. Return value 1.
Action 13:04:50: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:04:50: UnregisterComPlus.
Action ended 13:04:50: UnregisterComPlus. Return value 0.
Action 13:04:50: SelfUnregModules. Unregistering modules
Action start 13:04:50: SelfUnregModules.
Action ended 13:04:50: SelfUnregModules. Return value 1.
Action 13:04:50: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:04:50: UnregisterTypeLibraries.
Action ended 13:04:50: UnregisterTypeLibraries. Return value 0.
Action 13:04:50: RemoveODBC. Removing ODBC components
Action start 13:04:50: RemoveODBC.
Action ended 13:04:50: RemoveODBC. Return value 1.
Action 13:04:50: UnregisterFonts. Unregistering fonts
Action start 13:04:50: UnregisterFonts.
Action ended 13:04:50: UnregisterFonts. Return value 1.
Action 13:04:50: RemoveRegistryValues. Removing system registry values
Action start 13:04:50: RemoveRegistryValues.
Action ended 13:04:50: RemoveRegistryValues. Return value 1.
Action 13:04:50: UnregisterClassInfo. Unregister class servers
Action start 13:04:50: UnregisterClassInfo.
Action ended 13:04:50: UnregisterClassInfo. Return value 0.
Action 13:04:50: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:04:50: UnregisterExtensionInfo.
Action ended 13:04:50: UnregisterExtensionInfo. Return value 0.
Action 13:04:50: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:04:50: UnregisterProgIdInfo.
Action ended 13:04:50: UnregisterProgIdInfo. Return value 0.
Action 13:04:50: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:04:50: UnregisterMIMEInfo.
Action ended 13:04:50: UnregisterMIMEInfo. Return value 0.
Action 13:04:50: RemoveIniValues. Removing INI file entries
Action start 13:04:50: RemoveIniValues.
Action ended 13:04:50: RemoveIniValues. Return value 1.
Action 13:04:50: RemoveShortcuts. Removing shortcuts
Action start 13:04:50: RemoveShortcuts.
Action ended 13:04:50: RemoveShortcuts. Return value 0.
Action 13:04:50: RemoveEnvironmentStrings. Updating environment strings
Action start 13:04:50: RemoveEnvironmentStrings.
Action ended 13:04:50: RemoveEnvironmentStrings. Return value 1.
Action 13:04:50: RemoveDuplicateFiles. Removing duplicated files
Action start 13:04:50: RemoveDuplicateFiles.
Action ended 13:04:50: RemoveDuplicateFiles. Return value 1.
Action 13:04:50: RemoveFiles. Removing files
Action start 13:04:50: RemoveFiles.
Action ended 13:04:50: RemoveFiles. Return value 0.
Action 13:04:50: RemoveFolders. Removing folders
Action start 13:04:50: RemoveFolders.
Action ended 13:04:50: RemoveFolders. Return value 0.
Action 13:04:50: CreateFolders. Creating folders
Action start 13:04:50: CreateFolders.
Action ended 13:04:50: CreateFolders. Return value 0.
Action 13:04:50: MoveFiles. Moving files
Action start 13:04:50: MoveFiles.
Action ended 13:04:50: MoveFiles. Return value 1.
Action 13:04:50: InstallFiles. Copying new files
Action start 13:04:50: InstallFiles.
[ 3800] Sun Feb 13 13:04:52 2011 INFO
[ 3800] Sun Feb 13 13:04:58 2011 INFO
Action ended 13:04:58: InstallFiles. Return value 1.
Action 13:04:58: PatchFiles. Patching files
Action start 13:04:58: PatchFiles.
Action ended 13:04:58: PatchFiles. Return value 0.
Action 13:04:58: DuplicateFiles. Creating duplicate files
Action start 13:04:58: DuplicateFiles.
Action ended 13:04:58: DuplicateFiles. Return value 1.
Action 13:04:58: BindImage. Binding executables
Action start 13:04:58: BindImage.
Action ended 13:04:58: BindImage. Return value 1.
Action 13:04:58: CreateShortcuts. Creating shortcuts
Action start 13:04:58: CreateShortcuts.
Action ended 13:04:58: CreateShortcuts. Return value 0.
Action 13:04:58: RegisterClassInfo. Registering class servers
Action start 13:04:58: RegisterClassInfo.
Action ended 13:04:58: RegisterClassInfo. Return value 0.
Action 13:04:58: RegisterExtensionInfo. Registering extension servers
Action start 13:04:58: RegisterExtensionInfo.
Action ended 13:04:58: RegisterExtensionInfo. Return value 0.
Action 13:04:58: RegisterProgIdInfo. Registering program identifiers
Action start 13:04:58: RegisterProgIdInfo.
Action ended 13:04:58: RegisterProgIdInfo. Return value 0.
Action 13:04:58: RegisterMIMEInfo. Registering MIME info
Action start 13:04:58: RegisterMIMEInfo.
Action ended 13:04:58: RegisterMIMEInfo. Return value 0.
Action 13:04:58: WriteRegistryValues. Writing system registry values
Action start 13:04:58: WriteRegistryValues.
Action ended 13:04:58: WriteRegistryValues. Return value 1.
Action 13:04:58: WriteIniValues. Writing INI file values
Action start 13:04:58: WriteIniValues.
Action ended 13:04:58: WriteIniValues. Return value 1.
Action 13:04:58: WriteEnvironmentStrings. Updating environment strings
Action start 13:04:58: WriteEnvironmentStrings.
Action ended 13:04:58: WriteEnvironmentStrings. Return value 1.
Action 13:04:58: RegisterFonts. Registering fonts
Action start 13:04:58: RegisterFonts.
Action ended 13:04:58: RegisterFonts. Return value 1.
Action 13:04:58: InstallODBC. Installing ODBC components
Action start 13:04:58: InstallODBC.
Action ended 13:04:58: InstallODBC. Return value 0.
Action 13:04:58: RegisterTypeLibraries. Registering type libraries
Action start 13:04:58: RegisterTypeLibraries.
Action ended 13:04:58: RegisterTypeLibraries. Return value 0.
Action 13:04:58: SelfRegModules. Registering modules
Action start 13:04:58: SelfRegModules.
Action ended 13:04:58: SelfRegModules. Return value 1.
Action 13:04:58: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:04:58: RegisterComPlus.
Action ended 13:04:58: RegisterComPlus. Return value 0.
Action 13:04:58: InstallServices. Installing new services
Action start 13:04:58: InstallServices.
Action ended 13:04:58: InstallServices. Return value 1.
Action 13:04:58: StartServices. Starting services
Action start 13:04:58: StartServices.
Action ended 13:04:58: StartServices. Return value 1.
Action 13:04:58: RegisterUser. Registering user
Action start 13:04:58: RegisterUser.
Action ended 13:04:58: RegisterUser. Return value 0.
Action 13:04:58: RegisterProduct. Registering product
Action start 13:04:58: RegisterProduct.
Registering product
Action ended 13:04:58: RegisterProduct. Return value 1.
Action 13:04:58: PublishComponents. Publishing qualified components
Action start 13:04:58: PublishComponents.
Action ended 13:04:58: PublishComponents. Return value 0.
Action 13:04:58: MsiPublishAssemblies. Publishing assembly information
Action start 13:04:58: MsiPublishAssemblies.
Action ended 13:04:58: MsiPublishAssemblies. Return value 1.
Action 13:04:58: PublishFeatures. Publishing product features
Action start 13:04:58: PublishFeatures.
Action ended 13:04:58: PublishFeatures. Return value 1.
Action 13:04:58: PublishProduct. Publishing product information
Action start 13:04:58: PublishProduct.
Action ended 13:04:58: PublishProduct. Return value 1.
Action 13:04:58: InstallFinalize.
Action start 13:04:58: InstallFinalize.
Action 13:04:58: ProcessComponents. Updating component registration
Action 13:04:58: RemoveODBC. Removing ODBC components
Action 13:04:58: InstallFiles. Copying new files
[ 3800] Sun Feb 13 13:04:59 2011 INFO
Action 13:04:59: RegisterProduct. Registering product
35404c.msi
Action 13:04:59: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Action 13:04:59: PublishFeatures. Publishing product features
Feature: Microsoft_VC80_CRT_x86_
Action 13:04:59: PublishProduct. Publishing product information
Action 13:04:59: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b153.rbf
File: C:\Config.Msi\3b154.rbf
Action ended 13:04:59: InstallFinalize. Return value 1.
Action ended 13:04:59: INSTALL. Return value 1.
Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
Property(S): Installed = 2009/11/13 21:21:16
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b14d.msi
Property(S): Time = 13:04:59
Property(S): VirtualMemory = 14322
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_CRT_x86\
Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442a985d\
Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_516e2e610f48bda6\
Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51e427d4\
Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51e92911\
Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51e828d7\
Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51e92910\
Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51e92912\
Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51e92913\
Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51e92914\
Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51e92915\
Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51e92916\
Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_ac1be585\
Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_ac1be586\
Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_ac1be588\
Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_ac1be589\
Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_ac24e7bf\
Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c24773\
Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_ac9cf5cb\
Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_fc126593\
Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_fc1365cf\
Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_fc146616\
Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_a2f43fdd\
Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_2a9735d7\
Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_2a9735d8\
Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_2a9735d9\
Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_2a993653\
Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_2a9a368f\
Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_2a9a3690\
Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
Property(S): ProductName = Microsoft_VC80_CRT_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): RebootYesNo = No
Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbBAA9.tmp
Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
=== Logging stopped: 13/02/2011 13:04:59 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:04:59 2011 INFO
:: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 11024.1 miliseconds (11.0241 seconds) DTR = 31.2043 KBPS (0.0304729 MBPS)
Calling the custom action code for post-repair for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
Calling the custom action code for pre-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
::START TIMER:: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}]
[ 3440] Sun Feb 13 13:04:59 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
[ 3440] Sun Feb 13 13:05:00 2011 INFO
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_MFCLOC_x86.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\, Result: 0
Configuring MSI ProductCode: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbE62D.tmp"
1: 0 2: 1033 3: 1252
=== Logging started: 13/02/2011 13:05:00 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC80_MFCLOC_x86
Action 13:05:00: INSTALL.
Action start 13:05:00: INSTALL.
Action 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action start 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action ended 13:05:00: WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action start 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E.
Action ended 13:05:00: SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action start 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action ended 13:05:00: WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action start 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E.
Action ended 13:05:00: SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:00: AppSearch. Searching for installed applications
Action start 13:05:00: AppSearch.
Action ended 13:05:00: AppSearch. Return value 0.
Action 13:05:00: FindRelatedProducts. Searching for related applications
Action start 13:05:00: FindRelatedProducts.
Action ended 13:05:00: FindRelatedProducts. Return value 0.
Action 13:05:00: ValidateProductID.
Action start 13:05:00: ValidateProductID.
Action ended 13:05:00: ValidateProductID. Return value 1.
Action 13:05:00: CostInitialize. Computing space requirements
Action start 13:05:00: CostInitialize.
Action ended 13:05:00: CostInitialize. Return value 1.
Action 13:05:00: FileCost. Computing space requirements
Action start 13:05:00: FileCost.
Action ended 13:05:00: FileCost. Return value 1.
Action 13:05:00: IsolateComponents.
Action start 13:05:00: IsolateComponents.
Action ended 13:05:00: IsolateComponents. Return value 0.
Action 13:05:00: CostFinalize. Computing space requirements
Action start 13:05:00: CostFinalize.
Action ended 13:05:00: CostFinalize. Return value 1.
Action 13:05:00: SetODBCFolders. Initializing ODBC directories
Action start 13:05:00: SetODBCFolders.
Action ended 13:05:00: SetODBCFolders. Return value 0.
Action 13:05:00: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:00: MigrateFeatureStates.
Action ended 13:05:00: MigrateFeatureStates. Return value 0.
Action 13:05:00: InstallValidate. Validating install
Action start 13:05:00: InstallValidate.
Action ended 13:05:00: InstallValidate. Return value 1.
Action 13:05:00: RemoveExistingProducts. Removing applications
Action start 13:05:00: RemoveExistingProducts.
Action ended 13:05:00: RemoveExistingProducts. Return value 0.
Action 13:05:00: InstallInitialize.
Action start 13:05:00: InstallInitialize.
Action ended 13:05:00: InstallInitialize. Return value 1.
Action 13:05:00: SxsInstallCA.
Action start 13:05:00: SxsInstallCA.
[ 3440] Sun Feb 13 13:05:02 2011 INFO
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E
Action ended 13:05:02: SxsInstallCA. Return value 1.
Action 13:05:02: ProcessComponents. Updating component registration
Action start 13:05:02: ProcessComponents.
Action 13:05:02: GenerateScript. Generating script operations for action:
Action ended 13:05:02: ProcessComponents. Return value 1.
Action 13:05:02: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:02: UnpublishComponents.
Action ended 13:05:02: UnpublishComponents. Return value 0.
Action 13:05:02: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:02: MsiUnpublishAssemblies.
Action ended 13:05:02: MsiUnpublishAssemblies. Return value 1.
Action 13:05:02: UnpublishFeatures. Unpublishing product features
Action start 13:05:02: UnpublishFeatures.
Action ended 13:05:02: UnpublishFeatures. Return value 1.
Action 13:05:02: StopServices. Stopping services
Action start 13:05:02: StopServices.
Action ended 13:05:02: StopServices. Return value 1.
Action 13:05:02: DeleteServices. Deleting services
Action start 13:05:02: DeleteServices.
Action ended 13:05:02: DeleteServices. Return value 1.
Action 13:05:02: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:02: UnregisterComPlus.
Action ended 13:05:02: UnregisterComPlus. Return value 0.
Action 13:05:02: SelfUnregModules. Unregistering modules
Action start 13:05:02: SelfUnregModules.
Action ended 13:05:02: SelfUnregModules. Return value 1.
Action 13:05:02: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:02: UnregisterTypeLibraries.
Action ended 13:05:02: UnregisterTypeLibraries. Return value 0.
Action 13:05:02: RemoveODBC. Removing ODBC components
Action start 13:05:02: RemoveODBC.
Action ended 13:05:02: RemoveODBC. Return value 1.
Action 13:05:02: UnregisterFonts. Unregistering fonts
Action start 13:05:02: UnregisterFonts.
Action ended 13:05:02: UnregisterFonts. Return value 1.
Action 13:05:02: RemoveRegistryValues. Removing system registry values
Action start 13:05:02: RemoveRegistryValues.
Action ended 13:05:02: RemoveRegistryValues. Return value 1.
Action 13:05:02: UnregisterClassInfo. Unregister class servers
Action start 13:05:02: UnregisterClassInfo.
Action ended 13:05:02: UnregisterClassInfo. Return value 0.
Action 13:05:02: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:02: UnregisterExtensionInfo.
Action ended 13:05:02: UnregisterExtensionInfo. Return value 0.
Action 13:05:02: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:02: UnregisterProgIdInfo.
Action ended 13:05:02: UnregisterProgIdInfo. Return value 0.
Action 13:05:02: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:02: UnregisterMIMEInfo.
Action ended 13:05:02: UnregisterMIMEInfo. Return value 0.
Action 13:05:02: RemoveIniValues. Removing INI file entries
Action start 13:05:02: RemoveIniValues.
Action ended 13:05:02: RemoveIniValues. Return value 1.
Action 13:05:02: RemoveShortcuts. Removing shortcuts
Action start 13:05:02: RemoveShortcuts.
Action ended 13:05:02: RemoveShortcuts. Return value 0.
Action 13:05:02: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:02: RemoveEnvironmentStrings.
Action ended 13:05:02: RemoveEnvironmentStrings. Return value 1.
Action 13:05:02: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:02: RemoveDuplicateFiles.
Action ended 13:05:02: RemoveDuplicateFiles. Return value 1.
Action 13:05:02: RemoveFiles. Removing files
Action start 13:05:02: RemoveFiles.
Action ended 13:05:02: RemoveFiles. Return value 0.
Action 13:05:02: RemoveFolders. Removing folders
Action start 13:05:02: RemoveFolders.
Action ended 13:05:02: RemoveFolders. Return value 0.
Action 13:05:02: CreateFolders. Creating folders
Action start 13:05:02: CreateFolders.
Action ended 13:05:02: CreateFolders. Return value 0.
Action 13:05:02: MoveFiles. Moving files
Action start 13:05:02: MoveFiles.
Action ended 13:05:02: MoveFiles. Return value 1.
Action 13:05:02: InstallFiles. Copying new files
Action start 13:05:02: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 13:05:02: InstallFiles. Return value 1.
Action 13:05:02: PatchFiles. Patching files
Action start 13:05:02: PatchFiles.
Action ended 13:05:02: PatchFiles. Return value 0.
Action 13:05:02: DuplicateFiles. Creating duplicate files
Action start 13:05:02: DuplicateFiles.
Action ended 13:05:02: DuplicateFiles. Return value 1.
Action 13:05:02: BindImage. Binding executables
Action start 13:05:02: BindImage.
Action ended 13:05:02: BindImage. Return value 1.
Action 13:05:02: CreateShortcuts. Creating shortcuts
Action start 13:05:02: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 13:05:02: CreateShortcuts. Return value 0.
Action 13:05:02: RegisterClassInfo. Registering class servers
Action start 13:05:02: RegisterClassInfo.
Action ended 13:05:02: RegisterClassInfo. Return value 0.
Action 13:05:02: RegisterExtensionInfo. Registering extension servers
Action start 13:05:02: RegisterExtensionInfo.
Action ended 13:05:02: RegisterExtensionInfo. Return value 0.
Action 13:05:02: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:02: RegisterProgIdInfo.
Action ended 13:05:02: RegisterProgIdInfo. Return value 0.
Action 13:05:02: RegisterMIMEInfo. Registering MIME info
Action start 13:05:02: RegisterMIMEInfo.
Action ended 13:05:02: RegisterMIMEInfo. Return value 0.
Action 13:05:02: WriteRegistryValues. Writing system registry values
Action start 13:05:02: WriteRegistryValues.
Action ended 13:05:02: WriteRegistryValues. Return value 1.
Action 13:05:02: WriteIniValues. Writing INI file values
Action start 13:05:02: WriteIniValues.
Action ended 13:05:02: WriteIniValues. Return value 1.
Action 13:05:02: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:02: WriteEnvironmentStrings.
Action ended 13:05:02: WriteEnvironmentStrings. Return value 1.
Action 13:05:02: RegisterFonts. Registering fonts
Action start 13:05:02: RegisterFonts.
Action ended 13:05:02: RegisterFonts. Return value 1.
Action 13:05:02: InstallODBC. Installing ODBC components
Action start 13:05:02: InstallODBC.
Action ended 13:05:02: InstallODBC. Return value 0.
Action 13:05:02: RegisterTypeLibraries. Registering type libraries
Action start 13:05:02: RegisterTypeLibraries.
Action ended 13:05:02: RegisterTypeLibraries. Return value 0.
Action 13:05:02: SelfRegModules. Registering modules
Action start 13:05:02: SelfRegModules.
Action ended 13:05:02: SelfRegModules. Return value 1.
Action 13:05:02: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:02: RegisterComPlus.
Action ended 13:05:02: RegisterComPlus. Return value 0.
Action 13:05:02: InstallServices. Installing new services
Action start 13:05:02: InstallServices.
Action ended 13:05:02: InstallServices. Return value 1.
Action 13:05:02: StartServices. Starting services
Action start 13:05:02: StartServices.
Action ended 13:05:02: StartServices. Return value 1.
Action 13:05:02: RegisterUser. Registering user
Action start 13:05:02: RegisterUser.
Action ended 13:05:02: RegisterUser. Return value 0.
Action 13:05:02: RegisterProduct. Registering product
Action start 13:05:02: RegisterProduct.
Registering product
Action ended 13:05:02: RegisterProduct. Return value 1.
Action 13:05:02: PublishComponents. Publishing qualified components
Action start 13:05:02: PublishComponents.
Action ended 13:05:02: PublishComponents. Return value 0.
Action 13:05:02: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:02: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 13:05:02: MsiPublishAssemblies. Return value 1.
Action 13:05:02: PublishFeatures. Publishing product features
Action start 13:05:02: PublishFeatures.
Feature: Publishing product features
Action ended 13:05:02: PublishFeatures. Return value 1.
Action 13:05:02: PublishProduct. Publishing product information
Action start 13:05:02: PublishProduct.
Action ended 13:05:02: PublishProduct. Return value 1.
Action 13:05:02: InstallFinalize.
Action start 13:05:02: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
354055.msi
Application Context:Global, Assembly Name:Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFCLOC,publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32-policy",processorArchitecture="x86"
Feature: Microsoft_VC80_MFCLOC_x
Message type: 2, Argument: 0
Action 13:05:02: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b15c.rbf
File: C:\Config.Msi\3b15d.rbf
Message type: 2, Argument: 1
Action ended 13:05:02: InstallFinalize. Return value 1.
Action ended 13:05:02: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {DBBF67A0-1BA6-4CF4-A1EF-007F1FD45598}
Property(S): SourcedirProduct = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): Installed = 2009/11/13 21:27:58
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b156.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 13:05:02
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14311
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFCLOC_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WinSxsDirectory.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_03ca5532205cb096\
Property(S): payload.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0\
Property(S): WindowsFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir_ul.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c\
Property(S): policydir.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.89.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_3419f7d3\
Property(S): policydir.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.93.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_341af80c\
Property(S): payload.8.0.50727.94.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_341af80d\
Property(S): policydir.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.95.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_341af80e\
Property(S): policydir.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.96.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_341af80f\
Property(S): policydir.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.97.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_341af810\
Property(S): payload.8.0.50727.98.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_341af811\
Property(S): policydir.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.99.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_341af812\
Property(S): payload.8.0.50727.100.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_8e4db481\
Property(S): policydir.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.101.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_8e4db482\
Property(S): policydir.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.103.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_8e4db484\
Property(S): payload.8.0.50727.104.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_8e4db485\
Property(S): policydir.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.193.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_8e56b6bb\
Property(S): policydir.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.238.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_8ecec4c7\
Property(S): policydir.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.3044.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_de44348f\
Property(S): payload.8.0.50727.3051.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_de4534cb\
Property(S): policydir.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.3069.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_de463512\
Property(S): payload.8.0.50727.1833.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_85260ed9\
Property(S): policydir.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4027.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_0cc904d3\
Property(S): payload.8.0.50727.4028.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_0cc904d4\
Property(S): policydir.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): policydir.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4029.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_0cc904d5\
Property(S): payload.8.0.50727.4045.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_0ccb054f\
Property(S): policydir.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_2740f977\
Property(S): payload.8.0.50727.4052.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_0ccc058b\
Property(S): payload.8.0.50727.4053.74FD3CE6_2A8D_0E9C_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_0ccc058c\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_4db266e67dd280ef\
Property(S): WinSxsPolicies.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): WindowsFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_63bb0537\
Property(S): policydir.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir_ul.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_3c7113f3\
Property(S): policydir.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.94.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_63c00674\
Property(S): policydir.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.89.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_63bf063a\
Property(S): policydir.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.93.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_63c00673\
Property(S): policydir.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.95.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_63c00675\
Property(S): policydir.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.96.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_63c00676\
Property(S): policydir.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.97.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_63c00677\
Property(S): policydir.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.98.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_63c00678\
Property(S): policydir.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.99.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_63c00679\
Property(S): policydir.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.100.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_bdf2c2e8\
Property(S): payload.8.0.50727.101.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_bdf2c2e9\
Property(S): policydir.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.103.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_bdf2c2eb\
Property(S): payload.8.0.50727.104.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_bdf2c2ec\
Property(S): policydir.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.193.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_bdfbc522\
Property(S): policydir.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): policydir.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_x-ww_caeee150\
Property(S): payload.8.0.50727.238.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_be73d32e\
Property(S): payload.8.0.50727.3044.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_0de942f6\
Property(S): payload.8.0.50727.3051.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_0dea4332\
Property(S): payload.8.0.50727.3069.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_0deb4379\
Property(S): payload.8.0.50727.1833.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_b4cb1d40\
Property(S): payload.8.0.50727.4027.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_3c6e133a\
Property(S): payload.8.0.50727.4028.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_3c6e133b\
Property(S): payload.8.0.50727.4029.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_3c6e133c\
Property(S): payload.8.0.50727.4045.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_3c7013b6\
Property(S): payload.8.0.50727.4052.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_3c7113f2\
Property(S): payload.8.0.50727.4053.D2730D3F_3C41_5884_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_3c7113f3\
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC80_MFCLOC_x86
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CE0BC0C8E9CBE7B86EACE7CFDEDC978F99CC678F49ABA0E8CE6BC7C8BEDB9088F9ACF798D9AC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 4116
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbE62D.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {AF8EF662-EF5A-426A-AA7B-B83C3A5FFFBB}
=== Logging stopped: 13/02/2011 13:05:02 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:02 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{D92BBB52-82FF-42ED-8A3C-4E062F944AB7}] took 3027.02 miliseconds (3.02702 seconds) DTR = 9.25001 KBPS (0.00903322 MBPS)
[ 3432] Sun Feb 13 13:05:03 2011 INFO
User specified overrideFile:
Calling the custom action code for post-repair for payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86
Calling the custom action code for pre-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57}
::START TIMER:: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}]
[ 4664] Sun Feb 13 13:05:03 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_MFC_x86.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_MFC_x86\, Result: 0
Configuring MSI ProductCode: {D1A19B02-817E-4296-A45B-07853FD74D57}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbF1B4.tmp"
[ 4664] Sun Feb 13 13:05:04 2011 INFO
=== Logging started: 13/02/2011 13:05:04 ===
Message type: 1, Argument: Microsoft_VC80_MFC_x86
Action 13:05:04: INSTALL.
Action start 13:05:04: INSTALL.
Action 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action start 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action ended 13:05:04: WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action start 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E.
Action ended 13:05:04: SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action start 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action ended 13:05:04: WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action start 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E.
Action ended 13:05:04: SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:04: AppSearch. Searching for installed applications
Action start 13:05:04: AppSearch.
Action ended 13:05:04: AppSearch. Return value 0.
Action 13:05:04: FindRelatedProducts. Searching for related applications
Action start 13:05:04: FindRelatedProducts.
Action ended 13:05:04: FindRelatedProducts. Return value 0.
Action 13:05:04: ValidateProductID.
Action start 13:05:04: ValidateProductID.
Action ended 13:05:04: ValidateProductID. Return value 1.
Action 13:05:04: CostInitialize. Computing space requirements
Action start 13:05:04: CostInitialize.
Action ended 13:05:04: CostInitialize. Return value 1.
Action 13:05:04: FileCost. Computing space requirements
Action start 13:05:04: FileCost.
Action ended 13:05:04: FileCost. Return value 1.
Action 13:05:04: IsolateComponents.
Action start 13:05:04: IsolateComponents.
Action ended 13:05:04: IsolateComponents. Return value 0.
Action 13:05:04: CostFinalize. Computing space requirements
Action start 13:05:04: CostFinalize.
Action ended 13:05:04: CostFinalize. Return value 1.
Action 13:05:04: SetODBCFolders. Initializing ODBC directories
Action start 13:05:04: SetODBCFolders.
Action ended 13:05:04: SetODBCFolders. Return value 0.
Action 13:05:04: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:04: MigrateFeatureStates.
Action ended 13:05:04: MigrateFeatureStates. Return value 0.
Action 13:05:04: InstallValidate. Validating install
Action start 13:05:04: InstallValidate.
Action ended 13:05:04: InstallValidate. Return value 1.
Action 13:05:04: RemoveExistingProducts. Removing applications
Action start 13:05:04: RemoveExistingProducts.
Action ended 13:05:04: RemoveExistingProducts. Return value 0.
Action 13:05:04: InstallInitialize.
Action start 13:05:04: InstallInitialize.
Action ended 13:05:04: InstallInitialize. Return value 1.
Action 13:05:04: SxsInstallCA.
Action start 13:05:04: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: uplevel.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 13:05:04: SxsInstallCA. Return value 1.
Action 13:05:04: ProcessComponents. Updating component registration
Action start 13:05:04: ProcessComponents.
Action 13:05:04: GenerateScript. Generating script operations for action:
Action ended 13:05:04: ProcessComponents. Return value 1.
Action 13:05:04: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:04: UnpublishComponents.
Action ended 13:05:04: UnpublishComponents. Return value 0.
Action 13:05:04: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:04: MsiUnpublishAssemblies.
Action ended 13:05:04: MsiUnpublishAssemblies. Return value 1.
Action 13:05:04: UnpublishFeatures. Unpublishing product features
Action start 13:05:04: UnpublishFeatures.
Action ended 13:05:04: UnpublishFeatures. Return value 1.
Action 13:05:04: StopServices. Stopping services
Action start 13:05:04: StopServices.
Action ended 13:05:04: StopServices. Return value 1.
Action 13:05:04: DeleteServices. Deleting services
Action start 13:05:04: DeleteServices.
Action ended 13:05:04: DeleteServices. Return value 1.
Action 13:05:04: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:04: UnregisterComPlus.
Action ended 13:05:04: UnregisterComPlus. Return value 0.
Action 13:05:04: SelfUnregModules. Unregistering modules
Action start 13:05:04: SelfUnregModules.
Action ended 13:05:04: SelfUnregModules. Return value 1.
Action 13:05:04: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:04: UnregisterTypeLibraries.
Action ended 13:05:04: UnregisterTypeLibraries. Return value 0.
Action 13:05:04: RemoveODBC. Removing ODBC components
Action start 13:05:04: RemoveODBC.
Action ended 13:05:04: RemoveODBC. Return value 1.
Action 13:05:04: UnregisterFonts. Unregistering fonts
Action start 13:05:04: UnregisterFonts.
Action ended 13:05:04: UnregisterFonts. Return value 1.
Action 13:05:04: RemoveRegistryValues. Removing system registry values
Action start 13:05:04: RemoveRegistryValues.
Action ended 13:05:04: RemoveRegistryValues. Return value 1.
Action 13:05:04: UnregisterClassInfo. Unregister class servers
Action start 13:05:04: UnregisterClassInfo.
Action ended 13:05:04: UnregisterClassInfo. Return value 0.
Action 13:05:04: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:04: UnregisterExtensionInfo.
Action ended 13:05:04: UnregisterExtensionInfo. Return value 0.
Action 13:05:04: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:04: UnregisterProgIdInfo.
Action ended 13:05:04: UnregisterProgIdInfo. Return value 0.
Action 13:05:04: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:04: UnregisterMIMEInfo.
Action ended 13:05:04: UnregisterMIMEInfo. Return value 0.
Action 13:05:04: RemoveIniValues. Removing INI file entries
Action start 13:05:04: RemoveIniValues.
Action ended 13:05:04: RemoveIniValues. Return value 1.
Action 13:05:04: RemoveShortcuts. Removing shortcuts
Action start 13:05:04: RemoveShortcuts.
Action ended 13:05:04: RemoveShortcuts. Return value 0.
Action 13:05:04: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:04: RemoveEnvironmentStrings.
Action ended 13:05:04: RemoveEnvironmentStrings. Return value 1.
Action 13:05:04: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:04: RemoveDuplicateFiles.
Action ended 13:05:04: RemoveDuplicateFiles. Return value 1.
Action 13:05:04: RemoveFiles. Removing files
Action start 13:05:04: RemoveFiles.
Action ended 13:05:04: RemoveFiles. Return value 0.
Action 13:05:04: RemoveFolders. Removing folders
Action start 13:05:04: RemoveFolders.
Action ended 13:05:04: RemoveFolders. Return value 0.
Action 13:05:04: CreateFolders. Creating folders
Action start 13:05:04: CreateFolders.
Action ended 13:05:04: CreateFolders. Return value 0.
Action 13:05:04: MoveFiles. Moving files
Action start 13:05:04: MoveFiles.
Action ended 13:05:04: MoveFiles. Return value 1.
Action 13:05:04: InstallFiles. Copying new files
Action start 13:05:04: InstallFiles.
Action ended 13:05:04: InstallFiles. Return value 1.
Action 13:05:04: PatchFiles. Patching files
Action start 13:05:04: PatchFiles.
Action ended 13:05:04: PatchFiles. Return value 0.
Action 13:05:04: DuplicateFiles. Creating duplicate files
Action start 13:05:04: DuplicateFiles.
