After gathering information with Network Monitor in Flash Builder 4 Premium (build 272416) plug-in in Eclipse 3.5.2, NullPointerExceptions are popping up.
Here is an example:
java.lang.NullPointerException
at com.adobe.flexbuilder.monitors.network.store.records.impl.HTTPRecord.getElapsedTime(HTTPRecord.java:246)
at com.adobe.flexbuilder.monitors.network.store.records.impl.NetmonRecordDelegate.getElapsedTime(NetmonRecordDelegate.java:182)
at com.adobe.flexbuilder.monitors.network.view.MasterTableColumnType$6$1.getLabelObject(MasterTableColumnType.java:257)
at com.adobe.flexbuilder.monitors.network.view.MasterTableColumnType$6$1.getLabelText(MasterTableColumnType.java:262)
at com.adobe.flexbuilder.monitors.network.view.MasterTableConfig$MasterTableColumn.getText(MasterTableConfig.java:146)
at com.adobe.flexbuilder.monitors.network.view.MasterTableLabelProvider.getColumnText(MasterTableLabelProvider.java:49)
at org.eclipse.jface.viewers.TableColumnViewerLabelProvider.update(TableColumnViewerLabelProvider.java:70)
at org.eclipse.jface.viewers.ViewerColumn.refresh(ViewerColumn.java:145)
at org.eclipse.jface.viewers.AbstractTableViewer.doUpdateItem(AbstractTableViewer.java:399)
at org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRunnable.run(StructuredViewer.java:481)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.updateItem(StructuredViewer.java:2111)
at org.eclipse.jface.viewers.AbstractTableViewer.createItem(AbstractTableViewer.java:277)
at org.eclipse.jface.viewers.AbstractTableViewer.add(AbstractTableViewer.java:263)
at org.eclipse.jface.viewers.AbstractTableViewer.add(AbstractTableViewer.java:315)
at com.adobe.flexbuilder.monitors.network.view.MasterTableContentProvider$1.run(MasterTableContentProvider.java:82)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3885)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3506)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Often exception details are not recognizable.
After that happens, trying to save into XML doesn't save, though the Save dialog pops up.
Some relieve is possible by closing Network Monitor view and reopening via Window menu helps, otherwise these exceptions make work much less pleasing.
Also double clicking on an NW item to see the source code opens "Loading project...", which spins but does nothing and hangs Eclipse.
Thanks, Andrei.
WinXP SP3, 3GB RAM, Q6600
Message was edited by: kolinitcom
Please file a bug for this issue with a sample test case.
Kishan
Bug http://bugs.adobe.com/jira/browse/FB-30087 has been filed for this issue.
