Hello all,
This is a more precise question than my other one : http://forums.adobe.com/message/3462732#3462732
Can someone tell me what the causes can be that I get a NullPointer Exception in flex.data.adapters.JavaAdapter which ships with Adobe LCDS 3.1?
Log :
I really need to go on on this one.
The other question is left open to be able to post the entire solution when it is done
Thank you in advance!
Total Likes
Hi
Looks like the DataServiceTransaction is null.
Before you begin interacting with a DMS destination, you need to start a DataServiceTransaction using DST.begin() http://help.adobe.com/en_US/LiveCycleDataServicesES/3.1/Javadoc/flex/data/DataServiceTransaction.htm...
After you are done, you should use commit() or rollback() to finish the transaction as applicable.
Ashish Vashisht
[Ashish Vashisht : reply to this so that I can give you the correct answer points]
This was the problem, effectively. I had to code a bit more to get it working (compared to the doc examples...) :
Super-thanks, anyways!
Total Likes