Action ended 13:05:04: DuplicateFiles. Return value 1.
Action 13:05:04: BindImage. Binding executables
Action start 13:05:04: BindImage.
Action ended 13:05:04: BindImage. Return value 1.
Action 13:05:04: CreateShortcuts. Creating shortcuts
Action start 13:05:04: CreateShortcuts.
Action ended 13:05:04: CreateShortcuts. Return value 0.
Action 13:05:04: RegisterClassInfo. Registering class servers
Action start 13:05:04: RegisterClassInfo.
Action ended 13:05:04: RegisterClassInfo. Return value 0.
Action 13:05:04: RegisterExtensionInfo. Registering extension servers
Action start 13:05:04: RegisterExtensionInfo.
Action ended 13:05:04: RegisterExtensionInfo. Return value 0.
Action 13:05:04: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:04: RegisterProgIdInfo.
Action ended 13:05:04: RegisterProgIdInfo. Return value 0.
Action 13:05:04: RegisterMIMEInfo. Registering MIME info
Action start 13:05:04: RegisterMIMEInfo.
Action ended 13:05:04: RegisterMIMEInfo. Return value 0.
Action 13:05:04: WriteRegistryValues. Writing system registry values
Action start 13:05:04: WriteRegistryValues.
Action ended 13:05:04: WriteRegistryValues. Return value 1.
Action 13:05:04: WriteIniValues. Writing INI file values
Action start 13:05:04: WriteIniValues.
Action ended 13:05:04: WriteIniValues. Return value 1.
Action 13:05:04: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:04: WriteEnvironmentStrings.
Action ended 13:05:04: WriteEnvironmentStrings. Return value 1.
Action 13:05:04: RegisterFonts. Registering fonts
Action start 13:05:04: RegisterFonts.
Action ended 13:05:04: RegisterFonts. Return value 1.
Action 13:05:04: InstallODBC. Installing ODBC components
Action start 13:05:04: InstallODBC.
Action ended 13:05:04: InstallODBC. Return value 0.
Action 13:05:04: RegisterTypeLibraries. Registering type libraries
Action start 13:05:04: RegisterTypeLibraries.
Action ended 13:05:04: RegisterTypeLibraries. Return value 0.
Action 13:05:04: SelfRegModules. Registering modules
Action start 13:05:04: SelfRegModules.
Action ended 13:05:04: SelfRegModules. Return value 1.
Action 13:05:04: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:04: RegisterComPlus.
Action ended 13:05:04: RegisterComPlus. Return value 0.
Action 13:05:04: InstallServices. Installing new services
Action start 13:05:04: InstallServices.
Action ended 13:05:04: InstallServices. Return value 1.
Action 13:05:04: StartServices. Starting services
Action start 13:05:04: StartServices.
Action ended 13:05:04: StartServices. Return value 1.
Action 13:05:04: RegisterUser. Registering user
Action start 13:05:04: RegisterUser.
Action ended 13:05:04: RegisterUser. Return value 0.
Action 13:05:04: RegisterProduct. Registering product
Action start 13:05:04: RegisterProduct.
Registering product
Action ended 13:05:04: RegisterProduct. Return value 1.
Action 13:05:04: PublishComponents. Publishing qualified components
Action start 13:05:04: PublishComponents.
Action ended 13:05:04: PublishComponents. Return value 0.
Action 13:05:04: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:04: MsiPublishAssemblies.
Action ended 13:05:04: MsiPublishAssemblies. Return value 1.
Action 13:05:04: PublishFeatures. Publishing product features
Action start 13:05:04: PublishFeatures.
Action ended 13:05:04: PublishFeatures. Return value 1.
Action 13:05:04: PublishProduct. Publishing product information
Action start 13:05:04: PublishProduct.
Action ended 13:05:04: PublishProduct. Return value 1.
Action 13:05:04: InstallFinalize.
Action start 13:05:04: InstallFinalize.
Message type: 0, Argument: 1033
[ 4664] Sun Feb 13 13:05:05 2011 INFO
Action 13:05:05: CreateShortcuts. Creating shortcuts
Action 13:05:05: RegisterProduct. Registering product
35405e.msi
Action 13:05:05: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.MFC,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",version="8.0.50727.4053",type="win32-policy"
Action 13:05:05: PublishFeatures. Publishing product features
Feature: Microsoft_VC80_MFC_x86_
Action 13:05:05: PublishProduct. Publishing product information
Action 13:05:05: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b165.rbf
File: C:\Config.Msi\3b166.rbf
Action ended 13:05:05: InstallFinalize. Return value 1.
Action ended 13:05:05: INSTALL. Return value 1.
Property(S): SourcedirProduct = {D1A19B02-817E-4296-A45B-07853FD74D57}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
Property(S): UpgradeCode = {BA8F3080-8370-4EB2-8827-F83E97A7A343}
Property(S): Installed = 2009/11/13 21:25:22
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b15f.msi
Property(S): Time = 13:05:05
Property(S): VirtualMemory = 14309
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_MFC_x86\
Property(S): WinSxsDirectory.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_cbf21254470d8752\
Property(S): payload.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2\
Property(S): WindowsFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir_ul.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
Property(S): policydir.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.89.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_decaded5\
Property(S): policydir.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.93.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_decbdf0e\
Property(S): payload.8.0.50727.94.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_decbdf0f\
Property(S): policydir.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.95.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_decbdf10\
Property(S): payload.8.0.50727.96.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_decbdf11\
Property(S): policydir.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.97.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_decbdf12\
Property(S): payload.8.0.50727.98.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_decbdf13\
Property(S): policydir.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.99.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_decbdf14\
Property(S): policydir.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.100.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_38fe9b83\
Property(S): payload.8.0.50727.101.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_38fe9b84\
Property(S): policydir.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.103.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_38fe9b86\
Property(S): payload.8.0.50727.104.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_38fe9b87\
Property(S): payload.8.0.50727.193.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_39079dbd\
Property(S): policydir.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.238.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_397fabc9\
Property(S): policydir.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): policydir.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3044.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_88f51b91\
Property(S): policydir.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3051.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_88f61bcd\
Property(S): policydir.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.3069.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_88f71c14\
Property(S): policydir.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_dbdc31f5\
Property(S): payload.8.0.50727.1833.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_2fd6f5db\
Property(S): payload.8.0.50727.4027.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_b779ebd5\
Property(S): payload.8.0.50727.4028.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_b779ebd6\
Property(S): payload.8.0.50727.4029.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_b779ebd7\
Property(S): payload.8.0.50727.4045.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_b77bec51\
Property(S): payload.8.0.50727.4052.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_b77cec8d\
Property(S): payload.8.0.50727.4053.9BAE13A2_E7AF_D6C3_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_b77cec8e\
Property(S): WinSxsDirectory.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.4053_none_49ef489714173a89\
Property(S): WinSxsPolicies.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): WindowsFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_22ca9ad9\
Property(S): policydir.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir_ul.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_fb80a995\
Property(S): policydir.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.94.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_22cf9c16\
Property(S): policydir.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.89.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_22ce9bdc\
Property(S): policydir.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.93.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_22cf9c15\
Property(S): policydir.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.95.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_22cf9c17\
Property(S): policydir.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.96.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_22cf9c18\
Property(S): policydir.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.97.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_22cf9c19\
Property(S): policydir.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.98.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_22cf9c1a\
Property(S): policydir.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.99.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_22cf9c1b\
Property(S): policydir.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.100.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_7d02588a\
Property(S): payload.8.0.50727.101.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_7d02588b\
Property(S): policydir.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.103.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_7d02588d\
Property(S): payload.8.0.50727.104.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_7d02588e\
Property(S): policydir.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.193.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_7d0b5ac4\
Property(S): policydir.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): policydir.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_x-ww_0f75c32e\
Property(S): payload.8.0.50727.238.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_7d8368d0\
Property(S): payload.8.0.50727.3044.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ccf8d898\
Property(S): payload.8.0.50727.3051.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ccf9d8d4\
Property(S): payload.8.0.50727.3069.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ccfad91b\
Property(S): payload.8.0.50727.1833.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_73dab2e2\
Property(S): payload.8.0.50727.4027.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_fb7da8dc\
Property(S): payload.8.0.50727.4028.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_fb7da8dd\
Property(S): payload.8.0.50727.4029.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_fb7da8de\
Property(S): payload.8.0.50727.4045.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_fb7fa958\
Property(S): payload.8.0.50727.4052.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_fb80a994\
Property(S): payload.8.0.50727.4053.68B7C6D9_1DF2_54C1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_fb80a995\
Property(S): ProductCode = {D1A19B02-817E-4296-A45B-07853FD74D57}
Property(S): ProductName = Microsoft_VC80_MFC_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): RebootYesNo = No
Property(S): DWUSLINK = CE8C979FAE7BF06819ACF728AE3C978F3EBCC78FFEEB4798CE8CE7EF9EDBA75FF9ABA7E8FEAC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbF1B4.tmp
Property(S): PackageCode = {032B02B2-4D8D-45FF-BB1E-864B26F4ADDC}
=== Logging stopped: 13/02/2011 13:05:05 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:06 2011 INFO
:: END TIMER :: [Payload Operation :{D1A19B02-817E-4296-A45B-07853FD74D57}] took 3023.39 miliseconds (3.02339 seconds) DTR = 358.538 KBPS (0.350134 MBPS)
Calling the custom action code for post-repair for payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86
[ 3432] Sun Feb 13 13:05:06 2011 WARN
Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
Calling the custom action code for pre-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
::START TIMER:: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}]
[ 2676] Sun Feb 13 13:05:06 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86\, Result: 0
Configuring MSI ProductCode: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbFEC0.tmp"
[ 2676] Sun Feb 13 13:05:07 2011 INFO
1: 0 2: 1033 3: 1252
[ 2676] Sun Feb 13 13:05:09 2011 INFO
=== Logging started: 13/02/2011 13:05:09 ===
Message type: 1, Argument: Microsoft_VC90_MFC_x86
Action 13:05:09: INSTALL.
Action start 13:05:09: INSTALL.
Action 13:05:09: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action start 13:05:09: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action ended 13:05:09: SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
Action 13:05:09: AppSearch. Searching for installed applications
Action start 13:05:09: AppSearch.
Action ended 13:05:09: AppSearch. Return value 0.
Action 13:05:09: FindRelatedProducts. Searching for related applications
Action start 13:05:09: FindRelatedProducts.
Action ended 13:05:09: FindRelatedProducts. Return value 0.
Action 13:05:09: ValidateProductID.
Action start 13:05:09: ValidateProductID.
Action ended 13:05:09: ValidateProductID. Return value 1.
Action 13:05:09: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action start 13:05:09: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D.
Action ended 13:05:09: WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D. Return value 1.
Action 13:05:09: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF.
Action start 13:05:09: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF.
Action ended 13:05:09: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF. Return value 1.
Action 13:05:09: CostInitialize. Computing space requirements
Action start 13:05:09: CostInitialize.
Action ended 13:05:09: CostInitialize. Return value 1.
Action 13:05:09: FileCost. Computing space requirements
Action start 13:05:09: FileCost.
Action ended 13:05:09: FileCost. Return value 1.
Action 13:05:09: IsolateComponents.
Action start 13:05:09: IsolateComponents.
Action ended 13:05:09: IsolateComponents. Return value 0.
Action 13:05:09: CostFinalize. Computing space requirements
Action start 13:05:09: CostFinalize.
Action ended 13:05:09: CostFinalize. Return value 1.
Action 13:05:09: SetODBCFolders. Initializing ODBC directories
Action start 13:05:09: SetODBCFolders.
Action ended 13:05:09: SetODBCFolders. Return value 0.
Action 13:05:09: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:09: MigrateFeatureStates.
Action ended 13:05:09: MigrateFeatureStates. Return value 0.
Action 13:05:09: InstallValidate. Validating install
Action start 13:05:09: InstallValidate.
Action ended 13:05:09: InstallValidate. Return value 1.
Action 13:05:09: RemoveExistingProducts. Removing applications
Action start 13:05:09: RemoveExistingProducts.
Action ended 13:05:09: RemoveExistingProducts. Return value 0.
Action 13:05:09: InstallInitialize.
Action start 13:05:09: InstallInitialize.
[ 2676] Sun Feb 13 13:05:10 2011 INFO
Action ended 13:05:10: InstallInitialize. Return value 1.
Action 13:05:10: ProcessComponents. Updating component registration
Action start 13:05:10: ProcessComponents.
Action 13:05:10: GenerateScript. Generating script operations for action:
Action ended 13:05:10: ProcessComponents. Return value 1.
Action 13:05:10: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:10: UnpublishComponents.
Action ended 13:05:10: UnpublishComponents. Return value 0.
Action 13:05:10: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:10: MsiUnpublishAssemblies.
Action ended 13:05:10: MsiUnpublishAssemblies. Return value 1.
Action 13:05:10: UnpublishFeatures. Unpublishing product features
Action start 13:05:10: UnpublishFeatures.
Action ended 13:05:10: UnpublishFeatures. Return value 1.
Action 13:05:10: StopServices. Stopping services
Action start 13:05:10: StopServices.
Action ended 13:05:10: StopServices. Return value 1.
Action 13:05:10: DeleteServices. Deleting services
Action start 13:05:10: DeleteServices.
Action ended 13:05:10: DeleteServices. Return value 1.
Action 13:05:10: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:10: UnregisterComPlus.
Action ended 13:05:10: UnregisterComPlus. Return value 0.
Action 13:05:10: SelfUnregModules. Unregistering modules
Action start 13:05:10: SelfUnregModules.
Action ended 13:05:10: SelfUnregModules. Return value 1.
Action 13:05:10: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:10: UnregisterTypeLibraries.
Action ended 13:05:10: UnregisterTypeLibraries. Return value 0.
Action 13:05:10: RemoveODBC. Removing ODBC components
Action start 13:05:10: RemoveODBC.
Action ended 13:05:10: RemoveODBC. Return value 1.
Action 13:05:10: UnregisterFonts. Unregistering fonts
Action start 13:05:10: UnregisterFonts.
Action ended 13:05:10: UnregisterFonts. Return value 1.
Action 13:05:10: RemoveRegistryValues. Removing system registry values
Action start 13:05:10: RemoveRegistryValues.
Action ended 13:05:10: RemoveRegistryValues. Return value 1.
Action 13:05:10: UnregisterClassInfo. Unregister class servers
Action start 13:05:10: UnregisterClassInfo.
Action ended 13:05:10: UnregisterClassInfo. Return value 0.
Action 13:05:10: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:10: UnregisterExtensionInfo.
Action ended 13:05:10: UnregisterExtensionInfo. Return value 0.
Action 13:05:10: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:10: UnregisterProgIdInfo.
Action ended 13:05:10: UnregisterProgIdInfo. Return value 0.
Action 13:05:10: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:10: UnregisterMIMEInfo.
Action ended 13:05:10: UnregisterMIMEInfo. Return value 0.
Action 13:05:10: RemoveIniValues. Removing INI file entries
Action start 13:05:10: RemoveIniValues.
Action ended 13:05:10: RemoveIniValues. Return value 1.
Action 13:05:10: RemoveShortcuts. Removing shortcuts
Action start 13:05:10: RemoveShortcuts.
Action ended 13:05:10: RemoveShortcuts. Return value 0.
Action 13:05:10: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:10: RemoveEnvironmentStrings.
Action ended 13:05:10: RemoveEnvironmentStrings. Return value 1.
Action 13:05:10: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:10: RemoveDuplicateFiles.
Action ended 13:05:10: RemoveDuplicateFiles. Return value 1.
Action 13:05:10: RemoveFiles. Removing files
Action start 13:05:10: RemoveFiles.
Action ended 13:05:10: RemoveFiles. Return value 0.
Action 13:05:10: RemoveFolders. Removing folders
Action start 13:05:10: RemoveFolders.
Action ended 13:05:10: RemoveFolders. Return value 0.
Action 13:05:10: CreateFolders. Creating folders
Action start 13:05:10: CreateFolders.
Action ended 13:05:10: CreateFolders. Return value 0.
Action 13:05:10: MoveFiles. Moving files
Action start 13:05:10: MoveFiles.
Action ended 13:05:10: MoveFiles. Return value 1.
Action 13:05:10: InstallFiles. Copying new files
Action start 13:05:10: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 13:05:10: InstallFiles. Return value 1.
Action 13:05:10: PatchFiles. Patching files
Action start 13:05:10: PatchFiles.
Action ended 13:05:10: PatchFiles. Return value 0.
Action 13:05:10: DuplicateFiles. Creating duplicate files
Action start 13:05:10: DuplicateFiles.
Action ended 13:05:10: DuplicateFiles. Return value 1.
Action 13:05:10: BindImage. Binding executables
Action start 13:05:10: BindImage.
Action ended 13:05:10: BindImage. Return value 1.
Action 13:05:10: CreateShortcuts. Creating shortcuts
Action start 13:05:10: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 13:05:10: CreateShortcuts. Return value 0.
Action 13:05:10: RegisterClassInfo. Registering class servers
Action start 13:05:10: RegisterClassInfo.
Action ended 13:05:10: RegisterClassInfo. Return value 0.
Action 13:05:10: RegisterExtensionInfo. Registering extension servers
Action start 13:05:10: RegisterExtensionInfo.
Action ended 13:05:10: RegisterExtensionInfo. Return value 0.
Action 13:05:10: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:10: RegisterProgIdInfo.
Action ended 13:05:10: RegisterProgIdInfo. Return value 0.
Action 13:05:10: RegisterMIMEInfo. Registering MIME info
Action start 13:05:10: RegisterMIMEInfo.
Action ended 13:05:10: RegisterMIMEInfo. Return value 0.
Action 13:05:10: WriteRegistryValues. Writing system registry values
Action start 13:05:10: WriteRegistryValues.
Action ended 13:05:10: WriteRegistryValues. Return value 1.
Action 13:05:10: WriteIniValues. Writing INI file values
Action start 13:05:10: WriteIniValues.
Action ended 13:05:10: WriteIniValues. Return value 1.
Action 13:05:10: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:10: WriteEnvironmentStrings.
Action ended 13:05:10: WriteEnvironmentStrings. Return value 1.
Action 13:05:10: RegisterFonts. Registering fonts
Action start 13:05:10: RegisterFonts.
Action ended 13:05:10: RegisterFonts. Return value 1.
Action 13:05:10: InstallODBC. Installing ODBC components
Action start 13:05:10: InstallODBC.
Action ended 13:05:10: InstallODBC. Return value 0.
Action 13:05:10: RegisterTypeLibraries. Registering type libraries
Action start 13:05:10: RegisterTypeLibraries.
Action ended 13:05:10: RegisterTypeLibraries. Return value 0.
Action 13:05:10: SelfRegModules. Registering modules
Action start 13:05:10: SelfRegModules.
Action ended 13:05:10: SelfRegModules. Return value 1.
Action 13:05:10: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:10: RegisterComPlus.
Action ended 13:05:10: RegisterComPlus. Return value 0.
Action 13:05:10: InstallServices. Installing new services
Action start 13:05:10: InstallServices.
Action ended 13:05:10: InstallServices. Return value 1.
Action 13:05:10: StartServices. Starting services
Action start 13:05:10: StartServices.
Action ended 13:05:10: StartServices. Return value 1.
Action 13:05:10: RegisterUser. Registering user
Action start 13:05:10: RegisterUser.
Action ended 13:05:10: RegisterUser. Return value 0.
Action 13:05:10: RegisterProduct. Registering product
Action start 13:05:10: RegisterProduct.
Registering product
Action ended 13:05:10: RegisterProduct. Return value 1.
Action 13:05:10: PublishComponents. Publishing qualified components
Action start 13:05:10: PublishComponents.
Action ended 13:05:10: PublishComponents. Return value 0.
Action 13:05:10: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:10: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 13:05:10: MsiPublishAssemblies. Return value 1.
Action 13:05:10: PublishFeatures. Publishing product features
Action start 13:05:10: PublishFeatures.
Feature: Publishing product features
Action ended 13:05:10: PublishFeatures. Return value 1.
Action 13:05:10: PublishProduct. Publishing product information
Action start 13:05:10: PublishProduct.
Action ended 13:05:10: PublishProduct. Return value 1.
Action 13:05:10: InstallFinalize.
Action start 13:05:10: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
354067.msi
Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_MFC_x86_
Message type: 2, Argument: 0
Action 13:05:10: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b16e.rbf
File: C:\Config.Msi\3b16f.rbf
Message type: 2, Argument: 1
Action ended 13:05:10: InstallFinalize. Return value 1.
Action ended 13:05:10: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {7534F528-4E84-4BFB-A8F2-BBD75974F28F}
Property(S): SourcedirProduct = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
Property(S): Installed = 2009/07/28 04:13:22
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b168.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 13:05:10
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14300
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\SysWOW64\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_4bf45688bf9e2dbf\
Property(S): payload.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_a57b1f13\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_MFC_x86.QFE.2D812757_445C_3872_85D9_3C96F6A74B2D = C:\Windows\winsxs\x86_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aef5eff6\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.4137_none_ecfe4c8afb2661fb\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_4ee8bb30\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_MFC_x86.QFE.3400D0F1_7C00_33DE_BBF5_5539993CCCBF = C:\Windows\
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC90_MFC_x86
Property(S): ProductVersion = 1.00.0000
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CEDCD08F9EDBA7DF5EAC87CFDEDB978F8EABA08FCEECA7AFCEFCA0AFF9DBF78FB9ABA7F819AC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 4116
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbFEC0.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductState = 5
Property(S): PackageCode = {FCC5DFDD-8D3B-457A-9232-4D938A966CD6}
=== Logging stopped: 13/02/2011 13:05:10 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:11 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}] took 5026.38 miliseconds (5.02638 seconds) DTR = 15.1202 KBPS (0.0147658 MBPS)
User specified overrideFile:
Calling the custom action code for post-repair for payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86
Calling the custom action code for pre-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
::START TIMER:: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}]
[ 4848] Sun Feb 13 13:05:11 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86\, Result: 0
Configuring MSI ProductCode: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb1232.tmp"
[ 4848] Sun Feb 13 13:05:12 2011 INFO
=== Logging started: 13/02/2011 13:05:12 ===
Message type: 1, Argument: Microsoft_VC90_ATL_x86
Action 13:05:12: INSTALL.
Action start 13:05:12: INSTALL.
Action 13:05:12: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action start 13:05:12: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action ended 13:05:12: SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
Action 13:05:12: AppSearch. Searching for installed applications
Action start 13:05:12: AppSearch.
Action ended 13:05:12: AppSearch. Return value 0.
Action 13:05:12: FindRelatedProducts. Searching for related applications
Action start 13:05:12: FindRelatedProducts.
Action ended 13:05:12: FindRelatedProducts. Return value 0.
Action 13:05:12: ValidateProductID.
Action start 13:05:12: ValidateProductID.
Action ended 13:05:12: ValidateProductID. Return value 1.
Action 13:05:12: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action start 13:05:12: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A.
Action ended 13:05:12: WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A. Return value 1.
Action 13:05:12: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC.
Action start 13:05:12: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC.
Action ended 13:05:12: WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC. Return value 1.
Action 13:05:12: CostInitialize. Computing space requirements
Action start 13:05:12: CostInitialize.
Action ended 13:05:12: CostInitialize. Return value 1.
Action 13:05:12: FileCost. Computing space requirements
Action start 13:05:12: FileCost.
Action ended 13:05:12: FileCost. Return value 1.
Action 13:05:12: IsolateComponents.
Action start 13:05:12: IsolateComponents.
Action ended 13:05:12: IsolateComponents. Return value 0.
Action 13:05:12: CostFinalize. Computing space requirements
Action start 13:05:12: CostFinalize.
Action ended 13:05:12: CostFinalize. Return value 1.
Action 13:05:12: SetODBCFolders. Initializing ODBC directories
Action start 13:05:12: SetODBCFolders.
Action ended 13:05:12: SetODBCFolders. Return value 0.
Action 13:05:12: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:12: MigrateFeatureStates.
Action ended 13:05:12: MigrateFeatureStates. Return value 0.
Action 13:05:12: InstallValidate. Validating install
Action start 13:05:12: InstallValidate.
Action ended 13:05:12: InstallValidate. Return value 1.
Action 13:05:12: RemoveExistingProducts. Removing applications
Action start 13:05:12: RemoveExistingProducts.
Action ended 13:05:12: RemoveExistingProducts. Return value 0.
Action 13:05:12: InstallInitialize.
Action start 13:05:12: InstallInitialize.
Action ended 13:05:12: InstallInitialize. Return value 1.
Action 13:05:12: ProcessComponents. Updating component registration
Action start 13:05:12: ProcessComponents.
Action 13:05:12: GenerateScript. Generating script operations for action:
Action ended 13:05:12: ProcessComponents. Return value 1.
Action 13:05:12: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:12: UnpublishComponents.
Action ended 13:05:12: UnpublishComponents. Return value 0.
Action 13:05:12: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:12: MsiUnpublishAssemblies.
Action ended 13:05:12: MsiUnpublishAssemblies. Return value 1.
Action 13:05:12: UnpublishFeatures. Unpublishing product features
Action start 13:05:12: UnpublishFeatures.
Action ended 13:05:12: UnpublishFeatures. Return value 1.
Action 13:05:12: StopServices. Stopping services
Action start 13:05:12: StopServices.
Action ended 13:05:12: StopServices. Return value 1.
Action 13:05:12: DeleteServices. Deleting services
Action start 13:05:12: DeleteServices.
Action ended 13:05:12: DeleteServices. Return value 1.
Action 13:05:12: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:12: UnregisterComPlus.
Action ended 13:05:12: UnregisterComPlus. Return value 0.
Action 13:05:12: SelfUnregModules. Unregistering modules
Action start 13:05:12: SelfUnregModules.
Action ended 13:05:12: SelfUnregModules. Return value 1.
Action 13:05:12: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:12: UnregisterTypeLibraries.
Action ended 13:05:12: UnregisterTypeLibraries. Return value 0.
Action 13:05:12: RemoveODBC. Removing ODBC components
Action start 13:05:12: RemoveODBC.
Action ended 13:05:12: RemoveODBC. Return value 1.
Action 13:05:12: UnregisterFonts. Unregistering fonts
Action start 13:05:12: UnregisterFonts.
Action ended 13:05:12: UnregisterFonts. Return value 1.
Action 13:05:12: RemoveRegistryValues. Removing system registry values
Action start 13:05:12: RemoveRegistryValues.
Action ended 13:05:12: RemoveRegistryValues. Return value 1.
Action 13:05:12: UnregisterClassInfo. Unregister class servers
Action start 13:05:12: UnregisterClassInfo.
Action ended 13:05:12: UnregisterClassInfo. Return value 0.
Action 13:05:12: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:12: UnregisterExtensionInfo.
Action ended 13:05:12: UnregisterExtensionInfo. Return value 0.
Action 13:05:12: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:12: UnregisterProgIdInfo.
Action ended 13:05:12: UnregisterProgIdInfo. Return value 0.
Action 13:05:12: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:12: UnregisterMIMEInfo.
Action ended 13:05:12: UnregisterMIMEInfo. Return value 0.
Action 13:05:12: RemoveIniValues. Removing INI file entries
Action start 13:05:12: RemoveIniValues.
Action ended 13:05:12: RemoveIniValues. Return value 1.
Action 13:05:12: RemoveShortcuts. Removing shortcuts
Action start 13:05:12: RemoveShortcuts.
Action ended 13:05:12: RemoveShortcuts. Return value 0.
Action 13:05:12: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:12: RemoveEnvironmentStrings.
Action ended 13:05:12: RemoveEnvironmentStrings. Return value 1.
Action 13:05:12: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:12: RemoveDuplicateFiles.
Action ended 13:05:12: RemoveDuplicateFiles. Return value 1.
Action 13:05:12: RemoveFiles. Removing files
Action start 13:05:12: RemoveFiles.
Action ended 13:05:12: RemoveFiles. Return value 0.
Action 13:05:12: RemoveFolders. Removing folders
Action start 13:05:12: RemoveFolders.
Action ended 13:05:12: RemoveFolders. Return value 0.
Action 13:05:12: CreateFolders. Creating folders
Action start 13:05:12: CreateFolders.
Action ended 13:05:12: CreateFolders. Return value 0.
Action 13:05:12: MoveFiles. Moving files
Action start 13:05:12: MoveFiles.
Action ended 13:05:12: MoveFiles. Return value 1.
Action 13:05:12: InstallFiles. Copying new files
Action start 13:05:12: InstallFiles.
Action ended 13:05:12: InstallFiles. Return value 1.
Action 13:05:12: PatchFiles. Patching files
Action start 13:05:12: PatchFiles.
Action ended 13:05:12: PatchFiles. Return value 0.
Action 13:05:12: DuplicateFiles. Creating duplicate files
Action start 13:05:12: DuplicateFiles.
Action ended 13:05:12: DuplicateFiles. Return value 1.
Action 13:05:12: BindImage. Binding executables
Action start 13:05:12: BindImage.
Action ended 13:05:12: BindImage. Return value 1.
Action 13:05:12: CreateShortcuts. Creating shortcuts
Action start 13:05:12: CreateShortcuts.
Action ended 13:05:12: CreateShortcuts. Return value 0.
Action 13:05:12: RegisterClassInfo. Registering class servers
Action start 13:05:12: RegisterClassInfo.
Action ended 13:05:12: RegisterClassInfo. Return value 0.
Action 13:05:12: RegisterExtensionInfo. Registering extension servers
Action start 13:05:12: RegisterExtensionInfo.
Action ended 13:05:12: RegisterExtensionInfo. Return value 0.
Action 13:05:12: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:12: RegisterProgIdInfo.
Action ended 13:05:12: RegisterProgIdInfo. Return value 0.
Action 13:05:12: RegisterMIMEInfo. Registering MIME info
Action start 13:05:12: RegisterMIMEInfo.
Action ended 13:05:12: RegisterMIMEInfo. Return value 0.
Action 13:05:12: WriteRegistryValues. Writing system registry values
Action start 13:05:12: WriteRegistryValues.
Action ended 13:05:12: WriteRegistryValues. Return value 1.
Action 13:05:12: WriteIniValues. Writing INI file values
Action start 13:05:12: WriteIniValues.
Action ended 13:05:12: WriteIniValues. Return value 1.
Action 13:05:12: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:12: WriteEnvironmentStrings.
Action ended 13:05:12: WriteEnvironmentStrings. Return value 1.
Action 13:05:12: RegisterFonts. Registering fonts
Action start 13:05:12: RegisterFonts.
Action ended 13:05:12: RegisterFonts. Return value 1.
Action 13:05:12: InstallODBC. Installing ODBC components
Action start 13:05:12: InstallODBC.
Action ended 13:05:12: InstallODBC. Return value 0.
Action 13:05:12: RegisterTypeLibraries. Registering type libraries
Action start 13:05:12: RegisterTypeLibraries.
Action ended 13:05:12: RegisterTypeLibraries. Return value 0.
Action 13:05:12: SelfRegModules. Registering modules
Action start 13:05:12: SelfRegModules.
Action ended 13:05:12: SelfRegModules. Return value 1.
Action 13:05:12: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:12: RegisterComPlus.
Action ended 13:05:12: RegisterComPlus. Return value 0.
Action 13:05:12: InstallServices. Installing new services
Action start 13:05:12: InstallServices.
Action ended 13:05:12: InstallServices. Return value 1.
Action 13:05:12: StartServices. Starting services
Action start 13:05:12: StartServices.
Action ended 13:05:12: StartServices. Return value 1.
Action 13:05:12: RegisterUser. Registering user
Action start 13:05:12: RegisterUser.
Action ended 13:05:12: RegisterUser. Return value 0.
Action 13:05:12: RegisterProduct. Registering product
Action start 13:05:12: RegisterProduct.
Registering product
Action ended 13:05:12: RegisterProduct. Return value 1.
Action 13:05:12: PublishComponents. Publishing qualified components
Action start 13:05:12: PublishComponents.
Action ended 13:05:12: PublishComponents. Return value 0.
Action 13:05:12: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:12: MsiPublishAssemblies.
Action ended 13:05:12: MsiPublishAssemblies. Return value 1.
