Hi birchuso
If I'm understanding you correctly, you are talking about two
or three different things.
1. Absolute VS Relative linking
2. Linking one MenuBuilder file to another
3. Using Autorun to run HTML off a CD
Possible answers:
1. In MenuBuilder, when you establish a link to something, it
typically pops the full path in as part of the mix. Perhaps the
path would be something like this:
C:\MenuBuilder Output\MyProject.SWF
This is what is known as an "absolute" link. You are linking
explicitly to a known address. Now if you moved the output to
another PC, using this manner of linking, your end user would need
to have files in the identical location for things to work.
With absolute linking, it's like being inside a house and
asking someone to fetch something from 123 Maple Street, AnyTown
USA in the Garage. So the person would go outside the house, locate
123 Maple Street, AnyTown USA, go into the garage and get the item.
With relative linking, it's llike the same scenario, but
instead of supplying the full address, the person asks for
something from the Garage. Assuming the Garage exists, it doesn't
matter what town the house is in, only that the garage can be
found. In other words, it's relative to the house.
So here is one way to prevent this absolute linking from
occurring. When you create the links from MB, you probably click
and navigate to them. And when you look at the end result, you
probably see an absolute path in the field. So you simply edit the
path so it is no longer absolute. Perhaps it looks like this
initially: C:\MenuBuilder Output\MyProject.SWF. You would then edit
this so it appears as simply MyProject.SWF.
Next, you would want to be sure and place a check mark in the
check box labeled "Save file with project".
2. Linking one MenuBuilder file to another. Using the rules
above, you just establish the link. Now normally, MenuBuilder .SWF
output does not have a companion HTML page. But note that
MenuBuilder has about three flavors of output. So linking from one
flavor to another can sometimes result in odd behavior. Normally
when you decide to mix the flavors. In my experience, it's best to
avoid mixing flavors if you can.
Link from .EXE to Captivate .EXE or from .SWF to Captivate
.SWF. If you mix at all, I believe the best results are when you
link from .HTM MenuBuilder output to .SWF/.HTM Captivate output.
But when you go mixing .HTM with .EXE, or .EXE with .HTM, the
behavior may become unpredictable.
3. Autorunning HTML. I know MenuBuilder offers the ability to
produce an Autorun.inf (the "behind the scenes" file that provides
the magic for autorun) but I'm not 100% confident that it works to
kick off an HTML page. I've seen it fail on my own PCs from time to
time.
Note that sometimes autorun has issues if the file names in
use are long or have spaces. Consequently, I've always advised to
stick to the old DOS 8.3 format. Where the file you are trying to
automatically run looks like this:
MyMBFile.EXE as opposed to
My Most Wonderful And Delicious MenuBuilder File In The Whole
Entire Universe.EXE
Hopefully this helps... Rick