Action 13:05:12: PublishFeatures. Publishing product features
Action start 13:05:12: PublishFeatures.
Action ended 13:05:12: PublishFeatures. Return value 1.
Action 13:05:12: PublishProduct. Publishing product information
Action start 13:05:12: PublishProduct.
Action ended 13:05:12: PublishProduct. Return value 1.
Action 13:05:12: InstallFinalize.
Action start 13:05:12: InstallFinalize.
354070.msi
Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.4137",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86",type="win32-policy"
Feature: Microsoft_VC90_ATL_x86_
Action 13:05:12: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b177.rbf
File: C:\Config.Msi\3b178.rbf
[ 4848] Sun Feb 13 13:05:13 2011 INFO
Action ended 13:05:13: InstallFinalize. Return value 1.
Action ended 13:05:13: INSTALL. Return value 1.
Property(S): UpgradeCode = {F31F95D5-E2B6-4984-A9D1-CA5E8CF1BFFE}
Property(S): SourcedirProduct = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
Property(S): Installed = 2009/07/28 04:07:38
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b171.msi
Property(S): Time = 13:05:13
Property(S): VirtualMemory = 14299
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86\
Property(S): WindowsFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\
Property(S): SystemFolder.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\SysWOW64\
Property(S): WinSxsDirectory.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_51c97d20bbe8350e\
Property(S): payload.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.4137_x-ww_35349982\
Property(S): WinSxsManifests.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\Policies\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
Property(S): policydir_ul.30729.4137.Microsoft_VC90_ATL_x86.QFE.97C2F162_B003_3CF9_ADD9_EE9DFF225A2A = C:\Windows\winsxs\x86_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe8be9c7\
Property(S): WinSxsDirectory.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\
Property(S): payload_ul.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\x86_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.4137_none_f0eecac0f8a1c174\
Property(S): WinSxsPolicies.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\winsxs\Policies\x86_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_9e7eb501\
Property(S): WindowsFolder.30729.4137.policy_9_0_Microsoft_VC90_ATL_x86.QFE.9BAF37E4_C37F_3B9C_8A4D_0B4F390FB6DC = C:\Windows\
Property(S): ProductCode = {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
Property(S): ProductName = Microsoft_VC90_ATL_x86
Property(S): DWUSLINK = CEAC70DF2E8BD79FDEACA7FFC98B978FCE1B808FFE0BB73FCE1BE08F4EDCE7AFE9FB809F89AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb1232.tmp
Property(S): PackageCode = {BC1C6355-192C-4334-94F9-4A03B0DCB75C}
=== Logging stopped: 13/02/2011 13:05:13 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:13 2011 INFO
:: END TIMER :: [Payload Operation :{033E378E-6AD3-4AD5-BDEB-CBD69B31046C}] took 2023.28 miliseconds (2.02328 seconds)
Calling the custom action code for post-repair for payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86
Calling the custom action code for pre-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64}
::START TIMER:: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}]
[ 5484] Sun Feb 13 13:05:13 2011 INFO
Installer Operation: PayloadUninstaller
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6B485102-4593-43F6-BA45-F14D690B0C64}
Effective AdobeCode for: {6B485102-4593-43F6-BA45-F14D690B0C64} is {6B485102-4593-43F6-BA45-F14D690B0C64}
Session includes local copy of payload for repair source
Repair payload source package: E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
Extracting assets...
[ 5484] Sun Feb 13 13:05:14 2011 INFO
Extracting assets complete. Number assets: 1
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
[ 5484] Sun Feb 13 13:05:15 2011 INFO
Evaluating condition# 1
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6B485102-4593-43F6-BA45-F14D690B0C64}.db
Physical payload repair result:0
[ 3432] Sun Feb 13 13:05:16 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{6B485102-4593-43F6-BA45-F14D690B0C64}] took 3022.52 miliseconds (3.02252 seconds) DTR = 532.006 KBPS (0.519538 MBPS)
[ 3432] Sun Feb 13 13:05:17 2011 INFO
Calling the custom action code for post-repair for payload {6B485102-4593-43F6-BA45-F14D690B0C64} Suite Shared Configuration CS5
Calling the custom action code for pre-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923}
::START TIMER:: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}]
[ 2692] Sun Feb 13 13:05:17 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Effective AdobeCode for: {BD0D6363-E961-410F-8BF4-ECD8795F3923} is {BD0D6363-E961-410F-8BF4-ECD8795F3923}
Repair payload source package: E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
[ 2692] Sun Feb 13 13:05:19 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
[ 2692] Sun Feb 13 13:05:27 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeCMaps3-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{BD0D6363-E961-410F-8BF4-ECD8795F3923}.db
[ 2692] Sun Feb 13 13:05:28 2011 INFO
[ 3432] Sun Feb 13 13:05:28 2011 INFO
:: END TIMER :: [Payload Operation :{BD0D6363-E961-410F-8BF4-ECD8795F3923}] took 11023.7 miliseconds (11.0237 seconds)
[ 3432] Sun Feb 13 13:05:29 2011 INFO
Calling the custom action code for post-repair for payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5
Calling the custom action code for pre-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C}
::START TIMER:: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}]
[ 3780] Sun Feb 13 13:05:29 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {6F3A624B-1B72-4081-96E8-23261F389C5C}
[ 3780] Sun Feb 13 13:05:30 2011 INFO
Effective AdobeCode for: {6F3A624B-1B72-4081-96E8-23261F389C5C} is {6F3A624B-1B72-4081-96E8-23261F389C5C}
Repair payload source package: E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
[ 3780] Sun Feb 13 13:05:34 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeTypeSupport10-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{6F3A624B-1B72-4081-96E8-23261F389C5C}.db
[ 3432] Sun Feb 13 13:05:34 2011 INFO
:: END TIMER :: [Payload Operation :{6F3A624B-1B72-4081-96E8-23261F389C5C}] took 5050.04 miliseconds (5.05004 seconds) DTR = 9.50488 KBPS (0.00928211 MBPS)
[ 3432] Sun Feb 13 13:05:35 2011 INFO
Calling the custom action code for post-repair for payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5
Calling the custom action code for pre-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
::START TIMER:: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}]
[ 4296] Sun Feb 13 13:05:35 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC80_ATL_x86.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC80_ATL_x86\, Result: 0
Configuring MSI ProductCode: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb707D.tmp"
[ 4296] Sun Feb 13 13:05:36 2011 INFO
=== Logging started: 13/02/2011 13:05:36 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC80_ATL_x86
Action 13:05:36: INSTALL.
Action start 13:05:36: INSTALL.
Action 13:05:36: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action start 13:05:36: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action ended 13:05:36: WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:36: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action start 13:05:36: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E.
Action ended 13:05:36: SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:36: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action start 13:05:36: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action ended 13:05:36: WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:36: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action start 13:05:36: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E.
Action ended 13:05:36: SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E. Return value 1.
Action 13:05:36: AppSearch. Searching for installed applications
Action start 13:05:36: AppSearch.
Action ended 13:05:36: AppSearch. Return value 0.
Action 13:05:36: FindRelatedProducts. Searching for related applications
Action start 13:05:36: FindRelatedProducts.
Action ended 13:05:36: FindRelatedProducts. Return value 0.
Action 13:05:36: ValidateProductID.
Action start 13:05:36: ValidateProductID.
Action ended 13:05:36: ValidateProductID. Return value 1.
Action 13:05:36: CostInitialize. Computing space requirements
Action start 13:05:36: CostInitialize.
Action ended 13:05:36: CostInitialize. Return value 1.
Action 13:05:36: FileCost. Computing space requirements
Action start 13:05:36: FileCost.
Action ended 13:05:36: FileCost. Return value 1.
Action 13:05:36: IsolateComponents.
Action start 13:05:36: IsolateComponents.
Action ended 13:05:36: IsolateComponents. Return value 0.
Action 13:05:36: CostFinalize. Computing space requirements
Action start 13:05:36: CostFinalize.
Action ended 13:05:36: CostFinalize. Return value 1.
Action 13:05:36: SetODBCFolders. Initializing ODBC directories
Action start 13:05:36: SetODBCFolders.
Action ended 13:05:36: SetODBCFolders. Return value 0.
Action 13:05:36: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:36: MigrateFeatureStates.
Action ended 13:05:36: MigrateFeatureStates. Return value 0.
Action 13:05:36: InstallValidate. Validating install
Action start 13:05:36: InstallValidate.
Action ended 13:05:36: InstallValidate. Return value 1.
Action 13:05:36: RemoveExistingProducts. Removing applications
Action start 13:05:36: RemoveExistingProducts.
Action ended 13:05:36: RemoveExistingProducts. Return value 0.
Action 13:05:36: InstallInitialize.
Action start 13:05:36: InstallInitialize.
Action ended 13:05:36: InstallInitialize. Return value 1.
Action 13:05:36: SxsInstallCA.
Action start 13:05:36: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1318 4: 0
1: sxsdelca: Skipping component 2: uplevel.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: uplevel.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca: Skipping component 2: downlevel_manifest.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
Action ended 13:05:36: SxsInstallCA. Return value 1.
Action 13:05:36: ProcessComponents. Updating component registration
Action start 13:05:36: ProcessComponents.
Action 13:05:36: GenerateScript. Generating script operations for action:
Action ended 13:05:36: ProcessComponents. Return value 1.
Action 13:05:36: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:36: UnpublishComponents.
Action ended 13:05:36: UnpublishComponents. Return value 0.
Action 13:05:36: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:36: MsiUnpublishAssemblies.
Action ended 13:05:36: MsiUnpublishAssemblies. Return value 1.
Action 13:05:36: UnpublishFeatures. Unpublishing product features
Action start 13:05:36: UnpublishFeatures.
Action ended 13:05:36: UnpublishFeatures. Return value 1.
Action 13:05:36: StopServices. Stopping services
Action start 13:05:36: StopServices.
Action ended 13:05:36: StopServices. Return value 1.
Action 13:05:36: DeleteServices. Deleting services
Action start 13:05:36: DeleteServices.
Action ended 13:05:36: DeleteServices. Return value 1.
Action 13:05:36: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:36: UnregisterComPlus.
Action ended 13:05:36: UnregisterComPlus. Return value 0.
Action 13:05:36: SelfUnregModules. Unregistering modules
Action start 13:05:36: SelfUnregModules.
Action ended 13:05:36: SelfUnregModules. Return value 1.
Action 13:05:36: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:36: UnregisterTypeLibraries.
Action ended 13:05:36: UnregisterTypeLibraries. Return value 0.
Action 13:05:36: RemoveODBC. Removing ODBC components
Action start 13:05:36: RemoveODBC.
Action ended 13:05:36: RemoveODBC. Return value 1.
Action 13:05:36: UnregisterFonts. Unregistering fonts
Action start 13:05:36: UnregisterFonts.
Action ended 13:05:36: UnregisterFonts. Return value 1.
Action 13:05:36: RemoveRegistryValues. Removing system registry values
Action start 13:05:36: RemoveRegistryValues.
Action ended 13:05:36: RemoveRegistryValues. Return value 1.
Action 13:05:36: UnregisterClassInfo. Unregister class servers
Action start 13:05:36: UnregisterClassInfo.
Action ended 13:05:36: UnregisterClassInfo. Return value 0.
Action 13:05:36: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:36: UnregisterExtensionInfo.
Action ended 13:05:36: UnregisterExtensionInfo. Return value 0.
Action 13:05:36: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:36: UnregisterProgIdInfo.
Action ended 13:05:36: UnregisterProgIdInfo. Return value 0.
Action 13:05:36: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:36: UnregisterMIMEInfo.
Action ended 13:05:36: UnregisterMIMEInfo. Return value 0.
Action 13:05:36: RemoveIniValues. Removing INI file entries
Action start 13:05:36: RemoveIniValues.
Action ended 13:05:36: RemoveIniValues. Return value 1.
Action 13:05:36: RemoveShortcuts. Removing shortcuts
Action start 13:05:36: RemoveShortcuts.
Action ended 13:05:36: RemoveShortcuts. Return value 0.
Action 13:05:36: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:36: RemoveEnvironmentStrings.
Action ended 13:05:36: RemoveEnvironmentStrings. Return value 1.
Action 13:05:36: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:36: RemoveDuplicateFiles.
Action ended 13:05:36: RemoveDuplicateFiles. Return value 1.
Action 13:05:36: RemoveFiles. Removing files
Action start 13:05:36: RemoveFiles.
Action ended 13:05:36: RemoveFiles. Return value 0.
Action 13:05:36: RemoveFolders. Removing folders
Action start 13:05:36: RemoveFolders.
Action ended 13:05:36: RemoveFolders. Return value 0.
Action 13:05:36: CreateFolders. Creating folders
Action start 13:05:36: CreateFolders.
Action ended 13:05:36: CreateFolders. Return value 0.
Action 13:05:36: MoveFiles. Moving files
Action start 13:05:36: MoveFiles.
Action ended 13:05:36: MoveFiles. Return value 1.
Action 13:05:36: InstallFiles. Copying new files
Action start 13:05:36: InstallFiles.
[ 4296] Sun Feb 13 13:05:37 2011 INFO
Action ended 13:05:37: InstallFiles. Return value 1.
Action 13:05:37: PatchFiles. Patching files
Action start 13:05:37: PatchFiles.
Action ended 13:05:37: PatchFiles. Return value 0.
Action 13:05:37: DuplicateFiles. Creating duplicate files
Action start 13:05:37: DuplicateFiles.
Action ended 13:05:37: DuplicateFiles. Return value 1.
Action 13:05:37: BindImage. Binding executables
Action start 13:05:37: BindImage.
Action ended 13:05:37: BindImage. Return value 1.
Action 13:05:37: CreateShortcuts. Creating shortcuts
Action start 13:05:37: CreateShortcuts.
Action ended 13:05:37: CreateShortcuts. Return value 0.
Action 13:05:37: RegisterClassInfo. Registering class servers
Action start 13:05:37: RegisterClassInfo.
Action ended 13:05:37: RegisterClassInfo. Return value 0.
Action 13:05:37: RegisterExtensionInfo. Registering extension servers
Action start 13:05:37: RegisterExtensionInfo.
Action ended 13:05:37: RegisterExtensionInfo. Return value 0.
Action 13:05:37: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:37: RegisterProgIdInfo.
Action ended 13:05:37: RegisterProgIdInfo. Return value 0.
Action 13:05:37: RegisterMIMEInfo. Registering MIME info
Action start 13:05:37: RegisterMIMEInfo.
Action ended 13:05:37: RegisterMIMEInfo. Return value 0.
Action 13:05:37: WriteRegistryValues. Writing system registry values
Action start 13:05:37: WriteRegistryValues.
Action ended 13:05:37: WriteRegistryValues. Return value 1.
Action 13:05:37: WriteIniValues. Writing INI file values
Action start 13:05:37: WriteIniValues.
Action ended 13:05:37: WriteIniValues. Return value 1.
Action 13:05:37: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:37: WriteEnvironmentStrings.
Action ended 13:05:37: WriteEnvironmentStrings. Return value 1.
Action 13:05:37: RegisterFonts. Registering fonts
Action start 13:05:37: RegisterFonts.
Action ended 13:05:37: RegisterFonts. Return value 1.
Action 13:05:37: InstallODBC. Installing ODBC components
Action start 13:05:37: InstallODBC.
Action ended 13:05:37: InstallODBC. Return value 0.
Action 13:05:37: RegisterTypeLibraries. Registering type libraries
Action start 13:05:37: RegisterTypeLibraries.
Action ended 13:05:37: RegisterTypeLibraries. Return value 0.
Action 13:05:37: SelfRegModules. Registering modules
Action start 13:05:37: SelfRegModules.
Action ended 13:05:37: SelfRegModules. Return value 1.
Action 13:05:37: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:37: RegisterComPlus.
Action ended 13:05:37: RegisterComPlus. Return value 0.
Action 13:05:37: InstallServices. Installing new services
Action start 13:05:37: InstallServices.
Action ended 13:05:37: InstallServices. Return value 1.
Action 13:05:37: StartServices. Starting services
Action start 13:05:37: StartServices.
Action ended 13:05:37: StartServices. Return value 1.
Action 13:05:37: RegisterUser. Registering user
Action start 13:05:37: RegisterUser.
Action ended 13:05:37: RegisterUser. Return value 0.
Action 13:05:37: RegisterProduct. Registering product
Action start 13:05:37: RegisterProduct.
Registering product
Action ended 13:05:37: RegisterProduct. Return value 1.
Action 13:05:37: PublishComponents. Publishing qualified components
Action start 13:05:37: PublishComponents.
Action ended 13:05:37: PublishComponents. Return value 0.
Action 13:05:37: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:37: MsiPublishAssemblies.
Action ended 13:05:37: MsiPublishAssemblies. Return value 1.
Action 13:05:37: PublishFeatures. Publishing product features
Action start 13:05:37: PublishFeatures.
Action ended 13:05:37: PublishFeatures. Return value 1.
Action 13:05:37: PublishProduct. Publishing product information
Action start 13:05:37: PublishProduct.
Action ended 13:05:37: PublishProduct. Return value 1.
Action 13:05:37: InstallFinalize.
Action start 13:05:37: InstallFinalize.
Action 13:05:37: ProcessComponents. Updating component registration
Action 13:05:37: RemoveODBC. Removing ODBC components
Action 13:05:37: InstallFiles. Copying new files
354079.msi
Application Context:Global, Assembly Name:Microsoft.VC80.ATL,type="win32",version="8.0.50727.4053",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.ATL,type="win32-policy",version="8.0.50727.4053",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="x86"
Feature: Microsoft_VC80_ATL_x86_
Action 13:05:37: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b180.rbf
File: C:\Config.Msi\3b181.rbf
Action ended 13:05:37: InstallFinalize. Return value 1.
Action ended 13:05:37: INSTALL. Return value 1.
Property(S): SourcedirProduct = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
Property(S): UpgradeCode = {B42842E9-F9F7-4A0F-A616-857958BC88BF}
Property(S): Installed = 2009/11/13 01:34:20
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
Property(S): DATABASE = C:\Windows\Installer\3b17a.msi
Property(S): Time = 13:05:37
Property(S): VirtualMemory = 14284
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC80_ATL_x86\
Property(S): WinSxsDirectory.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d1c738ec43578ea1\
Property(S): payload.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_6e805841\
Property(S): WindowsFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): WinSxsPolicies.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_6e845944\
Property(S): payload.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_6e85597e\
Property(S): payload.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_6e85597d\
Property(S): policydir.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): ANSIFolder.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): payload.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_6e85597f\
Property(S): policydir.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_6e855980\
Property(S): payload.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_6e855983\
Property(S): payload.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_6e855981\
Property(S): payload.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_6e855982\
Property(S): payload.8.0.50727.100.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_c8b815f2\
Property(S): payload.8.0.50727.101.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_c8b815f3\
Property(S): policydir.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_c8b815f6\
Property(S): payload.8.0.50727.103.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_c8b815f5\
Property(S): policydir.8.0.50727.104.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_c8c1182c\
Property(S): payload.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_18ae9600\
Property(S): payload.8.0.50727.238.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_c9392638\
Property(S): payload.8.0.50727.3069.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_18b09683\
Property(S): policydir.8.0.50727.3044.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_18af963c\
Property(S): payload.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_47336645\
Property(S): payload.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_47336644\
Property(S): payload.8.0.50727.1833.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_bf90704a\
Property(S): policydir_ul.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
Property(S): payload.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_47336646\
Property(S): payload.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_473666fd\
Property(S): policydir.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.99.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.98.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.97.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.96.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.95.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.94.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): payload.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_473566c0\
Property(S): payload.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_473666fc\
Property(S): policydir.8.0.50727.93.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.89.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4053.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4052.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4045.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4029.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4028.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.3051.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.193.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): policydir.8.0.50727.4027.97F81AF1_0E47_DC99_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_2b722bc6\
Property(S): WinSxsDirectory.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
Property(S): payload_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.4053_none_4ddfc6cd11929a02\
Property(S): WinSxsPolicies.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
Property(S): policydir.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): WindowsFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\
Property(S): SystemFolder.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
Property(S): WinSxsManifests.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
Property(S): payload.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_b2841548\
Property(S): policydir.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir_ul.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_8b3a2404\
Property(S): policydir.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.94.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_b2891685\
Property(S): policydir.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.89.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_b288164b\
Property(S): policydir.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.93.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_b2891684\
Property(S): policydir.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.95.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_b2891686\
Property(S): policydir.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.96.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_b2891687\
Property(S): policydir.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.97.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_b2891688\
Property(S): policydir.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.98.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_b2891689\
Property(S): policydir.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.99.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_b289168a\
Property(S): policydir.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.100.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_0cbbd2f9\
Property(S): payload.8.0.50727.101.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_0cbbd2fa\
Property(S): policydir.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.103.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_0cbbd2fc\
Property(S): payload.8.0.50727.104.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_0cbbd2fd\
Property(S): policydir.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.193.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_0cc4d533\
Property(S): policydir.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): policydir.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_x-ww_5f0bbcff\
Property(S): payload.8.0.50727.238.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_0d3ce33f\
Property(S): payload.8.0.50727.3044.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_5cb25307\
Property(S): payload.8.0.50727.3051.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_5cb35343\
Property(S): payload.8.0.50727.3069.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_5cb4538a\
Property(S): payload.8.0.50727.1833.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_03942d51\
Property(S): payload.8.0.50727.4027.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_8b37234b\
Property(S): payload.8.0.50727.4028.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_8b37234c\
Property(S): payload.8.0.50727.4029.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_8b37234d\
Property(S): payload.8.0.50727.4045.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_8b3923c7\
Property(S): payload.8.0.50727.4052.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_8b3a2403\
Property(S): payload.8.0.50727.4053.66332652_9C28_58B1_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_8b3a2404\
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC80_ATL_x86
Property(S): ProductVersion = 8.0.50727.4053
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = No
Property(S): ReinstallModeText = omus
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CE0B90581E3CF05FFEAC57B89EEC978F9EDC508F591B0798CEABF7DFDEAB57D8FE1C47B8D9AC
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): REBOOT = ReallySuppress
Property(S): VersionDatabase = 200
Property(S): PRODUCTLANGUAGE = 1033
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 4116
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb707D.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): USERNAME = Gary & Susan
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {3C0DD3C2-B6EC-46C4-8544-00189BC45D86}
=== Logging stopped: 13/02/2011 13:05:37 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:37 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}] took 2044.74 miliseconds (2.04474 seconds) DTR = 33.2561 KBPS (0.0324766 MBPS)
User specified overrideFile:
Calling the custom action code for post-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86
[ 3432] Sun Feb 13 13:05:38 2011 INFO
Calling the custom action code for pre-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C}
::START TIMER:: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}]
[ 3784] Sun Feb 13 13:05:38 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {A8798E04-96FF-4564-9157-0D4C89CB794C}
Effective AdobeCode for: {A8798E04-96FF-4564-9157-0D4C89CB794C} is {A8798E04-96FF-4564-9157-0D4C89CB794C}
Repair payload source package: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
[ 3784] Sun Feb 13 13:05:39 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A8798E04-96FF-4564-9157-0D4C89CB794C}.db
[ 3432] Sun Feb 13 13:05:40 2011 INFO
:: END TIMER :: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}] took 2022.55 miliseconds (2.02255 seconds) DTR = 506.291 KBPS (0.494425 MBPS)
Calling the custom action code for post-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
Calling the custom action code for pre-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
::START TIMER:: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}]
[ 3376] Sun Feb 13 13:05:40 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86_x64.msi, Result: 0
Payload exists on removable media: E:\
[ 3376] Sun Feb 13 13:05:41 2011 INFO
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\, Result: 0
Configuring MSI ProductCode: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb8537.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 13:05:41 ===
Message type: 1, Argument: Microsoft_VC90_CRT_x86_x64
Action 13:05:41: INSTALL.
Action start 13:05:41: INSTALL.
Action 13:05:41: AppSearch. Searching for installed applications
Action start 13:05:41: AppSearch.
Action ended 13:05:41: AppSearch. Return value 0.
Action 13:05:41: FindRelatedProducts. Searching for related applications
Action start 13:05:41: FindRelatedProducts.
Action ended 13:05:41: FindRelatedProducts. Return value 0.
Action 13:05:41: ValidateProductID.
Action start 13:05:41: ValidateProductID.
Action ended 13:05:41: ValidateProductID. Return value 1.
Action 13:05:41: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action start 13:05:41: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action ended 13:05:41: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812. Return value 1.
Action 13:05:41: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action start 13:05:41: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action ended 13:05:41: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B. Return value 1.
Action 13:05:41: CostInitialize. Computing space requirements
Action start 13:05:41: CostInitialize.
Action ended 13:05:41: CostInitialize. Return value 1.
Action 13:05:41: FileCost. Computing space requirements
Action start 13:05:41: FileCost.
Action ended 13:05:41: FileCost. Return value 1.
Action 13:05:41: IsolateComponents.
Action start 13:05:41: IsolateComponents.
Action ended 13:05:41: IsolateComponents. Return value 0.
Action 13:05:41: CostFinalize. Computing space requirements
Action start 13:05:41: CostFinalize.
Action ended 13:05:41: CostFinalize. Return value 1.
Action 13:05:41: SetODBCFolders. Initializing ODBC directories
Action start 13:05:41: SetODBCFolders.
Action ended 13:05:41: SetODBCFolders. Return value 0.
Action 13:05:41: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:41: MigrateFeatureStates.
Action ended 13:05:41: MigrateFeatureStates. Return value 0.
Action 13:05:41: InstallValidate. Validating install
Action start 13:05:41: InstallValidate.
Action ended 13:05:41: InstallValidate. Return value 1.
Action 13:05:41: RemoveExistingProducts. Removing applications
Action start 13:05:41: RemoveExistingProducts.
Action ended 13:05:41: RemoveExistingProducts. Return value 0.
Action 13:05:41: InstallInitialize.
Action start 13:05:41: InstallInitialize.
Action ended 13:05:41: InstallInitialize. Return value 1.
Action 13:05:41: ProcessComponents. Updating component registration
Action start 13:05:41: ProcessComponents.
Action 13:05:41: GenerateScript. Generating script operations for action:
Action ended 13:05:41: ProcessComponents. Return value 1.
Action 13:05:41: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:41: UnpublishComponents.
Action ended 13:05:41: UnpublishComponents. Return value 0.
Action 13:05:41: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:41: MsiUnpublishAssemblies.
Action ended 13:05:41: MsiUnpublishAssemblies. Return value 1.
Action 13:05:41: UnpublishFeatures. Unpublishing product features
Action start 13:05:41: UnpublishFeatures.
Action ended 13:05:41: UnpublishFeatures. Return value 1.
Action 13:05:41: StopServices. Stopping services
Action start 13:05:41: StopServices.
Action ended 13:05:41: StopServices. Return value 1.
Action 13:05:41: DeleteServices. Deleting services
Action start 13:05:41: DeleteServices.
Action ended 13:05:41: DeleteServices. Return value 1.
Action 13:05:41: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:41: UnregisterComPlus.
Action ended 13:05:41: UnregisterComPlus. Return value 0.
Action 13:05:41: SelfUnregModules. Unregistering modules
Action start 13:05:41: SelfUnregModules.
Action ended 13:05:41: SelfUnregModules. Return value 1.
Action 13:05:41: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:41: UnregisterTypeLibraries.
Action ended 13:05:41: UnregisterTypeLibraries. Return value 0.
Action 13:05:41: RemoveODBC. Removing ODBC components
Action start 13:05:41: RemoveODBC.
Action ended 13:05:41: RemoveODBC. Return value 1.
Action 13:05:41: UnregisterFonts. Unregistering fonts
Action start 13:05:41: UnregisterFonts.
Action ended 13:05:41: UnregisterFonts. Return value 1.
Action 13:05:41: RemoveRegistryValues. Removing system registry values
Action start 13:05:41: RemoveRegistryValues.
Action ended 13:05:41: RemoveRegistryValues. Return value 1.
Action 13:05:41: UnregisterClassInfo. Unregister class servers
Action start 13:05:41: UnregisterClassInfo.
Action ended 13:05:41: UnregisterClassInfo. Return value 0.
Action 13:05:41: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:41: UnregisterExtensionInfo.
Action ended 13:05:41: UnregisterExtensionInfo. Return value 0.
Action 13:05:41: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:41: UnregisterProgIdInfo.
Action ended 13:05:41: UnregisterProgIdInfo. Return value 0.
Action 13:05:41: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:41: UnregisterMIMEInfo.
Action ended 13:05:41: UnregisterMIMEInfo. Return value 0.
Action 13:05:41: RemoveIniValues. Removing INI file entries
Action start 13:05:41: RemoveIniValues.
Action ended 13:05:41: RemoveIniValues. Return value 1.
Action 13:05:41: RemoveShortcuts. Removing shortcuts
Action start 13:05:41: RemoveShortcuts.
Action ended 13:05:41: RemoveShortcuts. Return value 0.
Action 13:05:41: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:41: RemoveEnvironmentStrings.
Action ended 13:05:41: RemoveEnvironmentStrings. Return value 1.
Action 13:05:41: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:41: RemoveDuplicateFiles.
Action ended 13:05:41: RemoveDuplicateFiles. Return value 1.
Action 13:05:41: RemoveFiles. Removing files
Action start 13:05:41: RemoveFiles.
Action ended 13:05:41: RemoveFiles. Return value 0.
Action 13:05:41: RemoveFolders. Removing folders
Action start 13:05:41: RemoveFolders.
Action ended 13:05:41: RemoveFolders. Return value 0.
Action 13:05:41: CreateFolders. Creating folders
Action start 13:05:41: CreateFolders.
Action ended 13:05:41: CreateFolders. Return value 0.
Action 13:05:41: MoveFiles. Moving files
Action start 13:05:41: MoveFiles.
Action ended 13:05:41: MoveFiles. Return value 1.
Action 13:05:41: InstallFiles. Copying new files
Action start 13:05:41: InstallFiles.
[ 3376] Sun Feb 13 13:05:42 2011 INFO
File: Copying new files, Directory: , Size:
Action ended 13:05:42: InstallFiles. Return value 1.
Action 13:05:42: PatchFiles. Patching files
Action start 13:05:42: PatchFiles.
Action ended 13:05:42: PatchFiles. Return value 0.
Action 13:05:42: DuplicateFiles. Creating duplicate files
Action start 13:05:42: DuplicateFiles.
Action ended 13:05:42: DuplicateFiles. Return value 1.
Action 13:05:42: BindImage. Binding executables
Action start 13:05:42: BindImage.
Action ended 13:05:42: BindImage. Return value 1.
Action 13:05:42: CreateShortcuts. Creating shortcuts
Action start 13:05:42: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 13:05:42: CreateShortcuts. Return value 0.
Action 13:05:42: RegisterClassInfo. Registering class servers
Action start 13:05:42: RegisterClassInfo.
Action ended 13:05:42: RegisterClassInfo. Return value 0.
Action 13:05:42: RegisterExtensionInfo. Registering extension servers
Action start 13:05:42: RegisterExtensionInfo.
Action ended 13:05:42: RegisterExtensionInfo. Return value 0.
Action 13:05:42: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:42: RegisterProgIdInfo.
Action ended 13:05:42: RegisterProgIdInfo. Return value 0.
Action 13:05:42: RegisterMIMEInfo. Registering MIME info
Action start 13:05:42: RegisterMIMEInfo.
Action ended 13:05:42: RegisterMIMEInfo. Return value 0.
Action 13:05:42: WriteRegistryValues. Writing system registry values
Action start 13:05:42: WriteRegistryValues.
Action ended 13:05:42: WriteRegistryValues. Return value 1.
Action 13:05:42: WriteIniValues. Writing INI file values
Action start 13:05:42: WriteIniValues.
Action ended 13:05:42: WriteIniValues. Return value 1.
Action 13:05:42: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:42: WriteEnvironmentStrings.
Action ended 13:05:42: WriteEnvironmentStrings. Return value 1.
Action 13:05:42: RegisterFonts. Registering fonts
Action start 13:05:42: RegisterFonts.
Action ended 13:05:42: RegisterFonts. Return value 1.
Action 13:05:42: InstallODBC. Installing ODBC components
Action start 13:05:42: InstallODBC.
Action ended 13:05:42: InstallODBC. Return value 0.
Action 13:05:42: RegisterTypeLibraries. Registering type libraries
Action start 13:05:42: RegisterTypeLibraries.
Action ended 13:05:42: RegisterTypeLibraries. Return value 0.
Action 13:05:42: SelfRegModules. Registering modules
Action start 13:05:42: SelfRegModules.
Action ended 13:05:42: SelfRegModules. Return value 1.
Action 13:05:42: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:42: RegisterComPlus.
Action ended 13:05:42: RegisterComPlus. Return value 0.
Action 13:05:42: InstallServices. Installing new services
Action start 13:05:42: InstallServices.
Action ended 13:05:42: InstallServices. Return value 1.
Action 13:05:42: StartServices. Starting services
Action start 13:05:42: StartServices.
Action ended 13:05:42: StartServices. Return value 1.
Action 13:05:42: RegisterUser. Registering user
Action start 13:05:42: RegisterUser.
Action ended 13:05:42: RegisterUser. Return value 0.
Action 13:05:42: RegisterProduct. Registering product
Action start 13:05:42: RegisterProduct.
Registering product
Action ended 13:05:42: RegisterProduct. Return value 1.
Action 13:05:42: PublishComponents. Publishing qualified components
Action start 13:05:42: PublishComponents.
Action ended 13:05:42: PublishComponents. Return value 0.
Action 13:05:42: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:42: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 13:05:42: MsiPublishAssemblies. Return value 1.
Action 13:05:42: PublishFeatures. Publishing product features
Action start 13:05:42: PublishFeatures.
Feature: Publishing product features
Action ended 13:05:42: PublishFeatures. Return value 1.
Action 13:05:42: PublishProduct. Publishing product information
Action start 13:05:42: PublishProduct.
Action ended 13:05:42: PublishProduct. Return value 1.
Action 13:05:42: InstallFinalize.
Action start 13:05:42: InstallFinalize.
Message type: 0, Argument: 0
Action 13:05:42: ProcessComponents. Updating component registration
Action 13:05:42: RemoveODBC. Removing ODBC components
Action 13:05:42: InstallFiles. Copying new files
Shortcut: ARPPRODUCTICON.exe
354082.msi
Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_CRT_x86_
Message type: 2, Argument: 0
Action 13:05:42: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b189.rbf
File: C:\Config.Msi\3b18a.rbf
Message type: 2, Argument: 1
Action ended 13:05:42: InstallFinalize. Return value 1.
Action ended 13:05:42: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {54AE2BD2-7685-4215-9490-3BBF14C2BBB4}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
Property(S): SourcedirProduct = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): Installed = 2009/03/11 04:02:22
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\3b183.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 13:05:42
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): VirtualMemory = 14279
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): PrimaryVolumePath = F:\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System16Folder = F:\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371c1d4\
Property(S): payload.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_a17e7c1e\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): policydir_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_3da38fdebd0e6822\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3e195\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\
Property(S): ProductCode = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): ProductName = Microsoft_VC90_CRT_x86_x64
Property(S): ProductVersion = 1.00.0000
Property(S): DWUSLINK = CE1C879F4EDBE0A8A9ACB06F8E0B978FAE9CF08F598C9758CE1CB08FFE8CF0C8AE8CF0EF8EAC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): PRODUCTLANGUAGE = 0
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb8537.tmp
Property(S): PackageCode = {EBEBD87C-43F1-4673-9D38-D8BA645AA1C5}
=== Logging stopped: 13/02/2011 13:05:42 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:43 2011 INFO
:: END TIMER :: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}] took 3023.62 miliseconds (3.02362 seconds)
Calling the custom action code for post-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64
Calling the custom action code for pre-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593}
::START TIMER:: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}]
[ 4160] Sun Feb 13 13:05:43 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86_x64.msi, Result: 0
[ 4160] Sun Feb 13 13:05:44 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\, Result: 0
Configuring MSI ProductCode: {8557397C-A42D-486F-97B3-A2CBC2372593}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb90EC.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 13:05:44 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC90_ATL_x86_x64
Action 13:05:44: INSTALL.
Action start 13:05:44: INSTALL.
Action 13:05:44: AppSearch. Searching for installed applications
Action start 13:05:44: AppSearch.
Action ended 13:05:44: AppSearch. Return value 0.
Action 13:05:44: FindRelatedProducts. Searching for related applications
Action start 13:05:44: FindRelatedProducts.
Action ended 13:05:44: FindRelatedProducts. Return value 0.
Action 13:05:44: ValidateProductID.
Action start 13:05:44: ValidateProductID.
Action ended 13:05:44: ValidateProductID. Return value 1.
Action 13:05:44: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action start 13:05:44: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action ended 13:05:44: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C. Return value 1.
Action 13:05:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action start 13:05:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action ended 13:05:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479. Return value 1.
Action 13:05:44: CostInitialize. Computing space requirements
Action start 13:05:44: CostInitialize.
Action ended 13:05:44: CostInitialize. Return value 1.
Action 13:05:44: FileCost. Computing space requirements
Action start 13:05:44: FileCost.
Action ended 13:05:44: FileCost. Return value 1.
Action 13:05:44: IsolateComponents.
Action start 13:05:44: IsolateComponents.
Action ended 13:05:44: IsolateComponents. Return value 0.
Action 13:05:44: CostFinalize. Computing space requirements
Action start 13:05:44: CostFinalize.
Action ended 13:05:44: CostFinalize. Return value 1.
Action 13:05:44: SetODBCFolders. Initializing ODBC directories
Action start 13:05:44: SetODBCFolders.
Action ended 13:05:44: SetODBCFolders. Return value 0.
Action 13:05:44: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:44: MigrateFeatureStates.
Action ended 13:05:44: MigrateFeatureStates. Return value 0.
Action 13:05:44: InstallValidate. Validating install
Action start 13:05:44: InstallValidate.
Action ended 13:05:44: InstallValidate. Return value 1.
Action 13:05:44: RemoveExistingProducts. Removing applications
Action start 13:05:44: RemoveExistingProducts.
Action ended 13:05:44: RemoveExistingProducts. Return value 0.
Action 13:05:44: InstallInitialize.
Action start 13:05:44: InstallInitialize.
Action ended 13:05:44: InstallInitialize. Return value 1.
Action 13:05:44: ProcessComponents. Updating component registration
Action start 13:05:44: ProcessComponents.
Action 13:05:44: GenerateScript. Generating script operations for action:
Action ended 13:05:44: ProcessComponents. Return value 1.
Action 13:05:44: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:44: UnpublishComponents.
Action ended 13:05:44: UnpublishComponents. Return value 0.
Action 13:05:44: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:44: MsiUnpublishAssemblies.
Action ended 13:05:44: MsiUnpublishAssemblies. Return value 1.
Action 13:05:44: UnpublishFeatures. Unpublishing product features
Action start 13:05:44: UnpublishFeatures.
Action ended 13:05:44: UnpublishFeatures. Return value 1.
Action 13:05:44: StopServices. Stopping services
Action start 13:05:44: StopServices.
Action ended 13:05:44: StopServices. Return value 1.
Action 13:05:44: DeleteServices. Deleting services
Action start 13:05:44: DeleteServices.
Action ended 13:05:44: DeleteServices. Return value 1.
Action 13:05:44: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:44: UnregisterComPlus.
Action ended 13:05:44: UnregisterComPlus. Return value 0.
Action 13:05:44: SelfUnregModules. Unregistering modules
Action start 13:05:44: SelfUnregModules.
Action ended 13:05:44: SelfUnregModules. Return value 1.
Action 13:05:44: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:44: UnregisterTypeLibraries.
Action ended 13:05:44: UnregisterTypeLibraries. Return value 0.
Action 13:05:44: RemoveODBC. Removing ODBC components
Action start 13:05:44: RemoveODBC.
Action ended 13:05:44: RemoveODBC. Return value 1.
Action 13:05:44: UnregisterFonts. Unregistering fonts
Action start 13:05:44: UnregisterFonts.
Action ended 13:05:44: UnregisterFonts. Return value 1.
Action 13:05:44: RemoveRegistryValues. Removing system registry values
Action start 13:05:44: RemoveRegistryValues.
Action ended 13:05:44: RemoveRegistryValues. Return value 1.
Action 13:05:44: UnregisterClassInfo. Unregister class servers
Action start 13:05:44: UnregisterClassInfo.
Action ended 13:05:44: UnregisterClassInfo. Return value 0.
Action 13:05:44: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:44: UnregisterExtensionInfo.
Action ended 13:05:44: UnregisterExtensionInfo. Return value 0.
Action 13:05:44: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:44: UnregisterProgIdInfo.
Action ended 13:05:44: UnregisterProgIdInfo. Return value 0.
Action 13:05:44: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:44: UnregisterMIMEInfo.
Action ended 13:05:44: UnregisterMIMEInfo. Return value 0.
Action 13:05:44: RemoveIniValues. Removing INI file entries
Action start 13:05:44: RemoveIniValues.
Action ended 13:05:44: RemoveIniValues. Return value 1.
Action 13:05:44: RemoveShortcuts. Removing shortcuts
Action start 13:05:44: RemoveShortcuts.
Action ended 13:05:44: RemoveShortcuts. Return value 0.
Action 13:05:44: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:44: RemoveEnvironmentStrings.
Action ended 13:05:44: RemoveEnvironmentStrings. Return value 1.
Action 13:05:44: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:44: RemoveDuplicateFiles.
Action ended 13:05:44: RemoveDuplicateFiles. Return value 1.
Action 13:05:44: RemoveFiles. Removing files
Action start 13:05:44: RemoveFiles.
Action ended 13:05:44: RemoveFiles. Return value 0.
Action 13:05:44: RemoveFolders. Removing folders
Action start 13:05:44: RemoveFolders.
Action ended 13:05:44: RemoveFolders. Return value 0.
Action 13:05:44: CreateFolders. Creating folders
Action start 13:05:44: CreateFolders.
Action ended 13:05:44: CreateFolders. Return value 0.
Action 13:05:44: MoveFiles. Moving files
Action start 13:05:44: MoveFiles.
Action ended 13:05:44: MoveFiles. Return value 1.
Action 13:05:44: InstallFiles. Copying new files
Action start 13:05:44: InstallFiles.
Action ended 13:05:44: InstallFiles. Return value 1.
Action 13:05:44: PatchFiles. Patching files
Action start 13:05:44: PatchFiles.
Action ended 13:05:44: PatchFiles. Return value 0.
Action 13:05:44: DuplicateFiles. Creating duplicate files
Action start 13:05:44: DuplicateFiles.
Action ended 13:05:44: DuplicateFiles. Return value 1.
Action 13:05:44: BindImage. Binding executables
Action start 13:05:44: BindImage.
Action ended 13:05:44: BindImage. Return value 1.
Action 13:05:44: CreateShortcuts. Creating shortcuts
Action start 13:05:44: CreateShortcuts.
Action ended 13:05:44: CreateShortcuts. Return value 0.
Action 13:05:44: RegisterClassInfo. Registering class servers
Action start 13:05:44: RegisterClassInfo.
Action ended 13:05:44: RegisterClassInfo. Return value 0.
Action 13:05:44: RegisterExtensionInfo. Registering extension servers
Action start 13:05:44: RegisterExtensionInfo.
Action ended 13:05:44: RegisterExtensionInfo. Return value 0.
Action 13:05:44: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:44: RegisterProgIdInfo.
Action ended 13:05:44: RegisterProgIdInfo. Return value 0.
Action 13:05:44: RegisterMIMEInfo. Registering MIME info
Action start 13:05:44: RegisterMIMEInfo.
Action ended 13:05:44: RegisterMIMEInfo. Return value 0.
Action 13:05:44: WriteRegistryValues. Writing system registry values
Action start 13:05:44: WriteRegistryValues.
Action ended 13:05:44: WriteRegistryValues. Return value 1.
Action 13:05:44: WriteIniValues. Writing INI file values
Action start 13:05:44: WriteIniValues.
Action ended 13:05:44: WriteIniValues. Return value 1.
Action 13:05:44: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:44: WriteEnvironmentStrings.
Action ended 13:05:44: WriteEnvironmentStrings. Return value 1.
Action 13:05:44: RegisterFonts. Registering fonts
Action start 13:05:44: RegisterFonts.
Action ended 13:05:44: RegisterFonts. Return value 1.
Action 13:05:44: InstallODBC. Installing ODBC components
Action start 13:05:44: InstallODBC.
Action ended 13:05:44: InstallODBC. Return value 0.
Action 13:05:44: RegisterTypeLibraries. Registering type libraries
Action start 13:05:44: RegisterTypeLibraries.
Action ended 13:05:44: RegisterTypeLibraries. Return value 0.
Action 13:05:44: SelfRegModules. Registering modules
Action start 13:05:44: SelfRegModules.
Action ended 13:05:44: SelfRegModules. Return value 1.
Action 13:05:44: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:44: RegisterComPlus.
Action ended 13:05:44: RegisterComPlus. Return value 0.
Action 13:05:44: InstallServices. Installing new services
Action start 13:05:44: InstallServices.
Action ended 13:05:44: InstallServices. Return value 1.
Action 13:05:44: StartServices. Starting services
Action start 13:05:44: StartServices.
Action ended 13:05:44: StartServices. Return value 1.
Action 13:05:44: RegisterUser. Registering user
Action start 13:05:44: RegisterUser.
Action ended 13:05:44: RegisterUser. Return value 0.
Action 13:05:44: RegisterProduct. Registering product
Action start 13:05:44: RegisterProduct.
Registering product
Action ended 13:05:44: RegisterProduct. Return value 1.
Action 13:05:44: PublishComponents. Publishing qualified components
Action start 13:05:44: PublishComponents.
Action ended 13:05:44: PublishComponents. Return value 0.
Action 13:05:44: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:44: MsiPublishAssemblies.
Action ended 13:05:44: MsiPublishAssemblies. Return value 1.
Action 13:05:44: PublishFeatures. Publishing product features
Action start 13:05:44: PublishFeatures.
Action ended 13:05:44: PublishFeatures. Return value 1.
Action 13:05:44: PublishProduct. Publishing product information
Action start 13:05:44: PublishProduct.
Action ended 13:05:44: PublishProduct. Return value 1.
Action 13:05:44: InstallFinalize.
Action start 13:05:44: InstallFinalize.
35408b.msi
[ 4160] Sun Feb 13 13:05:45 2011 INFO
Action 13:05:45: MsiPublishAssemblies. Publishing assembly information
Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Action 13:05:45: PublishFeatures. Publishing product features
Feature: Microsoft_VC90_ATL_x86_
Action 13:05:45: PublishProduct. Publishing product information
Action 13:05:45: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b192.rbf
File: C:\Config.Msi\3b193.rbf
Action ended 13:05:45: InstallFinalize. Return value 1.
Action ended 13:05:45: INSTALL. Return value 1.
Property(S): UpgradeCode = {B178CFE7-E127-4205-991D-147FA189D61F}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): SourcedirProduct = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): Installed = 2009/03/11 03:58:08
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\3b18c.msi
Property(S): Time = 13:05:45
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_9aefdaaa829eb818\
Property(S): payload.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_021e6992\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): policydir_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_3a15284abf58447e\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe3d5721\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\
Property(S): ProductCode = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): ProductName = Microsoft_VC90_ATL_x86_x64
Property(S): DWUSLINK = CEFCF71FEE8B30FFC9ACD09FCEDB978F9E9B078F69FC00D8CE9B17F8C9CBF7D899AC806FE9AC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb90EC.tmp
Property(S): PackageCode = {60C47539-11AA-4C6D-BA88-692C748A2ABC}
=== Logging stopped: 13/02/2011 13:05:45 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:45 2011 INFO
:: END TIMER :: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}] took 2027.17 miliseconds (2.02717 seconds)
Calling the custom action code for post-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64
Calling the custom action code for pre-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
::START TIMER:: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}]
[ 3704] Sun Feb 13 13:05:45 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86_x64.msi, Result: 0
[ 3704] Sun Feb 13 13:05:46 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\, Result: 0
Configuring MSI ProductCode: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb9966.tmp"
1: 0 2: 0 3: 1252
[ 3704] Sun Feb 13 13:05:47 2011 INFO
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 13:05:47 ===
Message type: 1, Argument: Microsoft_VC90_MFC_x86_x64
Action 13:05:47: INSTALL.
Action start 13:05:47: INSTALL.
Action 13:05:47: AppSearch. Searching for installed applications
Action start 13:05:47: AppSearch.
Action ended 13:05:47: AppSearch. Return value 0.
Action 13:05:47: FindRelatedProducts. Searching for related applications
Action start 13:05:47: FindRelatedProducts.
Action ended 13:05:47: FindRelatedProducts. Return value 0.
Action 13:05:47: ValidateProductID.
Action start 13:05:47: ValidateProductID.
Action ended 13:05:47: ValidateProductID. Return value 1.
Action 13:05:47: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action start 13:05:47: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action ended 13:05:47: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436. Return value 1.
Action 13:05:47: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action start 13:05:47: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action ended 13:05:47: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7. Return value 1.
Action 13:05:47: CostInitialize. Computing space requirements
Action start 13:05:47: CostInitialize.
[ 3704] Sun Feb 13 13:05:48 2011 INFO
Action ended 13:05:48: CostInitialize. Return value 1.
Action 13:05:48: FileCost. Computing space requirements
Action start 13:05:48: FileCost.
Action ended 13:05:48: FileCost. Return value 1.
Action 13:05:48: IsolateComponents.
Action start 13:05:48: IsolateComponents.
Action ended 13:05:48: IsolateComponents. Return value 0.
Action 13:05:48: CostFinalize. Computing space requirements
Action start 13:05:48: CostFinalize.
Action ended 13:05:48: CostFinalize. Return value 1.
Action 13:05:48: SetODBCFolders. Initializing ODBC directories
Action start 13:05:48: SetODBCFolders.
Action ended 13:05:48: SetODBCFolders. Return value 0.
Action 13:05:48: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:05:48: MigrateFeatureStates.
Action ended 13:05:48: MigrateFeatureStates. Return value 0.
Action 13:05:48: InstallValidate. Validating install
Action start 13:05:48: InstallValidate.
Action ended 13:05:48: InstallValidate. Return value 1.
Action 13:05:48: RemoveExistingProducts. Removing applications
Action start 13:05:48: RemoveExistingProducts.
Action ended 13:05:48: RemoveExistingProducts. Return value 0.
Action 13:05:48: InstallInitialize.
Action start 13:05:48: InstallInitialize.
Action ended 13:05:48: InstallInitialize. Return value 1.
Action 13:05:48: ProcessComponents. Updating component registration
Action start 13:05:48: ProcessComponents.
Action 13:05:48: GenerateScript. Generating script operations for action:
Action ended 13:05:48: ProcessComponents. Return value 1.
Action 13:05:48: UnpublishComponents. Unpublishing Qualified Components
Action start 13:05:48: UnpublishComponents.
Action ended 13:05:48: UnpublishComponents. Return value 0.
Action 13:05:48: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 13:05:48: MsiUnpublishAssemblies.
Action ended 13:05:48: MsiUnpublishAssemblies. Return value 1.
Action 13:05:48: UnpublishFeatures. Unpublishing product features
Action start 13:05:48: UnpublishFeatures.
Action ended 13:05:48: UnpublishFeatures. Return value 1.
Action 13:05:48: StopServices. Stopping services
Action start 13:05:48: StopServices.
Action ended 13:05:48: StopServices. Return value 1.
Action 13:05:48: DeleteServices. Deleting services
Action start 13:05:48: DeleteServices.
Action ended 13:05:48: DeleteServices. Return value 1.
Action 13:05:48: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:05:48: UnregisterComPlus.
Action ended 13:05:48: UnregisterComPlus. Return value 0.
Action 13:05:48: SelfUnregModules. Unregistering modules
Action start 13:05:48: SelfUnregModules.
Action ended 13:05:48: SelfUnregModules. Return value 1.
Action 13:05:48: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:05:48: UnregisterTypeLibraries.
Action ended 13:05:48: UnregisterTypeLibraries. Return value 0.
Action 13:05:48: RemoveODBC. Removing ODBC components
Action start 13:05:48: RemoveODBC.
Action ended 13:05:48: RemoveODBC. Return value 1.
Action 13:05:48: UnregisterFonts. Unregistering fonts
Action start 13:05:48: UnregisterFonts.
Action ended 13:05:48: UnregisterFonts. Return value 1.
Action 13:05:48: RemoveRegistryValues. Removing system registry values
Action start 13:05:48: RemoveRegistryValues.
Action ended 13:05:48: RemoveRegistryValues. Return value 1.
Action 13:05:48: UnregisterClassInfo. Unregister class servers
Action start 13:05:48: UnregisterClassInfo.
Action ended 13:05:48: UnregisterClassInfo. Return value 0.
Action 13:05:48: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:05:48: UnregisterExtensionInfo.
Action ended 13:05:48: UnregisterExtensionInfo. Return value 0.
Action 13:05:48: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:05:48: UnregisterProgIdInfo.
Action ended 13:05:48: UnregisterProgIdInfo. Return value 0.
Action 13:05:48: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:05:48: UnregisterMIMEInfo.
Action ended 13:05:48: UnregisterMIMEInfo. Return value 0.
Action 13:05:48: RemoveIniValues. Removing INI file entries
Action start 13:05:48: RemoveIniValues.
Action ended 13:05:48: RemoveIniValues. Return value 1.
Action 13:05:48: RemoveShortcuts. Removing shortcuts
Action start 13:05:48: RemoveShortcuts.
Action ended 13:05:48: RemoveShortcuts. Return value 0.
Action 13:05:48: RemoveEnvironmentStrings. Updating environment strings
Action start 13:05:48: RemoveEnvironmentStrings.
Action ended 13:05:48: RemoveEnvironmentStrings. Return value 1.
Action 13:05:48: RemoveDuplicateFiles. Removing duplicated files
Action start 13:05:48: RemoveDuplicateFiles.
Action ended 13:05:48: RemoveDuplicateFiles. Return value 1.
Action 13:05:48: RemoveFiles. Removing files
Action start 13:05:48: RemoveFiles.
Action ended 13:05:48: RemoveFiles. Return value 0.
Action 13:05:48: RemoveFolders. Removing folders
Action start 13:05:48: RemoveFolders.
Action ended 13:05:48: RemoveFolders. Return value 0.
Action 13:05:48: CreateFolders. Creating folders
Action start 13:05:48: CreateFolders.
Action ended 13:05:48: CreateFolders. Return value 0.
Action 13:05:48: MoveFiles. Moving files
Action start 13:05:48: MoveFiles.
Action ended 13:05:48: MoveFiles. Return value 1.
Action 13:05:48: InstallFiles. Copying new files
Action start 13:05:48: InstallFiles.
Action ended 13:05:48: InstallFiles. Return value 1.
Action 13:05:48: PatchFiles. Patching files
Action start 13:05:48: PatchFiles.
Action ended 13:05:48: PatchFiles. Return value 0.
Action 13:05:48: DuplicateFiles. Creating duplicate files
Action start 13:05:48: DuplicateFiles.
Action ended 13:05:48: DuplicateFiles. Return value 1.
Action 13:05:48: BindImage. Binding executables
Action start 13:05:48: BindImage.
Action ended 13:05:48: BindImage. Return value 1.
Action 13:05:48: CreateShortcuts. Creating shortcuts
Action start 13:05:48: CreateShortcuts.
Action ended 13:05:48: CreateShortcuts. Return value 0.
Action 13:05:48: RegisterClassInfo. Registering class servers
Action start 13:05:48: RegisterClassInfo.
Action ended 13:05:48: RegisterClassInfo. Return value 0.
Action 13:05:48: RegisterExtensionInfo. Registering extension servers
Action start 13:05:48: RegisterExtensionInfo.
Action ended 13:05:48: RegisterExtensionInfo. Return value 0.
Action 13:05:48: RegisterProgIdInfo. Registering program identifiers
Action start 13:05:48: RegisterProgIdInfo.
Action ended 13:05:48: RegisterProgIdInfo. Return value 0.
Action 13:05:48: RegisterMIMEInfo. Registering MIME info
Action start 13:05:48: RegisterMIMEInfo.
Action ended 13:05:48: RegisterMIMEInfo. Return value 0.
Action 13:05:48: WriteRegistryValues. Writing system registry values
Action start 13:05:48: WriteRegistryValues.
Action ended 13:05:48: WriteRegistryValues. Return value 1.
Action 13:05:48: WriteIniValues. Writing INI file values
Action start 13:05:48: WriteIniValues.
Action ended 13:05:48: WriteIniValues. Return value 1.
Action 13:05:48: WriteEnvironmentStrings. Updating environment strings
Action start 13:05:48: WriteEnvironmentStrings.
Action ended 13:05:48: WriteEnvironmentStrings. Return value 1.
Action 13:05:48: RegisterFonts. Registering fonts
Action start 13:05:48: RegisterFonts.
Action ended 13:05:48: RegisterFonts. Return value 1.
Action 13:05:48: InstallODBC. Installing ODBC components
Action start 13:05:48: InstallODBC.
Action ended 13:05:48: InstallODBC. Return value 0.
Action 13:05:48: RegisterTypeLibraries. Registering type libraries
Action start 13:05:48: RegisterTypeLibraries.
Action ended 13:05:48: RegisterTypeLibraries. Return value 0.
Action 13:05:48: SelfRegModules. Registering modules
Action start 13:05:48: SelfRegModules.
Action ended 13:05:48: SelfRegModules. Return value 1.
Action 13:05:48: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:05:48: RegisterComPlus.
Action ended 13:05:48: RegisterComPlus. Return value 0.
Action 13:05:48: InstallServices. Installing new services
Action start 13:05:48: InstallServices.
Action ended 13:05:48: InstallServices. Return value 1.
Action 13:05:48: StartServices. Starting services
Action start 13:05:48: StartServices.
Action ended 13:05:48: StartServices. Return value 1.
Action 13:05:48: RegisterUser. Registering user
Action start 13:05:48: RegisterUser.
Action ended 13:05:48: RegisterUser. Return value 0.
Action 13:05:48: RegisterProduct. Registering product
Action start 13:05:48: RegisterProduct.
Registering product
Action ended 13:05:48: RegisterProduct. Return value 1.
Action 13:05:48: PublishComponents. Publishing qualified components
Action start 13:05:48: PublishComponents.
Action ended 13:05:48: PublishComponents. Return value 0.
Action 13:05:48: MsiPublishAssemblies. Publishing assembly information
Action start 13:05:48: MsiPublishAssemblies.
Action ended 13:05:48: MsiPublishAssemblies. Return value 1.
Action 13:05:48: PublishFeatures. Publishing product features
Action start 13:05:48: PublishFeatures.
Action ended 13:05:48: PublishFeatures. Return value 1.
Action 13:05:48: PublishProduct. Publishing product information
Action start 13:05:48: PublishProduct.
Action ended 13:05:48: PublishProduct. Return value 1.
Action 13:05:48: InstallFinalize.
Action start 13:05:48: InstallFinalize.
354094.msi
Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_MFC_x86_
Action 13:05:48: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b19b.rbf
File: C:\Config.Msi\3b19c.rbf
Action ended 13:05:48: InstallFinalize. Return value 1.
Action ended 13:05:48: INSTALL. Return value 1.
Property(S): UpgradeCode = {D27B3F91-AF97-4C28-90D0-9243BD36B1CE}
Property(S): SourcedirProduct = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): Installed = 2009/03/11 04:06:40
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\3b195.msi
Property(S): Time = 13:05:48
Property(S): VirtualMemory = 14276
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\
Property(S): payload.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_7264ef23\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): policydir_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_3624aa14c1dce505\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aea75d50\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\
Property(S): ProductCode = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): ProductName = Microsoft_VC90_MFC_x86_x64
Property(S): DWUSLINK = CECCB788E98CF7E89EAC97BF99EB978FEE8BF08F69BCD7CFCEBC7798696BC0BF497CA0CFBEAC
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb9966.tmp
Property(S): PackageCode = {C90E5245-A463-4F12-854D-D812F26436F2}
=== Logging stopped: 13/02/2011 13:05:48 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:05:48 2011 INFO
:: END TIMER :: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}] took 3023.24 miliseconds (3.02324 seconds) DTR = 21.1694 KBPS (0.0206732 MBPS)
[ 3432] Sun Feb 13 13:05:49 2011 INFO
Calling the custom action code for post-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64
Calling the custom action code for pre-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593}
::START TIMER:: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}]
[ 5200] Sun Feb 13 13:05:49 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
Third party application path:E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
CommandLine: -airAppPath AdobeHelp.air -airRuntime AdobeAIRInstaller.exe -eulaAccepted -programMenu -silent
[ 3432] Sun Feb 13 13:05:56 2011 INFO
:: END TIMER :: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}] took 7024.14 miliseconds (7.02414 seconds) DTR = 2269.32 KBPS (2.21613 MBPS)
Calling the custom action code for post-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp
[ 3432] Sun Feb 13 13:05:56 2011 WARN
Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
Calling the custom action code for pre-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
::START TIMER:: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}]
[ 4244] Sun Feb 13 13:05:56 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
CommandLine: -silent
[ 3432] Sun Feb 13 13:05:59 2011 INFO
:: END TIMER :: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}] took 3031.56 miliseconds (3.03156 seconds)
Calling the custom action code for post-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR
Calling the custom action code for pre-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
::START TIMER:: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}]
[ 3804] Sun Feb 13 13:05:59 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
CommandLine: -silent -eulaAccepted -programMenu adobe_media_player.air
[ 3432] Sun Feb 13 13:06:04 2011 INFO
:: END TIMER :: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}] took 5022.93 miliseconds (5.02293 seconds) DTR = 2.38904 KBPS (0.00233305 MBPS)
Calling the custom action code for post-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player
[ 3432] Sun Feb 13 13:06:05 2011 INFO
Calling the custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200}
::START TIMER:: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}]
[ 4664] Sun Feb 13 13:06:05 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Installing payload
Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Command line arguments: /UILevel=2 REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
1: 0 2: 1033 3: 1252
[ 4664] Sun Feb 13 13:06:06 2011 INFO
=== Logging started: 13/02/2011 13:06:06 ===
Message type: 1, Argument: Adobe Flash Player 10 ActiveX
Action 13:06:06: INSTALL.
Action start 13:06:06: INSTALL.
Action 13:06:06: ISSetAllUsers.
Action start 13:06:06: ISSetAllUsers.
InstallShield 13:06:06: Begin SetAllUsers()
InstallShield 13:06:06: Getting records from Upgrade table
InstallShield 13:06:06: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 10.1.52.14 Language: Attributes: 769
InstallShield 13:06:06: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
InstallShield 13:06:06: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 13:06:06: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
InstallShield 13:06:06: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 13:06:06: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
InstallShield 13:06:06: End SetAllUsers()
Action ended 13:06:06: ISSetAllUsers. Return value 1.
Action 13:06:06: AppSearch. Searching for installed applications
Action start 13:06:06: AppSearch.
Action ended 13:06:06: AppSearch. Return value 0.
Action 13:06:06: LaunchConditions. Evaluating launch conditions
Action start 13:06:06: LaunchConditions.
Action ended 13:06:06: LaunchConditions. Return value 1.
Action 13:06:06: FindRelatedProducts. Searching for related applications
Action start 13:06:06: FindRelatedProducts.
Action ended 13:06:06: FindRelatedProducts. Return value 1.
Action 13:06:06: ValidateProductID.
Action start 13:06:06: ValidateProductID.
Action ended 13:06:06: ValidateProductID. Return value 1.
Action 13:06:06: CostInitialize. Computing space requirements
Action start 13:06:06: CostInitialize.
Action ended 13:06:06: CostInitialize. Return value 1.
Action 13:06:06: FileCost. Computing space requirements
Action start 13:06:06: FileCost.
Action ended 13:06:06: FileCost. Return value 1.
Action 13:06:06: IsolateComponents.
Action start 13:06:06: IsolateComponents.
Action ended 13:06:06: IsolateComponents. Return value 0.
Action 13:06:06: CostFinalize. Computing space requirements
Action start 13:06:06: CostFinalize.
Action ended 13:06:06: CostFinalize. Return value 1.
Action 13:06:06: SetARPINSTALLLOCATION.
Action start 13:06:06: SetARPINSTALLLOCATION.
Action ended 13:06:06: SetARPINSTALLLOCATION. Return value 1.
Action 13:06:06: SetODBCFolders. Initializing ODBC directories
Action start 13:06:06: SetODBCFolders.
Action ended 13:06:06: SetODBCFolders. Return value 0.
Action 13:06:06: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:06:06: MigrateFeatureStates.
Action ended 13:06:06: MigrateFeatureStates. Return value 0.
Action 13:06:06: InstallValidate. Validating install
Action start 13:06:06: InstallValidate.
Action ended 13:06:06: InstallValidate. Return value 1.
Action 13:06:06: RemoveExistingProducts. Removing applications
Action start 13:06:06: RemoveExistingProducts.
Action ended 13:06:06: RemoveExistingProducts. Return value 0.
Action 13:06:06: InstallInitialize.
Action start 13:06:06: InstallInitialize.
[ 4664] Sun Feb 13 13:06:07 2011 INFO
Action ended 13:06:07: InstallInitialize. Return value 1.
Action 13:06:07: CallExeUninstaller.
Action start 13:06:07: CallExeUninstaller.
Action 13:06:07: GenerateScript. Generating script operations for action:
CallExeUninstaller
Action ended 13:06:07: CallExeUninstaller. Return value 1.
Action 13:06:07: MakePropsAvailable.
Action start 13:06:07: MakePropsAvailable.
Action ended 13:06:07: MakePropsAvailable. Return value 1.
Action 13:06:07: AllocateRegistrySpace. Allocating registry space
Action start 13:06:07: AllocateRegistrySpace.
Action ended 13:06:07: AllocateRegistrySpace. Return value 1.
Action 13:06:07: ProcessComponents. Updating component registration
Action start 13:06:07: ProcessComponents.
Action ended 13:06:07: ProcessComponents. Return value 1.
Action 13:06:07: UnpublishComponents. Unpublishing Qualified Components
Action start 13:06:07: UnpublishComponents.
Action ended 13:06:07: UnpublishComponents. Return value 0.
Action 13:06:07: UnpublishFeatures. Unpublishing product features
Action start 13:06:07: UnpublishFeatures.
Action ended 13:06:07: UnpublishFeatures. Return value 1.
Action 13:06:07: StopServices. Stopping services
Action start 13:06:07: StopServices.
Action ended 13:06:07: StopServices. Return value 1.
Action 13:06:07: DeleteServices. Deleting services
Action start 13:06:07: DeleteServices.
Action ended 13:06:07: DeleteServices. Return value 1.
Action 13:06:07: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:06:07: UnregisterComPlus.
Action ended 13:06:07: UnregisterComPlus. Return value 0.
Action 13:06:07: SelfUnregModules. Unregistering modules
Action start 13:06:07: SelfUnregModules.
Action ended 13:06:07: SelfUnregModules. Return value 1.
Action 13:06:07: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:06:07: UnregisterTypeLibraries.
Action ended 13:06:07: UnregisterTypeLibraries. Return value 0.
Action 13:06:07: RemoveODBC. Removing ODBC components
Action start 13:06:07: RemoveODBC.
Action ended 13:06:07: RemoveODBC. Return value 1.
Action 13:06:07: UnregisterFonts. Unregistering fonts
Action start 13:06:07: UnregisterFonts.
Action ended 13:06:07: UnregisterFonts. Return value 1.
Action 13:06:07: RemoveRegistryValues. Removing system registry values
Action start 13:06:07: RemoveRegistryValues.
Action ended 13:06:07: RemoveRegistryValues. Return value 1.
Action 13:06:07: UnregisterClassInfo. Unregister class servers
Action start 13:06:07: UnregisterClassInfo.
Action ended 13:06:07: UnregisterClassInfo. Return value 0.
Action 13:06:07: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:06:07: UnregisterExtensionInfo.
Action ended 13:06:07: UnregisterExtensionInfo. Return value 0.
Action 13:06:07: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:06:07: UnregisterProgIdInfo.
Action ended 13:06:07: UnregisterProgIdInfo. Return value 0.
Action 13:06:07: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:06:07: UnregisterMIMEInfo.
Action ended 13:06:07: UnregisterMIMEInfo. Return value 0.
Action 13:06:07: RemoveIniValues. Removing INI file entries
Action start 13:06:07: RemoveIniValues.
Action ended 13:06:07: RemoveIniValues. Return value 1.
Action 13:06:07: RemoveShortcuts. Removing shortcuts
Action start 13:06:07: RemoveShortcuts.
Action ended 13:06:07: RemoveShortcuts. Return value 0.
Action 13:06:07: RemoveEnvironmentStrings. Updating environment strings
Action start 13:06:07: RemoveEnvironmentStrings.
Action ended 13:06:07: RemoveEnvironmentStrings. Return value 1.
Action 13:06:07: RemoveDuplicateFiles. Removing duplicated files
Action start 13:06:07: RemoveDuplicateFiles.
Action ended 13:06:07: RemoveDuplicateFiles. Return value 1.
Action 13:06:07: RemoveFolders. Removing folders
Action start 13:06:07: RemoveFolders.
Action ended 13:06:07: RemoveFolders. Return value 1.
Action 13:06:07: CreateFolders. Creating folders
Action start 13:06:07: CreateFolders.
Action ended 13:06:07: CreateFolders. Return value 1.
Action 13:06:07: MoveFiles. Moving files
Action start 13:06:07: MoveFiles.
Action ended 13:06:07: MoveFiles. Return value 1.
Action 13:06:07: InstallFiles. Copying new files
Action start 13:06:07: InstallFiles.
Action ended 13:06:07: InstallFiles. Return value 1.
Action 13:06:07: NewCustomAction1.
Action start 13:06:07: NewCustomAction1.
Error 2753.The File 'InstallAX.exe' is not marked for installation.
Action ended 13:06:07: NewCustomAction1. Return value 3.
Action ended 13:06:07: INSTALL. Return value 3.
Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(S): ProductCode = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SourcedirProduct = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): REMOVE = ALL
Property(S): MACROMED = C:\Windows\SysWOW64\Macromed\
Property(S): FLASH = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): INSTALLDIR = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\3b19e.msi
Property(S): Time = 13:06:07
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): ProductName = Adobe Flash Player 10 ActiveX
Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(S): ARPNOMODIFY = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): DWUSINTERVAL = 30
Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): InstallChoice = AR
Property(S): Manufacturer = Adobe Systems, Inc.
Property(S): MsiLogging = voicewarmupx
Property(S): NewProperty2 = 0
Property(S): NewProperty3 = 0
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductVersion = 10.1.52.14
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): RebootYesNo = Yes
Property(S): ReinstallModeText = omus
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(S): RemoveFilesCA = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): ARPINSTALLLOCATION = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): VirtualMemory = 14281
Property(S): USERNAME = Gary & Susan
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): VersionDatabase = 110
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): CLIENTPROCESSID = 4116
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): REBOOT = ReallySuppress
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): /UILEVEL = 2
Property(S): PackagecodeChanging = 1
Property(S): ProductState = -1
Property(S): PackageCode = {8C02D971-B819-4CCC-940B-1F1E34164635}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI4e5db.LOG
=== Logging stopped: 13/02/2011 13:06:07 ===
1: 2 2: 0
1: 2 2: 1
Installation result: 1603
[ 3432] Sun Feb 13 13:06:07 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}] took 2023.62 miliseconds (2.02362 seconds) DTR = 98.8327 KBPS (0.0965163 MBPS)
User specified overrideFile:
Calling the ROLLBACK custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX
[ 3432] Sun Feb 13 13:06:08 2011 INFO
Calling the custom action code for pre-repair for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34}
::START TIMER:: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}]
[ 3440] Sun Feb 13 13:06:08 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi is 0
MsiSourceListSetInfo with updated name: AdobeFlashPlayer10_plRel_mul.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\, Result: 0
Configuring MSI ProductCode: {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress UILevel=2 REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbF000.tmp"
[ 3440] Sun Feb 13 13:06:09 2011 INFO
=== Logging started: 13/02/2011 13:06:09 ===
Message type: 1, Argument: Adobe Flash Player 10 Plugin
Action 13:06:09: INSTALL.
Action start 13:06:09: INSTALL.
Action 13:06:09: AppSearch. Searching for installed applications
Action start 13:06:09: AppSearch.
Action ended 13:06:09: AppSearch. Return value 0.
Action 13:06:09: LaunchConditions. Evaluating launch conditions
Action start 13:06:09: LaunchConditions.
Action ended 13:06:09: LaunchConditions. Return value 1.
Action 13:06:09: FindRelatedProducts. Searching for related applications
Action start 13:06:09: FindRelatedProducts.
Action ended 13:06:09: FindRelatedProducts. Return value 0.
Action 13:06:09: ValidateProductID.
Action start 13:06:09: ValidateProductID.
Action ended 13:06:09: ValidateProductID. Return value 1.
Action 13:06:09: CostInitialize. Computing space requirements
Action start 13:06:09: CostInitialize.
Action ended 13:06:09: CostInitialize. Return value 1.
Action 13:06:09: FileCost. Computing space requirements
Action start 13:06:09: FileCost.
Action ended 13:06:09: FileCost. Return value 1.
Action 13:06:09: IsolateComponents.
Action start 13:06:09: IsolateComponents.
Action ended 13:06:09: IsolateComponents. Return value 0.
Action 13:06:09: CostFinalize. Computing space requirements
Action start 13:06:09: CostFinalize.
Action ended 13:06:09: CostFinalize. Return value 1.
Action 13:06:09: SetODBCFolders. Initializing ODBC directories
Action start 13:06:09: SetODBCFolders.
Action ended 13:06:09: SetODBCFolders. Return value 0.
Action 13:06:09: MigrateFeatureStates. Migrating feature states from related applications
Action start 13:06:09: MigrateFeatureStates.
Action ended 13:06:09: MigrateFeatureStates. Return value 0.
Action 13:06:09: InstallValidate. Validating install
Action start 13:06:09: InstallValidate.
Action ended 13:06:09: InstallValidate. Return value 1.
Action 13:06:09: RemoveExistingProducts. Removing applications
Action start 13:06:09: RemoveExistingProducts.
Action ended 13:06:09: RemoveExistingProducts. Return value 0.
Action 13:06:09: InstallInitialize.
Action start 13:06:09: InstallInitialize.
Action ended 13:06:09: InstallInitialize. Return value 1.
Action 13:06:09: MakePropsAvailable.
Action start 13:06:09: MakePropsAvailable.
Action ended 13:06:09: MakePropsAvailable. Return value 1.
Action 13:06:09: ProcessComponents. Updating component registration
Action start 13:06:09: ProcessComponents.
Action 13:06:09: GenerateScript. Generating script operations for action:
Action ended 13:06:09: ProcessComponents. Return value 1.
Action 13:06:09: UnpublishComponents. Unpublishing Qualified Components
Action start 13:06:09: UnpublishComponents.
Action ended 13:06:09: UnpublishComponents. Return value 0.
Action 13:06:09: UnpublishFeatures. Unpublishing product features
Action start 13:06:09: UnpublishFeatures.
Action ended 13:06:09: UnpublishFeatures. Return value 1.
Action 13:06:09: StopServices. Stopping services
Action start 13:06:09: StopServices.
Action ended 13:06:09: StopServices. Return value 1.
Action 13:06:09: DeleteServices. Deleting services
Action start 13:06:09: DeleteServices.
Action ended 13:06:09: DeleteServices. Return value 1.
Action 13:06:09: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 13:06:09: UnregisterComPlus.
Action ended 13:06:09: UnregisterComPlus. Return value 0.
Action 13:06:09: SelfUnregModules. Unregistering modules
Action start 13:06:09: SelfUnregModules.
Action ended 13:06:09: SelfUnregModules. Return value 1.
Action 13:06:09: UnregisterTypeLibraries. Unregistering type libraries
Action start 13:06:09: UnregisterTypeLibraries.
Action ended 13:06:09: UnregisterTypeLibraries. Return value 0.
Action 13:06:09: RemoveODBC. Removing ODBC components
Action start 13:06:09: RemoveODBC.
Action ended 13:06:09: RemoveODBC. Return value 1.
Action 13:06:09: UnregisterFonts. Unregistering fonts
Action start 13:06:09: UnregisterFonts.
Action ended 13:06:09: UnregisterFonts. Return value 1.
Action 13:06:09: RemoveRegistryValues. Removing system registry values
Action start 13:06:09: RemoveRegistryValues.
Action ended 13:06:09: RemoveRegistryValues. Return value 1.
Action 13:06:09: UnregisterClassInfo. Unregister class servers
Action start 13:06:09: UnregisterClassInfo.
Action ended 13:06:09: UnregisterClassInfo. Return value 0.
Action 13:06:09: UnregisterExtensionInfo. Unregistering extension servers
Action start 13:06:09: UnregisterExtensionInfo.
Action ended 13:06:09: UnregisterExtensionInfo. Return value 0.
Action 13:06:09: UnregisterProgIdInfo. Unregistering program identifiers
Action start 13:06:09: UnregisterProgIdInfo.
Action ended 13:06:09: UnregisterProgIdInfo. Return value 0.
Action 13:06:09: UnregisterMIMEInfo. Unregistering MIME info
Action start 13:06:09: UnregisterMIMEInfo.
Action ended 13:06:09: UnregisterMIMEInfo. Return value 0.
Action 13:06:09: RemoveIniValues. Removing INI file entries
Action start 13:06:09: RemoveIniValues.
Action ended 13:06:09: RemoveIniValues. Return value 1.
Action 13:06:09: RemoveShortcuts. Removing shortcuts
Action start 13:06:09: RemoveShortcuts.
Action ended 13:06:09: RemoveShortcuts. Return value 0.
Action 13:06:09: RemoveEnvironmentStrings. Updating environment strings
Action start 13:06:09: RemoveEnvironmentStrings.
Action ended 13:06:09: RemoveEnvironmentStrings. Return value 1.
Action 13:06:09: RemoveDuplicateFiles. Removing duplicated files
Action start 13:06:09: RemoveDuplicateFiles.
Action ended 13:06:09: RemoveDuplicateFiles. Return value 1.
Action 13:06:09: RemoveFolders. Removing folders
Action start 13:06:09: RemoveFolders.
Action ended 13:06:09: RemoveFolders. Return value 1.
Action 13:06:09: CreateFolders. Creating folders
Action start 13:06:09: CreateFolders.
Folder: Creating folders
Action ended 13:06:09: CreateFolders. Return value 1.
Action 13:06:09: MoveFiles. Moving files
Action start 13:06:09: MoveFiles.
Action ended 13:06:09: MoveFiles. Return value 1.
Action 13:06:09: InstallFiles. Copying new files
Action start 13:06:09: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 13:06:09: InstallFiles. Return value 1.
Action 13:06:09: PatchFiles. Patching files
Action start 13:06:09: PatchFiles.
Action ended 13:06:09: PatchFiles. Return value 1.
Action 13:06:09: DuplicateFiles. Creating duplicate files
Action start 13:06:09: DuplicateFiles.
Action ended 13:06:09: DuplicateFiles. Return value 1.
Action 13:06:09: BindImage. Binding executables
Action start 13:06:09: BindImage.
Action ended 13:06:09: BindImage. Return value 1.
Action 13:06:09: CreateShortcuts. Creating shortcuts
Action start 13:06:09: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 13:06:09: CreateShortcuts. Return value 0.
Action 13:06:09: RegisterClassInfo. Registering class servers
Action start 13:06:09: RegisterClassInfo.
Action ended 13:06:09: RegisterClassInfo. Return value 0.
Action 13:06:09: RegisterExtensionInfo. Registering extension servers
Action start 13:06:09: RegisterExtensionInfo.
Action ended 13:06:09: RegisterExtensionInfo. Return value 0.
Action 13:06:09: RegisterProgIdInfo. Registering program identifiers
Action start 13:06:09: RegisterProgIdInfo.
Action ended 13:06:09: RegisterProgIdInfo. Return value 0.
Action 13:06:09: RegisterMIMEInfo. Registering MIME info
Action start 13:06:09: RegisterMIMEInfo.
Action ended 13:06:09: RegisterMIMEInfo. Return value 0.
Action 13:06:09: WriteRegistryValues. Writing system registry values
Action start 13:06:09: WriteRegistryValues.
Key: Writing system registry values, Name: , Value:
Action ended 13:06:09: WriteRegistryValues. Return value 1.
Action 13:06:09: WriteIniValues. Writing INI file values
Action start 13:06:09: WriteIniValues.
Action ended 13:06:09: WriteIniValues. Return value 1.
Action 13:06:09: WriteEnvironmentStrings. Updating environment strings
Action start 13:06:09: WriteEnvironmentStrings.
Action ended 13:06:09: WriteEnvironmentStrings. Return value 1.
Action 13:06:09: RegisterFonts. Registering fonts
Action start 13:06:09: RegisterFonts.
Action ended 13:06:09: RegisterFonts. Return value 1.
Action 13:06:09: InstallODBC. Installing ODBC components
Action start 13:06:09: InstallODBC.
Action ended 13:06:09: InstallODBC. Return value 0.
Action 13:06:09: RegisterTypeLibraries. Registering type libraries
Action start 13:06:09: RegisterTypeLibraries.
Action ended 13:06:09: RegisterTypeLibraries. Return value 0.
Action 13:06:09: SelfRegModules. Registering modules
Action start 13:06:09: SelfRegModules.
Action ended 13:06:09: SelfRegModules. Return value 1.
Action 13:06:09: RegisterComPlus. Registering COM+ Applications and Components
Action start 13:06:09: RegisterComPlus.
Action ended 13:06:09: RegisterComPlus. Return value 0.
Action 13:06:09: InstallServices. Installing new services
Action start 13:06:09: InstallServices.
Action ended 13:06:09: InstallServices. Return value 1.
Action 13:06:09: StartServices. Starting services
Action start 13:06:09: StartServices.
Action ended 13:06:09: StartServices. Return value 1.
Action 13:06:09: RegisterUser. Registering user
Action start 13:06:09: RegisterUser.
Action ended 13:06:09: RegisterUser. Return value 0.
Action 13:06:09: RegisterProduct. Registering product
Action start 13:06:09: RegisterProduct.
Registering product
Action ended 13:06:09: RegisterProduct. Return value 1.
Action 13:06:09: PublishComponents. Publishing qualified components
Action start 13:06:09: PublishComponents.
Action ended 13:06:09: PublishComponents. Return value 0.
Action 13:06:09: PublishFeatures. Publishing product features
Action start 13:06:09: PublishFeatures.
Feature: Publishing product features
Action ended 13:06:09: PublishFeatures. Return value 1.
Action 13:06:09: PublishProduct. Publishing product information
Action start 13:06:09: PublishProduct.
Action ended 13:06:09: PublishProduct. Return value 1.
Action 13:06:09: InstallFinalize.
Action start 13:06:09: InstallFinalize.
Folder: C:\Windows\SysWOW64\Macromed\Flash\
File: InstallPlugin.exe, Directory: C:\Users\GARY&S~1\AppData\Local\Temp\, Size: 2516992
Shortcut: ARPPRODUCTICON.exe
Key: \Software\Macromedia\FlashPlayer, Name: , Value:
Key: \Software\Macromedia\FlashPlayer, Name: FlashPlayerVersion, Value: 10.1.52.14
3540a0.msi
Feature: FlashPlayerAXInstaller
Message type: 2, Argument: 0
Action 13:06:09: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3b1a9.rbf
File: C:\Config.Msi\3b1aa.rbf
File: C:\Config.Msi\3b1ab.rbf
Message type: 2, Argument: 1
Action ended 13:06:09: InstallFinalize. Return value 1.
Action ended 13:06:09: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
Property(S): ProductCode = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): Installed = 2010/03/24 00:43:56
Property(S): SourcedirProduct = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): VersionNT = 601
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): CostingComplete = 1
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): ROOTDRIVE = F:\
Property(S): USERPROFILE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\3b1a3.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 13:06:09
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): ProductName = Adobe Flash Player 10 Plugin
Property(S): ALLUSERS = 1
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): SecureCustomProperties = ISACTIONPROP1;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_plugin.exe
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): System64Folder = C:\Windows\system32\
Property(S): WindowsVolume = C:\
Property(S): WindowsFolder = C:\Windows\
Property(S): PRODUCTLANGUAGE = 1033
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbF000.tmp
Property(S): UILEVEL = 2
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {BD4109FD-A808-4EAE-B2BE-144DA3F3A299}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSI4e5dc.LOG
=== Logging stopped: 13/02/2011 13:06:09 ===
1: 2 2: 0
1: 2 2: 1
[ 3432] Sun Feb 13 13:06:10 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}] took 2023.02 miliseconds (2.02302 seconds) DTR = 122.589 KBPS (0.119716 MBPS)
Calling the custom action code for post-repair for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin
Calling the custom action code for pre-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0}
::START TIMER:: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: productName is Adobe Flash Fonts1
Font Installer: Using [AdobeCommon] path: C:\Program Files (x86)\Common Files\Adobe
Custom action return code: 0
:: END TIMER :: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 2.10259 miliseconds (0.00210259 seconds)
::START TIMER:: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}]
[ 4764] Sun Feb 13 13:06:10 2011 INFO
Installer Operation: PayloadUninstaller
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7745F18B-FD8A-4011-BE16-588900C503D0}
Effective AdobeCode for: {7745F18B-FD8A-4011-BE16-588900C503D0} is {7745F18B-FD8A-4011-BE16-588900C503D0}
Session includes local copy of payload for repair source
Repair payload source package: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Extracting assets...
Extracting assets complete. Number assets: 1
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Evaluating condition# 1
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7745F18B-FD8A-4011-BE16-588900C503D0}.db
Physical payload repair result:0
[ 3432] Sun Feb 13 13:06:11 2011 INFO
:: END TIMER :: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 1022.73 miliseconds (1.02273 seconds) DTR = 590.576 KBPS (0.576734 MBPS)
Calling the custom action code for post-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
::START TIMER:: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: Did not find any font files under:C:\Program Files (x86)\Common Files\Adobe\SavedFonts\current
:: END TIMER :: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 4.57511 miliseconds (0.00457511 seconds) DTR = 6994.37 KBPS (6.83044 MBPS)
Disk Swap Needed, Prompting user to swap disk CS5 Master Coll2 E:\
[ 3432] Sun Feb 13 13:06:48 2011 INFO
Starting installation from Disk 2 - CS5 Master Coll2
Calling the custom action code for pre-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
::START TIMER:: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}]
[ 3868] Sun Feb 13 13:06:48 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Effective AdobeCode for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} is {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 3868] Sun Feb 13 13:07:03 2011 INFO
Extracting assets complete. Number assets: 2
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 3868] Sun Feb 13 13:07:13 2011 INFO
Evaluating condition# 2
Condition failed
Condition failed
[ 3868] Sun Feb 13 13:07:23 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}.db
[ 3868] Sun Feb 13 13:07:26 2011 INFO
[ 3432] Sun Feb 13 13:07:27 2011 INFO
:: END TIMER :: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}] took 39041.9 miliseconds (39.0419 seconds) DTR = 83.2951 KBPS (0.0813429 MBPS)
Calling the custom action code for post-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
Calling the custom action code for pre-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
::START TIMER:: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}]
[ 4796] Sun Feb 13 13:07:27 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Effective AdobeCode for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} is {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
[ 4796] Sun Feb 13 13:07:28 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
Condition failed
Condition failed
[ 4796] Sun Feb 13 13:07:29 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}.db
[ 3432] Sun Feb 13 13:07:30 2011 INFO
:: END TIMER :: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}] took 3034.58 miliseconds (3.03458 seconds)
Calling the custom action code for post-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691}
::START TIMER:: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}]
[ 2544] Sun Feb 13 13:07:30 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Effective AdobeCode for: {0E3C6C75-872D-4B0D-B0B2-31C717250691} is {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Repair payload source package: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 2544] Sun Feb 13 13:07:32 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 2544] Sun Feb 13 13:07:33 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{0E3C6C75-872D-4B0D-B0B2-31C717250691}.db
[ 3432] Sun Feb 13 13:07:33 2011 INFO
:: END TIMER :: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}] took 3026.71 miliseconds (3.02671 seconds) DTR = 338.321 KBPS (0.330392 MBPS)
Calling the custom action code for post-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
::START TIMER:: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}]
[ 4228] Sun Feb 13 13:07:33 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Effective AdobeCode for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} is {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Repair payload source package: E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
[ 4228] Sun Feb 13 13:07:34 2011 INFO
[ 4228] Sun Feb 13 13:07:38 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
Completing installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5DDABB74-A879-4BE7-A4C6-FD41793942DB}.db
[ 3432] Sun Feb 13 13:07:39 2011 INFO
:: END TIMER :: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}] took 6027.82 miliseconds (6.02782 seconds) DTR = 84.9395 KBPS (0.0829487 MBPS)
[ 3432] Sun Feb 13 13:07:40 2011 INFO
Calling the custom action code for post-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64
Calling the custom action code for pre-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
::START TIMER:: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}]
[ 5072] Sun Feb 13 13:07:40 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Effective AdobeCode for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} is {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Repair payload source package: E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 5072] Sun Feb 13 13:07:42 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 5072] Sun Feb 13 13:07:47 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}.db
[ 3432] Sun Feb 13 13:07:48 2011 INFO
:: END TIMER :: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}] took 8033.51 miliseconds (8.03351 seconds) DTR = 254.932 KBPS (0.248957 MBPS)
Calling the custom action code for post-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64
Calling the custom action code for pre-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E}
::START TIMER:: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}]
[ 3784] Sun Feb 13 13:07:48 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Effective AdobeCode for: {7816FDDE-40D4-482D-AD7D-97858985DB3E} is {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
[ 3784] Sun Feb 13 13:07:49 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
[ 3784] Sun Feb 13 13:07:51 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7816FDDE-40D4-482D-AD7D-97858985DB3E}.db
[ 3432] Sun Feb 13 13:07:51 2011 INFO
:: END TIMER :: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}] took 3024 miliseconds (3.024 seconds)
[ 3432] Sun Feb 13 13:07:52 2011 INFO
Calling the custom action code for post-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
Calling the custom action code for pre-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8}
::START TIMER:: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}]
[ 928] Sun Feb 13 13:07:52 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
[ 928] Sun Feb 13 13:07:53 2011 INFO
Effective AdobeCode for: {B8D286BC-A68D-4E74-9F68-8756A49896D8} is {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Condition failed
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{B8D286BC-A68D-4E74-9F68-8756A49896D8}.db
[ 3432] Sun Feb 13 13:07:53 2011 INFO
:: END TIMER :: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}] took 1030.16 miliseconds (1.03016 seconds)
[ 3432] Sun Feb 13 13:07:54 2011 INFO
Calling the custom action code for post-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
Calling the custom action code for pre-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
::START TIMER:: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}]
[ 4508] Sun Feb 13 13:07:54 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Effective AdobeCode for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} is {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
[ 4508] Sun Feb 13 13:07:58 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
Condition failed
Condition failed
[ 4508] Sun Feb 13 13:08:00 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{565DE707-5798-4FC3-8DF6-0F58A348A9B0}.db
[ 3432] Sun Feb 13 13:08:01 2011 INFO
:: END TIMER :: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}] took 7024.15 miliseconds (7.02415 seconds)
Calling the custom action code for post-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
::START TIMER:: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}]
[ 2916] Sun Feb 13 13:08:01 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Effective AdobeCode for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} is {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 2916] Sun Feb 13 13:08:02 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 2916] Sun Feb 13 13:08:03 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{DE5DE662-2ECB-4D93-967B-221FBCC8A736}.db
[ 3432] Sun Feb 13 13:08:04 2011 INFO
:: END TIMER :: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}] took 3030.72 miliseconds (3.03072 seconds) DTR = 153.099 KBPS (0.149511 MBPS)
Calling the custom action code for post-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
Calling the custom action code for pre-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
::START TIMER:: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}]
[ 5516] Sun Feb 13 13:08:04 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Effective AdobeCode for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} is {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 5516] Sun Feb 13 13:08:06 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 5516] Sun Feb 13 13:08:07 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}.db
[ 3432] Sun Feb 13 13:08:07 2011 INFO
:: END TIMER :: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}] took 3022.25 miliseconds (3.02225 seconds) DTR = 508.23 KBPS (0.496319 MBPS)
[ 3432] Sun Feb 13 13:08:08 2011 INFO
Calling the custom action code for post-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
Calling the custom action code for pre-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4}
::START TIMER:: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}]
[ 2820] Sun Feb 13 13:08:08 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {FBB02B04-C034-4382-A3F6-57416E2752C4}
Effective AdobeCode for: {FBB02B04-C034-4382-A3F6-57416E2752C4} is {FBB02B04-C034-4382-A3F6-57416E2752C4}
Repair payload source package: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
[ 2820] Sun Feb 13 13:08:09 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{FBB02B04-C034-4382-A3F6-57416E2752C4}.db
[ 3432] Sun Feb 13 13:08:09 2011 INFO
:: END TIMER :: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}] took 1038.89 miliseconds (1.03889 seconds) DTR = 985.672 KBPS (0.96257 MBPS)
[ 3432] Sun Feb 13 13:08:10 2011 INFO
Calling the custom action code for post-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection
Calling the custom action code for pre-install for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
::START TIMER:: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
In PrePayloadInstallProc
hook checkDirs passed str:
C:\Program Files (x86)\Adobe
detected bad URL character
CHRC_NULL_POINTER_VALUE
Custom action return code: 1
:: END TIMER :: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 2.50478 miliseconds (0.00250478 seconds)
[ 3432] Sun Feb 13 13:08:10 2011 ERROR
Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
[ 3432] Sun Feb 13 13:08:11 2011 INFO
Deferring payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 because conflicting processes are running.
Waiting for UI to respose for cached payloads
[ 3432] Sun Feb 13 13:08:33 2011 INFO
Calling the custom action code for pre-install for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
::START TIMER:: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
:: END TIMER :: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 1.12187 miliseconds (0.00112187 seconds)
[ 3432] Sun Feb 13 13:08:33 2011 ERROR
Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 21458917KB
[ 3432] Sun Feb 13 13:08:36 2011 INFO
Total components installed: 0
Successfully repaired 32 components:
- Microsoft_VC90_ATL_x86
- Adobe Media Player
- Microsoft_VC90_CRT_x86
- Adobe Encore CS5 Third Party Royalty Content
- Microsoft_VC80_ATL_x86
- Adobe Player for Embedding
- AdobeHelp
- Adobe Flash Player 10 Plugin
- Adobe Premiere Pro CS5 Third Party Royalty Content
- Adobe Media Encoder CS5 Dolby X64
- Microsoft_VC90_MFC_x86
- Adobe Media Encoder CS5 X64
- Suite Shared Configuration CS5
- AdobeTypeSupport CS5
- Adobe Flash Fonts1
- Adobe OnLocation CS5 Royalty Content
- Microsoft_VC90_ATL_x86_x64
- Microsoft_VC90_CRT_x86_x64
- Microsoft_VC80_CRT_x86
- Microsoft_VC90_MFC_x86_x64
- DynamiclinkSupport
- Adobe Premiere Pro CS5 Third Party Content
- AdobeCMaps CS5
- Adobe After Effects CS5 Third Party Content
- Adobe After Effects CS5 Third Party Royalty Content
- Microsoft_VC80_MFC_x86
- Microsoft_VC80_MFCLOC_x86
- Adobe Soundbooth CS5 Codecs
- Adobe Soundbooth CS5 Royalty Codecs
- Adobe AIR
- Adobe Media Encoder CS5 PCI X64
- Creative Suite 5 Master Collection
Total components removed: 0
[ 3432] Sun Feb 13 13:08:36 2011 ERROR
The following payload errors were found during install:
- Adobe Flash Builder: Install failed
- Adobe Flash Player 10 ActiveX: Install failed
- Adobe Flash Catalyst CS5: Install failed
Restarting your computer is recommended:
In order to complete the installation, please restart the computer
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 256967 miliseconds (256.967 seconds) DTR = 34.7438 KBPS (0.0339295 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 6 error(s), 4 warning(s)
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
ERROR: The following payload errors were found during install:
ERROR: - Adobe Flash Builder: Install failed
ERROR: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: - Adobe Flash Catalyst CS5: Install failed
Property(S): DWUSLINK = CE0B90581E3CF05FFEAC57B89EEC978F9EDC508F591B0798CEABF7DFDEAB57D8FE1C47B8D9AC
Property(S): ARPSYSTEMCOMPONENT = 1
Property(S): VersionDatabase = 200
Property(S): MsiSystemRebootPending = 1
Property(S): CLIENTPROCESSID = 7008
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb977E.tmp
Property(S): PackageCode = {3C0DD3C2-B6EC-46C4-8544-00189BC45D86}
=== Logging stopped: 13/02/2011 14:03:40 ===
1: 2 2: 0
1: 2 2: 1
[ 1940] Sun Feb 13 14:03:40 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 7 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}] took 2032.82 miliseconds (2.03282 seconds) DTR = 606.055 KBPS (0.591851 MBPS)
Calling the custom action code for post-repair for payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86
[ 1940] Sun Feb 13 14:03:41 2011 INFO
Calling the custom action code for pre-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C}
::START TIMER:: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}]
[ 3652] Sun Feb 13 14:03:41 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {A8798E04-96FF-4564-9157-0D4C89CB794C}
Effective AdobeCode for: {A8798E04-96FF-4564-9157-0D4C89CB794C} is {A8798E04-96FF-4564-9157-0D4C89CB794C}
Repair payload source package: E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
[ 3652] Sun Feb 13 14:03:42 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
Completing installation for payload at E:\Adobe CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{A8798E04-96FF-4564-9157-0D4C89CB794C}.db
[ 1940] Sun Feb 13 14:03:43 2011 INFO
:: END TIMER :: [Payload Operation :{A8798E04-96FF-4564-9157-0D4C89CB794C}] took 2029.43 miliseconds (2.02943 seconds) DTR = 252.287 KBPS (0.246374 MBPS)
Calling the custom action code for post-repair for payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport
Calling the custom action code for pre-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
::START TIMER:: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}]
[ 6744] Sun Feb 13 14:03:43 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_CRT_x86_x64.msi, Result: 0
[ 6744] Sun Feb 13 14:03:44 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\, Result: 0
Configuring MSI ProductCode: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbAB3E.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 14:03:44 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Microsoft_VC90_CRT_x86_x64
Action 14:03:44: INSTALL.
Action start 14:03:44: INSTALL.
Action 14:03:44: AppSearch. Searching for installed applications
Action start 14:03:44: AppSearch.
Action ended 14:03:44: AppSearch. Return value 0.
Action 14:03:44: FindRelatedProducts. Searching for related applications
Action start 14:03:44: FindRelatedProducts.
Action ended 14:03:44: FindRelatedProducts. Return value 0.
Action 14:03:44: ValidateProductID.
Action start 14:03:44: ValidateProductID.
Action ended 14:03:44: ValidateProductID. Return value 1.
Action 14:03:44: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action start 14:03:44: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812.
Action ended 14:03:44: WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812. Return value 1.
Action 14:03:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action start 14:03:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B.
Action ended 14:03:44: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B. Return value 1.
Action 14:03:44: CostInitialize. Computing space requirements
Action start 14:03:44: CostInitialize.
Action ended 14:03:44: CostInitialize. Return value 1.
Action 14:03:44: FileCost. Computing space requirements
Action start 14:03:44: FileCost.
Action ended 14:03:44: FileCost. Return value 1.
Action 14:03:44: IsolateComponents.
Action start 14:03:44: IsolateComponents.
Action ended 14:03:44: IsolateComponents. Return value 0.
Action 14:03:44: CostFinalize. Computing space requirements
Action start 14:03:44: CostFinalize.
Action ended 14:03:44: CostFinalize. Return value 1.
Action 14:03:44: SetODBCFolders. Initializing ODBC directories
Action start 14:03:44: SetODBCFolders.
Action ended 14:03:44: SetODBCFolders. Return value 0.
Action 14:03:44: MigrateFeatureStates. Migrating feature states from related applications
Action start 14:03:44: MigrateFeatureStates.
Action ended 14:03:44: MigrateFeatureStates. Return value 0.
Action 14:03:44: InstallValidate. Validating install
Action start 14:03:44: InstallValidate.
Action ended 14:03:44: InstallValidate. Return value 1.
Action 14:03:44: RemoveExistingProducts. Removing applications
Action start 14:03:44: RemoveExistingProducts.
Action ended 14:03:44: RemoveExistingProducts. Return value 0.
Action 14:03:44: InstallInitialize.
Action start 14:03:44: InstallInitialize.
Action ended 14:03:44: InstallInitialize. Return value 1.
Action 14:03:44: ProcessComponents. Updating component registration
Action start 14:03:44: ProcessComponents.
Action 14:03:44: GenerateScript. Generating script operations for action:
Action ended 14:03:44: ProcessComponents. Return value 1.
Action 14:03:44: UnpublishComponents. Unpublishing Qualified Components
Action start 14:03:44: UnpublishComponents.
Action ended 14:03:44: UnpublishComponents. Return value 0.
Action 14:03:44: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 14:03:44: MsiUnpublishAssemblies.
Action ended 14:03:44: MsiUnpublishAssemblies. Return value 1.
Action 14:03:44: UnpublishFeatures. Unpublishing product features
Action start 14:03:44: UnpublishFeatures.
Action ended 14:03:44: UnpublishFeatures. Return value 1.
Action 14:03:44: StopServices. Stopping services
Action start 14:03:44: StopServices.
Action ended 14:03:44: StopServices. Return value 1.
Action 14:03:44: DeleteServices. Deleting services
Action start 14:03:44: DeleteServices.
Action ended 14:03:44: DeleteServices. Return value 1.
Action 14:03:44: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 14:03:44: UnregisterComPlus.
Action ended 14:03:44: UnregisterComPlus. Return value 0.
Action 14:03:44: SelfUnregModules. Unregistering modules
Action start 14:03:44: SelfUnregModules.
Action ended 14:03:44: SelfUnregModules. Return value 1.
Action 14:03:44: UnregisterTypeLibraries. Unregistering type libraries
Action start 14:03:44: UnregisterTypeLibraries.
Action ended 14:03:44: UnregisterTypeLibraries. Return value 0.
Action 14:03:44: RemoveODBC. Removing ODBC components
Action start 14:03:44: RemoveODBC.
Action ended 14:03:44: RemoveODBC. Return value 1.
Action 14:03:44: UnregisterFonts. Unregistering fonts
Action start 14:03:44: UnregisterFonts.
Action ended 14:03:44: UnregisterFonts. Return value 1.
Action 14:03:44: RemoveRegistryValues. Removing system registry values
Action start 14:03:44: RemoveRegistryValues.
Action ended 14:03:44: RemoveRegistryValues. Return value 1.
Action 14:03:44: UnregisterClassInfo. Unregister class servers
Action start 14:03:44: UnregisterClassInfo.
Action ended 14:03:44: UnregisterClassInfo. Return value 0.
Action 14:03:44: UnregisterExtensionInfo. Unregistering extension servers
Action start 14:03:44: UnregisterExtensionInfo.
Action ended 14:03:44: UnregisterExtensionInfo. Return value 0.
Action 14:03:44: UnregisterProgIdInfo. Unregistering program identifiers
Action start 14:03:44: UnregisterProgIdInfo.
Action ended 14:03:44: UnregisterProgIdInfo. Return value 0.
Action 14:03:44: UnregisterMIMEInfo. Unregistering MIME info
Action start 14:03:44: UnregisterMIMEInfo.
Action ended 14:03:44: UnregisterMIMEInfo. Return value 0.
Action 14:03:44: RemoveIniValues. Removing INI file entries
Action start 14:03:44: RemoveIniValues.
Action ended 14:03:44: RemoveIniValues. Return value 1.
Action 14:03:44: RemoveShortcuts. Removing shortcuts
Action start 14:03:44: RemoveShortcuts.
Action ended 14:03:44: RemoveShortcuts. Return value 0.
Action 14:03:44: RemoveEnvironmentStrings. Updating environment strings
Action start 14:03:44: RemoveEnvironmentStrings.
Action ended 14:03:44: RemoveEnvironmentStrings. Return value 1.
Action 14:03:44: RemoveDuplicateFiles. Removing duplicated files
Action start 14:03:44: RemoveDuplicateFiles.
Action ended 14:03:44: RemoveDuplicateFiles. Return value 1.
Action 14:03:44: RemoveFiles. Removing files
Action start 14:03:44: RemoveFiles.
Action ended 14:03:44: RemoveFiles. Return value 0.
Action 14:03:44: RemoveFolders. Removing folders
Action start 14:03:44: RemoveFolders.
Action ended 14:03:44: RemoveFolders. Return value 0.
Action 14:03:44: CreateFolders. Creating folders
Action start 14:03:44: CreateFolders.
Action ended 14:03:44: CreateFolders. Return value 0.
Action 14:03:44: MoveFiles. Moving files
Action start 14:03:44: MoveFiles.
Action ended 14:03:44: MoveFiles. Return value 1.
Action 14:03:44: InstallFiles. Copying new files
Action start 14:03:44: InstallFiles.
Action ended 14:03:44: InstallFiles. Return value 1.
Action 14:03:44: PatchFiles. Patching files
Action start 14:03:44: PatchFiles.
Action ended 14:03:44: PatchFiles. Return value 0.
Action 14:03:44: DuplicateFiles. Creating duplicate files
Action start 14:03:44: DuplicateFiles.
Action ended 14:03:44: DuplicateFiles. Return value 1.
Action 14:03:44: BindImage. Binding executables
Action start 14:03:44: BindImage.
Action ended 14:03:44: BindImage. Return value 1.
Action 14:03:44: CreateShortcuts. Creating shortcuts
Action start 14:03:44: CreateShortcuts.
Action ended 14:03:44: CreateShortcuts. Return value 0.
Action 14:03:44: RegisterClassInfo. Registering class servers
Action start 14:03:44: RegisterClassInfo.
Action ended 14:03:44: RegisterClassInfo. Return value 0.
Action 14:03:44: RegisterExtensionInfo. Registering extension servers
Action start 14:03:44: RegisterExtensionInfo.
Action ended 14:03:44: RegisterExtensionInfo. Return value 0.
Action 14:03:44: RegisterProgIdInfo. Registering program identifiers
Action start 14:03:44: RegisterProgIdInfo.
Action ended 14:03:44: RegisterProgIdInfo. Return value 0.
Action 14:03:44: RegisterMIMEInfo. Registering MIME info
Action start 14:03:44: RegisterMIMEInfo.
Action ended 14:03:44: RegisterMIMEInfo. Return value 0.
Action 14:03:44: WriteRegistryValues. Writing system registry values
Action start 14:03:44: WriteRegistryValues.
Action ended 14:03:44: WriteRegistryValues. Return value 1.
Action 14:03:44: WriteIniValues. Writing INI file values
Action start 14:03:44: WriteIniValues.
Action ended 14:03:44: WriteIniValues. Return value 1.
Action 14:03:44: WriteEnvironmentStrings. Updating environment strings
Action start 14:03:44: WriteEnvironmentStrings.
Action ended 14:03:44: WriteEnvironmentStrings. Return value 1.
Action 14:03:44: RegisterFonts. Registering fonts
Action start 14:03:44: RegisterFonts.
Action ended 14:03:44: RegisterFonts. Return value 1.
Action 14:03:44: InstallODBC. Installing ODBC components
Action start 14:03:44: InstallODBC.
Action ended 14:03:44: InstallODBC. Return value 0.
Action 14:03:44: RegisterTypeLibraries. Registering type libraries
Action start 14:03:44: RegisterTypeLibraries.
Action ended 14:03:44: RegisterTypeLibraries. Return value 0.
Action 14:03:44: SelfRegModules. Registering modules
Action start 14:03:44: SelfRegModules.
Action ended 14:03:44: SelfRegModules. Return value 1.
Action 14:03:44: RegisterComPlus. Registering COM+ Applications and Components
Action start 14:03:44: RegisterComPlus.
Action ended 14:03:44: RegisterComPlus. Return value 0.
Action 14:03:44: InstallServices. Installing new services
Action start 14:03:44: InstallServices.
Action ended 14:03:44: InstallServices. Return value 1.
Action 14:03:44: StartServices. Starting services
Action start 14:03:44: StartServices.
Action ended 14:03:44: StartServices. Return value 1.
Action 14:03:44: RegisterUser. Registering user
Action start 14:03:44: RegisterUser.
Action ended 14:03:44: RegisterUser. Return value 0.
Action 14:03:44: RegisterProduct. Registering product
Action start 14:03:44: RegisterProduct.
Registering product
Action ended 14:03:44: RegisterProduct. Return value 1.
Action 14:03:44: PublishComponents. Publishing qualified components
Action start 14:03:44: PublishComponents.
Action ended 14:03:44: PublishComponents. Return value 0.
Action 14:03:44: MsiPublishAssemblies. Publishing assembly information
Action start 14:03:44: MsiPublishAssemblies.
Application Context:Publishing assembly information, Assembly Name:
Action ended 14:03:44: MsiPublishAssemblies. Return value 1.
Action 14:03:44: PublishFeatures. Publishing product features
Action start 14:03:44: PublishFeatures.
Action ended 14:03:44: PublishFeatures. Return value 1.
Action 14:03:44: PublishProduct. Publishing product information
Action start 14:03:44: PublishProduct.
Action ended 14:03:44: PublishProduct. Return value 1.
Action 14:03:44: InstallFinalize.
Action start 14:03:44: InstallFinalize.
Message type: 0, Argument: 0
3b18b.msi
Application Context:Global, Assembly Name:Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.CRT,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_CRT_x86_
Action 14:03:44: RollbackCleanup. Removing backup files
File: C:\Config.Msi\384199.rbf
File: C:\Config.Msi\38419a.rbf
Action ended 14:03:44: InstallFinalize. Return value 1.
Action ended 14:03:44: INSTALL. Return value 1.
Property(S): UpgradeCode = {54AE2BD2-7685-4215-9490-3BBF14C2BBB4}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
Property(S): SourcedirProduct = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): Installed = 2009/03/11 04:02:22
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\384193.msi
Property(S): Time = 14:03:44
Property(S): VirtualMemory = 14149
Property(S): ADOBE = C:\Program Files (x86)\Adobe\
Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
Property(S): GlobalAssemblyCache = F:\
Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
Property(S): PrimaryVolumePath = F:\
Property(S): System16Folder = F:\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_CRT_x86_x64\
[ 6744] Sun Feb 13 14:03:45 2011 INFO
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_99b61f5e8371c1d4\
Property(S): payload.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_a17e7c1e\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): policydir_ul.30729.01.Microsoft_VC90_CRT_x64.SP.25A3A9CB_4A28_34E8_87BE_4A9057266812 = C:\Windows\winsxs\amd64_Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_7701165b\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.1_none_3da38fdebd0e6822\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.CRT_1fc8b3b9a1e18e3b_x-ww_16f3e195\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_CRT_x64.SP.E83531BF_FAC2_33DD_8232_0506BF31308B = C:\Windows\
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): RestartManagerOption = CloseRestart
Property(S): Display_IsBitmapDlg = 1
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): DWUSINTERVAL = 30
Property(S): ErrorDialog = SetupError
Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
Property(S): InstallChoice = AR
Property(S): INSTALLLEVEL = 100
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): ISVROOT_PORT_NO = 0
Property(S): Manufacturer = Adobe
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): ProductCode = {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
Property(S): ProductName = Microsoft_VC90_CRT_x86_x64
Property(S): ProductVersion = 1.00.0000
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
Property(S): RebootYesNo = No
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): DWUSLINK = CE1C879F4EDBE0A8A9ACB06F8E0B978FAE9CF08F598C9758CE1CB08FFE8CF0C8AE8CF0EF8EAC
Property(S): ARPURLINFOABOUT = http://www.Adobe.com
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): PRODUCTLANGUAGE = 0
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbAB3E.tmp
Property(S): USERNAME = Gary & Susan
Property(S): PackageCode = {EBEBD87C-43F1-4673-9D38-D8BA645AA1C5}
=== Logging stopped: 13/02/2011 14:03:45 ===
1: 2 2: 0
1: 2 2: 1
[ 1940] Sun Feb 13 14:03:45 2011 INFO
:: END TIMER :: [Payload Operation :{92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}] took 2017.45 miliseconds (2.01745 seconds) DTR = 1292.72 KBPS (1.26242 MBPS)
Calling the custom action code for post-repair for payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64
Calling the custom action code for pre-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593}
::START TIMER:: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}]
[ 1100] Sun Feb 13 14:03:45 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_ATL_x86_x64.msi, Result: 0
[ 1100] Sun Feb 13 14:03:46 2011 INFO
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\, Result: 0
Configuring MSI ProductCode: {8557397C-A42D-486F-97B3-A2CBC2372593}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbB2CF.tmp"
1: 0 2: 0 3: 1252
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 14:03:46 ===
Message type: 1, Argument: Microsoft_VC90_ATL_x86_x64
Action 14:03:46: INSTALL.
Action start 14:03:46: INSTALL.
Action 14:03:46: AppSearch. Searching for installed applications
Action start 14:03:46: AppSearch.
Action ended 14:03:46: AppSearch. Return value 0.
Action 14:03:46: FindRelatedProducts. Searching for related applications
Action start 14:03:46: FindRelatedProducts.
Action ended 14:03:46: FindRelatedProducts. Return value 0.
Action 14:03:46: ValidateProductID.
Action start 14:03:46: ValidateProductID.
Action ended 14:03:46: ValidateProductID. Return value 1.
Action 14:03:46: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action start 14:03:46: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C.
Action ended 14:03:46: WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C. Return value 1.
Action 14:03:46: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action start 14:03:46: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479.
Action ended 14:03:46: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479. Return value 1.
Action 14:03:46: CostInitialize. Computing space requirements
Action start 14:03:46: CostInitialize.
Action ended 14:03:46: CostInitialize. Return value 1.
Action 14:03:46: FileCost. Computing space requirements
Action start 14:03:46: FileCost.
Action ended 14:03:46: FileCost. Return value 1.
Action 14:03:46: IsolateComponents.
Action start 14:03:46: IsolateComponents.
Action ended 14:03:46: IsolateComponents. Return value 0.
Action 14:03:46: CostFinalize. Computing space requirements
Action start 14:03:46: CostFinalize.
Action ended 14:03:46: CostFinalize. Return value 1.
Action 14:03:46: SetODBCFolders. Initializing ODBC directories
Action start 14:03:46: SetODBCFolders.
Action ended 14:03:46: SetODBCFolders. Return value 0.
Action 14:03:46: MigrateFeatureStates. Migrating feature states from related applications
Action start 14:03:46: MigrateFeatureStates.
Action ended 14:03:46: MigrateFeatureStates. Return value 0.
Action 14:03:46: InstallValidate. Validating install
Action start 14:03:46: InstallValidate.
Action ended 14:03:46: InstallValidate. Return value 1.
Action 14:03:46: RemoveExistingProducts. Removing applications
Action start 14:03:46: RemoveExistingProducts.
Action ended 14:03:46: RemoveExistingProducts. Return value 0.
Action 14:03:46: InstallInitialize.
Action start 14:03:46: InstallInitialize.
Action ended 14:03:46: InstallInitialize. Return value 1.
Action 14:03:46: ProcessComponents. Updating component registration
Action start 14:03:46: ProcessComponents.
Action 14:03:46: GenerateScript. Generating script operations for action:
Action ended 14:03:46: ProcessComponents. Return value 1.
Action 14:03:46: UnpublishComponents. Unpublishing Qualified Components
Action start 14:03:46: UnpublishComponents.
Action ended 14:03:46: UnpublishComponents. Return value 0.
Action 14:03:46: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 14:03:46: MsiUnpublishAssemblies.
Action ended 14:03:46: MsiUnpublishAssemblies. Return value 1.
Action 14:03:46: UnpublishFeatures. Unpublishing product features
Action start 14:03:46: UnpublishFeatures.
Action ended 14:03:46: UnpublishFeatures. Return value 1.
Action 14:03:46: StopServices. Stopping services
Action start 14:03:46: StopServices.
Action ended 14:03:46: StopServices. Return value 1.
Action 14:03:46: DeleteServices. Deleting services
Action start 14:03:46: DeleteServices.
Action ended 14:03:46: DeleteServices. Return value 1.
Action 14:03:46: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 14:03:46: UnregisterComPlus.
Action ended 14:03:46: UnregisterComPlus. Return value 0.
Action 14:03:46: SelfUnregModules. Unregistering modules
Action start 14:03:46: SelfUnregModules.
Action ended 14:03:46: SelfUnregModules. Return value 1.
Action 14:03:46: UnregisterTypeLibraries. Unregistering type libraries
Action start 14:03:46: UnregisterTypeLibraries.
Action ended 14:03:46: UnregisterTypeLibraries. Return value 0.
Action 14:03:46: RemoveODBC. Removing ODBC components
Action start 14:03:46: RemoveODBC.
Action ended 14:03:46: RemoveODBC. Return value 1.
Action 14:03:46: UnregisterFonts. Unregistering fonts
Action start 14:03:46: UnregisterFonts.
Action ended 14:03:46: UnregisterFonts. Return value 1.
Action 14:03:46: RemoveRegistryValues. Removing system registry values
Action start 14:03:46: RemoveRegistryValues.
Action ended 14:03:46: RemoveRegistryValues. Return value 1.
Action 14:03:46: UnregisterClassInfo. Unregister class servers
Action start 14:03:46: UnregisterClassInfo.
Action ended 14:03:46: UnregisterClassInfo. Return value 0.
Action 14:03:46: UnregisterExtensionInfo. Unregistering extension servers
Action start 14:03:46: UnregisterExtensionInfo.
Action ended 14:03:46: UnregisterExtensionInfo. Return value 0.
Action 14:03:46: UnregisterProgIdInfo. Unregistering program identifiers
Action start 14:03:46: UnregisterProgIdInfo.
Action ended 14:03:46: UnregisterProgIdInfo. Return value 0.
Action 14:03:46: UnregisterMIMEInfo. Unregistering MIME info
Action start 14:03:46: UnregisterMIMEInfo.
Action ended 14:03:46: UnregisterMIMEInfo. Return value 0.
Action 14:03:46: RemoveIniValues. Removing INI file entries
Action start 14:03:46: RemoveIniValues.
Action ended 14:03:46: RemoveIniValues. Return value 1.
Action 14:03:46: RemoveShortcuts. Removing shortcuts
Action start 14:03:46: RemoveShortcuts.
Action ended 14:03:46: RemoveShortcuts. Return value 0.
Action 14:03:46: RemoveEnvironmentStrings. Updating environment strings
Action start 14:03:46: RemoveEnvironmentStrings.
Action ended 14:03:46: RemoveEnvironmentStrings. Return value 1.
Action 14:03:46: RemoveDuplicateFiles. Removing duplicated files
Action start 14:03:46: RemoveDuplicateFiles.
Action ended 14:03:46: RemoveDuplicateFiles. Return value 1.
Action 14:03:46: RemoveFiles. Removing files
Action start 14:03:46: RemoveFiles.
Action ended 14:03:46: RemoveFiles. Return value 0.
Action 14:03:46: RemoveFolders. Removing folders
Action start 14:03:46: RemoveFolders.
Action ended 14:03:46: RemoveFolders. Return value 0.
Action 14:03:46: CreateFolders. Creating folders
Action start 14:03:46: CreateFolders.
Action ended 14:03:46: CreateFolders. Return value 0.
Action 14:03:46: MoveFiles. Moving files
Action start 14:03:46: MoveFiles.
Action ended 14:03:46: MoveFiles. Return value 1.
Action 14:03:46: InstallFiles. Copying new files
Action start 14:03:46: InstallFiles.
Action ended 14:03:46: InstallFiles. Return value 1.
Action 14:03:46: PatchFiles. Patching files
Action start 14:03:46: PatchFiles.
Action ended 14:03:46: PatchFiles. Return value 0.
Action 14:03:46: DuplicateFiles. Creating duplicate files
Action start 14:03:46: DuplicateFiles.
Action ended 14:03:46: DuplicateFiles. Return value 1.
Action 14:03:46: BindImage. Binding executables
Action start 14:03:46: BindImage.
Action ended 14:03:46: BindImage. Return value 1.
Action 14:03:46: CreateShortcuts. Creating shortcuts
Action start 14:03:46: CreateShortcuts.
Action ended 14:03:46: CreateShortcuts. Return value 0.
Action 14:03:46: RegisterClassInfo. Registering class servers
Action start 14:03:46: RegisterClassInfo.
Action ended 14:03:46: RegisterClassInfo. Return value 0.
Action 14:03:46: RegisterExtensionInfo. Registering extension servers
Action start 14:03:46: RegisterExtensionInfo.
Action ended 14:03:46: RegisterExtensionInfo. Return value 0.
Action 14:03:46: RegisterProgIdInfo. Registering program identifiers
Action start 14:03:46: RegisterProgIdInfo.
Action ended 14:03:46: RegisterProgIdInfo. Return value 0.
Action 14:03:46: RegisterMIMEInfo. Registering MIME info
Action start 14:03:46: RegisterMIMEInfo.
Action ended 14:03:46: RegisterMIMEInfo. Return value 0.
Action 14:03:46: WriteRegistryValues. Writing system registry values
Action start 14:03:46: WriteRegistryValues.
Action ended 14:03:46: WriteRegistryValues. Return value 1.
Action 14:03:46: WriteIniValues. Writing INI file values
Action start 14:03:46: WriteIniValues.
Action ended 14:03:46: WriteIniValues. Return value 1.
Action 14:03:46: WriteEnvironmentStrings. Updating environment strings
Action start 14:03:46: WriteEnvironmentStrings.
Action ended 14:03:46: WriteEnvironmentStrings. Return value 1.
Action 14:03:46: RegisterFonts. Registering fonts
Action start 14:03:46: RegisterFonts.
Action ended 14:03:46: RegisterFonts. Return value 1.
Action 14:03:46: InstallODBC. Installing ODBC components
Action start 14:03:46: InstallODBC.
Action ended 14:03:46: InstallODBC. Return value 0.
Action 14:03:46: RegisterTypeLibraries. Registering type libraries
Action start 14:03:46: RegisterTypeLibraries.
Action ended 14:03:46: RegisterTypeLibraries. Return value 0.
Action 14:03:46: SelfRegModules. Registering modules
Action start 14:03:46: SelfRegModules.
Action ended 14:03:46: SelfRegModules. Return value 1.
Action 14:03:46: RegisterComPlus. Registering COM+ Applications and Components
Action start 14:03:46: RegisterComPlus.
Action ended 14:03:46: RegisterComPlus. Return value 0.
Action 14:03:46: InstallServices. Installing new services
Action start 14:03:46: InstallServices.
Action ended 14:03:46: InstallServices. Return value 1.
Action 14:03:46: StartServices. Starting services
Action start 14:03:46: StartServices.
Action ended 14:03:46: StartServices. Return value 1.
Action 14:03:46: RegisterUser. Registering user
Action start 14:03:46: RegisterUser.
Action ended 14:03:46: RegisterUser. Return value 0.
Action 14:03:46: RegisterProduct. Registering product
Action start 14:03:46: RegisterProduct.
Registering product
Action ended 14:03:46: RegisterProduct. Return value 1.
Action 14:03:46: PublishComponents. Publishing qualified components
Action start 14:03:46: PublishComponents.
Action ended 14:03:46: PublishComponents. Return value 0.
Action 14:03:46: MsiPublishAssemblies. Publishing assembly information
Action start 14:03:46: MsiPublishAssemblies.
Action ended 14:03:46: MsiPublishAssemblies. Return value 1.
Action 14:03:46: PublishFeatures. Publishing product features
Action start 14:03:46: PublishFeatures.
Action ended 14:03:46: PublishFeatures. Return value 1.
Action 14:03:46: PublishProduct. Publishing product information
Action start 14:03:46: PublishProduct.
Action ended 14:03:46: PublishProduct. Return value 1.
Action 14:03:46: InstallFinalize.
Action start 14:03:46: InstallFinalize.
3b194.msi
Application Context:Global, Assembly Name:Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.ATL,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_ATL_x86_
Action 14:03:46: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3841a2.rbf
File: C:\Config.Msi\3841a3.rbf
Action ended 14:03:46: InstallFinalize. Return value 1.
Action ended 14:03:46: INSTALL. Return value 1.
Property(S): UpgradeCode = {B178CFE7-E127-4205-991D-147FA189D61F}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): SourcedirProduct = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): Installed = 2009/03/11 03:58:08
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\38419c.msi
Property(S): Time = 14:03:46
Property(S): VirtualMemory = 14152
Property(S): RecentFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Recent\
Property(S): PrintHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_ATL_x86_x64\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_9aefdaaa829eb818\
Property(S): payload.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_021e6992\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): policydir_ul.30729.01.Microsoft_VC90_ATL_x64.SP.173E0444_05A1_3BC8_98FC_A5B6D145D82C = C:\Windows\winsxs\amd64_Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_5e4a8be7\
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.atl_1fc8b3b9a1e18e3b_9.0.30729.1_none_3a15284abf58447e\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.ATL_1fc8b3b9a1e18e3b_x-ww_fe3d5721\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_ATL_x64.SP.17324FD5_728B_383C_9599_593EA0CD0479 = C:\Windows\
Property(S): NetHoodFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
Property(S): RemoteAdminTS = 1
Property(S): MsiNTSuitePersonal = 1
Property(S): MsiNTProductType = 1
Property(S): ServicePackLevelMinor = 0
Property(S): ServicePackLevel = 0
Property(S): WindowsBuild = 7600
Property(S): VersionNT64 = 601
Property(S): VersionMsi = 5.00
Property(S): ProductCode = {8557397C-A42D-486F-97B3-A2CBC2372593}
Property(S): ProductID = none
Property(S): ProductLanguage = 1033
Property(S): ProductName = Microsoft_VC90_ATL_x86_x64
Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
Property(S): ProgressType0 = install
Property(S): ProgressType1 = Installing
Property(S): ProgressType2 = installed
Property(S): ProgressType3 = installs
Property(S): ReinstallModeText = omus
Property(S): DWUSLINK = CEFCF71FEE8B30FFC9ACD09FCEDB978F9E9B078F69FC00D8CE9B17F8C9CBF7D899AC806FE9AC
Property(S): CURRENTMEDIAVOLUMELABEL = CS5 Master Coll1
Property(S): MSICLIENTUSESEXTERNALUI = 1
Property(S): CLIENTUILEVEL = 3
Property(S): CURRENTDIRECTORY = C:\Users\Gary & Susan\AppData\Local\Adobe\OOBE\PDApp\DWA
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbB2CF.tmp
Property(S): REINSTALLMODE = pvoums
Property(S): REINSTALL = ALL
Property(S): PackageCode = {60C47539-11AA-4C6D-BA88-692C748A2ABC}
Property(S): REBOOT = ReallySuppress
=== Logging stopped: 13/02/2011 14:03:46 ===
1: 2 2: 0
1: 2 2: 1
[ 1940] Sun Feb 13 14:03:47 2011 INFO
:: END TIMER :: [Payload Operation :{8557397C-A42D-486F-97B3-A2CBC2372593}] took 2019.78 miliseconds (2.01978 seconds)
User specified overrideFile:
[ 1940] Sun Feb 13 14:03:48 2011 INFO
Calling the custom action code for post-repair for payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64
Calling the custom action code for pre-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
::START TIMER:: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}]
[ 6480] Sun Feb 13 14:03:48 2011 INFO
Installer Operation: ModifyThirdPartyPayloadOperation
Modify Thirdparty payload
Repairing third party payload with source: E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi is 0
MsiSourceListSetInfo with updated name: Microsoft_VC90_MFC_x86_x64.msi, Result: 0
Payload exists on removable media: E:\
Updating Media for package
Added volume name: CS5 Master Coll1 for diskID: 1 with result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\, Result: 0
Configuring MSI ProductCode: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Setting AFLPath C:\Program Files (x86)\Common Files\Adobe\Installers\{FBB02B04-C034-4382-A3F6-57416E2752C4}
MsiConfigureProductEx command line:
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adbBB59.tmp"
1: 0 2: 0 3: 1252
[ 6480] Sun Feb 13 14:03:50 2011 INFO
1: 0 2: 0 3: 1252
=== Logging started: 13/02/2011 14:03:50 ===
Message type: 1, Argument: Microsoft_VC90_MFC_x86_x64
Action 14:03:50: INSTALL.
Action start 14:03:50: INSTALL.
Action 14:03:50: AppSearch. Searching for installed applications
Action start 14:03:50: AppSearch.
Action ended 14:03:50: AppSearch. Return value 0.
Action 14:03:50: FindRelatedProducts. Searching for related applications
Action start 14:03:50: FindRelatedProducts.
Action ended 14:03:50: FindRelatedProducts. Return value 0.
Action 14:03:50: ValidateProductID.
Action start 14:03:50: ValidateProductID.
Action ended 14:03:50: ValidateProductID. Return value 1.
Action 14:03:50: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action start 14:03:50: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436.
Action ended 14:03:50: WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436. Return value 1.
Action 14:03:50: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action start 14:03:50: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7.
Action ended 14:03:50: WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7. Return value 1.
Action 14:03:50: CostInitialize. Computing space requirements
Action start 14:03:50: CostInitialize.
Action ended 14:03:50: CostInitialize. Return value 1.
Action 14:03:50: FileCost. Computing space requirements
Action start 14:03:50: FileCost.
Action ended 14:03:50: FileCost. Return value 1.
Action 14:03:50: IsolateComponents.
Action start 14:03:50: IsolateComponents.
Action ended 14:03:50: IsolateComponents. Return value 0.
Action 14:03:50: CostFinalize. Computing space requirements
Action start 14:03:50: CostFinalize.
Action ended 14:03:50: CostFinalize. Return value 1.
Action 14:03:50: SetODBCFolders. Initializing ODBC directories
Action start 14:03:50: SetODBCFolders.
Action ended 14:03:50: SetODBCFolders. Return value 0.
Action 14:03:50: MigrateFeatureStates. Migrating feature states from related applications
Action start 14:03:50: MigrateFeatureStates.
Action ended 14:03:50: MigrateFeatureStates. Return value 0.
Action 14:03:50: InstallValidate. Validating install
Action start 14:03:50: InstallValidate.
Action ended 14:03:50: InstallValidate. Return value 1.
Action 14:03:50: RemoveExistingProducts. Removing applications
Action start 14:03:50: RemoveExistingProducts.
Action ended 14:03:50: RemoveExistingProducts. Return value 0.
Action 14:03:50: InstallInitialize.
Action start 14:03:50: InstallInitialize.
Action ended 14:03:50: InstallInitialize. Return value 1.
Action 14:03:50: ProcessComponents. Updating component registration
Action start 14:03:50: ProcessComponents.
Action 14:03:50: GenerateScript. Generating script operations for action:
Action ended 14:03:50: ProcessComponents. Return value 1.
Action 14:03:50: UnpublishComponents. Unpublishing Qualified Components
Action start 14:03:50: UnpublishComponents.
Action ended 14:03:50: UnpublishComponents. Return value 0.
Action 14:03:50: MsiUnpublishAssemblies. Unpublishing assembly information
Action start 14:03:50: MsiUnpublishAssemblies.
Action ended 14:03:50: MsiUnpublishAssemblies. Return value 1.
Action 14:03:50: UnpublishFeatures. Unpublishing product features
Action start 14:03:50: UnpublishFeatures.
Action ended 14:03:50: UnpublishFeatures. Return value 1.
Action 14:03:50: StopServices. Stopping services
Action start 14:03:50: StopServices.
Action ended 14:03:50: StopServices. Return value 1.
Action 14:03:50: DeleteServices. Deleting services
Action start 14:03:50: DeleteServices.
Action ended 14:03:50: DeleteServices. Return value 1.
Action 14:03:50: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 14:03:50: UnregisterComPlus.
Action ended 14:03:50: UnregisterComPlus. Return value 0.
Action 14:03:50: SelfUnregModules. Unregistering modules
Action start 14:03:50: SelfUnregModules.
Action ended 14:03:50: SelfUnregModules. Return value 1.
Action 14:03:50: UnregisterTypeLibraries. Unregistering type libraries
Action start 14:03:50: UnregisterTypeLibraries.
Action ended 14:03:50: UnregisterTypeLibraries. Return value 0.
Action 14:03:50: RemoveODBC. Removing ODBC components
Action start 14:03:50: RemoveODBC.
Action ended 14:03:50: RemoveODBC. Return value 1.
Action 14:03:50: UnregisterFonts. Unregistering fonts
Action start 14:03:50: UnregisterFonts.
Action ended 14:03:50: UnregisterFonts. Return value 1.
Action 14:03:50: RemoveRegistryValues. Removing system registry values
Action start 14:03:50: RemoveRegistryValues.
Action ended 14:03:50: RemoveRegistryValues. Return value 1.
Action 14:03:50: UnregisterClassInfo. Unregister class servers
Action start 14:03:50: UnregisterClassInfo.
Action ended 14:03:50: UnregisterClassInfo. Return value 0.
Action 14:03:50: UnregisterExtensionInfo. Unregistering extension servers
Action start 14:03:50: UnregisterExtensionInfo.
Action ended 14:03:50: UnregisterExtensionInfo. Return value 0.
Action 14:03:50: UnregisterProgIdInfo. Unregistering program identifiers
Action start 14:03:50: UnregisterProgIdInfo.
Action ended 14:03:50: UnregisterProgIdInfo. Return value 0.
Action 14:03:50: UnregisterMIMEInfo. Unregistering MIME info
Action start 14:03:50: UnregisterMIMEInfo.
Action ended 14:03:50: UnregisterMIMEInfo. Return value 0.
Action 14:03:50: RemoveIniValues. Removing INI file entries
Action start 14:03:50: RemoveIniValues.
Action ended 14:03:50: RemoveIniValues. Return value 1.
Action 14:03:50: RemoveShortcuts. Removing shortcuts
Action start 14:03:50: RemoveShortcuts.
Action ended 14:03:50: RemoveShortcuts. Return value 0.
Action 14:03:50: RemoveEnvironmentStrings. Updating environment strings
Action start 14:03:50: RemoveEnvironmentStrings.
Action ended 14:03:50: RemoveEnvironmentStrings. Return value 1.
Action 14:03:50: RemoveDuplicateFiles. Removing duplicated files
Action start 14:03:50: RemoveDuplicateFiles.
Action ended 14:03:50: RemoveDuplicateFiles. Return value 1.
Action 14:03:50: RemoveFiles. Removing files
Action start 14:03:50: RemoveFiles.
Action ended 14:03:50: RemoveFiles. Return value 0.
Action 14:03:50: RemoveFolders. Removing folders
Action start 14:03:50: RemoveFolders.
Action ended 14:03:50: RemoveFolders. Return value 0.
Action 14:03:50: CreateFolders. Creating folders
Action start 14:03:50: CreateFolders.
Action ended 14:03:50: CreateFolders. Return value 0.
Action 14:03:50: MoveFiles. Moving files
Action start 14:03:50: MoveFiles.
Action ended 14:03:50: MoveFiles. Return value 1.
Action 14:03:50: InstallFiles. Copying new files
Action start 14:03:50: InstallFiles.
File: Copying new files, Directory: , Size:
Action ended 14:03:50: InstallFiles. Return value 1.
Action 14:03:50: PatchFiles. Patching files
Action start 14:03:50: PatchFiles.
Action ended 14:03:50: PatchFiles. Return value 0.
Action 14:03:50: DuplicateFiles. Creating duplicate files
Action start 14:03:50: DuplicateFiles.
Action ended 14:03:50: DuplicateFiles. Return value 1.
Action 14:03:50: BindImage. Binding executables
Action start 14:03:50: BindImage.
Action ended 14:03:50: BindImage. Return value 1.
Action 14:03:50: CreateShortcuts. Creating shortcuts
Action start 14:03:50: CreateShortcuts.
Shortcut: Creating shortcuts
Action ended 14:03:50: CreateShortcuts. Return value 0.
Action 14:03:50: RegisterClassInfo. Registering class servers
Action start 14:03:50: RegisterClassInfo.
Action ended 14:03:50: RegisterClassInfo. Return value 0.
Action 14:03:50: RegisterExtensionInfo. Registering extension servers
Action start 14:03:50: RegisterExtensionInfo.
Action ended 14:03:50: RegisterExtensionInfo. Return value 0.
Action 14:03:50: RegisterProgIdInfo. Registering program identifiers
Action start 14:03:50: RegisterProgIdInfo.
Action ended 14:03:50: RegisterProgIdInfo. Return value 0.
Action 14:03:50: RegisterMIMEInfo. Registering MIME info
Action start 14:03:50: RegisterMIMEInfo.
Action ended 14:03:50: RegisterMIMEInfo. Return value 0.
Action 14:03:50: WriteRegistryValues. Writing system registry values
Action start 14:03:50: WriteRegistryValues.
Action ended 14:03:50: WriteRegistryValues. Return value 1.
Action 14:03:50: WriteIniValues. Writing INI file values
Action start 14:03:50: WriteIniValues.
Action ended 14:03:50: WriteIniValues. Return value 1.
Action 14:03:50: WriteEnvironmentStrings. Updating environment strings
Action start 14:03:50: WriteEnvironmentStrings.
Action ended 14:03:50: WriteEnvironmentStrings. Return value 1.
Action 14:03:50: RegisterFonts. Registering fonts
Action start 14:03:50: RegisterFonts.
Action ended 14:03:50: RegisterFonts. Return value 1.
Action 14:03:50: InstallODBC. Installing ODBC components
Action start 14:03:50: InstallODBC.
Action ended 14:03:50: InstallODBC. Return value 0.
Action 14:03:50: RegisterTypeLibraries. Registering type libraries
Action start 14:03:50: RegisterTypeLibraries.
Action ended 14:03:50: RegisterTypeLibraries. Return value 0.
Action 14:03:50: SelfRegModules. Registering modules
Action start 14:03:50: SelfRegModules.
Action ended 14:03:50: SelfRegModules. Return value 1.
Action 14:03:50: RegisterComPlus. Registering COM+ Applications and Components
Action start 14:03:50: RegisterComPlus.
Action ended 14:03:50: RegisterComPlus. Return value 0.
Action 14:03:50: InstallServices. Installing new services
Action start 14:03:50: InstallServices.
Action ended 14:03:50: InstallServices. Return value 1.
Action 14:03:50: StartServices. Starting services
Action start 14:03:50: StartServices.
Action ended 14:03:50: StartServices. Return value 1.
Action 14:03:50: RegisterUser. Registering user
Action start 14:03:50: RegisterUser.
Action ended 14:03:50: RegisterUser. Return value 0.
Action 14:03:50: RegisterProduct. Registering product
Action start 14:03:50: RegisterProduct.
Registering product
Action ended 14:03:50: RegisterProduct. Return value 1.
Action 14:03:50: PublishComponents. Publishing qualified components
Action start 14:03:50: PublishComponents.
Action ended 14:03:50: PublishComponents. Return value 0.
Action 14:03:50: MsiPublishAssemblies. Publishing assembly information
Action start 14:03:50: MsiPublishAssemblies.
Action ended 14:03:50: MsiPublishAssemblies. Return value 1.
Action 14:03:50: PublishFeatures. Publishing product features
Action start 14:03:50: PublishFeatures.
Feature: Publishing product features
Action ended 14:03:50: PublishFeatures. Return value 1.
Action 14:03:50: PublishProduct. Publishing product information
Action start 14:03:50: PublishProduct.
Action ended 14:03:50: PublishProduct. Return value 1.
Action 14:03:50: InstallFinalize.
Action start 14:03:50: InstallFinalize.
Shortcut: ARPPRODUCTICON.exe
3b19d.msi
Application Context:Global, Assembly Name:Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32"
Application Context:Global, Assembly Name:policy.9.0.Microsoft.VC90.MFC,version="9.0.30729.1",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64",type="win32-policy"
Feature: Microsoft_VC90_MFC_x86_
Message type: 2, Argument: 0
Action 14:03:50: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3841ab.rbf
File: C:\Config.Msi\3841ac.rbf
Message type: 2, Argument: 1
Action ended 14:03:50: InstallFinalize. Return value 1.
Action ended 14:03:50: INSTALL. Return value 1.
Property(S): DiskPrompt = [1]
Property(S): UpgradeCode = {D27B3F91-AF97-4C28-90D0-9243BD36B1CE}
Property(S): SourcedirProduct = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): Installed = 2009/03/11 04:06:40
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): OutOfDiskSpace = 0
Property(S): CostingComplete = 1
Property(S): ROOTDRIVE = F:\
Property(S): ACTION = INSTALL
Property(S): Preselected = 1
Property(S): QFEUpgrade = 1
Property(S): UILevel = 2
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
Property(S): DATABASE = C:\Windows\Installer\3841a5.msi
Property(S): Privileged = 1
Property(S): MsiRunningElevated = 1
Property(S): RedirectedDllSupport = 2
Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
Property(S): MsiNetAssemblySupport = 4.0.30319.1
Property(S): Date = 13/02/2011
Property(S): Time = 14:03:50
Property(S): TTCSupport = 1
Property(S): ColorBits = 32
Property(S): TextInternalLeading = 3
Property(S): TextHeight = 16
Property(S): BorderSide = 1
Property(S): BorderTop = 1
Property(S): CaptionHeight = 22
Property(S): ScreenY = 768
Property(S): ScreenX = 1024
Property(S): SystemLanguageID = 3081
Property(S): ComputerName = PC
Property(S): UserLanguageID = 3081
Property(S): UserSID = S-1-5-21-618155685-1063480468-518450737-1000
Property(S): LogonUser = Gary & Susan
Property(S): MsiTrueAdminUser = 1
Property(S): AdminUser = 1
Property(S): PhysicalMemory = 8151
Property(S): Intel = 6
Property(S): Msix64 = 6
Property(S): MsiAMD64 = 6
Property(S): ShellAdvtSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): GPTSupport = 1
Property(S): VersionNT = 601
Property(S): ProgramFilesFolder = C:\Program Files (x86)\
Property(S): TARGETDIR = F:\
Property(S): ALLUSERSPROFILE = F:\
Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
Property(S): AppDataFolder = C:\Users\Gary & Susan\AppData\Roaming\
Property(S): CommonAppDataFolder = C:\ProgramData\
Property(S): CommonFiles64Folder = C:\Program Files\Common Files\
Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
Property(S): DesktopFolder = C:\Users\Public\Desktop\
Property(S): FavoritesFolder = C:\Users\Gary & Susan\Favorites\
Property(S): FontsFolder = C:\Windows\Fonts\
Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
Property(S): LocalAppDataFolder = C:\Users\Gary & Susan\AppData\Local\
Property(S): MyPicturesFolder = C:\Users\Gary & Susan\Pictures\
Property(S): PersonalFolder = C:\Users\Gary & Susan\Documents\
Property(S): ProgramFiles64Folder = C:\Program Files\
Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
Property(S): SendToFolder = C:\Users\Gary & Susan\AppData\Roaming\Microsoft\Windows\SendTo\
Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
Property(S): System64Folder = C:\Windows\system32\
Property(S): SystemFolder = C:\Windows\SysWOW64\
Property(S): SourceDir = E:\Adobe CS5\payloads\Microsoft_VC90_MFC_x86_x64\
Property(S): TempFolder = C:\Users\GARY&S~1\AppData\Local\Temp\
Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
Property(S): USERPROFILE = F:\
Property(S): WindowsFolder = C:\Windows\
Property(S): WindowsVolume = C:\
Property(S): WinSxsDirectory.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_951ab4128654b0c9\
Property(S): payload.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_9.0.30729.1_x-ww_7264ef23\
Property(S): WinSxsManifests.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Manifests\
Property(S): WindowsFolder.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\
Property(S): WinSxsPolicies.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\Policies\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): policydir_ul.30729.01.Microsoft_VC90_MFC_x64.SP.C45920A1_0BA8_3514_8C6E_F5B5E432E436 = C:\Windows\winsxs\amd64_Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_0eb49216\
Property(S): ALLUSERS = 1
Property(S): WinSxsDirectory.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\
Property(S): payload_ul.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\amd64_policy.9.0.microsoft.vc90.mfc_1fc8b3b9a1e18e3b_9.0.30729.1_none_3624aa14c1dce505\
Property(S): WinSxsPolicies.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\
Property(S): policydir.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\winsxs\Policies\amd64_policy.9.0.Microsoft.VC90.MFC_1fc8b3b9a1e18e3b_x-ww_aea75d50\
Property(S): WindowsFolder.30729.01.policy_9_0_Microsoft_VC90_MFC_x64.SP.4D63715F_A814_391A_A622_9058191930F7 = C:\Windows\
Property(S): ProductCode = {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
Property(S): ProductName = Microsoft_VC90_MFC_x86_x64
Property(S): DWUSLINK = CECCB788E98CF7E89EAC97BF99EB978FEE8BF08F69BCD7CFCEBC7798696BC0BF497CA0CFBEAC
Property(S): ADDLOCAL = ALL
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adbBB59.tmp
Property(S): MSIRESTARTMANAGERCONTROL = Disable
Property(S): ADOBE_SETUP = 1
Property(S): ProductToBeRegistered = 1
Property(S): ProductState = 5
Property(S): PackageCode = {C90E5245-A463-4F12-854D-D812F26436F2}
=== Logging stopped: 13/02/2011 14:03:50 ===
1: 2 2: 0
1: 2 2: 1
[ 1940] Sun Feb 13 14:03:51 2011 INFO
:: END TIMER :: [Payload Operation :{A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}] took 3016.24 miliseconds (3.01624 seconds) DTR = 21.2185 KBPS (0.0207211 MBPS)
Calling the custom action code for post-repair for payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64
Calling the custom action code for pre-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593}
::START TIMER:: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}]
[ 4064] Sun Feb 13 14:03:51 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
Third party application path:E:\Adobe CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
CommandLine: -airAppPath AdobeHelp.air -airRuntime AdobeAIRInstaller.exe -eulaAccepted -programMenu -silent
[ 1940] Sun Feb 13 14:03:58 2011 INFO
:: END TIMER :: [Payload Operation :{3BF96AC2-0CA1-11DF-B07B-459956D89593}] took 7034.14 miliseconds (7.03414 seconds) DTR = 33735.5 KBPS (32.9448 MBPS)
Calling the custom action code for post-repair for payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp
[ 1940] Sun Feb 13 14:03:58 2011 WARN
Calling the custom action code for pre-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
::START TIMER:: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}]
[ 1772] Sun Feb 13 14:03:58 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
CommandLine: -silent
[ 1940] Sun Feb 13 14:04:01 2011 INFO
:: END TIMER :: [Payload Operation :{F6FA54C9-3E8F-4416-905C-DA5398DF9640}] took 3047.22 miliseconds (3.04722 seconds) DTR = 2200.04 KBPS (2.14847 MBPS)
Calling the custom action code for post-repair for payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR
Calling the custom action code for pre-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
::START TIMER:: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}]
[ 1036] Sun Feb 13 14:04:01 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
Third party application path:E:\Adobe CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
CommandLine: -silent -eulaAccepted -programMenu adobe_media_player.air
[ 1940] Sun Feb 13 14:04:06 2011 INFO
:: END TIMER :: [Payload Operation :{03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}] took 5041.96 miliseconds (5.04196 seconds) DTR = 0.793342 KBPS (0.000774748 MBPS)
Calling the custom action code for post-repair for payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player
[ 1940] Sun Feb 13 14:04:07 2011 INFO
Calling the custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200}
::START TIMER:: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}]
[ 5240] Sun Feb 13 14:04:07 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Installing payload
Attempting to install package from:E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
[ 5240] Sun Feb 13 14:04:08 2011 INFO
Command line arguments: /UILevel=2 REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress
1: 0 2: 1033 3: 1252
=== Logging started: 13/02/2011 14:04:08 ===
Message type: 1, Argument: Adobe Flash Player 10 ActiveX
Action 14:04:08: INSTALL.
Action start 14:04:08: INSTALL.
Action 14:04:08: ISSetAllUsers.
Action start 14:04:08: ISSetAllUsers.
InstallShield 14:04:08: Begin SetAllUsers()
InstallShield 14:04:08: Getting records from Upgrade table
InstallShield 14:04:08: UpgradeCode: {42463807-970B-4257-BC95-5C348D61DF1C} MinVersion: 6.0.0.0 MaxVersion: 10.1.52.14 Language: Attributes: 769
InstallShield 14:04:08: No related products for UpgradeCode {42463807-970B-4257-BC95-5C348D61DF1C} found
InstallShield 14:04:08: UpgradeCode: {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 14:04:08: No related products for UpgradeCode {91ACC36E-CB92-44F0-AF4E-0BACC033F7F1} found
InstallShield 14:04:08: UpgradeCode: {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} MinVersion: MaxVersion: 10.1.52.14 Language: Attributes: 257
InstallShield 14:04:08: No related products for UpgradeCode {ECA98E30-EB7E-47D1-B47F-B3BEC081B7D8} found
InstallShield 14:04:08: End SetAllUsers()
Action ended 14:04:08: ISSetAllUsers. Return value 1.
Action 14:04:08: AppSearch. Searching for installed applications
Action start 14:04:08: AppSearch.
Action ended 14:04:08: AppSearch. Return value 0.
Action 14:04:08: LaunchConditions. Evaluating launch conditions
Action start 14:04:08: LaunchConditions.
Action ended 14:04:08: LaunchConditions. Return value 1.
Action 14:04:08: FindRelatedProducts. Searching for related applications
Action start 14:04:08: FindRelatedProducts.
Action ended 14:04:08: FindRelatedProducts. Return value 1.
Action 14:04:08: ValidateProductID.
Action start 14:04:08: ValidateProductID.
Action ended 14:04:08: ValidateProductID. Return value 1.
Action 14:04:08: CostInitialize. Computing space requirements
Action start 14:04:08: CostInitialize.
Action ended 14:04:08: CostInitialize. Return value 1.
Action 14:04:08: FileCost. Computing space requirements
Action start 14:04:08: FileCost.
Action ended 14:04:08: FileCost. Return value 1.
Action 14:04:08: IsolateComponents.
Action start 14:04:08: IsolateComponents.
Action ended 14:04:08: IsolateComponents. Return value 0.
Action 14:04:08: CostFinalize. Computing space requirements
Action start 14:04:08: CostFinalize.
Action ended 14:04:08: CostFinalize. Return value 1.
Action 14:04:08: SetARPINSTALLLOCATION.
Action start 14:04:08: SetARPINSTALLLOCATION.
Action ended 14:04:08: SetARPINSTALLLOCATION. Return value 1.
Action 14:04:08: SetODBCFolders. Initializing ODBC directories
Action start 14:04:08: SetODBCFolders.
Action ended 14:04:08: SetODBCFolders. Return value 0.
Action 14:04:08: MigrateFeatureStates. Migrating feature states from related applications
Action start 14:04:08: MigrateFeatureStates.
Action ended 14:04:08: MigrateFeatureStates. Return value 0.
Action 14:04:08: InstallValidate. Validating install
Action start 14:04:08: InstallValidate.
Action ended 14:04:08: InstallValidate. Return value 1.
Action 14:04:08: RemoveExistingProducts. Removing applications
Action start 14:04:08: RemoveExistingProducts.
Action ended 14:04:08: RemoveExistingProducts. Return value 0.
Action 14:04:08: InstallInitialize.
Action start 14:04:08: InstallInitialize.
Action ended 14:04:08: InstallInitialize. Return value 1.
Action 14:04:08: CallExeUninstaller.
Action start 14:04:08: CallExeUninstaller.
Action 14:04:08: GenerateScript. Generating script operations for action:
CallExeUninstaller
Action ended 14:04:08: CallExeUninstaller. Return value 1.
Action 14:04:08: MakePropsAvailable.
Action start 14:04:08: MakePropsAvailable.
Action ended 14:04:08: MakePropsAvailable. Return value 1.
Action 14:04:08: AllocateRegistrySpace. Allocating registry space
Action start 14:04:08: AllocateRegistrySpace.
Action ended 14:04:08: AllocateRegistrySpace. Return value 1.
Action 14:04:08: ProcessComponents. Updating component registration
Action start 14:04:08: ProcessComponents.
Action ended 14:04:08: ProcessComponents. Return value 1.
Action 14:04:08: UnpublishComponents. Unpublishing Qualified Components
Action start 14:04:08: UnpublishComponents.
Action ended 14:04:08: UnpublishComponents. Return value 0.
Action 14:04:08: UnpublishFeatures. Unpublishing product features
Action start 14:04:08: UnpublishFeatures.
Action ended 14:04:08: UnpublishFeatures. Return value 1.
Action 14:04:08: StopServices. Stopping services
Action start 14:04:08: StopServices.
Action ended 14:04:08: StopServices. Return value 1.
Action 14:04:08: DeleteServices. Deleting services
Action start 14:04:08: DeleteServices.
Action ended 14:04:08: DeleteServices. Return value 1.
Action 14:04:08: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 14:04:08: UnregisterComPlus.
Action ended 14:04:08: UnregisterComPlus. Return value 0.
Action 14:04:08: SelfUnregModules. Unregistering modules
Action start 14:04:08: SelfUnregModules.
Action ended 14:04:08: SelfUnregModules. Return value 1.
Action 14:04:08: UnregisterTypeLibraries. Unregistering type libraries
Action start 14:04:08: UnregisterTypeLibraries.
Action ended 14:04:08: UnregisterTypeLibraries. Return value 0.
Action 14:04:08: RemoveODBC. Removing ODBC components
Action start 14:04:08: RemoveODBC.
Action ended 14:04:08: RemoveODBC. Return value 1.
Action 14:04:08: UnregisterFonts. Unregistering fonts
Action start 14:04:08: UnregisterFonts.
Action ended 14:04:08: UnregisterFonts. Return value 1.
Action 14:04:08: RemoveRegistryValues. Removing system registry values
Action start 14:04:08: RemoveRegistryValues.
Action ended 14:04:08: RemoveRegistryValues. Return value 1.
Action 14:04:08: UnregisterClassInfo. Unregister class servers
Action start 14:04:08: UnregisterClassInfo.
Action ended 14:04:08: UnregisterClassInfo. Return value 0.
Action 14:04:08: UnregisterExtensionInfo. Unregistering extension servers
Action start 14:04:08: UnregisterExtensionInfo.
Action ended 14:04:08: UnregisterExtensionInfo. Return value 0.
Action 14:04:08: UnregisterProgIdInfo. Unregistering program identifiers
Action start 14:04:08: UnregisterProgIdInfo.
Action ended 14:04:08: UnregisterProgIdInfo. Return value 0.
Action 14:04:08: UnregisterMIMEInfo. Unregistering MIME info
Action start 14:04:08: UnregisterMIMEInfo.
Action ended 14:04:08: UnregisterMIMEInfo. Return value 0.
Action 14:04:08: RemoveIniValues. Removing INI file entries
Action start 14:04:08: RemoveIniValues.
Action ended 14:04:08: RemoveIniValues. Return value 1.
Action 14:04:08: RemoveShortcuts. Removing shortcuts
Action start 14:04:08: RemoveShortcuts.
Action ended 14:04:08: RemoveShortcuts. Return value 0.
Action 14:04:08: RemoveEnvironmentStrings. Updating environment strings
Action start 14:04:08: RemoveEnvironmentStrings.
Action ended 14:04:08: RemoveEnvironmentStrings. Return value 1.
Action 14:04:08: RemoveDuplicateFiles. Removing duplicated files
Action start 14:04:08: RemoveDuplicateFiles.
Action ended 14:04:08: RemoveDuplicateFiles. Return value 1.
Action 14:04:08: RemoveFolders. Removing folders
Action start 14:04:08: RemoveFolders.
Action ended 14:04:08: RemoveFolders. Return value 1.
Action 14:04:08: CreateFolders. Creating folders
Action start 14:04:08: CreateFolders.
Action ended 14:04:08: CreateFolders. Return value 1.
Action 14:04:08: MoveFiles. Moving files
Action start 14:04:08: MoveFiles.
Action ended 14:04:08: MoveFiles. Return value 1.
Action 14:04:08: InstallFiles. Copying new files
Action start 14:04:08: InstallFiles.
Action ended 14:04:08: InstallFiles. Return value 1.
Action 14:04:08: NewCustomAction1.
Action start 14:04:08: NewCustomAction1.
Error 2753.The File 'InstallAX.exe' is not marked for installation.
Action ended 14:04:08: NewCustomAction1. Return value 3.
Action ended 14:04:08: INSTALL. Return value 3.
Property(S): UpgradeCode = {42463807-970B-4257-BC95-5C348D61DF1C}
Property(S): ProductCode = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SourcedirProduct = {6E9EF98E-259E-416D-B5F8-0ABDB99942CE}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): REMOVE = ALL
Property(S): MACROMED = C:\Windows\SysWOW64\Macromed\
Property(S): FLASH = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): INSTALLDIR = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\3841ae.msi
Property(S): Time = 14:04:08
Property(S): ProductName = Adobe Flash Player 10 ActiveX
Property(S): ARPHELPLINK = http://www.adobe.com/go/flashplayer_support/
Property(S): ARPNOMODIFY = 1
Property(S): ARPURLINFOABOUT = http://www.adobe.com
Property(S): DWUSLINK = CECCA75FE9CBA098D9ACE02FFEDB978FBEECA78F69BBE0B8CE8BA7CFE97CF0AFCEBCE08FD9AC
Property(S): ISSCRIPT_VERSION_MISSING = The InstallScript engine is missing from this machine. If available, please run ISScript.msi, or contact your support personnel for further assistance.
Property(S): Manufacturer = Adobe Systems, Inc.
Property(S): MsiLogging = voicewarmupx
Property(S): NewProperty2 = 0
Property(S): NewProperty3 = 0
Property(S): PROGMSG_IIS_CREATEWEBSITE = Creating IIS website %s
Property(S): PROGMSG_IIS_CREATEWEBSITES = Creating IIS websites...
Property(S): PROGMSG_IIS_REMOVEWEBSITES = Removing IIS websites...
Property(S): ProductVersion = 10.1.52.14
Property(S): RebootYesNo = Yes
Property(S): SecureCustomProperties = ISACTIONPROP1;ISACTIONPROP2;ISACTIONPROP3;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_activeX.exe
Property(S): RemoveFilesCA = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): ARPINSTALLLOCATION = C:\Windows\SysWOW64\Macromed\Flash\
Property(S): VirtualMemory = 14169
Property(S): VersionDatabase = 110
Property(S): MsiSystemRebootPending = 1
Property(S): CLIENTPROCESSID = 7008
Property(S): /UILEVEL = 2
Property(S): PackagecodeChanging = 1
Property(S): ProductState = -1
Property(S): PackageCode = {8C02D971-B819-4CCC-940B-1F1E34164635}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSIa081b.LOG
=== Logging stopped: 13/02/2011 14:04:08 ===
1: 2 2: 0
1: 2 2: 1
Installation result: 1603
[ 1940] Sun Feb 13 14:04:09 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{7E5AA19B-0B85-4f44-BA26-728851489200}] took 2016.16 miliseconds (2.01616 seconds) DTR = 115.07 KBPS (0.112373 MBPS)
Calling the ROLLBACK custom action code for pre-repair for payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX
[ 1940] Sun Feb 13 14:04:10 2011 INFO
Calling the custom action code for pre-repair for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34}
::START TIMER:: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}]
[ 6996] Sun Feb 13 14:04:10 2011 INFO
Repairing third party payload with source: E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
MsiSourceListAddSource for E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi is 0
MsiSourceListSetInfo with updated name: AdobeFlashPlayer10_plRel_mul.msi, Result: 0
MsiSourceListSetInfo with alternative root: \Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\, Result: 0
Configuring MSI ProductCode: {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
ADOBE_SETUP=1 MSIRESTARTMANAGERCONTROL=Disable REBOOT=ReallySuppress UILevel=2 REINSTALL=ALL REINSTALLMODE=pvoums REBOOT=ReallySuppress PROPERTY_FILE="C:\Users\GARY&S~1\AppData\Local\Temp\adb11D3.tmp"
[ 6996] Sun Feb 13 14:04:11 2011 INFO
=== Logging started: 13/02/2011 14:04:11 ===
Message type: 0, Argument: 1033
Message type: 1, Argument: Adobe Flash Player 10 Plugin
Action 14:04:11: INSTALL.
Action start 14:04:11: INSTALL.
Action 14:04:11: AppSearch. Searching for installed applications
Action start 14:04:11: AppSearch.
Action ended 14:04:11: AppSearch. Return value 0.
Action 14:04:11: LaunchConditions. Evaluating launch conditions
Action start 14:04:11: LaunchConditions.
Action ended 14:04:11: LaunchConditions. Return value 1.
Action 14:04:11: FindRelatedProducts. Searching for related applications
Action start 14:04:11: FindRelatedProducts.
Action ended 14:04:11: FindRelatedProducts. Return value 0.
Action 14:04:11: ValidateProductID.
Action start 14:04:11: ValidateProductID.
Action ended 14:04:11: ValidateProductID. Return value 1.
Action 14:04:11: CostInitialize. Computing space requirements
Action start 14:04:11: CostInitialize.
Action ended 14:04:11: CostInitialize. Return value 1.
Action 14:04:11: FileCost. Computing space requirements
Action start 14:04:11: FileCost.
Action ended 14:04:11: FileCost. Return value 1.
Action 14:04:11: IsolateComponents.
Action start 14:04:11: IsolateComponents.
Action ended 14:04:11: IsolateComponents. Return value 0.
Action 14:04:11: CostFinalize. Computing space requirements
Action start 14:04:11: CostFinalize.
Action ended 14:04:11: CostFinalize. Return value 1.
Action 14:04:11: SetODBCFolders. Initializing ODBC directories
Action start 14:04:11: SetODBCFolders.
Action ended 14:04:11: SetODBCFolders. Return value 0.
Action 14:04:11: MigrateFeatureStates. Migrating feature states from related applications
Action start 14:04:11: MigrateFeatureStates.
Action ended 14:04:11: MigrateFeatureStates. Return value 0.
Action 14:04:11: InstallValidate. Validating install
Action start 14:04:11: InstallValidate.
Action ended 14:04:11: InstallValidate. Return value 1.
Action 14:04:11: RemoveExistingProducts. Removing applications
Action start 14:04:11: RemoveExistingProducts.
Action ended 14:04:11: RemoveExistingProducts. Return value 0.
Action 14:04:11: InstallInitialize.
Action start 14:04:11: InstallInitialize.
Action ended 14:04:11: InstallInitialize. Return value 1.
Action 14:04:11: MakePropsAvailable.
Action start 14:04:11: MakePropsAvailable.
Action ended 14:04:11: MakePropsAvailable. Return value 1.
Action 14:04:11: ProcessComponents. Updating component registration
Action start 14:04:11: ProcessComponents.
Action 14:04:11: GenerateScript. Generating script operations for action:
Action ended 14:04:11: ProcessComponents. Return value 1.
Action 14:04:11: UnpublishComponents. Unpublishing Qualified Components
Action start 14:04:11: UnpublishComponents.
Action ended 14:04:11: UnpublishComponents. Return value 0.
Action 14:04:11: UnpublishFeatures. Unpublishing product features
Action start 14:04:11: UnpublishFeatures.
Action ended 14:04:11: UnpublishFeatures. Return value 1.
Action 14:04:11: StopServices. Stopping services
Action start 14:04:11: StopServices.
Action ended 14:04:11: StopServices. Return value 1.
Action 14:04:11: DeleteServices. Deleting services
Action start 14:04:11: DeleteServices.
Action ended 14:04:11: DeleteServices. Return value 1.
Action 14:04:11: UnregisterComPlus. Unregistering COM+ Applications and Components
Action start 14:04:11: UnregisterComPlus.
Action ended 14:04:11: UnregisterComPlus. Return value 0.
Action 14:04:11: SelfUnregModules. Unregistering modules
Action start 14:04:11: SelfUnregModules.
Action ended 14:04:11: SelfUnregModules. Return value 1.
Action 14:04:11: UnregisterTypeLibraries. Unregistering type libraries
Action start 14:04:11: UnregisterTypeLibraries.
Action ended 14:04:11: UnregisterTypeLibraries. Return value 0.
Action 14:04:11: RemoveODBC. Removing ODBC components
Action start 14:04:11: RemoveODBC.
Action ended 14:04:11: RemoveODBC. Return value 1.
Action 14:04:11: UnregisterFonts. Unregistering fonts
Action start 14:04:11: UnregisterFonts.
Action ended 14:04:11: UnregisterFonts. Return value 1.
Action 14:04:11: RemoveRegistryValues. Removing system registry values
Action start 14:04:11: RemoveRegistryValues.
Action ended 14:04:11: RemoveRegistryValues. Return value 1.
Action 14:04:11: UnregisterClassInfo. Unregister class servers
Action start 14:04:11: UnregisterClassInfo.
Action ended 14:04:11: UnregisterClassInfo. Return value 0.
Action 14:04:11: UnregisterExtensionInfo. Unregistering extension servers
Action start 14:04:11: UnregisterExtensionInfo.
Action ended 14:04:11: UnregisterExtensionInfo. Return value 0.
Action 14:04:11: UnregisterProgIdInfo. Unregistering program identifiers
Action start 14:04:11: UnregisterProgIdInfo.
Action ended 14:04:11: UnregisterProgIdInfo. Return value 0.
Action 14:04:11: UnregisterMIMEInfo. Unregistering MIME info
Action start 14:04:11: UnregisterMIMEInfo.
Action ended 14:04:11: UnregisterMIMEInfo. Return value 0.
Action 14:04:11: RemoveIniValues. Removing INI file entries
Action start 14:04:11: RemoveIniValues.
Action ended 14:04:11: RemoveIniValues. Return value 1.
Action 14:04:11: RemoveShortcuts. Removing shortcuts
Action start 14:04:11: RemoveShortcuts.
Action ended 14:04:11: RemoveShortcuts. Return value 0.
Action 14:04:11: RemoveEnvironmentStrings. Updating environment strings
Action start 14:04:11: RemoveEnvironmentStrings.
Action ended 14:04:11: RemoveEnvironmentStrings. Return value 1.
Action 14:04:11: RemoveDuplicateFiles. Removing duplicated files
Action start 14:04:11: RemoveDuplicateFiles.
Action ended 14:04:11: RemoveDuplicateFiles. Return value 1.
Action 14:04:11: RemoveFolders. Removing folders
Action start 14:04:11: RemoveFolders.
Action ended 14:04:11: RemoveFolders. Return value 1.
Action 14:04:11: CreateFolders. Creating folders
Action start 14:04:11: CreateFolders.
Folder: Creating folders
Action ended 14:04:11: CreateFolders. Return value 1.
Action 14:04:11: MoveFiles. Moving files
Action start 14:04:11: MoveFiles.
Action ended 14:04:11: MoveFiles. Return value 1.
Action 14:04:11: InstallFiles. Copying new files
Action start 14:04:11: InstallFiles.
Action ended 14:04:11: InstallFiles. Return value 1.
Action 14:04:11: PatchFiles. Patching files
Action start 14:04:11: PatchFiles.
Action ended 14:04:11: PatchFiles. Return value 1.
Action 14:04:11: DuplicateFiles. Creating duplicate files
Action start 14:04:11: DuplicateFiles.
Action ended 14:04:11: DuplicateFiles. Return value 1.
Action 14:04:11: BindImage. Binding executables
Action start 14:04:11: BindImage.
Action ended 14:04:11: BindImage. Return value 1.
Action 14:04:11: CreateShortcuts. Creating shortcuts
Action start 14:04:11: CreateShortcuts.
Action ended 14:04:11: CreateShortcuts. Return value 0.
Action 14:04:11: RegisterClassInfo. Registering class servers
Action start 14:04:11: RegisterClassInfo.
Action ended 14:04:11: RegisterClassInfo. Return value 0.
Action 14:04:11: RegisterExtensionInfo. Registering extension servers
Action start 14:04:11: RegisterExtensionInfo.
Action ended 14:04:11: RegisterExtensionInfo. Return value 0.
Action 14:04:11: RegisterProgIdInfo. Registering program identifiers
Action start 14:04:11: RegisterProgIdInfo.
Action ended 14:04:11: RegisterProgIdInfo. Return value 0.
Action 14:04:11: RegisterMIMEInfo. Registering MIME info
Action start 14:04:11: RegisterMIMEInfo.
Action ended 14:04:11: RegisterMIMEInfo. Return value 0.
Action 14:04:11: WriteRegistryValues. Writing system registry values
Action start 14:04:11: WriteRegistryValues.
Key: Writing system registry values, Name: , Value:
Action ended 14:04:11: WriteRegistryValues. Return value 1.
Action 14:04:11: WriteIniValues. Writing INI file values
Action start 14:04:11: WriteIniValues.
Action ended 14:04:11: WriteIniValues. Return value 1.
Action 14:04:11: WriteEnvironmentStrings. Updating environment strings
Action start 14:04:11: WriteEnvironmentStrings.
Action ended 14:04:11: WriteEnvironmentStrings. Return value 1.
Action 14:04:11: RegisterFonts. Registering fonts
Action start 14:04:11: RegisterFonts.
Action ended 14:04:11: RegisterFonts. Return value 1.
Action 14:04:11: InstallODBC. Installing ODBC components
Action start 14:04:11: InstallODBC.
Action ended 14:04:11: InstallODBC. Return value 0.
Action 14:04:11: RegisterTypeLibraries. Registering type libraries
Action start 14:04:11: RegisterTypeLibraries.
Action ended 14:04:11: RegisterTypeLibraries. Return value 0.
Action 14:04:11: SelfRegModules. Registering modules
Action start 14:04:11: SelfRegModules.
Action ended 14:04:11: SelfRegModules. Return value 1.
Action 14:04:11: RegisterComPlus. Registering COM+ Applications and Components
Action start 14:04:11: RegisterComPlus.
Action ended 14:04:11: RegisterComPlus. Return value 0.
Action 14:04:11: InstallServices. Installing new services
Action start 14:04:11: InstallServices.
Action ended 14:04:11: InstallServices. Return value 1.
Action 14:04:11: StartServices. Starting services
Action start 14:04:11: StartServices.
Action ended 14:04:11: StartServices. Return value 1.
Action 14:04:11: RegisterUser. Registering user
Action start 14:04:11: RegisterUser.
Action ended 14:04:11: RegisterUser. Return value 0.
Action 14:04:11: RegisterProduct. Registering product
Action start 14:04:11: RegisterProduct.
Registering product
Action ended 14:04:11: RegisterProduct. Return value 1.
Action 14:04:11: PublishComponents. Publishing qualified components
Action start 14:04:11: PublishComponents.
Action ended 14:04:11: PublishComponents. Return value 0.
Action 14:04:11: PublishFeatures. Publishing product features
Action start 14:04:11: PublishFeatures.
Action ended 14:04:11: PublishFeatures. Return value 1.
Action 14:04:11: PublishProduct. Publishing product information
Action start 14:04:11: PublishProduct.
Action ended 14:04:11: PublishProduct. Return value 1.
Action 14:04:11: InstallFinalize.
Action start 14:04:11: InstallFinalize.
Folder: C:\Windows\SysWOW64\Macromed\Flash\
File: InstallPlugin.exe, Directory: C:\Users\GARY&S~1\AppData\Local\Temp\, Size: 2516992
Key: \Software\Macromedia\FlashPlayer, Name: , Value:
Key: \Software\Macromedia\FlashPlayer, Name: FlashPlayerVersion, Value: 10.1.52.14
3b1ac.msi
Feature: FlashPlayerAXInstaller
Action 14:04:11: RollbackCleanup. Removing backup files
File: C:\Config.Msi\3841b9.rbf
File: C:\Config.Msi\3841ba.rbf
File: C:\Config.Msi\3841bb.rbf
Action ended 14:04:11: InstallFinalize. Return value 1.
Action ended 14:04:11: INSTALL. Return value 1.
Property(S): UpgradeCode = {D85A1A59-DC52-4D13-9445-EF3F379D4DB5}
Property(S): ProductCode = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): Installed = 2010/03/24 00:43:56
Property(S): SourcedirProduct = {BC41C09D-FAA9-4346-9FE6-1E0017BC551A}
Property(S): SOURCEDIR = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): SourceDir = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\
Property(S): OriginalDatabase = E:\Adobe CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
Property(S): DATABASE = C:\Windows\Installer\3841b3.msi
Property(S): Time = 14:04:11
Property(S): ISCHECKFORPRODUCTUPDATES = 1
Property(S): ApplicationUsers = AllUsers
Property(S): AgreeToLicense = No
Property(S): _IsMaintenance = Change
Property(S): RestartManagerOption = CloseRestart
Property(S): IS_SQLSERVER_USERNAME = sa
Property(S): IS_SQLSERVER_AUTHENTICATION = 0
Property(S): SetupType = Typical
Property(S): _IsSetupTypeMin = Typical
Property(S): Display_IsBitmapDlg = 1
Property(S): ProductName = Adobe Flash Player 10 Plugin
Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
Property(S): DWUSINTERVAL = 30
Property(S): DefaultUIFont = Tahoma8
Property(S): DialogCaption = InstallShield for Windows Installer
Property(S): DisplayNameCustom = Custom
Property(S): DisplayNameMinimal = Minimal
Property(S): DisplayNameTypical = Typical
Property(S): ErrorDialog = SetupError
Property(S): INSTALLLEVEL = 100
Property(S): ISVROOT_PORT_NO = 0
Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
Property(S): InstallChoice = AR
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
Property(S): SHOWLAUNCHPROGRAM = 0
Property(S): SecureCustomProperties = ISACTIONPROP1;SUPPORTDIR
Property(S): UNINSTALLER_EXE = [SystemFolder]\Macromed\Flash\uninstall_plugin.exe
Property(S): USERNAME = Gary & Susan
Property(S): PRODUCTLANGUAGE = 1033
Property(S): PROPERTY_FILE = C:\Users\GARY&S~1\AppData\Local\Temp\adb11D3.tmp
Property(S): UILEVEL = 2
Property(S): PackageCode = {BD4109FD-A808-4EAE-B2BE-144DA3F3A299}
Property(S): MsiLogFileLocation = C:\Users\GARY&S~1\AppData\Local\Temp\MSIa081c.LOG
=== Logging stopped: 13/02/2011 14:04:11 ===
1: 2 2: 0
1: 2 2: 1
[ 1940] Sun Feb 13 14:04:12 2011 INFO
*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 0 =*=*=*=*=*=*=*=*=*=*=*=*=*
:: END TIMER :: [Payload Operation :{40F95A03-885A-45fb-9A14-486BEFEDDF34}] took 2023.84 miliseconds (2.02384 seconds) DTR = 122.539 KBPS (0.119667 MBPS)
Calling the custom action code for post-repair for payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin
Calling the custom action code for pre-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0}
::START TIMER:: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: productName is Adobe Flash Fonts1
Font Installer: Using [AdobeCommon] path: C:\Program Files (x86)\Common Files\Adobe
Custom action return code: 0
:: END TIMER :: [Pre payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 2.14989 miliseconds (0.00214989 seconds)
::START TIMER:: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}]
[ 6328] Sun Feb 13 14:04:12 2011 INFO
Installer Operation: PayloadUninstaller
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7745F18B-FD8A-4011-BE16-588900C503D0}
Effective AdobeCode for: {7745F18B-FD8A-4011-BE16-588900C503D0} is {7745F18B-FD8A-4011-BE16-588900C503D0}
Session includes local copy of payload for repair source
Repair payload source package: E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Extracting assets...
Extracting assets complete. Number assets: 1
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
Evaluating condition# 1
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeFlashFonts1-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7745F18B-FD8A-4011-BE16-588900C503D0}.db
[ 6328] Sun Feb 13 14:04:13 2011 INFO
Physical payload repair result:0
[ 1940] Sun Feb 13 14:04:13 2011 INFO
:: END TIMER :: [Payload Operation :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 1022.69 miliseconds (1.02269 seconds) DTR = 31.2901 KBPS (0.0305567 MBPS)
Calling the custom action code for post-repair for payload {7745F18B-FD8A-4011-BE16-588900C503D0} Adobe Flash Fonts1
::START TIMER:: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}]
Font Installer: Did not find any font files under:C:\Program Files (x86)\Common Files\Adobe\SavedFonts\current
:: END TIMER :: [Post payload :{7745F18B-FD8A-4011-BE16-588900C503D0}] took 2.35006 miliseconds (0.00235006 seconds) DTR = 13616.7 KBPS (13.2975 MBPS)
Disk Swap Needed, Prompting user to swap disk CS5 Master Coll2 E:\
[ 1940] Sun Feb 13 14:05:17 2011 INFO
Starting installation from Disk 2 - CS5 Master Coll2
Calling the custom action code for pre-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
::START TIMER:: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}]
[ 1968] Sun Feb 13 14:05:18 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Effective AdobeCode for: {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} is {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 1968] Sun Feb 13 14:05:33 2011 INFO
Extracting assets complete. Number assets: 2
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
[ 1968] Sun Feb 13 14:05:41 2011 INFO
Evaluating condition# 2
Condition failed
Condition failed
[ 1968] Sun Feb 13 14:05:50 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}.db
[ 1940] Sun Feb 13 14:05:51 2011 INFO
:: END TIMER :: [Payload Operation :{C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1}] took 33097.2 miliseconds (33.0972 seconds) DTR = 52.5725 KBPS (0.0513403 MBPS)
Calling the custom action code for post-repair for payload {C0AA232E-BD1B-40B5-A176-A2BEB67FFAE1} Adobe After Effects CS5 Third Party Content
Calling the custom action code for pre-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
::START TIMER:: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}]
[ 3444] Sun Feb 13 14:05:51 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Effective AdobeCode for: {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} is {CD29B5CA-4727-4114-9AD9-25CCCE6E4014}
Repair payload source package: E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
[ 3444] Sun Feb 13 14:05:52 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
Condition failed
Condition failed
[ 3444] Sun Feb 13 14:05:53 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeAfterEffects10RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}.db
[ 3444] Sun Feb 13 14:05:54 2011 INFO
[ 1940] Sun Feb 13 14:05:54 2011 INFO
:: END TIMER :: [Payload Operation :{CD29B5CA-4727-4114-9AD9-25CCCE6E4014}] took 3022.25 miliseconds (3.02225 seconds)
Calling the custom action code for post-repair for payload {CD29B5CA-4727-4114-9AD9-25CCCE6E4014} Adobe After Effects CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691}
::START TIMER:: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}]
[ 3728] Sun Feb 13 14:05:54 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Effective AdobeCode for: {0E3C6C75-872D-4B0D-B0B2-31C717250691} is {0E3C6C75-872D-4B0D-B0B2-31C717250691}
Repair payload source package: E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 3728] Sun Feb 13 14:05:55 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
[ 3728] Sun Feb 13 14:06:00 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeEncore5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{0E3C6C75-872D-4B0D-B0B2-31C717250691}.db
[ 1940] Sun Feb 13 14:06:00 2011 INFO
:: END TIMER :: [Payload Operation :{0E3C6C75-872D-4B0D-B0B2-31C717250691}] took 6035.71 miliseconds (6.03571 seconds)
Calling the custom action code for post-repair for payload {0E3C6C75-872D-4B0D-B0B2-31C717250691} Adobe Encore CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
::START TIMER:: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}]
[ 3620] Sun Feb 13 14:06:00 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Effective AdobeCode for: {5DDABB74-A879-4BE7-A4C6-FD41793942DB} is {5DDABB74-A879-4BE7-A4C6-FD41793942DB}
Repair payload source package: E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
[ 3620] Sun Feb 13 14:06:05 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
Completing installation for payload at E:\Adobe CS5\payloads\AMEDolby5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{5DDABB74-A879-4BE7-A4C6-FD41793942DB}.db
[ 1940] Sun Feb 13 14:06:06 2011 INFO
:: END TIMER :: [Payload Operation :{5DDABB74-A879-4BE7-A4C6-FD41793942DB}] took 6029.99 miliseconds (6.02999 seconds)
Calling the custom action code for post-repair for payload {5DDABB74-A879-4BE7-A4C6-FD41793942DB} Adobe Media Encoder CS5 Dolby X64
Calling the custom action code for pre-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
::START TIMER:: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}]
[ 7032] Sun Feb 13 14:06:06 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Effective AdobeCode for: {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} is {F9C71630-0EE3-475C-9E2B-ED95AE197DBD}
Repair payload source package: E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 7032] Sun Feb 13 14:06:07 2011 INFO
[ 7032] Sun Feb 13 14:06:08 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
[ 7032] Sun Feb 13 14:06:13 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AMEPCI5All_x64\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}.db
[ 1940] Sun Feb 13 14:06:13 2011 INFO
:: END TIMER :: [Payload Operation :{F9C71630-0EE3-475C-9E2B-ED95AE197DBD}] took 7030 miliseconds (7.03 seconds) DTR = 72.8307 KBPS (0.0711238 MBPS)
[ 1940] Sun Feb 13 14:06:14 2011 INFO
Calling the custom action code for post-repair for payload {F9C71630-0EE3-475C-9E2B-ED95AE197DBD} Adobe Media Encoder CS5 PCI X64
Calling the custom action code for pre-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E}
::START TIMER:: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}]
[ 1676] Sun Feb 13 14:06:14 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Effective AdobeCode for: {7816FDDE-40D4-482D-AD7D-97858985DB3E} is {7816FDDE-40D4-482D-AD7D-97858985DB3E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
[ 1676] Sun Feb 13 14:06:16 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeOnLocation5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{7816FDDE-40D4-482D-AD7D-97858985DB3E}.db
[ 1940] Sun Feb 13 14:06:17 2011 INFO
:: END TIMER :: [Payload Operation :{7816FDDE-40D4-482D-AD7D-97858985DB3E}] took 3026.64 miliseconds (3.02664 seconds)
Calling the custom action code for post-repair for payload {7816FDDE-40D4-482D-AD7D-97858985DB3E} Adobe OnLocation CS5 Royalty Content
Calling the custom action code for pre-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8}
::START TIMER:: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}]
[ 6252] Sun Feb 13 14:06:17 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Effective AdobeCode for: {B8D286BC-A68D-4E74-9F68-8756A49896D8} is {B8D286BC-A68D-4E74-9F68-8756A49896D8}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
Condition failed
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{B8D286BC-A68D-4E74-9F68-8756A49896D8}.db
[ 1940] Sun Feb 13 14:06:18 2011 INFO
:: END TIMER :: [Payload Operation :{B8D286BC-A68D-4E74-9F68-8756A49896D8}] took 1027.39 miliseconds (1.02739 seconds)
User specified overrideFile:
Calling the custom action code for post-repair for payload {B8D286BC-A68D-4E74-9F68-8756A49896D8} Adobe Premiere Pro CS5 Third Party Content
Calling the custom action code for pre-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
::START TIMER:: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}]
[ 3844] Sun Feb 13 14:06:18 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Effective AdobeCode for: {565DE707-5798-4FC3-8DF6-0F58A348A9B0} is {565DE707-5798-4FC3-8DF6-0F58A348A9B0}
Repair payload source package: E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
[ 3844] Sun Feb 13 14:06:23 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
Condition failed
Condition failed
[ 3844] Sun Feb 13 14:06:25 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobePremierePro5RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{565DE707-5798-4FC3-8DF6-0F58A348A9B0}.db
[ 3844] Sun Feb 13 14:06:26 2011 INFO
[ 1940] Sun Feb 13 14:06:26 2011 INFO
:: END TIMER :: [Payload Operation :{565DE707-5798-4FC3-8DF6-0F58A348A9B0}] took 8043.6 miliseconds (8.0436 seconds) DTR = 135.263 KBPS (0.132093 MBPS)
Calling the custom action code for post-repair for payload {565DE707-5798-4FC3-8DF6-0F58A348A9B0} Adobe Premiere Pro CS5 Third Party Royalty Content
Calling the custom action code for pre-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
::START TIMER:: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}]
[ 1088] Sun Feb 13 14:06:26 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Effective AdobeCode for: {DE5DE662-2ECB-4D93-967B-221FBCC8A736} is {DE5DE662-2ECB-4D93-967B-221FBCC8A736}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 1088] Sun Feb 13 14:06:27 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
[ 1088] Sun Feb 13 14:06:28 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3ProtectedAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{DE5DE662-2ECB-4D93-967B-221FBCC8A736}.db
[ 1940] Sun Feb 13 14:06:29 2011 INFO
:: END TIMER :: [Payload Operation :{DE5DE662-2ECB-4D93-967B-221FBCC8A736}] took 3021 miliseconds (3.021 seconds)
Calling the custom action code for post-repair for payload {DE5DE662-2ECB-4D93-967B-221FBCC8A736} Adobe Soundbooth CS5 Codecs
Calling the custom action code for pre-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
::START TIMER:: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}]
[ 1288] Sun Feb 13 14:06:29 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Effective AdobeCode for: {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} is {F319804F-E3A4-4C02-8AEC-CB39A4F6447E}
Repair payload source package: E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 1288] Sun Feb 13 14:06:31 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
[ 1288] Sun Feb 13 14:06:32 2011 INFO
Completing installation for payload at E:\Adobe CS5\payloads\AdobeSoundbooth3RoyaltyAll\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}.db
[ 1288] Sun Feb 13 14:06:33 2011 INFO
[ 1940] Sun Feb 13 14:06:33 2011 INFO
:: END TIMER :: [Payload Operation :{F319804F-E3A4-4C02-8AEC-CB39A4F6447E}] took 4029.43 miliseconds (4.02943 seconds) DTR = 254.13 KBPS (0.248174 MBPS)
Calling the custom action code for post-repair for payload {F319804F-E3A4-4C02-8AEC-CB39A4F6447E} Adobe Soundbooth CS5 Royalty Codecs
Calling the custom action code for pre-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4}
::START TIMER:: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}]
[ 5792] Sun Feb 13 14:06:33 2011 INFO
Session {FBB02B04-C034-4382-A3F6-57416E2752C4} modify request for AdobeCode: {FBB02B04-C034-4382-A3F6-57416E2752C4}
Effective AdobeCode for: {FBB02B04-C034-4382-A3F6-57416E2752C4} is {FBB02B04-C034-4382-A3F6-57416E2752C4}
Repair payload source package: E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
[ 5792] Sun Feb 13 14:06:34 2011 INFO
Beginning installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
Condition failed
Completing installation for payload at E:\Adobe CS5\payloads\AdobeMasterCollection5-mul\Install.db
UninstallDBPath=C:\Program Files (x86)\Common Files\Adobe\Installers\uninstall\{FBB02B04-C034-4382-A3F6-57416E2752C4}.db
[ 1940] Sun Feb 13 14:06:34 2011 INFO
:: END TIMER :: [Payload Operation :{FBB02B04-C034-4382-A3F6-57416E2752C4}] took 1025.5 miliseconds (1.0255 seconds) DTR = 499.269 KBPS (0.487567 MBPS)
[ 1940] Sun Feb 13 14:06:35 2011 INFO
Calling the custom action code for post-repair for payload {FBB02B04-C034-4382-A3F6-57416E2752C4} Creative Suite 5 Master Collection
Calling the custom action code for pre-install for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22}
::START TIMER:: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}]
In PrePayloadInstallProc
hook checkDirs passed str:
C:\Program Files (x86)\Adobe
detected bad URL character
CHRC_NULL_POINTER_VALUE
Custom action return code: 1
:: END TIMER :: [Pre payload :{177E1CA1-14CC-4398-AB15-A5746EFE8F22}] took 1.23589 miliseconds (0.00123589 seconds)
[ 1940] Sun Feb 13 14:06:35 2011 ERROR
Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
Calling the custom action code for pre-install for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A}
::START TIMER:: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}]
:: END TIMER :: [Pre payload :{E8815668-95B0-443D-AC92-2BFD7DD8F16A}] took 1.13764 miliseconds (0.00113764 seconds)
Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
No operation. We're done:
Updating driver data - Action: Remove driver entry
Updating driver data successful. Driver entry was added. ARP estimated size 21458917KB
[ 1940] Sun Feb 13 14:06:37 2011 INFO
Total components installed: 0
Successfully repaired 32 components:
- Microsoft_VC90_ATL_x86
- Adobe Media Player
- Microsoft_VC90_CRT_x86
- Adobe Encore CS5 Third Party Royalty Content
- Microsoft_VC80_ATL_x86
- Adobe Player for Embedding
- AdobeHelp
- Adobe Flash Player 10 Plugin
- Adobe Premiere Pro CS5 Third Party Royalty Content
- Adobe Media Encoder CS5 Dolby X64
- Microsoft_VC90_MFC_x86
- Adobe Media Encoder CS5 X64
- Suite Shared Configuration CS5
- AdobeTypeSupport CS5
- Adobe Flash Fonts1
- Adobe OnLocation CS5 Royalty Content
- Microsoft_VC90_ATL_x86_x64
- Microsoft_VC90_CRT_x86_x64
- Microsoft_VC80_CRT_x86
- Microsoft_VC90_MFC_x86_x64
- DynamiclinkSupport
- Adobe Premiere Pro CS5 Third Party Content
- AdobeCMaps CS5
- Adobe After Effects CS5 Third Party Content
- Adobe After Effects CS5 Third Party Royalty Content
- Microsoft_VC80_MFC_x86
- Microsoft_VC80_MFCLOC_x86
- Adobe Soundbooth CS5 Codecs
- Adobe Soundbooth CS5 Royalty Codecs
- Adobe AIR
- Adobe Media Encoder CS5 PCI X64
- Creative Suite 5 Master Collection
Total components removed: 0
[ 1940] Sun Feb 13 14:06:37 2011 ERROR
The following payload errors were found during install:
- Adobe Flash Builder: Install failed
- Adobe Flash Player 10 ActiveX: Install failed
- Adobe Flash Catalyst CS5: Install failed
Restarting your computer is recommended:
In order to complete the installation, please restart the computer
Call PostSession Custom Hook
:: END TIMER :: [Total Timer] took 286433 miliseconds (286.433 seconds) DTR = 839.248 KBPS (0.819578 MBPS)
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 6 error(s), 4 warning(s)
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Warning: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
ERROR: Custom Action for payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder returned error. Failing this payload.
ERROR: Custom Action for payload {E8815668-95B0-443D-AC92-2BFD7DD8F16A} Adobe Flash Catalyst CS5 returned error. Failing this payload.
ERROR: The following payload errors were found during install:
ERROR: - Adobe Flash Builder: Install failed
ERROR: - Adobe Flash Player 10 ActiveX: Install failed
ERROR: - Adobe Flash Catalyst CS5: Install failed
Search the same string above to find when the error occured.
Exit Code: 6 - Silent workflow completed with errors
END - Installer Session
OK then I've found the install logs (apologies as I'm going to ask a silly question here) I presume you want to see the install log titled
"Creative Suite 5 Master Collection 5.0" or so you infact want to see every single one of them??
I've unzipped the .gz files so I presume I just post them here for you then??
If it's the log from the Master Collection, it's going to be very long. Probably better to send that to me in zip (or gz) format as a mail attachment instead.
You can send it to me at cagruss (at adobe dot com).
-Chris
Looking at the log file that you sent (under separate cover), it looks as if your username contains an ampersand - &.
I believe that's one of the characters that java doesn't handle properly in paths, flagged in the error. Here's one way you can test this theory:
- log in as a different user with an alphanumeric-only user name, preferably one with machine Admin rights
- install FB as that user, and see if that succeeds.
If so, then you can switch back to your preferred user account, and run from there instead. In that case, you'll probably want to change FB's default workspace path to some custom path that's not underneath your user home folder, to avoid other problems with that ampersand in the path.
-Chris
Following up, Gary reported back (under separate cover) that this solution worked for him.
-Chris
Hi, I had the same problem, so I removed a old instalations of FlexBuilder 4 and Burrito and i dont marked "install flash player". Its work for me.
